commit 1adfa76a95fe4444124a502f7cc858a39d5b8e01 upstream.
Bit 1 in the x86 EFLAGS is always set. Name the macro something that
actually tries to explain what it is all about, rather than being a
tautology.
Cc: Gleb Natapov <gleb@redhat.com>
Link: http://lkml.kernel.org/n/tip-f10rx5vjjm6tfnt8o1wseb3v@git.kernel.org
commit v3.9-rc1-53-g6d0cda9 "lguest: cache last cpu we ran on." missed
one case, which causes a triple fault. The guest calls guest_set_pgd()
on the top page, and we carefully remap the Switcher text page. But
we didn't reset last_host_cpu, so map_switcher_in_guest() thinks
the guest's regs and IDT/GDT etc are already mapped.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Tested-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio & lguest updates from Rusty Russell:
"Lots of virtio work which wasn't quite ready for last merge window.
Plus I dived into lguest again, reworking the pagetable code so we can
move the switcher page: our fixmaps sometimes take more than 2MB now..."
Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename.
Hopefully correctly resolved.
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits)
caif_virtio: Remove bouncing email addresses
lguest: improve code readability in lg_cpu_start.
virtio-net: fill only rx queues which are being used
lguest: map Switcher below fixmap.
lguest: map Switcher text whenever we allocate a new pagetable.
lguest: don't share Switcher PTE pages between guests.
lguest: expost switcher_pages array (as lg_switcher_pages).
lguest: extract shadow PTE walking / allocating.
lguest: make check_gpte et. al return bool.
lguest: assume Switcher text is a single page.
lguest: rename switcher_page to switcher_pages.
lguest: remove RESERVE_MEM constant.
lguest: check vaddr not pgd for Switcher protection.
lguest: prepare to make SWITCHER_ADDR a variable.
virtio: console: replace EMFILE with EBUSY for already-open port
virtio-scsi: reset virtqueue affinity when doing cpu hotplug
virtio-scsi: introduce multiqueue support
virtio-scsi: push vq lock/unlock into virtscsi_vq_done
virtio-scsi: pass struct virtio_scsi to virtqueue completion function
Use preferable function name which implies using a pseudo-random
number generator.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Make the container_of call friendlier and fix some comment slip-ups.
Signed-off-by: Cosmin Paraschiv <csmnprschv@gmail.com>
Cc: Daniel Baluta <dbaluta@ixiacom.com>
Now we've adjusted all the code, we can simply set switcher_addr to
wherever it needs to go below the fixmaps, rather than asserting that
it should be so.
With large NR_CPUS and PAE, people were hitting the "mapping switcher
would thwack fixmap" message.
This optimizes the frobbing of our Switcher map.
It's always to same, so no need to put in the PTE every time we're
about to run. Keep a flag to track whether the pagetable has the
Switcher entries allocated, and when allocating always initialize the
Switcher text PTE.
We currently use the whole top PGD entry for the switcher, so we
simply share a fixed page of PTEs between all guests (actually, it's
one per Host CPU, to ensure isolation between guests).
Changes to a scheme where every guest has its own mappings.
We will need this in page_table.c soon.
We want a separate find_pte() function so we can call it for populating the
switcher PTE entries.
We can also use it in page_writable().
This is a bit neater: we can immediately return if a PTE/PGD/PMD entry
is invalid (which also kills the guest). It means we don't risk using
invalid entries as we reshuffle the code.
ie. SHARED_SWITCHER_PAGES == 1. It is well under a page, and it's a
minor simplification: it's nice to have *one* simplification in a
patch series!
There is a single page with the Switcher in it, but it's followed by 2
pages per Host CPU.
We can use switcher_addr directly.
We currently assume that the Switcher the top pgd; we want to remove
this assumption, so check that vaddr is OK, rather then checking pgd
index.
We currently use the whole top PGD entry for the switcher, but that's
hitting the fixmap in some configurations (mainly, large NR_CPUS).
Introduce a variable, currently set to the constant.
After commit 07fe997, lguest tool has already moved from
Documentation/virtual/lguest/ to tools/lguest/.
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Pull virtio updates from Rusty Russell:
"All trivial, thanks to the stuff which didn't quite make it time"
virtio_console: Initialize guest_connected=true for rproc_serial
virtio: use module_virtio_driver.
virtio: Add module driver macro for virtio drivers.
virtio_console: Use virtio device index to generate port name
virtio: make pci_device_id const
virtio: make config_ops const
virtio-mmio: fix wrong comment about register offset
virtio_console: Let unconnected rproc device receive data.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial patches from Greg Kroah-Hartman:
"Here's the big tty/serial driver patches for 3.9-rc1.
More tty port rework and fixes from Jiri here, as well as lots of
individual serial driver updates and fixes.
All of these have been in the linux-next tree for a while."
* tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits)
tty: mxser: improve error handling in mxser_probe() and mxser_module_init()
serial: imx: fix uninitialized variable warning
serial: tegra: assume CONFIG_OF
TTY: do not update atime/mtime on read/write
lguest: select CONFIG_TTY to build properly.
ARM defconfigs: add missing inclusions of linux/platform_device.h
fb/exynos: include platform_device.h
ARM: sa1100/assabet: include platform_device.h directly
serial: imx: Fix recursive locking bug
pps: Fix build breakage from decoupling pps from tty
tty: Remove ancient hardpps()
pps: Additional cleanups in uart_handle_dcd_change
pps: Move timestamp read into PPS code proper
pps: Don't crash the machine when exiting will do
pps: Fix a use-after free bug when unregistering a source.
pps: Use pps_lookup_dev to reduce ldisc coupling
pps: Add pps_lookup_dev() function
tty: serial: uartlite: Support uartlite on big and little endian systems
tty: serial: uartlite: Fix sparse and checkpatch warnings
serial/arc-uart: Miscll DT related updates (Grant's review comments)
Fix up trivial conflicts, mostly just due to the TTY config option
clashing with the EXPERIMENTAL removal.
It is just a table of function pointers, make it const for cleanliness and security
reasons.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
The option allows you to remove TTY and compile without errors. This
saves space on systems that won't support TTY interfaces anyway.
bloat-o-meter output is below.
The bulk of this patch consists of Kconfig changes adding "depends on
TTY" to various serial devices and similar drivers that require the TTY
layer. Ideally, these dependencies would occur on a common intermediate
symbol such as SERIO, but most drivers "select SERIO" rather than
"depends on SERIO", and "select" does not respect dependencies.
bloat-o-meter output comparing our previous minimal to new minimal by
removing TTY. The list is filtered to not show removed entries with awk
'$3 != "-"' as the list was very long.
add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350)
function old new delta
chr_dev_init 166 170 +4
allow_signal 80 82 +2
static.__warned 143 142 -1
disallow_signal 63 62 -1
__set_special_pids 95 94 -1
unregister_console 126 121 -5
start_kernel 546 541 -5
register_console 593 588 -5
copy_from_user 45 40 -5
sys_setsid 128 120 -8
sys_vhangup 32 19 -13
do_exit 1543 1526 -17
bitmap_zero 60 40 -20
arch_local_irq_save 137 117 -20
release_task 674 652 -22
static.spin_unlock_irqrestore 308 260 -48
Signed-off-by: Joe Millenbach <jmillenbach@gmail.com>
Reviewed-by: Jamey Sharp <jamey@minilop.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: Rusty Russell <rusty@rustcorp.com.au>
Signed-off-by: Alex Russell <giles.alex@hotmail.com>
Pull virtio changes from Rusty Russell:
"New workflow: same git trees pulled by linux-next get sent straight to
Linus. Git is awkward at shuffling patches compared with quilt or mq,
but that doesn't happen often once things get into my -next branch."
* 'virtio-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (24 commits)
lguest: fix occasional crash in example launcher.
virtio-blk: Disable callback in virtblk_done()
virtio_mmio: Don't attempt to create empty virtqueues
virtio_mmio: fix off by one error allocating queue
drivers/virtio/virtio_pci.c: fix error return code
virtio: don't crash when device is buggy
virtio: remove CONFIG_VIRTIO_RING
virtio: add help to CONFIG_VIRTIO option.
virtio: support reserved vqs
virtio: introduce an API to set affinity for a virtqueue
virtio-ring: move queue_index to vring_virtqueue
virtio_balloon: not EXPERIMENTAL any more.
virtio-balloon: dependency fix
virtio-blk: fix NULL checking in virtblk_alloc_req()
virtio-blk: Add REQ_FLUSH and REQ_FUA support to bio path
virtio-blk: Add bio-based IO path for virtio-blk
virtio: console: fix error handling in init() function
tools: Fix pthread flag for Makefile of trace-agent used by virtio-trace
tools: Add guest trace agent as a user tool
virtio/console: Allocate scatterlist according to the current pipe size
virtio network device multiqueue support reserves
vq 3 for future use (useful both for future extensions and to make it
pretty - this way receive vqs have even and transmit - odd numbers).
Make it possible to skip initialization for
specific vq numbers by specifying NULL for name.
Document this usage as well as (existing) NULL callback.
Drivers using this not coded up yet, so I simply tested
with virtio-pci and verified that this patch does
not break existing drivers.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Instead of storing the queue index in transport-specific virtio structs,
this patch moves them to vring_virtqueue and introduces an helper to get
the value. This lets drivers simplify their management and tracing of
virtqueues.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Instead of using unlazy_fpu() check if user_has_fpu() and set/clear
the host TS bits so that the lguest works fine with both the
lazy/non-lazy FPU host models with minimal changes.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/1345842782-24175-6-git-send-email-suresh.b.siddha@intel.com
Make sure the interrupt is allocated correctly by lguest_setup_irq (check the
return value of irq_alloc_desc_at for -ENOMEM)
Signed-off-by: Stratos Psomadakis <psomas@cslab.ece.ntua.gr>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (cleanups and commentry)
This is a better location instead of having it in Documentation.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (fixed compile)
When studying lguest's x86 segment descriptor code, it is not longer
necessary to have the Intel x86 architecture manual open on the page
with the segment descriptor illustration to understand the crazy
numbers assigned to both descriptor structure halves a/b.
Now the struct desc_struct's fields, like suggested by
Glauber de Oliveira Costa in 2008, are used.
Signed-off-by: Jacek Galowicz <jacek@galowicz.de>
We were cheating with our barriers; using the smp ones rather than the
real device ones. That was fine, until rpmsg came along, which is
used to talk to a real device (a non-SMP CPU).
Unfortunately, just putting back the real barriers (reverting
d57ed95d) causes a performance regression on virtio-pci. In
particular, Amos reports netbench's TCP_RR over virtio_net CPU
utilization increased up to 35% while throughput went down by up to
14%.
By comparison, this branch is in the noise.
Reference: https://lkml.org/lkml/2011/12/11/22
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits)
net: pack skb_shared_info more efficiently
net_sched: red: split red_parms into parms and vars
net_sched: sfq: extend limits
cnic: Improve error recovery on bnx2x devices
cnic: Re-init dev->stats_addr after chip reset
net_sched: Bug in netem reordering
bna: fix sparse warnings/errors
bna: make ethtool_ops and strings const
xgmac: cleanups
net: make ethtool_ops const
vmxnet3" make ethtool ops const
xen-netback: make ops structs const
virtio_net: Pass gfp flags when allocating rx buffers.
ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call
netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call
igb: reset PHY after recovering from PHY power down
igb: add basic runtime PM support
igb: Add support for byte queue limits.
e1000: cleanup CE4100 MDIO registers access
e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove
The x86_64 kernel pushes the fake kernel stack in
arch/x86/kernel/entry_64.S:FAKE_STACK_FRAME, and
rflags register in it does not conform to the specification.
Although Intel's manual[1] says bit 1 of it shall be set to 1,
this bit is cleared to 0 on pushing the fake stack.
[1] Intel(R) 64 and IA-32 Architectures Software Developer's Manual
Vol.1 3-21 Figure 3-8. EFLAGS Register
If it is not on purpose, it is better to be fixed, because
it can lead some tools misunderstanding the stack frame. For example,
"crash" utility[2] actually detects it and warns you like
below:
RIP: ffffffff8005dfa2 RSP: ffff8104ce0c7f58 RFLAGS: 00000200
bt: WARNING: possibly bogus exception frame
Signed-off-by: Seiichi Ikarashi <s.ikarashi@jp.fujitsu.com>
Tested-by: Masayoshi MIZUMA <m.mizuma@jp.fujitsu.com>
Cc: Jan Beulich <JBeulich@suse.com>
Add a new .bus_name to virtio_config_ops then modify virtio_net to
call through to it in an ethtool .get_drvinfo routine to report
bus_info in ethtool -i output which is consistent with other
emulated NICs and the output of lspci.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
We need this in advance of the module.h cleanup, or we'll
get compile errors like this:
CC drivers/lguest/lguest_device.o
drivers/lguest/lguest_device.c: In function ‘lguest_devices_init’:
drivers/lguest/lguest_device.c:490: error: ‘THIS_MODULE’ undeclared (first use in this function)
run_guest tries to freeze the current process after it has handled
pending interrupts and before it calls lguest_arch_run_guest.
This doesn't work nicely if the task has been killed while being frozen
and when we want to handle that signal as soon as possible.
Let's move try_to_freeze before we check for pending signal so that we
can get out of the loop as soon as possible.
We actually can run under KVM, as it doesn't paravirtualize anything we
need to use; reduce the check to checking we are the normal ringlevel.
Reported-by: Stefanos Geraggelos <sgerag@cslab.ece.ntua.gr>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au># HG changeset patch
We were blatting too much of the register. Linux didn't care, but in
theory it might.
Reported-by: Jonas Maebe <jonas.maebe@elis.ugent.be>
Also removes a long-unused #define and an extraneous semicolon.
We used to notify the Host every time we updated a device's status. However,
it only really needs to know when we're resetting the device, or failed to
initialize it, or when we've finished our feature negotiation.
In particular, we used to wait for VIRTIO_CONFIG_S_DRIVER_OK in the
status byte before starting the device service threads. But this
corresponds to the successful finish of device initialization, which
might (like virtio_blk's partition scanning) use the device. So we
had a hack, if they used the device before we expected we started the
threads anyway.
Now we hook into the finalize_features hook in the Guest: at that
point we tell the Launcher that it can rely on the features we have
acked. On the Launcher side, we look at the status at that point, and
start servicing the device.
Now we no longer use vmcall, we don't need to rewrite it in the Guest.
The Host used to create some page tables for the Guest to use at the
top of Guest memory; it would then tell the Guest where this was. In
particular, it created linear mappings for 0 and 0xC0000000 addresses
because lguest used to switch to its real page tables quite late in
boot.
However, since d50d8fe19 Linux initialized boot page tables in
head_32.S even before the "are we lguest?" boot jump. So, now we can
simplify things: the Host pagetable code assumes 1:1 linear mapping
until it first calls the LHCALL_NEW_PGTABLE hypercall, which we now do
before we reach C code.
This also means that the Host doesn't need to know anything about the
Guest's PAGE_OFFSET. (Non-Linux guests might not even have such a
thing).
- Documentation/kvm/ to Documentation/virtual/kvm
- Documentation/uml/ to Documentation/virtual/uml
- Documentation/lguest/ to Documentation/virtual/lguest
throughout the kernel source tree.
Signed-off-by: Rob Landley <rob@landley.net>
arch/x86/lguest/boot.c: In function ‘lguest_init_IRQ’:
arch/x86/lguest/boot.c:824: error: macro "__this_cpu_write" requires 2 arguments, but only 1 given
arch/x86/lguest/boot.c:824: error: ‘__this_cpu_write’ undeclared (first use in this function)
arch/x86/lguest/boot.c:824: error: (Each undeclared identifier is reported only once
arch/x86/lguest/boot.c:824: error: for each function it appears in.)
drivers/lguest/x86/core.c: In function ‘copy_in_guest_info’:
drivers/lguest/x86/core.c:94: error: lvalue required as left operand of assignment
Use this_cpu_ops in a couple of places in lguest.
Signed-off-by: Christoph Lameter <cl@linux.com>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
This is a partial revert of 4cd8b5e2a159 "lguest: use KVM hypercalls";
we revert to using (just as questionable but more reliable) int $15 for
hypercalls. I didn't revert the register mapping, so we still use the
same calling convention as kvm.
KVM in more recent incarnations stopped injecting a fault when a guest
tried to use the VMCALL instruction from ring 1, so lguest under kvm
fails to make hypercalls. It was nice to share code with our KVM
cousins, but this was overreach.
Cc: Matias Zabaljauregui <zabaljauregui@gmail.com>
Cc: Avi Kivity <avi@redhat.com>
It's only used by cmpxchg8b_emu (see db677ffa5f5a for the gory
details), and fixing that to be paravirt aware would be more work than
simply ignoring it (and AFAICT only help lguest). This makes lguest
work on machines which have cmpxchg8b, for kernels compiled for older
processors.
(We can't emulate it properly: the popf which expects to restore interrupts
does not trap).
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: virtualization@lists.osdl.org
