Pull block layer updates from Jens Axboe:
"This is the main pull request for block layer changes in 4.9.
As mentioned at the last merge window, I've changed things up and now
do just one branch for core block layer changes, and driver changes.
This avoids dependencies between the two branches. Outside of this
main pull request, there are two topical branches coming as well.
This pull request contains:
- A set of fixes, and a conversion to blk-mq, of nbd. From Josef.
- Set of fixes and updates for lightnvm from Matias, Simon, and Arnd.
Followup dependency fix from Geert.
- General fixes from Bart, Baoyou, Guoqing, and Linus W.
- CFQ async write starvation fix from Glauber.
- Add supprot for delayed kick of the requeue list, from Mike.
- Pull out the scalable bitmap code from blk-mq-tag.c and make it
generally available under the name of sbitmap. Only blk-mq-tag uses
it for now, but the blk-mq scheduling bits will use it as well.
From Omar.
- bdev thaw error progagation from Pierre.
- Improve the blk polling statistics, and allow the user to clear
them. From Stephen.
- Set of minor cleanups from Christoph in block/blk-mq.
- Set of cleanups and optimizations from me for block/blk-mq.
- Various nvme/nvmet/nvmeof fixes from the various folks"
* 'for-4.9/block' of git://git.kernel.dk/linux-block: (54 commits)
fs/block_dev.c: return the right error in thaw_bdev()
nvme: Pass pointers, not dma addresses, to nvme_get/set_features()
nvme/scsi: Remove power management support
nvmet: Make dsm number of ranges zero based
nvmet: Use direct IO for writes
admin-cmd: Added smart-log command support.
nvme-fabrics: Add host_traddr options field to host infrastructure
nvme-fabrics: revise host transport option descriptions
nvme-fabrics: rework nvmf_get_address() for variable options
nbd: use BLK_MQ_F_BLOCKING
blkcg: Annotate blkg_hint correctly
cfq: fix starvation of asynchronous writes
blk-mq: add flag for drivers wanting blocking ->queue_rq()
blk-mq: remove non-blocking pass in blk_mq_map_request
blk-mq: get rid of manual run of queue with __blk_mq_run_hw_queue()
block: export bio_free_pages to other modules
lightnvm: propagate device_add() error code
lightnvm: expose device geometry through sysfs
lightnvm: control life of nvm_dev in driver
blk-mq: register device instead of disk
For a host to access an Open-Channel SSD, it has to know its geometry,
so that it writes and reads at the appropriate device bounds.
Currently, the geometry information is kept within the kernel, and not
exported to user-space for consumption. This patch exposes the
configuration through sysfs and enables user-space libraries, such as
liblightnvm, to use the sysfs implementation to get the geometry of an
Open-Channel SSD.
The sysfs entries are stored within the device hierarchy, and can be
found using the "lightnvm" device type.
An example configuration looks like this:
/sys/class/nvme/
└── nvme0n1
├── capabilities: 3
├── device_mode: 1
├── erase_max: 1000000
├── erase_typ: 1000000
├── flash_media_type: 0
├── media_capabilities: 0x00000001
├── media_type: 0
├── multiplane: 0x00010101
├── num_blocks: 1022
├── num_channels: 1
├── num_luns: 4
├── num_pages: 64
├── num_planes: 1
├── page_size: 4096
├── prog_max: 100000
├── prog_typ: 100000
├── read_max: 10000
├── read_typ: 10000
├── sector_oob_size: 0
├── sector_size: 4096
├── media_manager: gennvm
├── ppa_format: 0x380830082808001010102008
├── vendor_opcode: 0
├── max_phys_secs: 64
└── version: 1
Signed-off-by: Simon A. F. Lund <slund@cnexlabs.com>
Signed-off-by: Matias Bjørling <m@bjorling.me>
Signed-off-by: Jens Axboe <axboe@fb.com>
LightNVM compatible device drivers does not have a method to expose
LightNVM specific sysfs entries.
To enable LightNVM sysfs entries to be exposed, lightnvm device
drivers require a struct device to attach it to. To allow both the
actual device driver and lightnvm sysfs entries to coexist, the device
driver tracks the lifetime of the nvm_dev structure.
This patch refactors NVMe and null_blk to handle the lifetime of struct
nvm_dev, which eliminates the need for struct gendisk when a lightnvm
compatible device is provided.
With LightNVM enabled namespaces, the gendisk structure is not exposed
to the user. This prevents LightNVM users from accessing the NVMe device
driver specific sysfs entries, and LightNVM namespace geometry.
Refactor the revalidation process, so that a namespace, instead of a
gendisk, is revalidated. This later allows patches to wire up the
sysfs entries up to a non-gendisk namespace.
This patch removes module_init()/module_exit() from driver code by using
module_misc_device() macro. All modules in this patch has a print
statement which is removed when module_misc_device() macro is used.
If undesirable this patch can be dropped entirely, this is the only
purpose of making this as a separate patch.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
The __nvm_submit_ppa() function is not used outside lightnvm core.
The passed by reference ppa list in nvm_set_rqd_list() is updated when
multiple planes are available. In that case, each PPA plane is
incremented when the device side PPA list is created. This prevents the
caller to rely on the PPA list to be unmodified after a call.
The [get/put]_blk API enables targets to get ownership of blocks at
runtime. This information is currently not recorded on disk, and the
information is therefore lost on power failure. To restore the
metadata, the [get/put]_blk must persist its metadata. In that case,
we need to control the outer lock, so that we can disable them while
updating the on-disk metadata. Fortunately, the _unlocked versions can
be removed, which allows us to move the lock into the [get/put]_blk
functions.
If a media manager tries to initialize it targets upon media manager
initialization, the media manager will need to know which target types
are available in LightNVM. The lists of which managers and target types
are available shares the same lock.
Therefore, on initialization, the nvm_lock is taken by LightNVM core,
which later leads to a deadlock when target types are enumerated by the
media manager.
Add an exclusive lock for target types to resolve this conflict.
To enable persistent block management to easily control creation and
removal of targets, we move target management into the media
manager. The LightNVM core continues to maintain which target types are
registered, while the media manager now keeps track of its initialized
targets.
Two new callbacks for the media manager are introduced. create_tgt and
remove_tgt. Note that remove_tgt returns 0 on successfully removing a
target, and returns 1 if the target was not found.
A couple of small checkpatch fixups to stop it from complaining.
./drivers/lightnvm/core.c:360: WARNING: line over 80 characters
./drivers/lightnvm/core.c:360: ERROR: trailing statements should be on
next line
./drivers/lightnvm/core.c:503: WARNING: Block comments use a trailing */
on a separate line
Mark functions not used by ouside of thier implementing file as static.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Expose media manager mark_blk() to targets, as done for the rest of the
media manager callback functions.
Signed-off-by: Javier González <javier@cnexlabs.com>
Updated description
The number of ppas contained on a request is not necessarily the number
of pages that it maps to neither on the target nor on the device side.
In order to avoid confusion, rename nr_pages to nr_ppas since it is what
the variable actually contains.
Targets associated with a device manager are not freed on device
removal. They have to be manually removed before shutdown. Make sure
any outstanding targets are freed upon shutdown.
Until now, the dma pool have been exclusively used to allocate the ppa
list being sent to the device. In pblk (upcoming), we use these pools to
allocate metadata too. Thus, we generalize the names of some variables
on the dma helper functions to make the code more readable.
A virtual block enables a block to identify multiple physical blocks.
This is useful for metadata where a device media supports multiple
planes. In that case, a block, with multiple planes can be managed
as a single vblk. Reducing the metadata required by one forth.
nvm_set_rqd_ppalist() takes care of expanding a ppa_list with vblks
automatically. However, for some use-cases, where only a single physical
block is required, the ppa_list should not be expanded.
Therefore, add a vblk parameter to nvm_set_rqd_ppalist(), and only
expand the ppa_list if vblk is set.
The device ops->get_bb_tbl() takes a callback, that allows the caller
to use its own callback function to update its data structures in the
returning function.
This makes it difficult to send parameters to the callback, and usually
is circumvented by small private structures, that both carry the callers
state and any flags needed to fulfill the update.
Refactor ops->get_bb_tbl() to fill a data buffer with the status of the
blocks returned, and let the user call the callback function manually.
That will provide the necessary flags and data structures and simplify
the logic around ops->get_bb_tbl().
A target name must be unique. However, a per-device registration of
targets is maintained on a dev->online_targets list, with a per-device
search for targets upon registration.
This results in a name collision when two targets, with the same name,
are created on two different targets, where the per-device list is not
shared.
The functions nvm_register_target(), nvm_unregister_target() and
associated list refers to a target type that is being registered by a
target type module. Rename nvm_*_targets() to nvm_*_tgt_type(), so that
the intension is clear.
This enables target instances to use the _nvm_*_targets() naming.
A memory leak occurs if the lower page table is initialized and the
following dev->lun_map fails on allocation.
Rearrange the initialization of lower page table to allow dev->lun_map
to fail gracefully without memory leak.
Reviewed by: Johannes Thumshirn <jthumshirn@suse.de>
Move kfree of dev->lun_map to nvm_free()
The get block table command returns a list of blocks and planes
with their associated state. Users, such as gennvm and sysblk,
manages all planes as a single virtual block.
It was therefore natural to fold the bad block list before it is
returned. However, to allow users, which manages on a per-plane
block level, to also use the interface, the get_bb_tbl interface is
changed to not fold by default and instead let the caller fold if
necessary.
The flash page size (fpg) and size across planes (pfpg) are convenient
to know when allocating buffer sizes. This has previously been a
calculated in various places. Replace with the pre-calculated values.
The nvm_submit_ppa function assumes that users manage all plane
blocks as a single block. Extend the API with nvm_submit_ppa_list
to allow the user to send its own ppa list. If the user submits more
than a single PPA, the user must take care to allocate and free
the corresponding ppa list.
The device ->submit_io() callback might fail to submit I/O to device.
In that case, the nvm_submit_ppa function should not wait for
completion. Instead return the ->submit_io() error.
Add a bitmap of luns to indicate the status
of luns: inuse/available. When create targets
do the necessary check to avoid allocating luns
that are already allocated.
Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com>
Freed dev->lun_map if nvm_core_init later failed in the init process.
We can create more than one target on a lightnvm
device by specifying its begin lun and end lun.
But only specify the physical address area is not
enough, we need to get the corresponding non-
intersection logical address area division from
the backend device's logcial address space.
Otherwise the targets on the device might use
the same logical addresses cause incorrect
information in the device's l2p table.
Pull block driver updates from Jens Axboe:
"This is the block driver pull request for this merge window. It sits
on top of for-4.6/core, that was just sent out.
This contains:
- A set of fixes for lightnvm. One from Alan, fixing an overflow,
and the rest from the usual suspects, Javier and Matias.
- A set of fixes for nbd from Markus and Dan, and a fixup from Arnd
for correct usage of the signed 64-bit divider.
- A set of bug fixes for the Micron mtip32xx, from Asai.
- A fix for the brd discard handling from Bart.
- Update the maintainers entry for cciss, since that hardware has
transferred ownership.
- Three bug fixes for bcache from Eric Wheeler.
- Set of fixes for xen-blk{back,front} from Jan and Konrad.
- Removal of the cpqarray driver. It has been disabled in Kconfig
since 2013, and we were initially scheduled to remove it in 3.15.
- Various updates and fixes for NVMe, with the most important being:
- Removal of the per-device NVMe thread, replacing that with a
watchdog timer instead. From Christoph.
- Exposing the namespace WWID through sysfs, from Keith.
- Set of cleanups from Ming Lin.
- Logging the controller device name instead of the underlying
PCI device name, from Sagi.
- And a bunch of fixes and optimizations from the usual suspects
in this area"
* 'for-4.6/drivers' of git://git.kernel.dk/linux-block: (49 commits)
NVMe: Expose ns wwid through single sysfs entry
drivers:block: cpqarray clean up
brd: Fix discard request processing
cpqarray: remove it from the kernel
cciss: update MAINTAINERS
NVMe: Remove unused sq_head read in completion path
bcache: fix cache_set_flush() NULL pointer dereference on OOM
bcache: cleaned up error handling around register_cache()
bcache: fix race of writeback thread starting before complete initialization
NVMe: Create discard zero quirk white list
nbd: use correct div_s64 helper
mtip32xx: remove unneeded variable in mtip_cmd_timeout()
lightnvm: generalize rrpc ppa calculations
lightnvm: remove struct nvm_dev->total_blocks
lightnvm: rename ->nr_pages to ->nr_sects
lightnvm: update closed list outside of intr context
xen/blback: Fit the important information of the thread in 17 characters
lightnvm: fold get bb tbl when using dual/quad plane mode
lightnvm: fix up nonsensical configure overrun checking
xen-blkback: advertise indirect segment support earlier
The struct nvm_dev->total_blocks was only used for calculating total
sectors. Remove and instead calculate total sectors from the number of
luns and its sectors.
The struct rrpc->nr_pages can easily be interpreted as the number of
flash pages allocated to rrpc, while it is the nr_sects. Make sure that
this is reflected from the variable name.
When the media manager runs in dual or quad plane mode, lightnvm
abstracts away plane specific commands. This poses a problem for
get bad block table, as it reports bad blocks per plane, making the
table either two or four times bigger than expected. Fold the bad block
list before returning.
Instead of checking a constant 0 actually check the space available. Even
better remember to allow for the header and also check the right amount of
space is needed.
Signed-off-by: Alan Cox <alan@linux.intel.com>
System block allows the device to initialize with its configured media
manager. The system blocks is written to disk, and read again when media
manager is determined. For this to work, the backend must store the
data. Device drivers, such as null_blk, does not have any backend
storage. This patch allows the media manager to be initialized without a
storage backend.
It also fix incorrect configuration of capabilities in null_blk, as it
does not support get/set bad block interface.
Now that a device can be managed using the system blocks, a method to
reset the device is necessary as well. This patch introduces logic to
reset the device easily to factory state and exposes it through an
ioctl.
The ioctl takes the following flags:
NVM_FACTORY_ERASE_ONLY_USER
By default all blocks, except host-reserved blocks are erased upon
factory reset. Instead of this, only erase host-reserved blocks.
NVM_FACTORY_RESET_HOST_BLKS
Mark host-reserved blocks to be erased and set their type to free.
NVM_FACTORY_RESET_GRWN_BBLKS
Mark "grown bad blocks" to be erased and set their type to free.
Use system block information to register the appropriate media manager.
This enables the LightNVM subsystem to instantiate a media manager
selected by the user, instead of relying on automatic detection by each
media manager loaded in the kernel.
A device must now be initialized before it can proceed to initialize its
media manager. Upon initialization, the configured media manager is
automatically initialized as well.
Based on the previous patch, we now introduce an ioctl to initialize the
device using nvm_init_sysblock and create the necessary system blocks.
The user may specify the media manager that they wish to instantiate on
top. Default from user-space will be "gennvm".
An Open-Channel SSD shall be initialized before use. To initialize, we
define an on-disk format, that keeps a small set of metadata to bring up
the media manager on top of the device.
The initial step is introduced to allow a user to format the disks for a
given media manager. During format, a system block is stored on one to
three separate luns on the device. Each lun has the system block
duplicated. During initialization, the system block can be retrieved and
the appropriate media manager can initialized.
The on-disk format currently covers (struct nvm_system_block):
- Magic value "NVMS".
- Monotonic increasing sequence number.
- The physical block erase count.
- Version of the system block format.
- Media manager type.
- Media manager superblock physical address.
The interface provides three functions to manage the system block:
int nvm_init_sysblock(struct nvm_dev *, struct nvm_sb_info *)
int nvm_get_sysblock(struct nvm *dev, struct nvm_sb_info *)
int nvm_update_sysblock(struct nvm *dev, struct nvm_sb_info *)
Each implement a part of the logic to manage the system block. The
initialization creates the first system blocks and mark them on the
device. Get retrieves the latest system block by scanning all pages in
the associated system blocks. The update sysblock writes new metadata
and allocates new block if necessary.
NAND MLC memories have both lower and upper pages. When programming,
both of these must be written, before data can be read. However,
these lower and upper pages might not placed at even and odd flash
pages, but can be skipped. Therefore each flash memory has its lower
pages defined, which can then be used when programming and to know when
padding are necessary.
This patch implements the lower page definition in the specification,
and exposes it through a simple lookup table at dev->lptbl.
Some flash media has extended capabilities, such as programming SLC
pages on MLC/TLC flash, erase/program suspend, scramble and encryption.
MCCAP is introduced to detect support for these capabilities in the
command set.
LightNVM targets need to know the state of the flash block when doing
flash optimizations. An example is implementing a write buffer to
respect the flash page size. Currently, block state is not accounted
for; the media manager only differentiates among free, bad and in-use
blocks.
This patch adds the logic in the generic media manager to enable
targets manage blocks into open and close separately, and it implements
such management in rrpc. It also adds a set of flags to describe the
state of the block (open, closed, free, bad).
In order to avoid taking two locks (nvm_lun and rrpc_lun) consecutively,
we introduce lockless get_/put_block primitives so that the open and
close list locks and future common logic is handled within the nvm_lun
lock.
Internal logic for both core and media managers, does not have a
backing bio for issuing I/Os. Introduce nvm_submit_ppa to allow raw
I/Os to be submitted to the underlying device driver.
The function request the device, ppa, data buffer and its length and
will submit the I/O synchronously to the device. The return value may
therefore be used to detect any errors regarding the issued I/O.
Instead of passing request error into the LightNVM modules, incorporate
it into the nvm_rq.
Sometimes a user want to erase multiple PPAs at the same time. Extend
nvm_erase_ppa to take multiple ppas and number of ppas to be erased.
The Westlake controller requires that the PPA list has sectors defined
sequentially. Currently, the PPA list is created with planes first, then
sectors. Change this to sectors first, then planes.
To implement sync I/O support within the LightNVM core, the end_io
functions are refactored to take an end_io function pointer instead of
testing for initialized media manager, followed by calling its end_io
function.
Sync I/O can then be implemented using a callback that signal I/O
completion. This is similar to the logic found in blk_to_execute_io().
By implementing it this way, the underlying device I/Os submission logic
is abstracted away from core, targets, and media managers.
A device may be driven in single, double or quad plane mode. In that
case, the rqd must have either one, two, or four PPAs set for a single
PPA sent to the device. Refactor this logic into their own
functions to be shared by program/erase/read in the core.
A device may function in single, dual or quad plane mode. The gennvm
media manager manages this with explicit helpers. They convert a single
ppa to 1, 2 or 4 separate ppas in a ppa list. To aid implementation of
recovery and system blocks, this functionality can be moved directly
into the core.
This patch fixes two issues during media manager registration.
1. The ppa pool can be used at media manager registration. Allocate the
ppa pool before that.
2. If a media manager can't be found, this should not lead to the
device being unallocated. A media manager can be registered later, that
can manage the device. Only warn if a media manager fails
initialization.
In the case where a request queue is passed to the low lever lightnvm
device drive integration, the device driver might pass its admin
commands through another queue. Instead pass nvm_dev, and let the
low level drive the appropriate queue.
Reported-by: Christoph Hellwig <hch@infradead.org>
To avoid race conditions, traverse dev, media manager,
and target lists and also register, unregister entries
to/from them, should be always under the nvm_lock control.
