We can't know if a block is closed or not on 1.2 devices, so assume
closed state to make sure that blocks are erased before writing.
Fixes: 32ef9412c114 ("lightnvm: pblk: implement get log report chunk")
Signed-off-by: Hans Holmberg <hans.holmberg@cnexlabs.com>
Signed-off-by: Matias Bjørling <mb@lightnvm.io>
The error messages in pblk does not say which pblk instance that
a message occurred from. Update each error message to reflect the
instance it belongs to, and also prefix it with pblk, so we know
the message comes from the pblk module.
Reviewed-by: Javier González <javier@cnexlabs.com>
There is no users of CONFIG_NVM_DEBUG in the LightNVM subsystem. All
users are in pblk. Rename NVM_DEBUG to NVM_PBLK_DEBUG and enable
only for pblk.
Also fix up the CONFIG_NVM_PBLK entry to follow the code style for
Kconfig files.
Some devices can expose mw_cunits equal to 0, it can cause the
creation of too small write buffer and cause performance to drop
on write workloads.
Additionally, write buffer size must cover write data requirements,
such as WS_MIN and MW_CUNITS - it must be greater than or equal to
the larger one multiplied by the number of PUs. However, for
performance reasons, use the WS_OPT value to calculation instead of
WS_MIN.
Because the place where buffer size is calculated was changed, this
patch also removes pgs_in_buffer filed in pblk structure.
Signed-off-by: Marcin Dziegielewski <marcin.dziegielewski@intel.com>
Signed-off-by: Igor Konopko <igor.j.konopko@intel.com>
The vzalloc() function has no 2-factor argument form, so multiplication
factors need to be wrapped in array_size(). This patch replaces cases of:
vzalloc(a * b)
with:
vzalloc(array_size(a, b))
as well as handling cases of:
vzalloc(a * b * c)
with:
vzalloc(array3_size(a, b, c))
This does, however, attempt to ignore constant size factors like:
vzalloc(4 * 1024)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
vzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
vzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
vzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(u8) * COUNT
+ COUNT
vzalloc(
- sizeof(__u8) * COUNT
+ COUNT
vzalloc(
- sizeof(char) * COUNT
+ COUNT
vzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
vzalloc(
- sizeof(TYPE) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_ID
vzalloc(
- sizeof(TYPE) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_CONST
vzalloc(
- sizeof(THING) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_ID
vzalloc(
- sizeof(THING) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
vzalloc(
- SIZE * COUNT
+ array_size(COUNT, SIZE)
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
vzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
vzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
vzalloc(
- sizeof(TYPE) * COUNT * STRIDE
vzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
vzalloc(
- sizeof(THING) * (COUNT) * STRIDE
vzalloc(
- sizeof(THING) * COUNT * (STRIDE)
vzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
vzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
vzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
vzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
vzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
vzalloc(
- COUNT * (STRIDE) * SIZE
vzalloc(
- COUNT * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * SIZE
vzalloc(
- COUNT * (STRIDE) * (SIZE)
vzalloc(
- (COUNT) * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * (SIZE)
vzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
vzalloc(C1 * C2 * C3, ...)
vzalloc(
- E1 * E2 * E3
+ array3_size(E1, E2, E3)
// And then all remaining 2 factors products when they're not all constants.
expression E1, E2;
constant C1, C2;
vzalloc(C1 * C2, ...)
vzalloc(
- E1 * E2
+ array_size(E1, E2)
The kzalloc() function has a 2-factor argument form, kcalloc(). This
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
kzalloc(4 * 1024, gfp)
type TYPE;
kzalloc(
+ sizeof(TYPE) * E
kzalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
type TYPE;
expression THING;
- kzalloc
+ kcalloc
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
// Any remaining multi-factor products, first at least 3-factor products,
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
kmalloc_array(array_size(a, b), c, gfp)
kmalloc(4 * 1024, gfp)
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
type TYPE;
kmalloc(
+ sizeof(TYPE) * E
kmalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
type TYPE;
expression THING;
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
kmalloc(
- (E1) * (E2) * E3
kmalloc(
kmalloc(
- E1 * E2 * E3
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
Fixes the following sparse warning:
drivers/lightnvm/pblk-init.c:23:14: warning:
symbol 'write_buffer_size' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
In some cases, users can want set write buffer size manually, e.g. to
adjust it to specific workload. This patch provides the possibility
to set write buffer size via module parameter feature.
Write failures should not happen under normal circumstances,
so in order to bring the chunk back into a known state as soon
as possible, evacuate all the valid data out of the line and let the
fw judge if the block can be written to in the next reset cycle.
Do this by introducing a new gc list for lines with failed writes,
and ensure that the rate limiter allocates a small portion of
the write bandwidth to get the job done.
The lba list is saved in memory for use during gc as we
cannot gurantee that the emeta data is readable if a write
error occurred.
The write error recovery path is incomplete, so rework
the write error recovery handling to do resubmits directly
from the write buffer.
When a write error occurs, the remaining sectors in the chunk are
mapped out and invalidated and the request inserted in a resubmit list.
The writer thread checks if there are any requests to resubmit,
scans and invalidates any lbas that have been overwritten by later
writes and resubmits the failed entries.
If the namespace is unregistered before the LightNVM target is removed
(e.g., on hot unplug) it is too late for the target to store any metadata
on the device - any attempt to write to the device will fail. In this
case, pass on a "gracefull teardown" flag to the target to let it know
when this happens.
In the case of pblk, we pad the open line (close all open chunks) to
improve data retention. In the event of an ungraceful shutdown, avoid
this part and just clean up.
Signed-off-by: Javier González <javier@cnexlabs.com>
Do the check for the chunk state after making sure that the chunk type
is supported.
Remove unnecessary argument on pblk_line_free()
Bad blocks can grow at runtime. Check that the number of valid blocks in
a line are within the sanity threshold before allocating the line for
new writes.
In the event of a line failing to allocate, fail gracefully and stop the
pipeline to avoid more write failing in the same place.
Convert lightnvm to embedded bio sets.
Signed-off-by: Kent Overstreet <kent.overstreet@gmail.com>
Implement 2.0 support in pblk. This includes the address formatting and
mapping paths, as well as the sysfs entries for them.
In preparation of pblk supporting 2.0, implement the get log report
chunk in pblk. Also, define the chunk states as given in the 2.0 spec.
In preparation for 2.0 support in pblk, rename variables referring to
the address format to addrf and reserve ppaf for the 1.2 path.
At this point, only 1.2 spec is supported, thus check for it. Also,
since device-side L2P is only supported in the 1.2 spec, make sure to
only check its value under 1.2.
Normalize nomenclature for naming channels, luns, chunks, planes and
sectors as well as derivations in order to improve readability.
Currently, the device geometry is stored redundantly in the nvm_id and
nvm_geo structures at a device level. Moreover, when instantiating
targets on a specific number of LUNs, these structures are replicated
and manually modified to fit the instance channel and LUN partitioning.
Instead, create a generic geometry around nvm_geo, which can be used by
(i) the underlying device to describe the geometry of the whole device,
and (ii) instances to describe their geometry independently.
Refactor init and exit sequences to eliminate dependencies among init
modules and improve readability.
fix reading bad block device information to correctly setup the per line
blk_bitmap during lightnvm initialization
Signed-off-by: Heiner Litz <hlitz@ucsc.edu>
The value of max_phys_sect is always static. Instead of
defining it in the nvm_dev_ops structure, declare it as a global
value.
In preparation for the OCSSD 2.0 spec. bad block identification,
refactor the current code to generalize bad block get/set functions and
structures.
Unless we delete the timer that wakes up the write thread
before we stop the thread we risk re-starting the thread, so
delete the timer first.
When pblk receives a sync, all data up to that point in the write buffer
must be comitted to persistent storage, and as flash memory comes with a
minimal write size there is a significant cost involved both in terms
of time for completing the sync and in terms of write amplification
padded sectors for filling up to the minimal write size.
In order to get a better understanding of the costs involved for syncs,
Add a sysfs attribute to pblk: padded_dist, showing a normalized
distribution of sectors padded. In order to facilitate measurements of
specific workloads during the lifetime of the pblk instance, the
distribution can be reset by writing 0 to the attribute.
Do this by introducing counters for each possible padding:
{0..(minimal write size - 1)} and calculate the normalized distribution
when showing the attribute.
Rearranged total_buckets statement in pblk_sysfs_get_padding_dist
In a SSD, write amplification, WA, is defined as the average
number of page writes per user page write. Write amplification
negatively affects write performance and decreases the lifetime
of the disk, so it's a useful metric to add to sysfs.
In plkb's case, the number of writes per user sector is the sum of:
(1) number of user writes
(2) number of sectors written by the garbage collector
(3) number of sectors padded (i.e. due to syncs)
This patch adds persistent counters for 1-3 and two sysfs attributes
to export these along with WA calculated with five decimals:
write_amp_mileage: the accumulated write amplification stats
for the lifetime of the pblk instance
write_amp_trip: resetable stats to facilitate delta measurements,
values reset at creation and if 0 is written
to the attribute.
64-bit counters are used as a 32 bit counter would wrap around
already after about 17 TB worth of user data. It will take a
long long time before the 64 bit sector counters wrap around.
The counters are stored after the bad block bitmap in the first
emeta sector of each written line. There is plenty of space in the
first emeta sector, so we don't need to bump the major version of
the line data format.
This patch has been generated as follows:
for verb in set_unlocked clear_unlocked set clear; do
replace-in-files queue_flag_${verb} blk_queue_flag_${verb%_unlocked} \
$(git grep -lw queue_flag_${verb} drivers block/bsg*)
done
Except for protecting all queue flag changes with the queue lock
this patch does not change any functionality.
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Shaohua Li <shli@fb.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Add the instance name to the information printed out on target creation.
Signed-off-by: Matias Bjørling <m@bjorling.me>
Refactor the way we free the write buffer to ensure that all entries get
freed in case of an error on the init sequence.
When creating the write thread, ensure that the kthread has been created
before initializing the timer responsible from kicking it. Otherwise, if
the kthread creation fails or gets killed from used space, we risk
kicking an empty thread structure.
Also, since the kthread creation can be interrupted form user space,
adapt the error path to not report an error when this happens, since it
is intentional that the instance creation is aborted.
Updated source to reflect the new timer_setup API.
Allow to set the over-provision percentage on target creation. In case
that the value is not provided, fall back to the default value set by
the target.
In pblk, set the default OP to 11% of the total size of the device
Until now, pblk's rate-limiter has used a heuristic to reserve space for
GC I/O given that the over-provision area was fixed.
In preparation for allowing to define the over-provision area on target
creation, define a dedicated free_block counter in the rate-limiter to
track the number of blocks being used for user data.
Prepare for the 2.0 revision by adapting the geometry
structures to coexist with the 1.2 revision.
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Matias Bjorling <mb@lightnvm.io>
Cc: linux-block@vger.kernel.org
Lockdep complains about being in atomic context while freeing line
metadata - and rightly so as we take a spinlock and end up calling
vfree that might sleep(in pblk_mfree).
There is no need for holding the line manager free_lock while
freeing line metadata as the pipeline as stopped, so remove the lock.
Fixes: 588726d3ec68 ("lightnvm: pblk: fail gracefully on irrec. error")
Print the CRC of the logical-to-physical mapping during exit and
after recovering the L2P table to facilitate detection of meta
data corruption/recovery issues.
The CRC printed after recovery should match the CRC printed during
the previous exit - if it doesn't this indicates that either the meta
data written to the disk is corrupt or recovery failed.
Start GC if needed, directly after init, as we might
need to garbage collect in order to make room for user writes.
Create a helper function that allows to kick GC without exposing the
internals of the GC/rate-limiter interaction.
When rebuilding the L2P table, any full lines (lines without any
valid sectors) will be identified. If these lines are not freed,
we risk not being able to allocate the first data line.
This patch refactors the part of GC that frees empty lines
into a separate function and adds a call to this after the
L2P table has been rebuilt.
GC can be kicked after it has been shut down when closing the last
line during exit, resulting in accesses to freed structures.
Make sure that GC is not triggered while it is not operational.
Also make sure that GC won't be re-activated during exit when
running on another processor by using timer_del_sync.
If pblk_core_init fails lets destroy all global caches.
Signed-off-by: Rakesh Pandit <rakesh@tuxera.com>
pblk_line_gc_list seems to had a bug since the introduction of pblk in
getting GC list for a line. In b20ba1bc7 while redesigning the GC
algorithm, the naming for the GC thresholds was altered, but the
values for high_thrs and mid_thrs were not. The result is that when
moving to the GC lists, the mid threshold is never evaluated.
Fixes: a4bd217b4("lightnvm: physical block device (pblk) target")
Make sure that the variable controlling block threshold for allocating
extra metadata sectors in case of a line with bad blocks does not get a
negative value. Otherwise, the line will be marked as corrupted and
wasted.
Metadata I/Os are scheduled to minimize their impact on user data I/Os.
When there are enough LUNs instantiated (i.e., enough bandwidth), it is
easy to interleave metadata and data one after the other so that
metadata I/Os are the ones being blocked and not vice-versa.
We do this by calculating the distance between the I/Os in terms of the
LUNs that are not in used, and selecting a free LUN that satisfies a
the simple heuristic that metadata is scheduled behind. The per-LUN
semaphores guarantee consistency. This works fine on >1 LUN
configuration. However, when a single LUN is instantiated, this design
leads to a deadlock, where metadata waits to be scheduled on a free LUN.
This patch implements the 1 LUN case by simply scheduling the metadada
I/O after the data I/O. In the process, we refactor the way a line is
replaced to ensure that metadata writes are submitted after data writes
in order to guarantee block sequentiality. Note that, since there is
only one LUN, both I/Os will block each other by design. However, such
configuration only pursues tight read latencies, not write bandwidth.
When a line is recycled during garbage collection, reads can still be
issued to the line. If the line is freed in the middle of this process,
data corruption might occur.
This patch guarantees that lines are not freed in the middle of reads
that target them (lines). Specifically, we use the existing line
reference to decide when a line is eligible for being freed after the
recycle process.
pblk holds two sector bitmaps: one to keep track of the mapped sectors
while the line is active and another one to keep track of the invalid
sectors. The latter is kept during the whole live of the line, until it
is recycled. Since we cannot guarantee forward progress for the mempool
in this case, get rid of the mempool and simply allocate memory through
kmalloc.
Reported-by: Jens Axboe <axboe@kernel.dk>
Since read and erase paths offer different guarantees for inflight I/Os,
separate the mempools to set the right min_nr for each on creation.
