path: root/drivers/lightnvm/rrpc.c
2017-06-18blk: remove bio_set arg from blk_queue_split()NeilBrown
blk_queue_split() is always called with the last arg being q->bio_split, where 'q' is the first arg. Also blk_queue_split() sometimes uses the passed-in 'bs' and sometimes uses q->bio_split. This is inconsistent and unnecessary. Remove the last arg and always use q->bio_split inside blk_queue_split() Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ming Lei <ming.lei@redhat.com> Credit-to: Javier González <jg@lightnvm.io> (Noticed that lightnvm was missed) Reviewed-by: Javier González <javier@cnexlabs.com> Tested-by: Javier González <javier@cnexlabs.com> Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-06-09block: switch bios to blk_status_tChristoph Hellwig
Replace bi_error with a new bi_status to allow for a clear conversion. Note that device mapper overloaded bi_error with a private value, which we'll have to keep arround at least for now and thus propagate to a proper blk_status_t value. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-16lightnvm: fix type checks on rrpcJavier González
sector_t is always unsigned, therefore avoid < 0 checks on it. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-16lightnvm: allow to init targets on factory modeJavier González
Target initialization has two responsibilities: creating the target partition and instantiating the target. This patch enables to create a factory partition (e.g., do not trigger recovery on the given target). This is useful for target development and for being able to restore the device state at any moment in time without requiring a full-device erase. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-16lightnvm: don't check for failure from mempool_alloc()NeilBrown
mempool_alloc() cannot fail if the gfp flags allow it to sleep, and both GFP_KERNEL and GFP_NOIO allows for sleeping. So rrpc_move_valid_pages() and rrpc_make_rq() don't need to test the return value. Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-16lightnvm: submit erases using the I/O pathJavier González
Until now erases have been submitted as synchronous commands through a dedicated erase function. In order to enable targets implementing asynchronous erases, refactor the erase path so that it uses the normal async I/O submission functions. If a target requires sync I/O, it can implement it internally. Also, adapt rrpc to use the new erase path. Signed-off-by: Javier González <javier@cnexlabs.com> Fixed spelling error. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-16lightnvm: Fix error handlingChristophe JAILLET
According to error handling in this function, it is likely that going to 'out' was expected here. Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31lightnvm: use end_io callback instead of instanceMatias Bjørling
When the lightnvm core had the "gennvm" layer between the device and the target, there was a need for the core to be able to figure out which target it should send an end_io callback to. Leading to a "double" end_io, first for the media manager instance, and then for the target instance. Now that core and gennvm is merged, there is no longer a need for this, and a single end_io callback will do. Signed-off-by: Matias Bjørling <matias@cnexlabs.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: transform target get/set bad blockJavier González
Since targets are given a virtual target device, it is necessary to translate all communication between targets and the backend device. Implement the translation layer for get/set bad block table. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: use target nvm on target-specific ops.Javier González
On target-specific operations pass on nvm_tgt_dev instead of the generic nvm device. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: introduce helpers for generic ops in rrpcJavier González
Avoid calling media manager and device-specific operations directly from rrpc. Create helper functions on lightnvm's core instead. Signed-off-by: Javier González <javier@cnexlabs.com> Made it work with null_blk as well. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: eliminate nvm_lun abstraction in mmJavier González
In order to naturally support multi-target instances on an Open-Channel SSD, targets should own the LUNs they get blocks from and manage provisioning internally. This is done in several steps. Since targets own the LUNs the are instantiated on top of and manage the free block list internally, there is no need for a LUN abstraction in the media manager. LUNs are intrinsically managed as in the physical layout (ch:0,lun:0, ..., ch:0,lun:n, ch:1,lun:0, ch:1,lun:n, ..., ch:m,lun:0, ch:m,lun:n) and given to the targets based on the target creation ioctl. This simplifies LUN management and clears the path for a partition manager to sit directly underneath LightNVM targets. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: eliminate nvm_block abstraction on mmJavier González
In order to naturally support multi-target instances on an Open-Channel SSD, targets should own the LUNs they get blocks from and manage provisioning internally. This is done in several steps. A part of this transformation is that targets manage their blocks internally. This patch eliminates the nvm_block abstraction and moves block management to the target logic. The rrpc target is transformed. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: remove get_lun operation on gennvmJavier González
Since LUNs are managed internally on the target, there is no need for the media manager to implement a get_lun operation. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: move block provisioning to targetsJavier González
In order to naturally support multi-target instances on an Open-Channel SSD, targets should own the LUNs they get blocks from and manage provisioning internally. This is done in several steps. This patch moves the block provisioning inside of the target and removes the get/put block interface from the media manager. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: manage lun partitions internally in mmJavier González
LUNs are exclusively owned by targets implementing a block device FTL. Doing this reservation requires at the moment a 2-way callback gennvm <-> target. The reason behind this is that LUNs were not assumed to always be exclusively owned by targets. However, this design decision goes against I/O determinism QoS (two targets would mix I/O on the same parallel unit in the device). This patch makes LUN reservation as part of the target creation on the media manager. This makes that LUNs are always exclusively owned by the target instantiated on top of them. LUN stripping and/or sharing should be implemented on the target itself or the layers on top. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: remove unnecessary variables in rrpcJavier González
Before vectored I/Os were supported on rrpc, the physical address was stored as part of the nvm_rqd request. This variable become obsolete when the ppa_list was introduced. Cleanup this variable. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: make address conversion functions globalJavier González
Targets are assumed to used the same generic ppa format, where the address is partitioned on ch:lun:block:pg:pl:sec. Thus, make the function in charge of transforming the ppa address from a linear format to the generic one available to all targets. This function will be needed by the media manager in order to do target mapping translations when targets are divided on different physical partitions. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: rrpc: split bios of size > 256kbJavier González
rrpc cannot handle bios of size > 256kb due to NVMe using a 64 bit bitmap to signal I/O completion. If a larger bio comes, split it explicitly. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: export set bad block tableJavier González
Bad blocks should be managed by block owners. This would be either targets for data blocks or sysblk for system blocks. In order to support this, export two functions: One to mark a block as an specific type (e.g., bad block) and another to update the bad block table on the device. Move bad block management to rrpc. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-29lightnvm: enable to send hint to erase commandJavier González
Erases might be subject to host hints. An example is multi-plane programming to erase blocks in parallel. Enable targets to specify this hint. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-20block: get rid of bio_rw and READAChristoph Hellwig
These two are confusing leftover of the old world order, combining values of the REQ_OP_ and REQ_ namespaces. For callers that don't special case we mostly just replace bi_rw with bio_data_dir or op_is_write, except for the few cases where a switch over the REQ_OP_ values makes more sense. Any check for READA is replaced with an explicit check for REQ_RAHEAD. Also remove the READA alias for REQ_RAHEAD. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-07lightnvm: make rrpc_map_page call nvm_get_blk outside locksMatias Bjørling
The nvm_get_blk() function is called with rlun->lock held. This is ok when the media manager implementation doesn't go out of its atomic context. However, if a media manager persists its metadata, and guarantees that the block is given to the target, this is no longer a viable approach. Therefore, clean up the flow of rrpc_map_page, and make sure that nvm_get_blk() is called without any locks acquired. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-07lightnvm: remove _unlocked variant of [get/put]_blkMatias Bjørling
The [get/put]_blk API enables targets to get ownership of blocks at runtime. This information is currently not recorded on disk, and the information is therefore lost on power failure. To restore the metadata, the [get/put]_blk must persist its metadata. In that case, we need to control the outer lock, so that we can disable them while updating the on-disk metadata. Fortunately, the _unlocked versions can be removed, which allows us to move the lock into the [get/put]_blk functions. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-07lightnvm: remove unused lists from struct rrpc_blockMatias Bjørling
The ->list, ->open_list, and ->closed_list lists were previously used for statistics. However, their usage have been removed, and thus these can safely be removed. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-07lightnvm: remove open/close statistics for gennvmMatias Bjørling
The responsibility of the media manager is not to keep track of open/closed blocks. This is better maintained within a target, that already manages this information on writes. Remove the statistics and merge the states NVM_BLK_ST_OPEN and NVM_BLK_ST_CLOSED. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-07lightnvm: remove checkpatch warning for unsigned intsMatias Bjørling
Checkpatch found two incidents where the type was preferred to be written out in full. ./drivers/lightnvm/rrpc.h:184: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' ./drivers/lightnvm/rrpc.h:209: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' ./drivers/lightnvm/rrpc.c:51: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-07lightnvm: break the loop when rqd is not nullWenwei Tao
Break the loop when rqd is not null to reduce an unnecessary schedule. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-06-07block, fs, mm, drivers: use bio set/get op accessorsMike Christie
This patch converts the simple bi_rw use cases in the block, drivers, mm and fs code to set/get the bio operation using bio_set_op_attrs/bio_op These should be simple one or two liner cases, so I just did them in one patch. The next patches handle the more complicated cases in a module per patch. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-06lightnvm: reserved space calculation incorrectJavier González
The nvm_dev->max_pages_per_blk variable was removed in favor of the new nvm->sec_per_blk variable. The ->max_pages_per_blk variable was still used in rrpc_capacity, reporting the reserved capacity to zero. Replace with ->sec_per_blk to calculate the reserved area again. Signed-off-by: Javier González <javier@cnexlabs.com> Updated patch description. Was "lightnvm: eliminate redundant variable" Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-06lightnvm: rename nr_pages to nr_ppas on nvm_rqJavier González
The number of ppas contained on a request is not necessarily the number of pages that it maps to neither on the target nor on the device side. In order to avoid confusion, rename nr_pages to nr_ppas since it is what the variable actually contains. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-06lightnvm: do not assume sequential lun alloc.Javier González
When doing GC, rrpc calculates the physical LUN to which the rrpc block belongs too. This calculation is based on the assumption that LUNs are assigned sequentially to the LUN list. Use the reference to the LUN instead. This saves us the calculation and allows us to align LUNs in a different manner to, for example, take advantage of devide parallelism. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-06lightnvm: do not free unused metadata on rrpcJavier González
rrpc does not save any metadata on a given request. Thus, do not attempt to free the metadata dma region. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-06lightnvm: rename nvm_targets to nvm_tgt_typeSimon A. F. Lund
The functions nvm_register_target(), nvm_unregister_target() and associated list refers to a target type that is being registered by a target type module. Rename nvm_*_targets() to nvm_*_tgt_type(), so that the intension is clear. This enables target instances to use the _nvm_*_targets() naming. Signed-off-by: Simon A. F. Lund <slund@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-06lightnvm: store rrpc->soffset in device sector sizeWenwei Tao
Since we mainly use soffset in device sector size, we therefore store this value in rrpc->soffset, instead of the offset in 512byte sector size. This eliminates the "(ilog2(dev->sec_size) - 9)" calculation on each I/O. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Updated patch description. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-06lightnvm: calculate rrpc total blocks and sectors up frontWenwei Tao
Calculate rrpc total blocks and sectors up front, make sense to use them. For example, we use rrpc->nr_sects to calculate rrpc area size, but it makes no sense if we don't initialize it up front, since it would be zero until we finish rrpc luns init. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-03-18lightnvm: add a bitmap of lunsWenwei Tao
Add a bitmap of luns to indicate the status of luns: inuse/available. When create targets do the necessary check to avoid allocating luns that are already allocated. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Freed dev->lun_map if nvm_core_init later failed in the init process. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-03-18lightnvm: specify target's logical address areaWenwei Tao
We can create more than one target on a lightnvm device by specifying its begin lun and end lun. But only specify the physical address area is not enough, we need to get the corresponding non- intersection logical address area division from the backend device's logcial address space. Otherwise the targets on the device might use the same logical addresses cause incorrect information in the device's l2p table. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-03-18Merge branch 'for-4.6/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "This is the block driver pull request for this merge window. It sits on top of for-4.6/core, that was just sent out. This contains: - A set of fixes for lightnvm. One from Alan, fixing an overflow, and the rest from the usual suspects, Javier and Matias. - A set of fixes for nbd from Markus and Dan, and a fixup from Arnd for correct usage of the signed 64-bit divider. - A set of bug fixes for the Micron mtip32xx, from Asai. - A fix for the brd discard handling from Bart. - Update the maintainers entry for cciss, since that hardware has transferred ownership. - Three bug fixes for bcache from Eric Wheeler. - Set of fixes for xen-blk{back,front} from Jan and Konrad. - Removal of the cpqarray driver. It has been disabled in Kconfig since 2013, and we were initially scheduled to remove it in 3.15. - Various updates and fixes for NVMe, with the most important being: - Removal of the per-device NVMe thread, replacing that with a watchdog timer instead. From Christoph. - Exposing the namespace WWID through sysfs, from Keith. - Set of cleanups from Ming Lin. - Logging the controller device name instead of the underlying PCI device name, from Sagi. - And a bunch of fixes and optimizations from the usual suspects in this area" * 'for-4.6/drivers' of git://git.kernel.dk/linux-block: (49 commits) NVMe: Expose ns wwid through single sysfs entry drivers:block: cpqarray clean up brd: Fix discard request processing cpqarray: remove it from the kernel cciss: update MAINTAINERS NVMe: Remove unused sq_head read in completion path bcache: fix cache_set_flush() NULL pointer dereference on OOM bcache: cleaned up error handling around register_cache() bcache: fix race of writeback thread starting before complete initialization NVMe: Create discard zero quirk white list nbd: use correct div_s64 helper mtip32xx: remove unneeded variable in mtip_cmd_timeout() lightnvm: generalize rrpc ppa calculations lightnvm: remove struct nvm_dev->total_blocks lightnvm: rename ->nr_pages to ->nr_sects lightnvm: update closed list outside of intr context xen/blback: Fit the important information of the thread in 17 characters lightnvm: fold get bb tbl when using dual/quad plane mode lightnvm: fix up nonsensical configure overrun checking xen-blkback: advertise indirect segment support earlier ...
2016-03-03lightnvm: generalize rrpc ppa calculationsJavier González
In rrpc, some calculations assume a certain configuration (e.g., 1 LUN, 1 sector per page). The reason behind this was that LightNVM used a simple configuration with QEMU to test core features in the beginning. This patch relaxes these assumptions and generalizes calculation, allowing multiple luns to be used. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-03-03lightnvm: rename ->nr_pages to ->nr_sectsMatias Bjørling
The struct rrpc->nr_pages can easily be interpreted as the number of flash pages allocated to rrpc, while it is the nr_sects. Make sure that this is reflected from the variable name. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-03-03lightnvm: update closed list outside of intr contextJavier González
When an I/O finishes, full blocks are moved from the open to the closed list - a lock is taken to protect the list. This happens at the moment in the interrupt context, which is not correct. This patch moves this logic to the block workqueue instead, avoiding holding a spinlock without interrupt save in an interrupt context. Signed-off-by: Javier González <javier@cnexlabs.com> Fixes: ff0e498bfa18 ("lightnvm: manage open and closed blocks sepa...") Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-02-04lightnvm: put bio before returnWenwei Tao
The bio is not returned if the data page cannot be allocated. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-01-12lightnvm: manage open and closed blocks separatelyJavier González
LightNVM targets need to know the state of the flash block when doing flash optimizations. An example is implementing a write buffer to respect the flash page size. Currently, block state is not accounted for; the media manager only differentiates among free, bad and in-use blocks. This patch adds the logic in the generic media manager to enable targets manage blocks into open and close separately, and it implements such management in rrpc. It also adds a set of flags to describe the state of the block (open, closed, free, bad). In order to avoid taking two locks (nvm_lun and rrpc_lun) consecutively, we introduce lockless get_/put_block primitives so that the open and close list locks and future common logic is handled within the nvm_lun lock. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-01-12lightnvm: reference rrpc lun in rrpc blockJavier González
Currently, a rrpc block only points to its nvm_lun. If a user wants to find the associated rrpc lun, it will have to calculate the index and look it up manually. By referencing the rrpc lun directly, this step can be omitted, at the cost of a larger memory footprint. This is important for upcoming patches that implement write buffering in rrpc. Signed-off-by: Javier González <javier@cnexlabs.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-01-12lightnvm: move rq->error to nvm_rq->errorMatias Bjørling
Instead of passing request error into the LightNVM modules, incorporate it into the nvm_rq. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-01-12lightnvm: move the pages per block check out of the loopWenwei Tao
There is no need to check whether dev's pages per block is beyond rrpc support every time we init a lun, we only need to check it once before enter the lun init loop. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-01-12lightnvm: fix locking and mempool in rrpc_lun_gcWenwei Tao
This patch fix two issues in rrpc_lun_gc 1. prio_list is protected by rrpc_lun's lock not nvm_lun's, so acquire rlun's lock instead of lun's before operate on the list. 2. we delete block from prio_list before allocating gcb, but gcb allocation may fail, we end without putting it back to the list, this makes the block won't get reclaimed in the future. To solve this issue, delete block after gcb allocation. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-01-12lightnvm: put block back to gc list on its reclaim failWenwei Tao
We delete a block from the gc list before reclaim it, so put it back to the list on its reclaim fail, otherwise this block will not get reclaimed and be programmable in the future. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-01-12lightnvm: check bi_error in gcWenwei Tao
We should check last io completion status before starting another one. Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
