path: root/drivers/macintosh/adbhid.c
2018-10-08macintosh/adb: Rework printk output againFinn Thain
Avoid the KERN_CONT problem by avoiding message fragments. The problem arises during async ADB bus probing, when ADB messages may get mixed up with other messages. See also, commit 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines"). Remove a number of printk() continuation lines by logging handler changes in adb_try_handler_change() instead. This patch addresses the problematic use of "\n" at the beginning of pr_cont() messages, which got overlooked in commit f2be6295684b ("macintosh/adb: Properly mark continued kernel messages"). That commit also changed printk(KERN_DEBUG ...) to pr_debug(...), which hinders work on low-level ADB driver bugs. Revert that change. Cc: Andreas Schwab <schwab@linux-m68k.org> Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-01-27macintosh/adb: Properly mark continued kernel messagesAndreas Schwab
Use pr_cont where appropriate, and switch to pr_foo throughout. Additionally, lower messages in adb_probe_task to debug level. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> [mpe: Clean up whitespace slightly] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2008-07-21Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into nextDmitry Torokhov
2008-07-01drivers/macintosh: Various cleanupsAdrian Bunk
This contains the following cleanups: - make the following needlessly global code static: - adb.c: adb_controller - adb.c: adb_init() - adbhid.c: adb_to_linux_keycodes[] (also make it const) - via-pmu68k.c: backlight_level - via-pmu68k.c: backlight_enabled - remove the following unused code: - via-pmu68k.c: sleep_notifier_list Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-16Input: adbhid - capslock and power button fixRodney Lorrimar
If the adbhid module parameter restore_capslock_events is used, pressing the power button may confuse the capslock state. This is because the power button release scancode (0xff) is sometimes the same as the capslock press/release scancode. This fix adds yet another flag to track the state of the power button so that it works independently of capslock. Signed-off-by: Rodney Lorrimar <rodney@rodney.id.au> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-16Input: adbhid - fix capslock key state after suspendRodney Lorrimar
If the adbhid module parameter restore_capslock_events is used, sometimes capslock will get stuck down after resuming. My fix is to remember the capslock state before suspend and then ignore the first 'caps lock key down' message after resume if the capslock LED was on before suspending. Signed-off-by: Rodney Lorrimar <rodney@rodney.id.au> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-01-14macintosh: fix fabrication of caplock key eventsAndy Wingo
If the user has turned on the "restore_caplock_events" parameter, the code mangles the capslock events correctly, then erroneously ignores those events. Fix logic to allow correct fallthrough. Signed-off-by: Andy Wingo <wingo@pobox.com> Acked-by: Andrew McNabb <amcnabb@mcnabbs.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fix adbhid mismergeAl Viro
This fixes a lost 'key' variable declaration that went missing in a mismerge (commit b981d8b3f5e008ff10d993be633ad00564fc22cd) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
Conflicts: drivers/macintosh/adbhid.c
2007-10-11Input: adbhid - produce all CapsLock key eventsAndrew McNabb
The ADB keyboard, which is used for Apple PowerBooks, has strange behavior with regard to the capslock key. It keeps track of capslock state internally, and it sends a keycode when capslock is engaged and a keycode when capslock is disengaged. When the current adbhid driver sees that the capslock key is pressed or released, it creates both a keypress event and a keyrelease event simultaneously. This results in normal capslock behavior. While this works, it makes it impossible to remap the capslock key to be a control key. However, by translating the 0xff keycode into capslock keycodes, we can restore the missing capslock events and make it possible to remap the capslock key. With this patch, the adbhid driver will translate these 0xff keycodes into capslock keypresses and keyreleases if /sys/module/adbhid/parameters/restore_capslock_events is set to 1. Otherwise it will retain the current behavior. This option is off by default because occasionally the 0xff keycode is not a capslock event, and a mistake may require the user to tap the capslock key. [akpm@linux-foundation.org: cleanups] Signed-off-by: Andrew McNabb <amcnabb@mcnabbs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-09-22[POWERPC] adbhid: Enable KEY_FN key reportingAristeu Rozanski
When a Fn key is used in combination with another key in ADB keyboards it will generate a Fn event and then a second event that can be a different key than pressed (Fn + F1 for instance can generate Fn + brightness down if it's configured like that). This enables the reporting of the Fn key to the input system. As Fn is a dead key for most purposes, it's useful to report it so applications can make use of it. One example is apple_mouse (https://jake.ruivo.org/uinputd/trunk/apple_mouse/) that emulates the second and third keys using a combination of keyboard keys and the mouse button. Other applications may use the KEY_FN as a modifier as well. I've been updating and using this patch for months without problems. Signed-off-by: Aristeu Rozanski <aris@ruivo.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08Input: adbhid - do not access input_dev->private directlyDmitry Torokhov
Use input_get_drvdata() and input_set_drvdata() helpers to do that. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-02-13[POWERPC] move variables in drivers/macintosh to bssOlaf Hering
Move all the initialized variables to bss. Mark a version string as const. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-24Input: handle errors from input_register_device in drivers/macintoshDmitry Torokhov
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-22[PATCH] asm/backlight.h is ppc-onlyAl Viro
2006-07-31[PATCH] powermac: More powermac backlight fixesMichael Hanselmann
This patch fixes several problems: - The legacy backlight value might be set at interrupt time. Introduced a worker to prevent it from directly calling the backlight code. - via-pmu allows the backlight to be grabbed, in which case we need to prevent other kernel code from changing the brightness. - Don't send PMU requests in via-pmu-backlight when the machine is about to sleep or waking up. - More Kconfig fixes. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26Input: fix misspelling of Hangeul keyJerome Pinot
Fix a mispelling of the korean alphabet name in the input subsystem. See http://en.wikipedia.org/wiki/Hangeul#Names for more details. KEY_HANGUEL left to not break people Signed-off-by: Jerome Pinot <ngc891@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-06-25[PATCH] Rewritten backlight infrastructure for portable Apple computersMichael Hanselmann
This patch contains a total rewrite of the backlight infrastructure for portable Apple computers. Backward compatibility is retained. A sysfs interface allows userland to control the brightness with more steps than before. Userland is allowed to upload a brightness curve for different monitors, similar to Mac OS X. [akpm@osdl.org: add needed exports] Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-29Merge ../linux-2.6Paul Mackerras
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: misc remaining driversJesper Juhl
This is the remaining misc drivers/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in misc files in drivers/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org> Acked-by: Roland Dreier <rolandd@cisco.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Len Brown <len.brown@intel.com> Acked-by: "Antonino A. Daplas" <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31Input: adbhid - fix OOPS introduced by dynalloc conversionPaul Mackerras
The problem is that adbhid[]->input is NULL, so the kernel oopses with a null pointer dereference as soon as a key is pressed. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-28[PATCH] Input: convert drivers/macintosh to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/macntosh to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-01[PATCH] macintosh/adbhid.c: adb buttons support for aluminium PowerBook G4Andreas Jaggi
This patch adds support for the special adb buttons of the aluminium PowerBook G4. Signed-off-by: Andreas Jaggi <andreas.jaggi@waterwave.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
