path: root/drivers/macintosh/ans-lcd.c
2007-08-22[POWERPC] Copy over headers from arch/ppc to arch/powerpc that we needKumar Gala
To build arch/powerpc without including asm-ppc/ we need these files in asm-powerpc/ Moved some headers under arch/powerpc/platforms if they were only used by platform or driver files and fixed up the source file includes to match the new locations Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-24[POWERPC] Remove old interface find_devicesStephen Rothwell
Replace uses with of_find_node_by_name and for_each_node_by_name. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-09-19[PATCH] powerpc: Remove sections use from ppc64 and driversJon Loeliger
Here is a new patch that removes all notion of the pmac, prep, chrp and openfirmware initialization sections, and then unifies the sections.h files without those __pmac, etc, sections identifiers cluttering things up. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
