path: root/drivers/macintosh/smu.c
2008-07-15Merge commit '85082fd7cbe3173198aac0eb5e85ab1edcc6352c' into test-buildBenjamin Herrenschmidt
Manual fixup of: arch/powerpc/Kconfig
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-01drivers/macintosh/smu.c: Improve error handlingJulia Lawall
This makes two changes: * As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b, alloc_bootmem never returns NULL and always returns a zeroed region of memory. Thus the error checking code and memset after the call to alloc_bootmem are not necessary. * The old error handling code consisted of setting a global variable to NULL and returning an error code, which could cause previously allocated resources never to be freed. The patch adds calls to appropriate resource deallocation functions. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-30macintosh: Use linux/of_{device,platform}.h instead of asmStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-20macintosh-smu: BKL pushdownArnd Bergmann
2008-06-16[POWERPC] Add missing of_node_put in drivers/macintosh/smu.cJulia Lawall
of_node_put is needed before discarding a value received from of_find_node_by_type, eg in error handling code. The semantic patch that makes the change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct device_node *n; struct device_node *n1; struct device_node *n2; statement S; identifier f1,f2; expression E1,E2; constant C; @@ n = of_find_node_by_type(...) ... if (!n) S ... when != of_node_put(n) when != n1 = f1(n,...) when != E1 = n when any when strict ( + of_node_put(n); return -C; | of_node_put(n); | n2 = f2(n,...) | E2 = n | return ...; ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-08[POWERPC] Disable G5 NAP mode during SMU commands on U3Benjamin Herrenschmidt
It appears that with the U3 northbridge, if the processor is in NAP mode the whole time while waiting for an SMU command to complete, then the SMU will fail. It could be related to the weird backward mechanism the SMU uses to get to system memory via i2c to the northbridge that doesn't operate properly when the said bridge is in napping along with the CPU. That is on U3 at least, U4 doesn't seem to be affected. This didn't show before NO_HZ as the timer wakeup was enough to make it work it seems, but that is no longer the case. This fixes it by disabling NAP mode on those machines while an SMU command is in flight. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-03drivers/macintosh/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07[POWERPC] Rename device_is_compatible to of_device_is_compatibleStephen Rothwell
for consistency with other Open Firmware interfaces (and Sparc). This is just a straight replacement. This leaves the compatibility define in place. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-04-27[POWERPC] Rename get_property to of_get_property: partial driversStephen Rothwell
This does drivers/machintosh and the hvc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-26Revert "[POWERPC] Rename get_property to of_get_property: drivers"Paul Mackerras
This reverts commit d05c7a80cf39ae7d0f8d0c3e47c93d51fcd393d3, which included changes which should go via other subsystem maintainers.
2007-04-17drivers/macintosh/smu.c: fix locking snafuAndrew Morton
It got its lock and unlock backwards. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=8334 (obviously, this code could be using plain old spin_lock_irq(), too) Cc: <matthias.kaehlcke@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
2007-04-13[POWERPC] Make struct property's value a void *Stephen Rothwell
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[POWERPC] Souped-up of_platform_device supportBenjamin Herrenschmidt
This patch first splits of_device.c and of_platform.c, the later containing the bits relative to of_platform_device's. On the "breaks" side of things, drivers uisng of_platform_device(s) need to include asm/of_platform.h now and of_(un)register_driver is now of_(un)register_platform_driver. In addition to a few utility functions to locate of_platform_device(s), the main new addition is of_platform_bus_probe() which allows the platform code to trigger an automatic creation of of_platform_devices for a whole tree of devices. The function acts based on the type of the various "parent" devices encountered from a provided root, using either a default known list of bus types that can be "probed" or a passed-in list. It will only register devices on busses matching that list, which mean that typically, it will not register PCI devices, as expected (since they will be picked up by the PCI layer). This will be used by Cell platforms using 4xx-type IOs in the Axon bridge and can be used by any embedded-type device as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-01Merge branch 'merge'Paul Mackerras
2006-07-31[POWERPC] powermac: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powermac platform & macintosh driver changes. Built for pmac32_defconfig, g5_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-10[PATCH] powerpc: fix SMU driver interrupt mappingBenjamin Herrenschmidt
The SMU driver tries to map an interrupt from the device-tree before the interrupt controllers in the machine have been enumerated. This doesn't work properly and cause machines like the Quad g5 to fail booting later on when some drivers waits endlessly for an SMU request to complete. This is the second problem preventing boot on the Quad g5. This fixes it and also makes the SMU driver a bit more resilient to not having an interrupt. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[POWERPC] Add new interrupt mapping core and change platforms to use itBenjamin Herrenschmidt
This adds the new irq remapper core and removes the old one. Because there are some fundamental conflicts with the old code, like the value of NO_IRQ which I'm now setting to 0 (as per discussions with Linus), etc..., this commit also changes the relevant platform and driver code over to use the new remapper (so as not to cause difficulties later in bisecting). This patch removes the old pre-parsing of the open firmware interrupt tree along with all the bogus assumptions it made to try to renumber interrupts according to the platform. This is all to be handled by the new code now. For the pSeries XICS interrupt controller, a single remapper host is created for the whole machine regardless of how many interrupt presentation and source controllers are found, and it's set to match any device node that isn't a 8259. That works fine on pSeries and avoids having to deal with some of the complexities of split source controllers vs. presentation controllers in the pSeries device trees. The powerpc i8259 PIC driver now always requests the legacy interrupt range. It also has the feature of being able to match any device node (including NULL) if passed no device node as an input. That will help porting over platforms with broken device-trees like Pegasos who don't have a proper interrupt tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] powerpc: tidy-up of_register_driver()/driver_register() return valuesBjorn Helgaas
Remove the assumption that driver_register() returns the number of devices bound to the driver. In fact, it returns zero for success or a negative error value. Nobody uses the return value of of_register_driver() anyway. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] 2/5 powerpc: Rework PowerMac i2c part 2Benjamin Herrenschmidt
This is the continuation of the previous patch. This one removes the old PowerMac i2c drivers (i2c-keywest and i2c-pmac-smu) and replaces them both with a single stub driver that uses the new PowerMac low i2c layer. Now that i2c-keywest is gone, the low-i2c code is extended to support interrupt driver transfers. All i2c busses now appear as platform devices. Compatibility with existing drivers should be maintained as the i2c bus names have been kept identical, except for the SMU bus but in that later case, all users has been fixed. With that patch added, matching a device node to an i2c_adapter becomes trivial. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] 1/5 powerpc: Rework PowerMac i2c part 1Benjamin Herrenschmidt
This is the first part of a rework of the PowerMac i2c code. It completely reworks the "low_i2c" layer. It is now more flexible, supports KeyWest, SMU and PMU i2c busses, and provides functions to match device nodes to i2c busses and adapters. This patch also extends & fix some bugs in the SMU driver related to i2c support and removes the clock spreading hacks from the pmac feature code rather than adapting them to the new API since they'll be replaced by the platform function code completely in patch 3/5 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Experimental support for new G5 Macs (#2)Benjamin Herrenschmidt
This adds some very basic support for the new machines, including the Quad G5 (tested), and other new dual core based machines and iMac G5 iSight (untested). This is still experimental ! There is no thermal control yet, there is no proper handing of MSIs, etc.. but it boots, I have all 4 cores up on my machine. Compared to the previous version of this patch, this one adds DART IOMMU support for the U4 chipset and thus should work fine on setups with more than 2Gb of RAM. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] ppc64: Thermal control for SMU based machinesBenjamin Herrenschmidt
This adds a new thermal control framework for PowerMac, along with the implementation for PowerMac8,1, PowerMac8,2 (iMac G5 rev 1 and 2), and PowerMac9,1 (latest single CPU desktop). In the future, I expect to move the older G5 thermal control to the new framework as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] ppc64: SMU partition recoveryBenjamin Herrenschmidt
This patch adds the ability to the SMU driver to recover missing calibration partitions from the SMU chip itself. It also adds some dynamic mecanism to /proc/device-tree so that new properties are visible to userland. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] ppc64: SMU based macs cpufreq supportBenjamin Herrenschmidt
CPU freq support using 970FX powertune facility for iMac G5 and SMU based single CPU desktop. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-12Merge from Linus' treePaul Mackerras
2005-09-29[PATCH] Fix ppc64 smu driver lockingBenjamin Herrenschmidt
The SMU driver has a small mistake in the locking of the interrupt code, if polled access and interrupt access race, interrupt may take a lock and return without releasing it. This fixes it. With that patch, the driver is rock solid with my experimental thermal control (which bangs it pretty hard) racing with real time clock and cpufreq handling. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-27[PATCH] ppc64 g5: merge tree build fixStephen Rothwell
We removed __pmacdata in the merge. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-22[PATCH] ppc64: SMU driver update & i2c supportBenjamin Herrenschmidt
The SMU is the "system controller" chip used by Apple recent G5 machines including the iMac G5. It drives things like fans, i2c busses, real time clock, etc... The current kernel contains a very crude driver that doesn't do much more than reading the real time clock synchronously. This is a completely rewritten driver that provides interrupt based command queuing, a userland interface, and an i2c/smbus driver for accessing the devices hanging off the SMU i2c busses like temperature sensors. This driver is a basic block for upcoming work on thermal control for those machines, among others. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
