path: root/drivers/macintosh/windfarm_cpufreq_clamp.c
2010-02-09of: add 'of_' prefix to machine_is_compatible()Grant Likely
machine is compatible is an OF-specific call. It should have the of_ prefix to protect the global namespace. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2006-03-03[PATCH] powerpc: Fix old g5 issues with windfarmBenjamin Herrenschmidt
Some of the windfarm sensor modules can initialize on old machines that don't have full windfarm support like non-dual core desktop G5s. Unfortunately, by doing so, they would trigger a bug in their matching algorithm causing them to attach to the wrong bus, thus triggering issues with the i2c core and breaking the thermal driver. This patch fixes the probing issue (so that they will work when a windfarm port is done to these machines) and also prevents for now windfarm to load at all on these machines that still use therm_pm72 to avoid wasting resources. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] ppc64: Thermal control for SMU based machinesBenjamin Herrenschmidt
This adds a new thermal control framework for PowerMac, along with the implementation for PowerMac8,1, PowerMac8,2 (iMac G5 rev 1 and 2), and PowerMac9,1 (latest single CPU desktop). In the future, I expect to move the older G5 thermal control to the new framework as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
