path: root/drivers/macintosh/windfarm_pm91.c
2010-04-07powerpc/pmac/windfarm: Correct potential double freeJulia Lawall
The conditionals were testing different values, but then all freeing the same one, which could result in a double free. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,e; identifier f; iterator I; statement S; @@ *kfree(x); ... when != &x when != x = e when != I(x,...) S *x // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-09of: add 'of_' prefix to machine_is_compatible()Grant Likely
machine is compatible is an OF-specific call. It should have the of_ prefix to protect the global namespace. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2008-04-24[POWERPC] macintosh/windfarm: Fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable "macintosh" platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-15[PATCH] powerpc: windfarm shall request it's sub modulesBenjamin Herrenschmidt
The windfarm code, in it's current incarnation, uses request_module() to load the various submodules it needs for a given platform so that only the main platform control module needs to be modprobed. However, it was missing various bits. This fixes it. In the future, we'll use some hotplug mecanisms to try to get all of this auto-loaded on the platforms where it matters but that isn't ready yet. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[POWERPC] Fix windfarm platform device usageBenjamin Herrenschmidt
The windfarm code uses a struct device_driver instead of platform_driver, which can cause crashes if any of the callbacks are called (like on module removal). This fixes it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-31[POWERPC] powermac: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powermac platform & macintosh driver changes. Built for pmac32_defconfig, g5_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: Thermal control for dual core G5sBenjamin Herrenschmidt
This patch adds a windfarm module, windfarm_pm112, for the dual core G5s (both 2 and 4 core models), keeping the machine from getting into vacuum-cleaner mode ;) For proper credits, the patch was initially written by Paul Mackerras, and slightly reworked by me to add overtemp handling among others. The patch also removes the sysfs attributes from windfarm_pm81 and windfarm_pm91 and instead adds code to the windfarm core to automagically expose attributes for sensor & controls. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[PATCH] ppc64: Thermal control for SMU based machinesBenjamin Herrenschmidt
This adds a new thermal control framework for PowerMac, along with the implementation for PowerMac8,1, PowerMac8,2 (iMac G5 rev 1 and 2), and PowerMac9,1 (latest single CPU desktop). In the future, I expect to move the older G5 thermal control to the new framework as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
