path: root/drivers/macintosh
2014-01-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "So here's my next branch for powerpc. A bit late as I was on vacation last week. It's mostly the same stuff that was in next already, I just added two patches today which are the wiring up of lockref for powerpc, which for some reason fell through the cracks last time and is trivial. The highlights are, in addition to a bunch of bug fixes: - Reworked Machine Check handling on kernels running without a hypervisor (or acting as a hypervisor). Provides hooks to handle some errors in real mode such as TLB errors, handle SLB errors, etc... - Support for retrieving memory error information from the service processor on IBM servers running without a hypervisor and routing them to the memory poison infrastructure. - _PAGE_NUMA support on server processors - 32-bit BookE relocatable kernel support - FSL e6500 hardware tablewalk support - A bunch of new/revived board support - FSL e6500 deeper idle states and altivec powerdown support You'll notice a generic mm change here, it has been acked by the relevant authorities and is a pre-req for our _PAGE_NUMA support" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (121 commits) powerpc: Implement arch_spin_is_locked() using arch_spin_value_unlocked() powerpc: Add support for the optimised lockref implementation powerpc/powernv: Call OPAL sync before kexec'ing powerpc/eeh: Escalate error on non-existing PE powerpc/eeh: Handle multiple EEH errors powerpc: Fix transactional FP/VMX/VSX unavailable handlers powerpc: Don't corrupt transactional state when using FP/VMX in kernel powerpc: Reclaim two unused thread_info flag bits powerpc: Fix races with irq_work Move precessing of MCE queued event out from syscall exit path. pseries/cpuidle: Remove redundant call to ppc64_runlatch_off() in cpu idle routines powerpc: Make add_system_ram_resources() __init powerpc: add SATA_MV to ppc64_defconfig powerpc/powernv: Increase candidate fw image size powerpc: Add debug checks to catch invalid cpu-to-node mappings powerpc: Fix the setup of CPU-to-Node mappings during CPU online powerpc/iommu: Don't detach device without IOMMU group powerpc/eeh: Hotplug improvement powerpc/eeh: Call opal_pci_reinit() on powernv for restoring config space powerpc/eeh: Add restore_config operation ...
2014-01-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - Zorro bus cleanups and UAPI revival - Bootinfo cleanups and UAPI revival - Kexec support - Memory size reductions and bug fixes for multi-platform kernels - Polled interrupt support for Atari EtherNAT, EtherNEC and NetUSBee - Machine-specific random_get_entropy() - Defconfig updates and cleanups * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (46 commits) m68k/mac: Make SCC reset work more reliably m68k/irq - Use polled IRQ flag for MFP timer cascaded interrupts m68k: Update defconfigs for v3.13-rc1 m68k/defconfig: Enable EARLY_PRINTK m68k/mm: kmap spelling/grammar fixes m68k: Convert arch/m68k/kernel/traps.c to pr_*() m68k: Convert arch/m68k/mm/fault.c to pr_*() m68k/mm: Check for mm != NULL in do_page_fault() debug code m68k/defconfig: Disable /sbin/hotplug fork-bomb by default m68k/atari: Hide RTC_PORT() macro from rtc-cmos m68k/amiga,atari: Fix specifying multiple debug= parameters m68k/defconfig: Use ext4 for ext2/ext3 file systems m68k: Add support to export bootinfo in procfs m68k: Add kexec support m68k/mac: Mark Mac IIsi ADB driver BROKEN m68k/amiga: Provide mach_random_get_entropy() m68k: Add infrastructure for machine-specific random_get_entropy() m68k/atari: Call paging_init() before nf_init() m68k: Remove superfluous inclusions of <asm/bootinfo.h> m68k/UAPI: Use proper types (endianness/size) in <asm/bootinfo*.h> ...
2013-12-08m68k/mac: Mark Mac IIsi ADB driver BROKENGeert Uytterhoeven
As reported by Finn Thain, the Mac IIsi ADB driver should be disabled because it will crash. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-12-05powerpc/windfarm: Remove superfluous name castsGeert Uytterhoeven
wf_sensor.name is "const char *" Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-11-27powerpc/windfarm: Fix XServe G5 fan control Makefile issueBenjamin Herrenschmidt
We are missing building windfarm_max6690_sensor.o when building CONFIG_WINDFARM_RM31. Usually all the windfarm drivers are built and thus this isn't a problem but some more "tailored" setups (Gentoo ?) building only that driver are not working because the require sensor module is missing. Reported-by: Stanislav Ponomarev <devhexorg@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-10-31powerpc/pmu: Fix ADB_PMU_LED_IDE dependenciesChristian Kujau
for quite some time the following is printed (twice) after doing "make oldconfig": [...] scripts/kconfig/conf --oldconfig Kconfig warning: (ADB_PMU_LED_IDE) selects LEDS_TRIGGER_IDE_DISK which has unmet direct dependencies (NEW_LEDS && IDE_GD_ATA && LEDS_TRIGGERS) warning: (ADB_PMU_LED_IDE) selects LEDS_TRIGGER_IDE_DISK which has unmet direct dependencies (NEW_LEDS && IDE_GD_ATA && LEDS_TRIGGERS) The following patch causes ADB_PMU_LED to depend on IDE_GD_ATA, so that the options above are only available when IDE_GD_ATA is actually selected and thus eliminates the warning. Signed-off-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-08-14macintosh/ams: Replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-01powerpc/windfarm: Fix noisy slots-fan on Xserve (rm31)Aaro Koskinen
slots-fan on G5 Xserve is always running at full speed with windfarm_rm31 driver, resulting in a very high acoustic noise level. It seems the fan parameters are incorrect, and have been copied from the Drive Bay fan (RPM, not present on rm31) of the legacy therm_pm72 driver. This patch changes the parameters to match the Slots fan (PWM) of therm_pm72. With the patch, slots-fan speed drops from 99% to 19% during normal use, and slots-temp settle to ~42'C. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> CC: <stable@vger.kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01macintosh/windfarm: Remove obsolete cleanup for clientdataWolfram Sang
A few new i2c-drivers came into the kernel which clear the clientdata-pointer on exit or error. This is obsolete meanwhile, the core will do it. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01mac: Make cuda_init_via() __initGeert Uytterhoeven
cuda_init_via() is called from find_via_cuda() only, which is __init. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01macintosh: Convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01powerpc/windfarm: Fix overtemperature clearingAaro Koskinen
With pm81/pm91/pm121, when the overtemperature state is entered, and when it remains on after skipped ticks, the driver will try to leave it too soon (immediately on the next tick). This is because the active FAILURE_OVERTEMP state is not visible in "new_failure" variable of the current tick. Furthermore, the driver will keep trying to clear condition in subsequent ticks as FAILURE_OVERTEMP remains set in the "last_failure" variable. These will start to trigger WARNINGS from windfarm core: [ 100.082735] windfarm: Clamping CPU frequency to minimum ! [ 100.108132] windfarm: Overtemp condition detected ! [ 101.952908] windfarm: Overtemp condition cleared ! [...] [ 102.980388] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 103.982227] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 105.030494] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 105.973666] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 106.977913] WARNING: at drivers/macintosh/windfarm_core.c:463 Fix by adding a helper global variable. We leave the overtemp state only after all failure bits have been cleared. I saw this error on iMac G5 iSight (pm121). Also pm81/pm91 are fixed based on the observation that these are almost identical/copy-pasted code. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-25macintosh/adb: Replace __WAITQUEUE_INITIALIZER with more standard ↵Robert P. J. Day
DECLARE_WAITQUEUE. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlights this time around are: - A pile of addition POWER8 bits and nits, such as updated performance counter support (Michael Ellerman), new branch history buffer support (Anshuman Khandual), base support for the new PCI host bridge when not using the hypervisor (Gavin Shan) and other random related bits and fixes from various contributors. - Some rework of our page table format by Aneesh Kumar which fixes a thing or two and paves the way for THP support. THP itself will not make it this time around however. - More Freescale updates, including Altivec support on the new e6500 cores, new PCI controller support, and a pile of new boards support and updates. - The usual batch of trivial cleanups & fixes" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) powerpc: Fix build error for book3e powerpc: Context switch the new EBB SPRs powerpc: Turn on the EBB H/FSCR bits powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S powerpc: Setup BHRB instructions facility in HFSCR for POWER8 powerpc: Fix interrupt range check on debug exception powerpc: Update tlbie/tlbiel as per ISA doc powerpc: Print page size info during boot powerpc: print both base and actual page size on hash failure powerpc: Fix hpte_decode to use the correct decoding for page sizes powerpc: Decode the pte-lp-encoding bits correctly. powerpc: Use encode avpn where we need only avpn values powerpc: Reduce PTE table memory wastage powerpc: Move the pte free routines from common header powerpc: Reduce the PTE_INDEX_SIZE powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format powerpc: New hugepage directory format powerpc: Don't truncate pgd_index wrongly powerpc: Don't hard code the size of pte page powerpc: Save DAR and DSISR in pt_regs on MCE ...
2013-04-23powerpc/pmac/smu: Use %*ph to print small buffersAndy Shevchenko
Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "So from the depth of frozen Minnesota, here's the powerpc pull request for 3.9. It has a few interesting highlights, in addition to the usual bunch of bug fixes, minor updates, embedded device tree updates and new boards: - Hand tuned asm implementation of SHA1 (by Paulus & Michael Ellerman) - Support for Doorbell interrupts on Power8 (kind of fast thread-thread IPIs) by Ian Munsie - Long overdue cleanup of the way we handle relocation of our open firmware trampoline (prom_init.c) on 64-bit by Anton Blanchard - Support for saving/restoring & context switching the PPR (Processor Priority Register) on server processors that support it. This allows the kernel to preserve thread priorities established by userspace. By Haren Myneni. - DAWR (new watchpoint facility) support on Power8 by Michael Neuling - Ability to change the DSCR (Data Stream Control Register) which controls cache prefetching on a running process via ptrace by Alexey Kardashevskiy - Support for context switching the TAR register on Power8 (new branch target register meant to be used by some new specific userspace perf event interrupt facility which is yet to be enabled) by Ian Munsie. - Improve preservation of the CFAR register (which captures the origin of a branch) on various exception conditions by Paulus. - Move the Bestcomm DMA driver from arch powerpc to drivers/dma where it belongs by Philippe De Muyter - Support for Transactional Memory on Power8 by Michael Neuling (based on original work by Matt Evans). For those curious about the feature, the patch contains a pretty good description." (See commit db8ff907027b: "powerpc: Documentation for transactional memory on powerpc" for the mentioned description added to the file Documentation/powerpc/transactional_memory.txt) * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (140 commits) powerpc/kexec: Disable hard IRQ before kexec powerpc/85xx: l2sram - Add compatible string for BSC9131 platform powerpc/85xx: bsc9131 - Correct typo in SDHC device node powerpc/e500/qemu-e500: enable coreint powerpc/mpic: allow coreint to be determined by MPIC version powerpc/fsl_pci: Store the pci ctlr device ptr in the pci ctlr struct powerpc/85xx: Board support for ppa8548 powerpc/fsl: remove extraneous DIU platform functions arch/powerpc/platforms/85xx/p1022_ds.c: adjust duplicate test powerpc: Documentation for transactional memory on powerpc powerpc: Add transactional memory to pseries and ppc64 defconfigs powerpc: Add config option for transactional memory powerpc: Add transactional memory to POWER8 cpu features powerpc: Add new transactional memory state to the signal context powerpc: Hook in new transactional memory code powerpc: Routines for FP/VSX/VMX unavailable during a transaction powerpc: Add transactional memory unavaliable execption handler powerpc: Add reclaim and recheckpoint functions for context switching transactional memory processes powerpc: Add FP/VSX and VMX register load functions for transactional memory powerpc: Add helper functions for transactional memory context switching ...
2013-01-21drivers/macintosh: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-10powerpc/windfarm: Use for_each_node_by_type() macroWei Yongjun
Use for_each_node_by_type() macro instead of open coding it. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-03Drivers: macintosh: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-18Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlight is probably some base POWER8 support. There's more to come such as transactional memory support but that will wait for the next one. Overall it's pretty quiet, or rather I've been pretty poor at picking things up from patchwork and reviewing them this time around and Kumar no better on the FSL side it seems..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits) powerpc+of: Rename and fix OF reconfig notifier error inject module powerpc: mpc5200: Add a3m071 board support powerpc/512x: don't compile any platform DIU code if the DIU is not enabled powerpc/mpc52xx: use module_platform_driver macro powerpc+of: Export of_reconfig_notifier_[register,unregister] powerpc/dma/raidengine: add raidengine device powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct powerpc/mpc85xx: Change spin table to cached memory powerpc/fsl-pci: Add PCI controller ATMU PM support powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS] powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers powerpc: Disable relocation on exceptions when kexecing powerpc: Enable relocation on during exceptions at boot powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function powerpc: Add wrappers to enable/disable relocation on exceptions powerpc: Add set_mode hcall powerpc: Setup relocation on exceptions for bare metal systems powerpc: Move initial mfspr LPCR out of __init_LPCR powerpc: Add relocation on exception vector handlers ...
2012-12-11bootmem: fix wrong call parameter for free_bootmem()Joonsoo Kim
It is strange that alloc_bootmem() returns a virtual address and free_bootmem() requires a physical address. Anyway, free_bootmem()'s first parameter should be physical address. There are some call sites for free_bootmem() with virtual address. So fix them. [akpm@linux-foundation.org: improve free_bootmem() and free_bootmem_pate() documentation] Signed-off-by: Joonsoo Kim <js1304@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-15Merge branch 'dt' into nextBenjamin Herrenschmidt
2012-11-15powerpc/windfarm: Use module_i2c_driver to simplify the codeWei Yongjun
Use the module_i2c_driver() macro to make the code smaller and a bit simpler. dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-11-15powerpc+of: Rename the drivers/of prom_* functions to of_*Nathan Fontenot
Rename the prom_*_property routines of the generic OF code to of_*_property. This brings them in line with the naming used by the rest of the OF code. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Acked-by: Geoff Levand <geoff@infradead.org> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-10-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "Some highlights in addition to the usual batch of fixes: - 64TB address space support for 64-bit processes by Aneesh Kumar - Gavin Shan did a major cleanup & re-organization of our EEH support code (IBM fancy PCI error handling & recovery infrastructure) which paves the way for supporting different platform backends, along with some rework of the PCIe code for the PowerNV platform in order to remove home made resource allocations and instead use the generic code (which is possible after some small improvements to it done by Gavin). - Uprobes support by Ananth N Mavinakayanahalli - A pile of embedded updates from Freescale folks, including new SoC and board supports, more KVM stuff including preparing for 64-bit BookE KVM support, ePAPR 1.1 updates, etc..." Fixup trivial conflicts in drivers/scsi/ipr.c * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits) powerpc/iommu: Fix multiple issues with IOMMU pools code powerpc: Fix VMX fix for memcpy case driver/mtd:IFC NAND:Initialise internal SRAM before any write powerpc/fsl-pci: use 'Header Type' to identify PCIE mode powerpc/eeh: Don't release eeh_mutex in eeh_phb_pe_get powerpc: Remove tlb batching hack for nighthawk powerpc: Set paca->data_offset = 0 for boot cpu powerpc/perf: Sample only if SIAR-Valid bit is set in P7+ powerpc/fsl-pci: fix warning when CONFIG_SWIOTLB is disabled powerpc/mpc85xx: Update interrupt handling for IFC controller powerpc/85xx: Enable USB support in p1023rds_defconfig powerpc/smp: Do not disable IPI interrupts during suspend powerpc/eeh: Fix crash on converting OF node to edev powerpc/eeh: Lock module while handling EEH event powerpc/kprobe: Don't emulate store when kprobe stwu r1 powerpc/kprobe: Complete kprobe and migrate exception frame powerpc/kprobe: Introduce a new thread flag powerpc: Remove unused __get_user64() and __put_user64() powerpc/eeh: Global mutex to protect PE tree powerpc/eeh: Remove EEH PE for normal PCI hotplug ...
2012-10-06sections: fix section conflicts in drivers/macintoshAndi Kleen
[akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-09-11macintosh/mediabay: make data used as *of_device_id.data constArnd Bergmann
Since of_device_id.data is declared as a pointer to const data a few more consts can be added in this driver. [ukl: split Arnd's patch by driver] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2012-09-11macintosh/mediabay: add a const qualifierUwe Kleine-König
This prepares *of_device_id.data becoming const. Without this change the following warning would occur: drivers/macintosh/mediabay.c: In function 'media_bay_attach': drivers/macintosh/mediabay.c:589:11: warning: assignment discards 'const' qualifier from pointer target type [enabled by default] Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2012-09-05drivers/macintosh/smu.c: Replace abs_to_virt() with __va()Michael Ellerman
abs_to_virt() is just a wrapper around __va(), call __va() directly. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-05-09powerpc/windfarm: Fix crash on SMU based machine after i2c conversionBenjamin Herrenschmidt
We no longer get the device node in platform_data but instead where it belongs in struct device, so get it from there instead of blowing up. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-05-03powerpc/windfarm: don't pass const strings to snprintfStephen Rothwell
Fixes these build warnings: drivers/macintosh/windfarm_smu_sat.c: In function 'wf_sat_probe': drivers/macintosh/windfarm_smu_sat.c:290:3: warning: passing argument 1 of 'snprintf' discards qualifiers from pointer target type include/linux/kernel.h:323:5: note: expected 'char *' but argument is of type 'const char *' drivers/macintosh/windfarm_smu_sat.c:317:3: warning: passing argument 1 of 'snprintf' discards qualifiers from pointer target type include/linux/kernel.h:323:5: note: expected 'char *' but argument is of type 'const char *' Introduced by commit e074d08e2b98 ("powerpc/windfarm: const'ify and add "priv" field to controls & sensors"). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-05-03powerpc/windfarm: fix compiler warningStephen Rothwell
Fixes this warning: drivers/macintosh/windfarm_pm91.c: In function 'wf_smu_cpu_fans_tick': drivers/macintosh/windfarm_pm91.c:237:2: warning: passing argument 1 of 'wf_sensor_get' from incompatible pointer type drivers/macintosh/windfarm.h:124:19: note: expected 'struct wf_sensor *' but argument is of type 'struct wf_sensor **' Introduced by commit 33e6820b767a ("powerpc/windfarm: Add useful accessors"). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/powermac: New windfarm driver for PowerMac G5 (AGP) and Xserve G5Benjamin Herrenschmidt
This replaces the old therm_pm72 using the same windfarm infrastructure that was used for other PowerMac G5 models. The fan speeds and sensors should now be visible in the same location in sysfs. The driver is split into separate core modules for PowerMac7,2 (and 7,3) and RackMac3,1, with a lot of the shared code now in the separate sensor and control modules. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: Add Fan Control Unit controls for G5sBenjamin Herrenschmidt
The FCU operates the fans on the earlier generation G5 machines, this module will be used by upcoming windfarm drivers. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: Updates to lm75 and max6690 sensorsBenjamin Herrenschmidt
This allows those modules to load on PowerMac7,2 PowerMac7,3 and RackMac3,1 and add the sensor name conversion for those machines. This will be used by the corresponding new windfarm modules for those machines. Note that since therm_pm72 is linked first, it will still take priority on those i2c devices if built-in. If using modules it will depend which is loaded first, but you should avoid building therm_pm72 if you are using the new windfarm drivers Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: Add lm87 sensorBenjamin Herrenschmidt
For use by the upcoming windfarm_rm31 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: Add ad7417 sensorBenjamin Herrenschmidt
For user by the upcoming windfarm_pm72 and windfarm_rm31 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: Add useful accessorsBenjamin Herrenschmidt
Makes the code more readable Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: Improve display of fan speeds in sysfsBenjamin Herrenschmidt
Controls registered as RPM and PWM fans are now displayed with the "RPM" or "%" suffix respectively to make it clearer to the user what the value actually means since the fan type isn't otherwise obvious. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: Remove spurrious sysfs_attr_init()Benjamin Herrenschmidt
The windfarm core will do it, so this is a duplicate. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/windfarm: const'ify and add "priv" field to controls & sensorsBenjamin Herrenschmidt
const'ify the sensor ops and name and add a void* for use by the control and sensor drivers to point back to their private data, avoiding the need to create a wrapper data structure per sensor or control instance. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/pmac: Convert windfarm_smu_sat to new i2c probingBenjamin Herrenschmidt
This simplifies the driver to stop using the deprecated attach interface. While at it we also implement teardown properly and fix the refcounting by using a kref. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/pmac: Convert windfarm_max6690 to new i2c probingBenjamin Herrenschmidt
This simplifies the driver to stop using the deprecated attach interface Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-30powerpc/pmac: Convert windfarm_lm75 to new i2c probingBenjamin Herrenschmidt
2012-04-30powerpc/pmac: Convert therm_adt746x to new i2c probingBenjamin Herrenschmidt
This simplifies the driver to stop using the deprecated attach interface, Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
