this fixes an oops in 2.6.16.X when loading the snd_powermac module. The
name of the requested module changed during the 2.6.16 development cycle
from i2c-keylargo to i2c-powermac:
Signed-off-by: Guido Guenther <agx@sigxcpu.org>
Report AC Power present in /proc/pmu/info if there is no battery.
Signed-off-by: Olaf Hering <olh@suse.de>
Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>,
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-merge:
powerpc: Fix various syscall/signal/swapcontext bugs
[PATCH] powerpc: incorrect rmo_top handling in prom_init
[PATCH] powerpc: Fix incorrect pud_ERROR() message
[PATCH] powerpc: Expose SMT and L1 icache snoop userland features
[PATCH] powerpc: Fix windfarm_pm112 not starting all control loops
[PATCH] powerpc: Fix old g5 issues with windfarm
powerpc32: Fix timebase synchronization on 32-bit powermacs
powerpc: Turn off verbose debug output in powermac platform functions
powerpc: Fix might-sleep warning in program check exception handler
The Windfarm PID module lacks a licence, it should be GPL, here it is
This adds a couple of printk's to windfarm_pm112 to display which
control loops are actually starting and fixes a bug where it would not
start all loops.
Some of the windfarm sensor modules can initialize on old machines that
don't have full windfarm support like non-dual core desktop G5s.
Unfortunately, by doing so, they would trigger a bug in their matching
algorithm causing them to attach to the wrong bus, thus triggering
issues with the i2c core and breaking the thermal driver.
This patch fixes the probing issue (so that they will work when a
windfarm port is done to these machines) and also prevents for now
windfarm to load at all on these machines that still use therm_pm72 to
avoid wasting resources.
The windfarm_pm112 module relies on smu_sat_get_sdb_partition which is in
windfarm_smu_sat.c but is not exported to modules, so despite Kconfig
having the option to build the pm112 as modules, this can never be loaded.
This patch fixes that by exporting smu_sat_get_sdb_partition with
EXPORT_SYMBOL_GPL
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Quoth BenH:
"Ok, looks like I forgot to update the Kconfig for the new i2c driver,
it should select I2C_POWERMAC instead. Do you want a new patch or
can you just fix it there ?"
This patch adds a windfarm module, windfarm_pm112, for the dual core G5s
(both 2 and 4 core models), keeping the machine from getting into
vacuum-cleaner mode ;) For proper credits, the patch was initially
written by Paul Mackerras, and slightly reworked by me to add overtemp
handling among others. The patch also removes the sysfs attributes from
windfarm_pm81 and windfarm_pm91 and instead adds code to the windfarm
core to automagically expose attributes for sensor & controls.
Prodive a MODALIAS= enviroment variable for devices on the mac-io bus.
Change the buffer length counter to not waste memory by advancing the
pointer for the next string too far. Tested on an ibook1 with modular
pmac_zilog.
semaphore to mutex conversion.
the conversion was generated via scripts, and the result was validated
automatically via a script as well.
build and boot tested.
This makes macio-adb.c build again. Entirely untested.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
cuda/pmu/maciisi requests
kill ADBREQ_RAW use, replace adb_read_time(), etc. with per-type variants,
eliminated remapping from pmu ones, fix the ifdefs (PMU->PMU68K)
This is the platform function interpreter itself along with the backends
for UniN/U3/U4, mac-io, GPIOs and i2c. It adds the ability to execute
those do-platform-* scripts in the device-tree (at least for most
devices for which a backend is provided). This should replace the clock
spreading hacks properly. It might also have an impact on all sort of
machines since some of the scripts marked "at init" will now be executed
on boot (or some other on sleep/wakeup), those will possibly do things
that the kernel didn't do at all, like setting some values into some i2c
devices (changing thermal sensor calibration or conversion rate) etc...
Thus regression testing is MUCH welcome. Also loook for errors in dmesg.
That's also why I've left rather verbose debugging enabled in this
version of the patch.
(I do expect some Windtunnel G4s to show some errors as they have an i2c
clock chip on the PMU bus that uses some primitives that the i2c backend
doesn't implement yet. I really need users that have one of those
machine to come back to me so we can get that done right, though the
errors themselves should be harmless, I suspect the machine might not
run at full speed).
This is the continuation of the previous patch. This one removes the old
PowerMac i2c drivers (i2c-keywest and i2c-pmac-smu) and replaces them
both with a single stub driver that uses the new PowerMac low i2c layer.
Now that i2c-keywest is gone, the low-i2c code is extended to support
interrupt driver transfers. All i2c busses now appear as platform
devices. Compatibility with existing drivers should be maintained as the
i2c bus names have been kept identical, except for the SMU bus but in
that later case, all users has been fixed.
With that patch added, matching a device node to an i2c_adapter becomes
trivial.
This is the first part of a rework of the PowerMac i2c code. It
completely reworks the "low_i2c" layer. It is now more flexible,
supports KeyWest, SMU and PMU i2c busses, and provides functions to
match device nodes to i2c busses and adapters.
This patch also extends & fix some bugs in the SMU driver related to i2c
support and removes the clock spreading hacks from the pmac feature code
rather than adapting them to the new API since they'll be replaced by
the platform function code completely in patch 3/5
Include fixes for 2.6.14-git11. Should allow to remove sched.h from
module.h on i386, x86_64, arm, ia64, ppc, ppc64, and s390. Probably more
to come since I haven't yet checked the other archs.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Fix compilation of via-pmu.c without Power Management support.
This adds some very basic support for the new machines, including the
Quad G5 (tested), and other new dual core based machines and iMac G5
iSight (untested). This is still experimental ! There is no thermal
control yet, there is no proper handing of MSIs, etc.. but it
boots, I have all 4 cores up on my machine. Compared to the previous
version of this patch, this one adds DART IOMMU support for the U4
chipset and thus should work fine on setups with more than 2Gb of RAM.
The pre-parsed addrs/n_addrs fields in struct device_node are finally
gone. Remove the dodgy heuristics that did that parsing at boot and
remove the fields themselves since we now have a good replacement with
the new OF parsing code. This patch also fixes a bunch of drivers to use
the new code instead, so that at least pmac32, pseries, iseries and g5
defconfigs build.
This updates the OF address parsers to return the IO flags
indicating the type of address obtained. It also adds a PCI
call for converting physical addresses that hit IO space into
into IO tokens, and add routines that return the translated
addresses into struct resource
The udbg low level io layer has an issue with udbg_getc() returning a
char (unsigned on ppc) instead of an int, thus the -1 if you had no
available input device could end up turned into 0xff, filling your
display with bogus characters. This fixes it, along with adding a little
blob to xmon to do a delay before exiting when getting an EOF and fixing
the detection of ADB keyboards in udbg_adb.c
Converts the macio_asic core to use the new OF parsing routines instead
of relying on the pre-parsed values in struct device_node.
This patch unifies udbg for both ppc32 and ppc64 when building the
merged achitecture. xmon now has a single "back end". The powermac udbg
stuff gets enriched with some ADB capabilities and btext output. In
addition, the early_init callback is now called on ppc32 as well,
approx. in the same order as ppc64 regarding device-tree manipulations.
The init sequences of ppc32 and ppc64 are getting closer, I'll unify
them in a later patch.
For now, you can force udbg to the scc using "sccdbg" or to btext using
"btextdbg" on powermacs. I'll implement a cleaner way of forcing udbg
output to something else than the autodetected OF output device in a
later patch.
Only output the messages about fan speed changes with a verbose=1 module
param.
Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com>
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
processing done
therm_pm72.c and windfarm_lm75_sensor.c both store the return from
i2c_add_driver() but do no further processing on the result. Simply return
what i2c_add_driver() did, instead.
Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch>
Now that i2c_add_driver() doesn't need the module owner to be set by
hand, we can delete it from the drivers. This patch catches all of the
drivers that I found in the current tree (if a driver sets the .owner by
hand, it's not a problem, just not needed.)
Cc: Jean Delvare <khali@linux-fr.org>
We should use the i2c_driver.driver's .name and .owner fields
instead of the i2c_driver's ones.
This patch updates the drivers for macintosh.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we
can simply make it the default and drop the flag. If any driver really
doesn't want to be notified when i2c adapters are added, that driver
can simply omit to set .attach_adapter. This approach is also more
robust as it prevents accidental NULL pointer dereferences.
Leave the overloaded "hotplug" word to susbsystems which are handling
real devices. The driver core does not "plug" anything, it just exports
the state to userspace and generates events.
Signed-off-by: Kay Sievers <kay.sievers@suse.de>
Some G5s still occasionally experience shutdowns due to overtemp
conditions despite the recent fix. After analyzing logs from such
machines, it appears that the overtemp code is a bit too quick at
shutting the machine down when reaching the critical temperature (tmax +
8) and doesn't leave the fan enough time to actually cool it down. This
happens if the temperature of a CPU suddenly rises too high in a very
short period of time, or occasionally on boot (that is the CPUs are
already overtemp by the time the driver loads).
This patches makes the code a bit more relaxed, leaving a few seconds to
the fans to do their job before kicking the machine shutown.
The g5 thermal control for liquid cooled machines has a small bug, when
the temperatures gets too high, it boosts all fans to the max, but
incorrectly sets the liquids pump to the min instead of the max speed,
thus causing the overtemp condition not to clear and the machine to shut
down after a while. This fixes it to set the pumps to max speed instead.
This problem might explain some of the reports of random shutdowns that
some g5 users have been reporting in the past.
Many thanks to Marcus Rothe for spending a lot of time trying various
patches & sending log logs before I found out that typo. Note that
overtemp handling is still not perfect and the machine might still
shutdown, that patch should reduce if not eliminate such occcurences in
"normal" conditions with high load. I'll implement a better handling
with proper slowing down of the CPUs later.
model_id fields of wf_smu_sys_all_params should match the model ID
they are supposed to represent (as commented). Fixes windfarm on some
iMac 8,1 models.
Signed-off-by: Michal Ostrowski <mostrows at watson ibm com>
This fixes a build error when building the pmac sound driver as a
module for 64-bit powermacs.
Building a PowerMac kernel with ARCH=powerpc causes a bunch of warnings,
this fixes some of them
This adds a new thermal control framework for PowerMac, along with the
implementation for PowerMac8,1, PowerMac8,2 (iMac G5 rev 1 and 2), and
PowerMac9,1 (latest single CPU desktop). In the future, I expect to move
the older G5 thermal control to the new framework as well.
This patch adds the ability to the SMU driver to recover missing
calibration partitions from the SMU chip itself. It also adds some
dynamic mecanism to /proc/device-tree so that new properties are visible
to userland.
CPU freq support using 970FX powertune facility for iMac G5 and SMU
based single CPU desktop.
This is the remaining misc drivers/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in misc files in
drivers/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org>
Acked-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
Acked-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Len Brown <len.brown@intel.com>
Acked-by: "Antonino A. Daplas" <adaplas@gmail.com>
Use schedule_timeout_interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
We were getting powerbook sleep code included, and giving compile
errors, with CONFIG_PM=y on a 64-bit build. This excludes that code
so the kernel will compile. One day BenH will implement on sleep on
the G5...
The problem is that adbhid[]->input is NULL, so the kernel oopses with
a null pointer dereference as soon as a key is pressed.
