path: root/drivers/mailbox
2014-01-23drivers/mailbox/omap: make mbox->irq signed for error handlingDan Carpenter
There is a bug in omap2_mbox_probe() where we try do: mbox->irq = platform_get_irq(pdev, info->irq_id); if (mbox->irq < 0) { The problem is that mbox->irq is unsigned so the error handling doesn't work. I've changed it to a signed integer. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Suman Anna <s-anna@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Omar Ramirez Luna <omar.ramirez@copitl.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-18mailbox: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-06-11mailbox/omap: move the OMAP mailbox framework to driversSuman Anna
The mailbox hardware (in OMAP) uses a queued mailbox interrupt mechanism that provides a communication channel between processors through a set of registers and their associated interrupt signals by sending and receiving messages. The OMAP mailbox framework/driver code is moved to be under drivers/mailbox, in preparation for adapting to a common mailbox driver framework. This allows the build for OMAP mailbox to be enabled (it was disabled during the multi-platform support). As part of the migration from plat and mach code: - Kconfig symbols have been renamed to build OMAP1 or OMAP2+ drivers. - mailbox.h under plat-omap/plat/include has been split into a public and private header files. The public header has only the API related functions and types. - The module name mailbox.ko from plat-omap is changed to omap-mailbox.ko - The module name mailbox_mach.ko from mach-omapX is changed as mailbox_omap1.ko for OMAP1 mailbox_omap2.ko for OMAP2+ Cc: Tony Lindgren <tony@atomide.com> [gregkh@linuxfoundation.org: ack for staging part] Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Omar Ramirez Luna <omar.ramirez@copitl.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2013-03-04mailbox, pl320-ipc: remove __init from probe functionMark Langsdorf
Avoids a section mismatch. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-02ARM / highbank: add support for pl320 IPCRob Herring
The pl320 IPC allows for interprocessor communication between the highbank A9 and the EnergyCore Management Engine. The pl320 implements a straightforward mailbox protocol. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
