There's a bug in the MCA bus matching algorithm in that it promotes from
signed short to int before comparing with the actual id and does sign
extension on anything > 0x7fff (which means that pos ids > 0x7fff never
get correctly matched).
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
I didn't find any possible modular usage of mca_find_device_by_slot in
the kernel, and this patch therefore removes the EXPORT_SYMBOL.
This patch should be safe since mca-legacy is nothing drivers should
move to.
drivers/s390/block/dcssblk.c: update device attribute callbacks
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com>
infrastructure for it.
Let it rip!
