path: root/drivers/md/Makefile
2011-03-24dm: add flakey targetJosef Bacik
This target is the same as the linear target except that it returns I/O errors periodically. It's been found useful in simulating failing devices for testing purposes. I needed a dm target to do some failure testing on btrfs's raid code, and Mike pointed me at this. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm: raid456 basic supportNeilBrown
This patch is the skeleton for the DM target that will be the bridge from DM to MD (initially RAID456 and later RAID1). It provides a way to use device-mapper interfaces to the MD RAID456 drivers. As with all device-mapper targets, the nominal public interfaces are the constructor (CTR) tables and the status outputs (both STATUSTYPE_INFO and STATUSTYPE_TABLE). The CTR table looks like the following: 1: <s> <l> raid \ 2: <raid_type> <#raid_params> <raid_params> \ 3: <#raid_devs> <meta_dev1> <dev1> .. <meta_devN> <devN> Line 1 contains the standard first three arguments to any device-mapper target - the start, length, and target type fields. The target type in this case is "raid". Line 2 contains the arguments that define the particular raid type/personality/level, the required arguments for that raid type, and any optional arguments. Possible raid types include: raid4, raid5_la, raid5_ls, raid5_rs, raid6_zr, raid6_nr, and raid6_nc. (again, raid1 is planned for the future.) The list of required and optional parameters is the same for all the current raid types. The required parameters are positional, while the optional parameters are given as key/value pairs. The possible parameters are as follows: <chunk_size> Chunk size in sectors. [[no]sync] Force/Prevent RAID initialization [rebuild <idx>] Rebuild the drive indicated by the index [daemon_sleep <ms>] Time between bitmap daemon work to clear bits [min_recovery_rate <kB/sec/disk>] Throttle RAID initialization [max_recovery_rate <kB/sec/disk>] Throttle RAID initialization [max_write_behind <value>] See '-write-behind=' (man mdadm) [stripe_cache <sectors>] Stripe cache size for higher RAIDs Line 3 contains the list of devices that compose the array in metadata/data device pairs. If the metadata is stored separately, a '-' is given for the metadata device position. If a drive has failed or is missing at creation time, a '-' can be given for both the metadata and data drives for a given position. Examples: # RAID4 - 4 data drives, 1 parity # No metadata devices specified to hold superblock/bitmap info # Chunk size of 1MiB # (Lines separated for easy reading) 0 1960893648 raid \ raid4 1 2048 \ 5 - 8:17 - 8:33 - 8:49 - 8:65 - 8:81 # RAID4 - 4 data drives, 1 parity (no metadata devices) # Chunk size of 1MiB, force RAID initialization, # min recovery rate at 20 kiB/sec/disk 0 1960893648 raid \ raid4 4 2048 min_recovery_rate 20 sync\ 5 - 8:17 - 8:33 - 8:49 - 8:65 - 8:81 Performing a 'dmsetup table' should display the CTR table used to construct the mapping (with possible reordering of optional parameters). Performing a 'dmsetup status' will yield information on the state and health of the array. The output is as follows: 1: <s> <l> raid \ 2: <raid_type> <#devices> <1 health char for each dev> <resync_ratio> Line 1 is standard DM output. Line 2 is best shown by example: 0 1960893648 raid raid4 5 AAAAA 2/490221568 Here we can see the RAID type is raid4, there are 5 devices - all of which are 'A'live, and the array is 2/490221568 complete with recovery. Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-08-09Merge branch 'async' of macbook:git/btrfs-unstableDavid Woodhouse
Conflicts: drivers/md/Makefile lib/raid6/unroll.pl
2009-10-29md: Factor out RAID6 algorithms into lib/David Woodhouse
We'll want to use these in btrfs too. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-16md: drivers/md/unroll.pl replaced with awk analogVladimir Dronnikov
drivers/md/unroll.pl replaced by awk script to drop build-time dependency on perl Signed-off-by: Vladimir Dronnikov <dronnikov@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-22dm raid1: add userspace logJonthan Brassow
This patch contains a device-mapper mirror log module that forwards requests to userspace for processing. The structures used for communication between kernel and userspace are located in include/linux/dm-log-userspace.h. Due to the frequency, diversity, and 2-way communication nature of the exchanges between kernel and userspace, 'connector' was chosen as the interface for communication. The first log implementations written in userspace - "clustered-disk" and "clustered-core" - support clustered shared storage. A userspace daemon (in the LVM2 source code repository) uses openAIS/corosync to process requests in an ordered fashion with the rest of the nodes in the cluster so as to prevent log state corruption. Other implementations with no association to LVM or openAIS/corosync, are certainly possible. (Imagine if two machines are writing to the same region of a mirror. They would both mark the region dirty, but you need a cluster-aware entity that can handle properly marking the region clean when they are done. Otherwise, you might clear the region when the first machine is done, not the second.) Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: add service time load balancerKiyoshi Ueda
This patch adds a service time oriented dynamic load balancer, dm-service-time, which selects the path with the shortest estimated service time for the incoming I/O. The service time is estimated by dividing the in-flight I/O size by a performance value of each path. The performance value can be given as a table argument at the table loading time. If no performance value is given, all paths are considered equal. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: add queue length load balancerKiyoshi Ueda
This patch adds a dynamic load balancer, dm-queue-length, which balances the number of in-flight I/Os across the paths. The code is based on the patch posted by Stefan Bader: https://www.redhat.com/archives/dm-devel/2005-October/msg00050.html Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-03-31md/raid6: move raid6 data processing to raid6_pq.koDan Williams
Move the raid6 data processing routines into a standalone module (raid6_pq) to prepare them to be called from async_tx wrappers and other non-md drivers/modules. This precludes a circular dependency of raid456 needing the async modules for data processing while those modules in turn depend on raid456 for the base level synchronous raid6 routines. To support this move: 1/ The exportable definitions in raid6.h move to include/linux/raid/pq.h 2/ The raid6_call, recovery calls, and table symbols are exported 3/ Extra #ifdef __KERNEL__ statements to enable the userspace raid6test to compile Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31cleanup drivers/md/MakefileChristoph Hellwig
Use the -y variables instead of the old -objs so we can easily add conditional objects to the modules. Also always use += to add subobjects to avoid problems when placing additional objects in some place in the file. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: NeilBrown <neilb@suse.de>
2009-01-06dm snapshot: split out exception store implementationsAlasdair G Kergon
Move the existing snapshot exception store implementations out into separate files. Later patches will place these behind a new interface in preparation for alternative implementations. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm: add name and uuid to sysfsMilan Broz
Implement simple read-only sysfs entry for device-mapper block device. This patch adds a simple sysfs directory named "dm" under block device properties and implements - name attribute (string containing mapped device name) - uuid attribute (string containing UUID, or empty string if not set) The kobject is embedded in mapped_device struct, so no additional memory allocation is needed for initializing sysfs entry. During the processing of sysfs attribute we need to lock mapped device which is done by a new function dm_get_from_kobj, which returns the md associated with kobject and increases the usage count. Each 'show attribute' function is responsible for its own locking. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-21dm raid1: separate region_hash interface part1Heinz Mauelshagen
Separate the region hash code from raid1 so it can be shared by forthcoming targets. Use BUG_ON() for failed async dm_io() calls. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-06-05[SCSI] scsi_dh: Remove hardware handler infrastructure from dmChandra Seetharaman
This patch just removes infrastructure that provided support for hardware handlers in the dm layer as it is not needed anymore. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-06-05[SCSI] scsi_dh: Remove hardware handlers from dmChandra Seetharaman
This patch removes the 3 hardware handlers that currently exist under dm as the functionality is moved to SCSI layer in the earlier patches. [jejb: removed more makefile hunks and rejection fixes] Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-25dm: move include filesAlasdair G Kergon
Publish the dm-io, dm-log and dm-kcopyd headers in include/linux. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm log: move dirty region log code into separate moduleHeinz Mauelshagen
Move the dirty region log code into a separate module so other targets can share the code. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2007-10-20dm: add uevent to coreMike Anderson
This patch adds a uevent skeleton to device-mapper. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2007-10-20dm mpath: add hp handlerDave Wysochanski
This patch adds the most basic dm-multipath hardware support for the HP active/passive arrays. Signed-off-by: Dave Wysochanski <dwysocha@redhat.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2007-07-13Merge branch 'ioat-md-accel-for-linus' of ↵Linus Torvalds
git://lost.foo-projects.org/~dwillia2/git/iop * 'ioat-md-accel-for-linus' of git://lost.foo-projects.org/~dwillia2/git/iop: (28 commits) ioatdma: add the unisys "i/oat" pci vendor/device id ARM: Add drivers/dma to arch/arm/Kconfig iop3xx: surface the iop3xx DMA and AAU units to the iop-adma driver iop13xx: surface the iop13xx adma units to the iop-adma driver dmaengine: driver for the iop32x, iop33x, and iop13xx raid engines md: remove raid5 compute_block and compute_parity5 md: handle_stripe5 - request io processing in raid5_run_ops md: handle_stripe5 - add request/completion logic for async expand ops md: handle_stripe5 - add request/completion logic for async read ops md: handle_stripe5 - add request/completion logic for async check ops md: handle_stripe5 - add request/completion logic for async compute ops md: handle_stripe5 - add request/completion logic for async write ops md: common infrastructure for running operations with raid5_run_ops md: raid5_run_ops - run stripe operations outside sh->lock raid5: replace custom debug PRINTKs with standard pr_debug raid5: refactor handle_stripe5 and handle_stripe6 (v3) async_tx: add the async_tx api xor: make 'xor_blocks' a library routine for use with async_tx dmaengine: make clients responsible for managing channels dmaengine: refactor dmaengine around dma_async_tx_descriptor ...
2007-07-13xor: make 'xor_blocks' a library routine for use with async_txDan Williams
The async_tx api tries to use a dma engine for an operation, but will fall back to an optimized software routine otherwise. Xor support is implemented using the raid5 xor routines. For organizational purposes this routine is moved to a common area. The following fixes are also made: * rename xor_block => xor_blocks, suggested by Adrian Bunk * ensure that xor.o initializes before md.o in the built-in case * checkpatch.pl fixes * mark calibrate_xor_blocks __init, Adrian Bunk Cc: Adrian Bunk <bunk@stusta.de> Cc: NeilBrown <neilb@suse.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2007-07-12dm mpath: rdacChandra Seetharaman
This patch supports LSI/Engenio devices in RDAC mode. Like dm-emc it requires userspace support. In your multipath.conf file you must have: path_checker rdac hardware_handler "1 rdac" prio_callout "/sbin/mpath_prio_tpc /dev/%n" And you also then must have a updated multipath tools release which has rdac support. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm: delay targetHeinz Mauelshagen
New device-mapper target that can delay I/O (for testing). Reads can be separated from writes, redirected to different underlying devices and delayed by differing amounts of time. Signed-off-by: Heinz Mauelshagen <mauelshagen@redhat.com> Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-26[PATCH] md: merge raid5 and raid6 codeNeilBrown
There is a lot of commonality between raid5.c and raid6main.c. This patches merges both into one module called raid456. This saves a lot of code, and paves the way for online raid5->raid6 migrations. There is still duplication, e.g. between handle_stripe5 and handle_stripe6. This will probably be cleaned up later. Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: optimised resync using Bitmap based intent loggingNeilBrown
With this patch, the intent to write to some block in the array can be logged to a bitmap file. Each bit represents some number of sectors and is set before any update happens, and only cleared when all writes relating to all sectors are complete. After an unclean shutdown, information in this bitmap can be used to optimise resync - only sectors which could be out-of-sync need to be updated. Also if a drive is removed and then added back into an array, the recovery can make use of the bitmap to optimise reconstruction. This is not implemented in this patch. Currently the bitmap is stored in a file which must (obviously) be stored on a separate device. The patch only provided infrastructure. It does not update any personalities to bitmap intent logging. Md arrays can still be used with no bitmap file. This patch has minimal impact on such arrays. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
