commit 81bc6d150ace6250503b825d9d0c10f7bbd24095 upstream.
When the target line contains an invalid device, delay_ctr() will call
delay_dtr() with NULL workqueue. Attempting to destroy the NULL
workqueue causes a crash.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Request-based DM will also make use of per_bio_data_size.
Only delay params are mentioned in delay.txt.
Mention offsets just like documents for linear and flakey do.
Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@gmail.com>
All other error messages start capitalized.
.map function of dm-delay returns return value of delay_bio(),
hence it's supposed to return using a defined DM_MAPIO macro.
Acked-By: Mikulas Patocka <mpatocka@redhat.com>
Some of the device mapper targets override the error code returned by
dm_get_device() and return either -EINVAL or -ENXIO. There is nothing
gained by this override. It is better to propagate the returned error
code unchanged to caller.
This work was motivated by hitting an issue where the underlying device
was busy but -EINVAL was being returned. After this change we get
-EBUSY instead and it is easier to figure out the problem.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Converting milliseconds to jiffies by "val * HZ / 1000" is technically
OK but msecs_to_jiffies(val) is the cleaner solution and handles all
corner cases correctly.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Pull core block IO changes from Jens Axboe:
"The major piece in here is the immutable bio_ve series from Kent, the
rest is fairly minor. It was supposed to go in last round, but
various issues pushed it to this release instead. The pull request
contains:
- Various smaller blk-mq fixes from different folks. Nothing major
here, just minor fixes and cleanups.
- Fix for a memory leak in the error path in the block ioctl code
from Christian Engelmayer.
- Header export fix from CaiZhiyong.
- Finally the immutable biovec changes from Kent Overstreet. This
enables some nice future work on making arbitrarily sized bios
possible, and splitting more efficient. Related fixes to immutable
bio_vecs:
- dm-cache immutable fixup from Mike Snitzer.
- btrfs immutable fixup from Muthu Kumar.
- bio-integrity fix from Nic Bellinger, which is also going to stable"
* 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits)
xtensa: fixup simdisk driver to work with immutable bio_vecs
block/blk-mq-cpu.c: use hotcpu_notifier()
blk-mq: for_each_* macro correctness
block: Fix memory leak in rw_copy_check_uvector() handling
bio-integrity: Fix bio_integrity_verify segment start bug
block: remove unrelated header files and export symbol
blk-mq: uses page->list incorrectly
blk-mq: use __smp_call_function_single directly
btrfs: fix missing increment of bi_remaining
Revert "block: Warn and free bio if bi_end_io is not set"
blk-mq: fix initializing request's start time
block: blk-mq: don't export blk_mq_free_queue()
block: blk-mq: make blk_sync_queue support mq
block: blk-mq: support draining mq queue
dm cache: increment bi_remaining when bi_end_io is restored
block: fixup for generic bio chaining
block: Really silence spurious compiler warnings
block: Silence spurious compiler warnings
block: Kill bio_pair_split()
Starting with commit c0820cf5ad095 ("dm: introduce per_bio_data"),
device mapper has the capability to pre-allocate a target-specific
structure with the bio.
This patch changes dm-delay to use this facility instead of a slab cache
and mempool.
Needed to bring blk-mq uptodate, since changes have been going in
since for-3.14/core was established.
Fixup merge issues related to the immutable biovec changes.
block/blk-flush.c
fs/btrfs/check-integrity.c
fs/btrfs/extent_io.c
fs/btrfs/scrub.c
fs/logfs/dev_bdev.c
Immutable biovecs are going to require an explicit iterator. To
implement immutable bvecs, a later patch is going to add a bi_bvec_done
member to this struct; for now, this patch effectively just renames
things.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: "Ed L. Cashin" <ecashin@coraid.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Alex Elder <elder@inktank.com>
Cc: ceph-devel@vger.kernel.org
Cc: Joshua Morris <josh.h.morris@us.ibm.com>
Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: dm-devel@redhat.com
Cc: linux390@de.ibm.com
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: Benny Halevy <bhalevy@tonian.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Joern Engel <joern@logfs.org>
Cc: Prasad Joshi <prasadjoshi.linux@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: xfs@oss.sgi.com
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Guo Chao <yan@linux.vnet.ibm.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: "Roger Pau Monné" <roger.pau@citrix.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Jerome Marchand <jmarchand@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Peng Tao <tao.peng@emc.com>
Cc: Andy Adamson <andros@netapp.com>
Cc: fanchaoting <fanchaoting@cn.fujitsu.com>
Cc: Jie Liu <jeff.liu@oracle.com>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Namjae Jeon <namjae.jeon@samsung.com>
Cc: Pankaj Kumar <pankaj.km@samsung.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Mel Gorman <mgorman@suse.de>6
The dm-delay target uses a shared workqueue for multiple instances. This
can cause deadlock if two or more dm-delay targets are stacked on the top
of each other.
This patch changes dm-delay to use a per-instance workqueue.
Cc: stable@vger.kernel.org # 2.6.22+
Use 'bio' in the name of variables and functions that deal with
bios rather than 'request' to avoid confusion with the normal
block layer use of 'request'.
No functional changes.
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Avoid returning a truncated table or status string instead of setting
the DM_BUFFER_FULL_FLAG when the last target of a table fills the
buffer.
When processing a table or status request, the function retrieve_status
calls ti->type->status. If ti->type->status returns non-zero,
retrieve_status assumes that the buffer overflowed and sets
DM_BUFFER_FULL_FLAG.
However, targets don't return non-zero values from their status method
on overflow. Most targets returns always zero.
If a buffer overflow happens in a target that is not the last in the
table, it gets noticed during the next iteration of the loop in
retrieve_status; but if a buffer overflow happens in the last target, it
goes unnoticed and erroneously truncated data is returned.
In the current code, the targets behave in the following way:
* dm-crypt returns -ENOMEM if there is not enough space to store the
key, but it returns 0 on all other overflows.
* dm-thin returns errors from the status method if a disk error happened.
This is incorrect because retrieve_status doesn't check the error
code, it assumes that all non-zero values mean buffer overflow.
* all the other targets always return 0.
This patch changes the ti->type->status function to return void (because
most targets don't use the return code). Overflow is detected in
retrieve_status: if the status method fills up the remaining space
completely, it is assumed that buffer overflow happened.
This patch removes map_info from bio-based device mapper targets.
map_info is still used for request-based targets.
Commit outstanding metadata before returning the status for a dm thin
pool so that the numbers reported are as up-to-date as possible.
The commit is not performed if the device is suspended or if
the DM_NOFLUSH_FLAG is supplied by userspace and passed to the target
through a new 'status_flags' parameter in the target's dm_status_fn.
The userspace dmsetup tool will support the --noflush flag with the
'dmsetup status' and 'dmsetup wait' commands from version 1.02.76
onwards.
Tested-by: Mike Snitzer <snitzer@redhat.com>
Device mapper uses sscanf to convert arguments to numbers. The problem is that
the way we use it ignores additional unmatched characters in the scanned string.
For example, this `if (sscanf(string, "%d", &number) == 1)' will match a number,
but also it will match number with some garbage appended, like "123abc".
As a result, device mapper accepts garbage after some numbers. For example
the command `dmsetup create vg1-new --table "0 16384 linear 254:1bla 34816bla"'
will pass without an error.
This patch fixes all sscanf uses in device mapper. It appends "%c" with
a pointer to a dummy character variable to every sscanf statement.
The construct `if (sscanf(string, "%d%c", &number, &dummy) == 1)' succeeds
only if string is a null-terminated number (optionally preceded by some
whitespace characters). If there is some character appended after the number,
sscanf matches "%c", writes the character to the dummy variable and returns 2.
We check the return value for 1 and consequently reject numbers with some
garbage appended.
Acked-by: Mike Snitzer <snitzer@redhat.com>
Convert all create[_singlethread]_work() users to the new
alloc[_ordered]_workqueue(). This conversion is mechanical and
doesn't introduce any behavior change.
Enable discard support for the delay target.
Use new dm_target_offset() macro to avoid most references to ti->begin
in dm targets.
Remove unused parameters(start and len) of dm_get_device()
and fix the callers.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Incorrect device area lengths are being passed to device_area_is_valid().
The regression appeared in 2.6.31-rc1 through commit
754c5fc7ebb417b23601a6222a6005cc2e7f2913.
With the dm-stripe target, the size of the target (ti->len) was used
instead of the stripe_width (ti->len/#stripes). An example of a
consequent incorrect error message is:
device-mapper: table: 254:0: sdb too small for target
Add .iterate_devices to 'struct target_type' to allow a function to be
called for all devices in a DM target. Implemented it for all targets
except those in dm-snap.c (origin and snapshot).
(The raid1 version number jumps to 1.12 because we originally reserved
1.1 to 1.11 for 'block_on_error' but ended up using 'handle_errors'
instead.)
Cc: martin.petersen@oracle.com
Flush support for dm-delay target.
It's used by DM and MD and generally useful, so move the bio list
helpers into bio.h.
Acked-by: Alasdair G Kergon <agk@redhat.com>
Change dm_unregister_target to return void and use BUG() for error
reporting.
dm_unregister_target can only fail because of programming bug in the
target driver. It can't fail because of user's behavior or disk errors.
This patch changes unregister_target to return void and use BUG if
someone tries to unregister non-registered target or unregister target
that is in use.
This patch removes code duplication (testing of error codes in all dm
targets) and reports bugs in just one place, in dm_unregister_target. In
some target drivers, these return codes were ignored, which could lead
to a situation where bugs could be missed.
Change #include "dm.h" to #include <linux/device-mapper.h> in all targets.
Targets should not need direct access to internal DM structures.
Remove BIO_LIST and DEFINE_BIO_LIST macros that gain us nothing
since contents are initialised to NULL.
Cc: Jan Engelhardt <jengelh@linux01.gwdg.de>
Fix missing space in dm-delay target status output
if separate read and write delay are configured.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Add missing 'dm_put_device' to dm-delay target constructor.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Use setup_timer().
Replace semaphore with mutex.
Use new KMEM_CACHE() macro and make the newly-exposed structure names more
meaningful. Also remove some superfluous casts and inlines (let a modern
compiler be the judge).
Acked-by: Christoph Lameter <clameter@sgi.com>
New device-mapper target that can delay I/O (for testing). Reads can be
separated from writes, redirected to different underlying devices and delayed
by differing amounts of time.
Signed-off-by: Heinz Mauelshagen <mauelshagen@redhat.com>
