path: root/drivers/md/dm-exception-store.c
2010-08-12dm snapshot: test chunk size against both origin and snapshotMikulas Patocka
Validate chunk size against both origin and snapshot sector size Don't allow chunk size smaller than either origin or snapshot logical sector size. Reading or writing data not aligned to sector size is not allowed and causes immediate errors. This requires us to open the origin before initialising the exception store and to export dm_snap_origin. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: move cow ref from exception store to snap coreMike Snitzer
Store the reference to the snapshot cow device in the core snapshot code instead of each exception store. It can be accessed through the new function dm_snap_cow(). Exception stores should each now maintain a reference to their parent snapshot struct. This is cleaner and makes part of the forthcoming snapshot merge code simpler. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Cc: Mikulas Patocka <mpatocka@redhat.com>
2009-12-10dm exception store: free tmp_store on persistent flag errorJulia Lawall
Error handling code following a kmalloc should free the allocated data. Cc: stable@kernel.org Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: allow chunk size to be less than page sizeMikulas Patocka
Allow the snapshot chunk size to be smaller than the page size The code is now capable of handling this due to some previous fixes and enhancements. As the page size varies between computers, prior to this patch, the chunk size of a snapshot dictated which machines could read it: Snapshots created on one machine might not be readable on another. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: use unsigned integer chunk sizeMikulas Patocka
Use unsigned integer chunk size. Maximum chunk size is 512kB, there won't ever be need to use 4GB chunk size, so the number can be 32-bit. This fixes compiler failure on 32-bit systems with large block devices. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm exception store: fix failed set_chunk_size error pathMikulas Patocka
Properly close the device if failing because of an invalid chunk size. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-09-04dm snapshot: fix on disk chunk size validationMikulas Patocka
Fix some problems seen in the chunk size processing when activating a pre-existing snapshot. For a new snapshot, the chunk size can either be supplied by the creator or a default value can be used. For an existing snapshot, the chunk size in the snapshot header on disk should always be used. If someone attempts to load an existing snapshot and has the 'default chunk size' option set, the kernel uses its default value even when it is incorrect for the snapshot being loaded. This patch ensures the correct on-disk value is always used. Secondly, when the code does use the chunk size stored on the disk it is prudent to revalidate it, so the code can exit cleanly if it got corrupted as happened in https://bugzilla.redhat.com/show_bug.cgi?id=461506 . Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-09-04dm exception store: split set_chunk_sizeMikulas Patocka
Break the function set_chunk_size to two functions in preparation for the fix in the following patch. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-30dm exception store: really fix type lookupMilan Broz
Fix exception store name handling. We need to reference exception store by zero terminated string. Fixes regression introduced in commit f6bd4eb73cdf2a5bf954e497972842f39cabb7e3 Cc: Yi Yang <yi.y.yang@intel.com> Cc: Jonathan Brassow <jbrassow@redhat.com> Cc: stable@kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm exception store: fix exstore lookup to be case insensitiveJonathan Brassow
When snapshots are created using 'p' instead of 'P' as the exception store type, the device-mapper table loading fails. This patch makes the code case insensitive as intended and fixes some regressions reported with device-mapper snapshots. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-02dm snapshot: move ctr parsing to exception storeJonathan Brassow
First step of having the exception stores parse their own arguments - generalizing the interface. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move cow pointerJonathan Brassow
Move COW device from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move chunk_fieldsJonathan Brassow
Move chunk fields from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move dm_target pointerJonathan Brassow
Move target pointer from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: introduce registryJonathan Brassow
Move exception stores into a registry. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: extend exception store functionsJonathan Brassow
Supply dm_add_exception as a callback to the read_metadata function. Add a status function ready for a later patch and name the functions consistently. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: split out exception store implementationsAlasdair G Kergon
Move the existing snapshot exception store implementations out into separate files. Later patches will place these behind a new interface in preparation for alternative implementations. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: rename struct exception_storeJonathan Brassow
Rename struct exception_store to dm_exception_store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: separate out exception store interfaceJonathan Brassow
Pull structures that bridge the gap between snapshot and exception store out of dm-snap.h and put them in a new .h file - dm-exception-store.h. This file will define the API for new exception stores. Ultimately, dm-snap.h is unnecessary, since only dm-snap.c should be using it. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-21dm: remove dm header from targetsMikulas Patocka
Change #include "dm.h" to #include <linux/device-mapper.h> in all targets. Targets should not need direct access to internal DM structures. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-21dm exception store: fix misordered writesMikulas Patocka
We must zero the next chunk on disk *before* writing out the current chunk, not after. Otherwise if the machine crashes at the wrong time, the "end of metadata" marker may be missing. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: stable@kernel.org
2008-10-21dm exception store: refactor zero_areaAlasdair G Kergon
Use a separate buffer for writing zeroes to the on-disk snapshot exception store, make the updating of ps->current_area explicit and refactor the code in preparation for the fix in the next patch. No functional change. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@kernel.org
2008-10-10dm exception store: use chunk_t for_areasMikulas Patocka
Change uint32_t into chunk_t to remove 32-bit limitation on the number of chunks on systems with 64-bit sector numbers. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-10dm exception store: introduce area_location functionMikulas Patocka
Move this logic to a function, because it will be reused later. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm: move include filesAlasdair G Kergon
Publish the dm-io, dm-log and dm-kcopyd headers in include/linux. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm io: clean interfaceHeinz Mauelshagen
Clean up the dm-io interface to prepare for publishing it in include/linux. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm snapshot: fix chunksize sector conversionMikulas Patocka
If a snapshot has a smaller chunksize than the page size the conversion to pages currently returns 0 instead of 1, causing: kernel BUG in mempool_resize. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: stable@kernel.org
2008-02-08dm snapshot: use uninitialized_varAndrew Morton
drivers/md/dm-exception-store.c: In function 'persistent_read_metadata': drivers/md/dm-exception-store.c:452: warning: 'new_snapshot' may be used uninitialized in this function Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2007-07-18dm: fix memory leak in dm_create_persistent() when starting metadata update ↵Jesper Juhl
thread fails If, in dm_create_persistent(), the call to create_singlethread_workqueue() fails then we'll return without freeing the memory allocated to 'ps', thus leaking sizeof(struct pstore) bytes. This patch fixes the leak. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12dm snapshot: permit invalid activationMilan Broz
Allow invalid snapshots to be activated instead of failing. This allows userspace to reinstate any given snapshot state - for example after an unscheduled reboot - and clean up the invalid snapshot at its leisure. Cc: stable@kernel.org Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12dm snapshot: fix invalidation deadlockMilan Broz
Process persistent exception store metadata IOs in a separate thread. A snapshot may become invalid while inside generic_make_request(). A synchronous write is then needed to update the metadata while still inside that function. Since the introduction of md-dm-reduce-stack-usage-with-stacked-block-devices.patch this has to be performed by a separate thread to avoid deadlock. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12dm: use kmem_cache macroAlasdair G Kergon
Use new KMEM_CACHE() macro and make the newly-exposed structure names more meaningful. Also remove some superfluous casts and inlines (let a modern compiler be the judge). Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm exception store: update dm io interfaceHeinz Mauelshagen
This patch ports dm-exception-store.c to the new, scalable dm_io() interface. It replaces dm_io_get()/dm_io_put() by dm_io_client_create()/dm_io_client_destroy() calls and dm_io_sync_vm() by dm_io() to achive this. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] dm snapshot: fix metadata writing when suspendingMark McLoughlin
When suspending a device-mapper device, dm_suspend() sleeps until all necessary I/O is completed. This state is triggered by a callback from persistent_commit(). But some I/O can still be issued *after* the callback (to prepare the next metadata area for use if the current one is full). This patch delays the callback until after that I/O is complete. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] dm snapshot: make read and write exception functions voidMark McLoughlin
read_exception() and write_exception() only return an error if supplied with an out-of-range index. If this ever happens it's the result of a bug in the calling code so we handle this with an assertion and remove the error handling in the callers. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] dm snapshot: allow zero chunk_sizeMark McLoughlin
The chunk size of snapshots cannot be changed so it is redundant to require it as a parameter when activating an existing snapshot. Allow a value of zero in this case and ignore it. For a new snapshot, use a default value if zero is specified. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: improve error message consistencyAlasdair G Kergon
Tidy device-mapper error messages to include context information automatically. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm snapshot: unify chunk_sizeAlasdair G Kergon
Persistent snapshots currently store a private copy of the chunk size. Userspace also supplies the chunk size when loading a snapshot. Ensure consistency by only storing the chunk_size in one place instead of two. Currently the two sizes will differ if the chunk size supplied by userspace does not match the chunk size an existing snapshot actually uses. Amongst other problems, this causes an incorrect 'percentage full' to be reported. The patch ensures consistency by only storing the chunk_size in one place, removing it from struct pstore. Some initialisation is delayed until the correct chunk_size is known. If read_header() discovers that the wrong chunk size was supplied, the 'area' buffer (which the header already got read into) is reinitialised to the correct size. [akpm: too late for 2.6.17 - suitable for 2.6.17.x after it has settled] Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] vfree and kfree cleanup in drivers/Jesper Juhl
This patch does a full cleanup of 'NULL checks before vfree', and a partial cleanup of calls to kfree for all of drivers/ - the kfree bit is partial in that I only did the files that also had vfree calls in them. The patch also gets rid of some redundant (void *) casts of pointers being passed to [vk]free, and a some tiny whitespace corrections also crept in. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
