path: root/drivers/md/dm-mpath.c
2011-08-02dm table: share target argument parsing functionsMike Snitzer
Move multipath target argument parsing code into dm-table so other targets can share it. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-08-02dm mpath: fix potential NULL pointer in feature arg processingMike Snitzer
Avoid dereferencing a NULL pointer if the number of feature arguments supplied is fewer than indicated. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: stable@kernel.org
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-29dm mpath: do not fail paths after integrity errorsMartin K. Petersen
Integrity errors need to be passed to the owner of the integrity metadata for processing. Consequently EILSEQ should be passed up the stack. Cc: stable@kernel.org Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-03-24dm mpath: allow table load with no priority groupsMike Snitzer
This patch adjusts the multipath target to allow a table with both 0 priority groups and 0 for the initial priority group number. If any mpath device is held open when all paths in the last priority group have failed, userspace multipathd will attempt to reload the associated DM table to reflect the fact that the device no longer has any priority groups. But the reload attempt always failed because the multipath target did not allow 0 priority groups. All multipath target messages related to priority group (enable_group, disable_group, switch_group) will handle a priority group of 0 (will cause error). When reloading a multipath table with 0 priority groups, userspace multipathd must be updated to specify an initial priority group number of 0 (rather than 1). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: Babu Moger <babu.moger@lsi.com> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-03-24dm mpath: fail message ioctl if specified path is not validMike Snitzer
Fail the reinstate_path and fail_path message ioctl if the specified path is not valid. The message ioctl would succeed for the 'reinistate_path' and 'fail_path' messages even if action was not taken because the specified device was not a valid path of the multipath device. Before, when /dev/vdb is not a path of mpathb: $ dmsetup message mpathb 0 reinstate_path /dev/vdb $ echo $? 0 After: $ dmsetup message mpathb 0 reinstate_path /dev/vdb device-mapper: message ioctl failed: Invalid argument Command failed $ echo $? 1 Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-02-12[SCSI] dm mpath: propagate target errors immediatelyHannes Reinecke
DM now has more information about the nature of the underlying storage failure. Path failure is avoided if a request failed due to a target error. Instead the target error is immediately passed up the stack. Discard requests that fail due to non-target errors may now be retried. Errors restricted to the path will be retried or returned if no paths are available, irregarding the no_path_retry setting. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-13dm mpath: delay activate_path retry on SCSI_DH_RETRYChandra Seetharaman
This patch adds a user-configurable 'pg_init_delay_msecs' feature. Use this feature to specify the number of milliseconds to delay before retrying scsi_dh_activate, when SCSI_DH_RETRY is returned. SCSI Device Handlers return SCSI_DH_IMM_RETRY if we could retry activation immediately and SCSI_DH_RETRY in cases where it is better to retry after some delay. Currently we immediately retry scsi_dh_activate irrespective of SCSI_DH_IMM_RETRY and SCSI_DH_RETRY. The 'pg_init_delay_msecs' feature may be provided during table create or load, e.g.: dmsetup create --table "0 20971520 multipath 3 queue_if_no_path \ pg_init_delay_msecs 2500 ..." mpatha The default for 'pg_init_delay_msecs' is 2000 milliseconds. Maximum configurable delay is 60000 milliseconds. Specifying a 'pg_init_delay_msecs' of 0 will cause immediate retry. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Acked-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm: convert workqueues to alloc_orderedTejun Heo
Convert all create[_singlethread]_work() users to the new alloc[_ordered]_workqueue(). This conversion is mechanical and doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm: dont use flush_scheduled_workTejun Heo
flush_scheduled_work() is being deprecated. Flush the used work directly instead. In all dm targets, the only work which uses system_wq is ->trigger_event. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm mpath: disable blk_abort_queueMike Snitzer
Revert commit 224cb3e981f1b2f9f93dbd49eaef505d17d894c2 dm: Call blk_abort_queue on failed paths Multipath began to use blk_abort_queue() to allow for lower latency path deactivation. This was found to cause list corruption: the cmd gets blk_abort_queued/timedout run on it and the scsi eh somehow is able to complete and run scsi_queue_insert while scsi_request_fn is still trying to process the request. https://www.redhat.com/archives/dm-devel/2010-November/msg00085.html Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: stable@kernel.org
2010-08-12dm mpath: support discardMike Snitzer
Enable discard support in the DM multipath target. This discard support depends on a few discard-specific fixes to the block layer's request stacking driver methods. Discard requests are optional so don't allow a failed discard to trigger path failures. If there is a real problem with a given path the barriers associated with the discard (either before or after the discard) will cause path failure. That said, unconditionally passing discard failures up the stack is not ideal. This must be fixed once DM has more information about the nature of the underlying storage failure. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
2010-08-12dm mpath: fix NULL pointer dereference when path parameters missingAlasdair G Kergon
multipath_ctr() forgets to return an error after detecting missing path parameters. Fix this. Signed-off-by: Patrick LoPresti <lopresti@gmail.com> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm table: remove unused dm_get_device range parametersNikanth Karthikesan
Remove unused parameters(start and len) of dm_get_device() and fix the callers. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: refactor pg_initKiyoshi Ueda
This patch pulls the pg_init path activation code out of process_queued_ios() into a new function. No functional change. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: wait for pg_init completion when suspendingKiyoshi Ueda
When suspending the device we must wait for all I/O to complete, but pg-init may be still in progress even after flushing the workqueue for kmpath_handlerd in multipath_postsuspend. This patch waits for pg-init completion correctly in multipath_postsuspend(). Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: hold io until all pg_inits completedKiyoshi Ueda
m->queue_io is set to block processing I/Os, and it needs to be kept while pg-init, which issues multiple path activations, is in progress. But m->queue is cleared when a path activation completes without error in pg_init_done(), even while other path activations are in progress. That may cause undesired -EIO on paths which are not complete activation. This patch fixes that by not clearing m->queue_io until all path activations complete. (Before the hardware handlers were moved into the SCSI layer, pg_init only used one path.) Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: avoid storing private suspended stateKiyoshi Ueda
'suspended' flag in struct multipath was introduced to check whether the multipath target is in suspended state, but the same check is done through dm_suspended() now, so remove the flag and related code. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: skip activate_path for failed pathsMoger, Babu
This patch adds two minor fixes while processing device mapper path activation. Skip failed paths while calling activate_path. If the path is already failed then activate_path will fail for sure. We don't have to call in that case. In some case this might cause prolonged retries unnecessarily. Change the misleading message if the path being activated fails with SCSI_DH_NOSYS. Signed-off-by: Babu Moger <babu.moger@lsi.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: pass struct pgpath to pg init doneMoger, Babu
This patch removes some unnecessary argument casting. There is no functional change with this patch. Passes 'struct pgpath' through to pg_init_done() instead of the enclosed 'struct dm_path'. Tested the changes with LSI storage.. CC: Chandra Seetharaman <chandra.seetharaman@us.ibm.com> Signed-off-by: Babu Moger <babu.moger@lsi.com> Acked-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm mpath: reject messages when device is suspendedKiyoshi Ueda
This patch rejects messages that can generate I/O while the device itself is suspended. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm mpath: prevent io from work queue while suspendedMike Anderson
Reject messages that can generate I/O while the device itself is suspended. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Acked-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm mpath: add mutex to synchronize adding and flushing workMike Anderson
Add a mutex to allow possible creators of new work to synchronize with flushing work queues. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Acked-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm mpath: flush workqueues before suspend completesKiyoshi Ueda
This patch stops the remaining dm-mpath activity during the suspend sequence by flushing workqueues in postsuspend function. The current dm-mpath target may not be quiet even after suspend completes because some workqueues (e.g. device_handler's work, event handling) are not flushed during the suspend sequence, even though suspended devices/targets are supposed to be quiet in this state. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-04[SCSI] scsi_dh: Change the scsidh_activate interface to be asynchronousChandra Seetharaman
Make scsi_dh_activate() function asynchronous, by taking in two additional parameters, one is the callback function and the other is the data to call the callback function with. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-22[SCSI] scsi_dh: Use scsi_dh_set_params() in multipath.Chandra Seetharaman
Use scsi_dh_set_params() set parameters provided. Save the parameters in parse_hw_handler() and use it in parse_path(). Reported-by: Eddie Williams <Eddie.Williams@steeleye.com> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Tested-by: Eddie Williams <Eddie.Williams@steeleye.com> Cc: Alasdair G Kergon <agk@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-07-23dm table: pass correct dev area size to device_area_is_validMike Snitzer
Incorrect device area lengths are being passed to device_area_is_valid(). The regression appeared in 2.6.31-rc1 through commit 754c5fc7ebb417b23601a6222a6005cc2e7f2913. With the dm-stripe target, the size of the target (ti->len) was used instead of the stripe_width (ti->len/#stripes). An example of a consequent incorrect error message is: device-mapper: table: 254:0: sdb too small for target Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: change to be request basedKiyoshi Ueda
This patch converts dm-multipath target to request-based from bio-based. Basically, the patch just converts the I/O unit from struct bio to struct request. In the course of the conversion, it also changes the I/O queueing mechanism. The change in the I/O queueing is described in details as follows. I/O queueing mechanism change ----------------------------- In I/O submission, map_io(), there is no mechanism change from bio-based, since the clone request is ready for retry as it is. However, in I/O complition, do_end_io(), there is a mechanism change from bio-based, since the clone request is not ready for retry. In do_end_io() of bio-based, the clone bio has all needed memory for resubmission. So the target driver can queue it and resubmit it later without memory allocations. The mechanism has almost no overhead. On the other hand, in do_end_io() of request-based, the clone request doesn't have clone bios, so the target driver can't resubmit it as it is. To resubmit the clone request, memory allocation for clone bios is needed, and it takes some overheads. To avoid the overheads just for queueing, the target driver doesn't queue the clone request inside itself. Instead, the target driver asks dm core for queueing and remapping the original request of the clone request, since the overhead for queueing is just a freeing memory for the clone request. As a result, the target driver doesn't need to record/restore the information of the original request for resubmitting the clone request. So dm_bio_details in dm_mpath_io is removed. multipath_busy() --------------------- The target driver returns "busy", only when the following case: o The target driver will map I/Os, if map() function is called and o The mapped I/Os will wait on underlying device's queue due to their congestions, if map() function is called now. In other cases, the target driver doesn't return "busy". Otherwise, dm core will keep the I/Os and the target driver can't do what it wants. (e.g. the target driver can't map I/Os now, so wants to kill I/Os.) Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm target:s introduce iterate devices fnMike Snitzer
Add .iterate_devices to 'struct target_type' to allow a function to be called for all devices in a DM target. Implemented it for all targets except those in dm-snap.c (origin and snapshot). (The raid1 version number jumps to 1.12 because we originally reserved 1.1 to 1.11 for 'block_on_error' but ended up using 'handle_errors' instead.) Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: martin.petersen@oracle.com
2009-06-22dm mpath: add start_io and nr_bytes to path selectorsKiyoshi Ueda
This patch makes two additions to the dm path selector interface for dynamic load balancers: o a new hook, start_io() o a new parameter 'nr_bytes' to select_path()/start_io()/end_io() to pass the size of the I/O start_io() is called when a target driver actually submits I/O to the selected path. Path selectors can use it to start accounting of the I/O. (e.g. counting the number of in-flight I/Os.) The start_io hook is based on the patch posted by Stefan Bader: https://www.redhat.com/archives/dm-devel/2005-October/msg00050.html nr_bytes, the size of the I/O, is so path selectors can take the size of the I/O into account when deciding which path to use. dm-service-time uses it to estimate service time, for example. (Added the nr_bytes member to dm_mpath_io instead of using existing details.bi_size, since request-based dm patch deletes it.) Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: support barriersMikulas Patocka
Flush support for dm-multipath target. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: flush keventd queue in destructorMikulas Patocka
The commit fe9cf30eb8186ef267d1868dc9f12f2d0f40835a moves dm table event submission from kmultipath queue to kernel kevent queue to avoid a deadlock. There is a possibility of race condition because kevent queue is not flushed in the multipath destructor. The scenario is: - some event happens and is queued to keventd - keventd thread is delayed due to scheuling latency or some other work - multipath device is destroyed - keventd now attempts to process work_struct that is residing in already released memory. The patch flushes the keventd queue in multipath constructor. I've already fixed similar bug in dm-raid1. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: stable@kernel.org
2009-06-22dm mpath: call activate fn for each path in pg_initChandra Seetharaman
Fixed a problem affecting reinstatement of passive paths. Before we moved the hardware handler from dm to SCSI, it performed a pg_init for a path group and didn't maintain any state about each path in hardware handler code. But in SCSI dh, such state is now maintained, as we want to fail I/O early on a path if it is not the active path. All the hardware handlers have a state now and set to active or some form of inactive. They have prep_fn() which uses this state to fail the I/O without it ever being sent to the device. So in effect when dm-multipath calls scsi_dh_activate(), activate is sent to only one path and the "state" of that path is changed appropriately to "active" while other paths in the same path group are never changed as they never got an "activate". In order make sure all the paths in a path group gets their state set properly when a pg_init happens, we need to call scsi_dh_activate() on all paths in a path group. Doing this at the hardware handler layer is not a good option as we want the multipath layer to define the relationship between path and path groups and not the hardware handler. Attached patch sends an "activate" on each path in a path group when a path group is switched. It also sends an activate when a path is reinstated. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: change attached scsi_dhHannes Reinecke
When specifying a different hardware handler via multipath features we should be able to override the built-in defaults. The problem here is the hardware table from scsi_dh is compiled in and cannot be changed from userland. The multipath.conf OTOH is purely user-defined and, what's more, the user might have a valid reason for modifying it. (EG EMC Clariion can well be run in PNR mode even though ALUA is active, or the user might want to try ALUA on any as-of-yet unknown devices) So _not_ allowing multipath to override the device handler setting will just add to the confusion and makes error tracking even more difficult. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: validate hw_handler argument countMikulas Patocka
Fix arg count parsing error in hw handlers. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm mpath: validate table argument countMikulas Patocka
The parser reads the argument count as a number but doesn't check that sufficient arguments are supplied. This command triggers the bug: dmsetup create mpath --table "0 `blockdev --getsize /dev/mapper/cr0` multipath 0 0 2 1 round-robin 1000 0 1 1 /dev/mapper/cr0 round-robin 0 1 1 /dev/mapper/cr1 1000" kernel BUG at drivers/md/dm-mpath.c:530! Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-15block: move bio list helpers into bio.hChristoph Hellwig
It's used by DM and MD and generally useful, so move the bio list helpers into bio.h. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-06dm mpath: move trigger_event to system workqueueAlasdair G Kergon
The same workqueue is used both for sending uevents and processing queued I/O. Deadlock has been reported in RHEL5 when sending a uevent was blocked waiting for the queued I/O to be processed. Use scheduled_work() for the asynchronous uevents instead. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm: consolidate target deregistration error handlingMikulas Patocka
Change dm_unregister_target to return void and use BUG() for error reporting. dm_unregister_target can only fail because of programming bug in the target driver. It can't fail because of user's behavior or disk errors. This patch changes unregister_target to return void and use BUG if someone tries to unregister non-registered target or unregister target that is in use. This patch removes code duplication (testing of error codes in all dm targets) and reports bugs in just one place, in dm_unregister_target. In some target drivers, these return codes were ignored, which could lead to a situation where bugs could be missed. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-11-13dm mpath: warn if args ignoredChandra Seetharaman
Currently dm ignores the parameters provided to hardware handlers without providing any notifications to the user. This patch just prints a warning message so that the user knows that the arguments are ignored. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-11-13dm mpath: avoid attempting to activate null pathChandra Seetharaman
Path activation code is called even when the pgpath is NULL. This could lead to a panic in activate_path(). Such a panic is seen in -rt kernel. This problem has been there before the pg_init() was moved to a workqueue. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
2008-10-21dm: remove dm header from targetsMikulas Patocka
Change #include "dm.h" to #include <linux/device-mapper.h> in all targets. Targets should not need direct access to internal DM structures. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-21[PATCH] introduce __blkdev_driver_ioctl()Al Viro
Analog of blkdev_driver_ioctl() with sane arguments. For now uses fake struct file, by the end of the series it won't and blkdev_driver_ioctl() will become a wrapper around it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] lose unused arguments in dm ioctl callbacksAl Viro
2008-10-13[SCSI] block: separate failfast into multiple bits.Mike Christie
Multipath is best at handling transport errors. If it gets a device error then there is not much the multipath layer can do. It will just access the same device but from a different path. This patch breaks up failfast into device, transport and driver errors. The multipath layers (md and dm mutlipath) only ask the lower levels to fast fail transport errors. The user of failfast, read ahead, will ask to fast fail on all errors. Note that blk_noretry_request will return true if any failfast bit is set. This allows drivers that do not support the multipath failfast bits to continue to fail on any failfast error like before. Drivers like scsi that are able to fail fast specific errors can check for the specific fail fast type. In the next patch I will convert scsi. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: dm: detect lost queue dm: publish dm_vcalloc dm: publish dm_table_unplug_all dm: publish dm_get_mapinfo dm: export struct dm_dev dm crypt: avoid unnecessary wait when splitting bio dm crypt: tidy ctx pending dm crypt: fix async inc_pending dm crypt: move dec_pending on error into write_io_submit dm crypt: remove inc_pending from write_io_submit dm crypt: tidy write loop pending dm crypt: tidy crypt alloc dm crypt: tidy inc pending dm exception store: use chunk_t for_areas dm exception store: introduce area_location function dm raid1: kcopyd should stop on error if errors handled dm mpath: remove is_active from struct dm_path dm mpath: use more error codes Fixed up trivial conflict in drivers/md/dm-mpath.c manually.
2008-10-10dm mpath: remove is_active from struct dm_pathKiyoshi Ueda
This patch moves 'is_active' from struct dm_path to struct pgpath as it does not need exporting. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-10dm mpath: use more error codesBenjamin Marzinski
This patch allows path errors from the multipath ctr function to propagate up to userspace as errno values from the ioctl() call. This is in response to https://www.redhat.com/archives/dm-devel/2008-May/msg00000.html and https://bugzilla.redhat.com/show_bug.cgi?id=444421 The patch only lets through the errors that it needs to in order to get the path errors from parse_path(). Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-09dm: Call blk_abort_queue on failed pathsMike Anderson
Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
