path: root/drivers/md/dm-mpath.h
2008-10-10dm mpath: remove is_active from struct dm_pathKiyoshi Ueda
This patch moves 'is_active' from struct dm_path to struct pgpath as it does not need exporting. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-06-05[SCSI] scsi_dh: Remove hardware handler infrastructure from dmChandra Seetharaman
This patch just removes infrastructure that provided support for hardware handlers in the dm layer as it is not needed anymore. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2006-12-08[PATCH] struct path: rename DM's struct pathJosef "Jeff" Sipek
Rename DM's struct path to struct dm_path to prevent name collision between it and struct path from fs/namei.c. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: <reiserfs-dev@namesys.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
