path: root/drivers/md/dm-region-hash.c
2010-09-10dm: implement REQ_FLUSH/FUA support for bio-based dmTejun Heo
This patch converts bio-based dm to support REQ_FLUSH/FUA instead of now deprecated REQ_HARDBARRIER. * -EOPNOTSUPP handling logic dropped. * Preflush is handled as before but postflush is dropped and replaced with passing down REQ_FUA to member request_queues. This replaces one array wide cache flush w/ member specific FUA writes. * __split_and_process_bio() now calls __clone_and_map_flush() directly for flushes and guarantees all FLUSH bio's going to targets are zero ` length. * It's now guaranteed that all FLUSH bio's which are passed onto dm targets are zero length. bio_empty_barrier() tests are replaced with REQ_FLUSH tests. * Empty WRITE_BARRIERs are replaced with WRITE_FLUSHes. * Dropped unlikely() around REQ_FLUSH tests. Flushes are not unlikely enough to be marked with unlikely(). * Block layer now filters out REQ_FLUSH/FUA bio's if the request_queue doesn't support cache flushing. Advertise REQ_FLUSH | REQ_FUA capability. * Request based dm isn't converted yet. dm_init_request_based_queue() resets flush support to 0 for now. To avoid disturbing request based dm code, dm->flush_error is added for bio based dm while requested based dm continues to use dm->barrier_error. Lightly tested linear, stripe, raid1, snap and crypt targets. Please proceed with caution as I'm not familiar with the code base. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: dm-devel@redhat.com Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-16dm raid1: fix null pointer dereference in suspendTakahiro Yasui
When suspending a failed mirror, bios are completed by mirror_end_io() and __rh_lookup() in dm_rh_dec() returns NULL where a non-NULL return value is required by design. Fix this by not changing the state of the recovery failed region from DM_RH_RECOVERING to DM_RH_NOSYNC in dm_rh_recovery_end(). Issue On 2.6.33-rc1 kernel, I hit the bug when I suspended the failed mirror by dmsetup command. BUG: unable to handle kernel NULL pointer dereference at 00000020 IP: [<f94f38e2>] dm_rh_dec+0x35/0xa1 [dm_region_hash] ... EIP: 0060:[<f94f38e2>] EFLAGS: 00010046 CPU: 0 EIP is at dm_rh_dec+0x35/0xa1 [dm_region_hash] EAX: 00000286 EBX: 00000000 ECX: 00000286 EDX: 00000000 ESI: eff79eac EDI: eff79e80 EBP: f6915cd4 ESP: f6915cc4 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process dmsetup (pid: 2849, ti=f6914000 task=eff03e80 task.ti=f6914000) ... Call Trace: [<f9530af6>] ? mirror_end_io+0x53/0x1b1 [dm_mirror] [<f9413104>] ? clone_endio+0x4d/0xa2 [dm_mod] [<f9530aa3>] ? mirror_end_io+0x0/0x1b1 [dm_mirror] [<f94130b7>] ? clone_endio+0x0/0xa2 [dm_mod] [<c02d6bcb>] ? bio_endio+0x28/0x2b [<f952f303>] ? hold_bio+0x2d/0x62 [dm_mirror] [<f952f942>] ? mirror_presuspend+0xeb/0xf7 [dm_mirror] [<c02aa3e2>] ? vmap_page_range+0xb/0xd [<f9414c8d>] ? suspend_targets+0x2d/0x3b [dm_mod] [<f9414ca9>] ? dm_table_presuspend_targets+0xe/0x10 [dm_mod] [<f941456f>] ? dm_suspend+0x4d/0x150 [dm_mod] [<f941767d>] ? dev_suspend+0x55/0x18a [dm_mod] [<c0343762>] ? _copy_from_user+0x42/0x56 [<f9417fb0>] ? dm_ctl_ioctl+0x22c/0x281 [dm_mod] [<f9417628>] ? dev_suspend+0x0/0x18a [dm_mod] [<f9417d84>] ? dm_ctl_ioctl+0x0/0x281 [dm_mod] [<c02c3c4b>] ? vfs_ioctl+0x22/0x85 [<c02c422c>] ? do_vfs_ioctl+0x4cb/0x516 [<c02c42b7>] ? sys_ioctl+0x40/0x5a [<c0202858>] ? sysenter_do_call+0x12/0x28 Analysis When recovery process of a region failed, dm_rh_recovery_end() function changes the state of the region from RM_RH_RECOVERING to DM_RH_NOSYNC. When recovery_complete() is executed between dm_rh_update_states() and dm_writes() in do_mirror(), bios are processed with the region state, DM_RH_NOSYNC. However, the region data is freed without checking its pending count when dm_rh_update_states() is called next time. When bios are finished by mirror_end_io(), __rh_lookup() in dm_rh_dec() returns NULL even though a valid return value are expected. Solution Remove the state change of the recovery failed region from DM_RH_RECOVERING to DM_RH_NOSYNC in dm_rh_recovery_end(). We can remove the state change because: - If the region data has been released by dm_rh_update_states(), a new region data is created with the state of DM_RH_NOSYNC, and bios are processed according to the DM_RH_NOSYNC state. - If the region data has not been released by dm_rh_update_states(), a state of the region is DM_RH_RECOVERING and bios are put in the delayed_bio list. The flag change from DM_RH_RECOVERING to DM_RH_NOSYNC in dm_rh_recovery_end() was added in the following commit: dm raid1: handle resync failures author Jonathan Brassow <jbrassow@redhat.com> Thu, 12 Jul 2007 16:29:04 +0000 (17:29 +0100) http://git.kernel.org/linus/f44db678edcc6f4c2779ac43f63f0b9dfa28b724 Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Reviewed-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm raid1: remove bio_endio from dm_rh_mark_nosyncMikulas Patocka
Move bio completion out of dm_rh_mark_nosync in preparation for the next patch. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Takahiro Yasui <tyasui@redhat.com> Tested-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm raid1: support flushMikulas Patocka
Flush support for dm-raid1. When it receives an empty barrier, submit it to all the devices via dm-io. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm raid1: keep retrying alloc if mempool_alloc failedMikulas Patocka
If the code can't handle allocation failures, use __GFP_NOFAIL so that in case of memory pressure the allocator will retry indefinitely and won't return NULL which would cause a crash in the function. This is still not a correct fix, it may cause a classic deadlock when memory manager waits for I/O being done and I/O waits for some free memory. I/O code shouldn't allocate any memory. But in this case it probably doesn't matter much in practice, people usually do not swap on RAID. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-15block: move bio list helpers into bio.hChristoph Hellwig
It's used by DM and MD and generally useful, so move the bio list helpers into bio.h. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-21dm raid1: separate region_hash interface part1Heinz Mauelshagen
Separate the region hash code from raid1 so it can be shared by forthcoming targets. Use BUG_ON() for failed async dm_io() calls. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
