path: root/drivers/md/dm-snap-transient.c
2009-12-10dm snapshot: move cow ref from exception store to snap coreMike Snitzer
Store the reference to the snapshot cow device in the core snapshot code instead of each exception store. It can be accessed through the new function dm_snap_cow(). Exception stores should each now maintain a reference to their parent snapshot struct. This is cleaner and makes part of the forthcoming snapshot merge code simpler. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Cc: Mikulas Patocka <mpatocka@redhat.com>
2009-12-10dm snapshot: add allocated metadata to snapshot statusMike Snitzer
Add number of sectors used by metadata to the end of the snapshot's status line. Renamed dm_exception_store_type's 'fraction_full' to 'usage'. Renamed arguments to be clearer about what is being returned. Also added 'metadata_sectors'. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: rename dm_snap_exception to dm_exceptionJon Brassow
The exception structure is not necessarily just a snapshot element (especially after we pull it out of dm-snap.c). Renaming appropriately. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm snapshot: move status to exception storeJonathan Brassow
Let the exception store types print out their status through the new API, rather than having the snapshot code do it. Adjust the buffer position to allow for the preceding DMEMIT in the arguments to type->status(). Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm snapshot: remove dm_snap header useJonathan Brassow
Move useful functions out of dm-snap.h and stop using dm-snap.h. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move cow pointerJonathan Brassow
Move COW device from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move chunk_fieldsJonathan Brassow
Move chunk fields from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: introduce registryJonathan Brassow
Move exception stores into a registry. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: separate type from instanceJonathan Brassow
Introduce struct dm_exception_store_type. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: extend exception store functionsJonathan Brassow
Supply dm_add_exception as a callback to the read_metadata function. Add a status function ready for a later patch and name the functions consistently. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: split out exception store implementationsAlasdair G Kergon
Move the existing snapshot exception store implementations out into separate files. Later patches will place these behind a new interface in preparation for alternative implementations. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
