commit 8e87b9b81b3c370f7e53c1ab6e1c3519ef37a644 upstream.
Under some special conditions the snapshot hash_size is calculated as zero.
This patch instead sets a minimum value of 64, the same as for the
pending exception table.
rounddown_pow_of_two(0) is an undefined operation (it expands to shift
by -1). init_exception_table with an argument of 0 would fail with -ENOMEM.
The way to trigger the problem is to create a snapshot with a chunk size
that is larger than the origin device.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit 94e76572b5dd37b1f0f4b3742ee8a565daead932 upstream.
Take snapshot lock only for STATUSTYPE_INFO, not STATUSTYPE_TABLE.
Commit 4c6fff445d7aa753957856278d4d93bcad6e2c14
(dm-snapshot-lock-snapshot-while-supplying-status.patch)
introduced this use of the lock, but userspace applications using
libdevmapper have been found to request STATUSTYPE_TABLE while the device
is suspended and the lock is already held, leading to deadlock. Since
the lock is not necessary in this case, don't try to take it.
Use unsigned integer chunk size.
Maximum chunk size is 512kB, there won't ever be need to use 4GB chunk size,
so the number can be 32-bit. This fixes compiler failure on 32-bit systems
with large block devices.
Cc: stable@kernel.org
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Reviewed-by: Jonathan Brassow <jbrassow@redhat.com>
This patch locks the snapshot when returning status. It fixes a race
when it could return an invalid number of free chunks if someone
was simultaneously modifying it.
If we are creating snapshot with memory-stored exception store, fail if
the user didn't specify chunk size. Zero chunk size would probably crash
a lot of places in the rest of snapshot code.
Reviewed-by: Mike Snitzer <snitzer@redhat.com>
While initializing the snapshot module, if we fail to register
the snapshot target then we must back-out the exception store
module initialization.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Reviewed-by: Mikulas Patocka <mpatocka@redhat.com>
Avoid a race causing corruption when snapshots of the same origin have
different chunk sizes by sorting the internal list of snapshots by chunk
size, largest first.
https://bugzilla.redhat.com/show_bug.cgi?id=182659
For example, let's have two snapshots with different chunk sizes. The
first snapshot (1) has small chunk size and the second snapshot (2) has
large chunk size. Let's have chunks A, B, C in these snapshots:
snapshot1: ====A==== ====B====
snapshot2: ==========C==========
(Chunk size is a power of 2. Chunks are aligned.)
A write to the origin at a position within A and C comes along. It
triggers reallocation of A, then reallocation of C and links them
together using A as the 'primary' exception.
Then another write to the origin comes along at a position within B and
C. It creates pending exception for B. C already has a reallocation in
progress and it already has a primary exception (A), so nothing is done
to it: B and C are not linked.
If the reallocation of B finishes before the reallocation of C, because
there is no link with the pending exception for C it does not know to
wait for it and, the second write is dispatched to the origin and causes
data corruption in the chunk C in snapshot2.
To avoid this situation, we maintain snapshots sorted in descending
order of chunk size. This leads to a guaranteed ordering on the links
between the pending exceptions and avoids the problem explained above -
both A and B now get linked to C.
Implement the .iterate_devices for the origin and snapshot targets.
dm-snapshot's lack of .iterate_devices resulted in the inability to
properly establish queue_limits for both targets.
With 4K sector drives: an unfortunate side-effect of not establishing
proper limits in either targets' DM device was that IO to the devices
would fail even though both had been created without error.
Commit af4874e03ed82f050d5872d8c39ce64bf16b5c38 ("dm target:s introduce
iterate devices fn") in 2.6.31-rc1 should have implemented .iterate_devices
for dm-snap.c's origin and snapshot targets.
Flush support for dm-snapshot target.
This patch just forwards the flush request to either the origin or the snapshot
device. (It doesn't flush exception store metadata.)
It's used by DM and MD and generally useful, so move the bio list
helpers into bio.h.
Acked-by: Alasdair G Kergon <agk@redhat.com>
Let the exception store types print out their status through
the new API, rather than having the snapshot code do it.
Adjust the buffer position to allow for the preceding DMEMIT in the
arguments to type->status().
First step of having the exception stores parse their own arguments -
generalizing the interface.
Use DMEMIT in place of snprintf. This makes it easier later when
other modules are helping to populate our status output.
Move some of the last bits from dm-snap.h into dm-snap.c where they
belong and remove dm-snap.h.
Move useful functions out of dm-snap.h and stop using dm-snap.h.
Move COW device from snapshot to exception store.
Move chunk fields from snapshot to exception store.
Move target pointer from snapshot to exception store.
Move exception stores into a registry.
Introduce struct dm_exception_store_type.
We need to check if the exception was completed after dropping the lock.
After regaining the lock, __find_pending_exception checks if the exception
was already placed into &s->pending hash.
But we don't check if the exception was already completed and placed into
&s->complete hash. If the process waiting in alloc_pending_exception was
delayed at this point because of a scheduling latency and the exception
was meanwhile completed, we'd miss that and allocate another pending
exception for already completed chunk.
It would lead to a situation where two records for the same chunk exist
and potential data corruption because multiple snapshot I/Os to the
affected chunk could be redirected to different locations in the
snapshot.
It is uncommon and bug-prone to drop a lock in a function that is called with
the lock held, so this is moved to the caller.
Move looking-up of a pending exception from __find_pending_exception to another
function.
Supply dm_add_exception as a callback to the read_metadata function.
Add a status function ready for a later patch and name the functions
consistently.
Move the existing snapshot exception store implementations out into
separate files. Later patches will place these behind a new
interface in preparation for alternative implementations.
Pull structures that bridge the gap between snapshot and
exception store out of dm-snap.h and put them in a new
.h file - dm-exception-store.h. This file will define the
API for new exception stores.
Ultimately, dm-snap.h is unnecessary, since only dm-snap.c
should be using it.
Change dm_unregister_target to return void and use BUG() for error
reporting.
dm_unregister_target can only fail because of programming bug in the
target driver. It can't fail because of user's behavior or disk errors.
This patch changes unregister_target to return void and use BUG if
someone tries to unregister non-registered target or unregister target
that is in use.
This patch removes code duplication (testing of error codes in all dm
targets) and reports bugs in just one place, in dm_unregister_target. In
some target drivers, these return codes were ignored, which could lead
to a situation where bugs could be missed.
Change yield() to msleep(1). If the thread had realtime priority,
yield() doesn't really yield, so the yielding process would loop
indefinitely and cause machine lockup.
If there are several snapshots sharing an origin and one is removed
while the origin is being written to, the snapshot's mempool may get
deleted while elements are still referenced.
Prior to dm-snapshot-use-per-device-mempools.patch the pending
exceptions may still have been referenced after the snapshot was
destroyed, but this was not a problem because the shared mempool
was still there.
This patch fixes the problem by tracking the number of mempool elements
in use.
The scenario:
- You have an origin and two snapshots 1 and 2.
- Someone writes to the origin.
- It creates two exceptions in the snapshots, snapshot 1 will be primary
exception, snapshot 2's pending_exception->primary_pe will point to the
exception in snapshot 1.
- The exceptions are being relocated, relocation of exception 1 finishes
(but it's pending_exception is still allocated, because it is referenced
by an exception from snapshot 2)
- The user lvremoves snapshot 1 --- it calls just suspend (does nothing)
and destructor. md->pending is zero (there is no I/O submitted to the
snapshot by md layer), so it won't help us.
- The destructor waits for kcopyd jobs to finish on snapshot 1 --- but
there are none.
- The destructor on snapshot 1 cleans up everything.
- The relocation of exception on snapshot 2 finishes, it drops reference
on primary_pe. This frees its primary_pe pointer. Primary_pe points to
pending exception created for snapshot 1. So it frees memory into
non-existing mempool.
register_snapshot() performs a GFP_KERNEL allocation while holding
_origins_lock for write, but that could write out dirty pages onto a
device that attempts to acquire _origins_lock for read, resulting in
deadlock.
So move the allocation up before taking the lock.
This path is not performance-critical, so it doesn't matter that we
allocate memory and free it if we find that we won't need it.
The last_percent field is unused - remove it.
(It dates from when events were triggered as each X% filled up.)
Fix a race condition with primary_pe ref_count handling.
put_pending_exception runs under dm_snapshot->lock, it does atomic_dec_and_test
on primary_pe->ref_count, and later does atomic_read primary_pe->ref_count.
__origin_write does atomic_dec_and_test on primary_pe->ref_count without holding
dm_snapshot->lock.
This opens the following race condition:
Assume two CPUs, CPU1 is executing put_pending_exception (and holding
dm_snapshot->lock). CPU2 is executing __origin_write in parallel.
primary_pe->ref_count == 2.
CPU1:
if (primary_pe && atomic_dec_and_test(&primary_pe->ref_count))
origin_bios = bio_list_get(&primary_pe->origin_bios);
... decrements primary_pe->ref_count to 1. Doesn't load origin_bios
CPU2:
if (first && atomic_dec_and_test(&primary_pe->ref_count)) {
flush_bios(bio_list_get(&primary_pe->origin_bios));
free_pending_exception(primary_pe);
/* If we got here, pe_queue is necessarily empty. */
return r;
... decrements primary_pe->ref_count to 0, submits pending bios, frees
primary_pe.
CPU1:
if (!primary_pe || primary_pe != pe)
free_pending_exception(pe);
... this has no effect.
if (primary_pe && !atomic_read(&primary_pe->ref_count))
... sees ref_count == 0 (written by CPU 2), does double free !!
This bug can happen only if someone is simultaneously writing to both the
origin and the snapshot.
If someone is writing only to the origin, __origin_write will submit kcopyd
request after it decrements primary_pe->ref_count (so it can't happen that the
finished copy races with primary_pe->ref_count decrementation).
If someone is writing only to the snapshot, __origin_write isn't invoked at all
and the race can't happen.
The race happens when someone writes to the snapshot --- this creates
pending_exception with primary_pe == NULL and starts copying. Then, someone
writes to the same chunk in the snapshot, and __origin_write races with
termination of already submitted request in pending_complete (that calls
put_pending_exception).
This race may be reason for bugs:
http://bugzilla.kernel.org/show_bug.cgi?id=11636
https://bugzilla.redhat.com/show_bug.cgi?id=465825
The patch fixes the code to make sure that:
1. If atomic_dec_and_test(&primary_pe->ref_count) returns false, the process
must no longer dereference primary_pe (because someone else may free it under
us).
2. If atomic_dec_and_test(&primary_pe->ref_count) returns true, the process
is responsible for freeing primary_pe.
Change snapshot per-module mempool to per-device mempool.
Per-module mempools could cause a deadlock if multiple
snapshot devices are stacked above each other.
Fix a race condition that returns incorrect data when a write causes an
exception to be allocated whilst a read is still in flight.
The race condition happens as follows:
* A read to non-reallocated sector in the snapshot is submitted so that the
read is routed to the original device.
* A write to the original device is submitted. The write causes an exception
that reallocates the block. The write proceeds.
* The original read is dequeued and reads the wrong data.
This race can be triggered with CFQ scheduler and one thread writing and
multiple threads reading simultaneously.
(This patch relies upon the earlier dm-kcopyd-per-device.patch to avoid a
deadlock.)
Whenever a snapshot read gets mapped through to the origin, track it in
a per-snapshot hash table indexed by chunk number, using memory allocated
from a new per-snapshot mempool.
We need to track these reads to avoid race conditions which will be fixed
by patches that follow.
Publish the dm-io, dm-log and dm-kcopyd headers in include/linux.
Clean up the kcopyd interface to prepare for publishing it in include/linux.
Signed-off-by: Heinz Mauelshagen <hjm@redhat.com>
Clean up the dm-io interface to prepare for publishing it in include/linux.
Save pointer to dm_target in dm_snapshot structure.
Limit the amount of memory allocated per snapshot on systems
with a large page size. (The larger default chunk size on
these systems compensates for the smaller number of pages reserved.)
Signed-off-by: Milan Broz <mbroz@redhat.com>
write_err is an unsigned long used with set_bit() so should not be passed
around as unsigned int.
http://bugzilla.kernel.org/show_bug.cgi?id=10271
Provided sector_t is 64 bits, reduce the in-memory footprint of the
snapshot exception table by the simple method of using unused bits of
the chunk number to combine consecutive entries.
Since the source file already includes the log2.h header file, it
seems pointless to re-invent the necessary routine.
Replacing n & (n - 1) for power of 2 check by is_power_of_2(n)
Signed-off-by: vignesh babu <vignesh.babu@wipro.com>
As bi_end_io is only called once when the reqeust is complete,
the 'size' argument is now redundant. Remove it.
Now there is no need for bio_endio to subtract the size completed
from bi_size. So don't do that either.
While we are at it, change bi_end_io to return void.
Signed-off-by: Neil Brown <neilb@suse.de>
This patch causes device-mapper to reject any barrier requests. This is done
since most of the targets won't handle this correctly anyway. So until the
situation improves it is better to reject these requests at the first place.
Since barrier requests won't get to the targets, the checks there can be
removed.
Signed-off-by: Stefan Bader <shbader@de.ibm.com>
Allow invalid snapshots to be activated instead of failing.
This allows userspace to reinstate any given snapshot state - for
example after an unscheduled reboot - and clean up the invalid snapshot
at its leisure.
Use new KMEM_CACHE() macro and make the newly-exposed structure names more
meaningful. Also remove some superfluous casts and inlines (let a modern
compiler be the judge).
Acked-by: Christoph Lameter <clameter@sgi.com>
Move the code that releases memory used by a snapshot into a separate function.
Cc: dm-devel@redhat.com
