path: root/drivers/md/dm-snap.h
2008-04-25dm kcopyd: clean interfaceHeinz Mauelshagen
Clean up the kcopyd interface to prepare for publishing it in include/linux. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm snapshot: store pointer to target instanceMikulas Patocka
Save pointer to dm_target in dm_snapshot structure. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-02-08dm snapshot: combine consecutive exceptions in memoryMilan Broz
Provided sector_t is 64 bits, reduce the in-memory footprint of the snapshot exception table by the simple method of using unused bits of the chunk number to combine consecutive entries. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2007-07-12dm: use kmem_cache macroAlasdair G Kergon
Use new KMEM_CACHE() macro and make the newly-exposed structure names more meaningful. Also remove some superfluous casts and inlines (let a modern compiler be the judge). Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] dm snapshot: add workqueueAlasdair G Kergon
Add a workqueue so that I/O can be queued up to be flushed from a separate thread (e.g. if local interrupts are disabled). A new per-snapshot spinlock pe_lock is introduced to protect queued_bios. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] dm snapshot: allow zero chunk_sizeMark McLoughlin
The chunk size of snapshots cannot be changed so it is redundant to require it as a parameter when activating an existing snapshot. Allow a value of zero in this case and ignore it. For a new snapshot, use a default value if zero is specified. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] device-mapper snapshot: load metadata on creationAlasdair G Kergon
Move snapshot metadata loading to happen when the table is created instead of when the device is resumed. Writes to the origin device don't trigger exceptions until each snapshot table becomes active when resume() is called on each snapshot. If you're using lvm2, for this patch to work properly you should update to lvm2 version 2.02.01 or later and device-mapper version 1.02.02 or later. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
