path: root/drivers/md/dm-verity-fec.h
2017-04-12dm verity fec: limit error correction recursionSami Tolvanen
commit f1a880a93baaadb14c10a348fd199f1cdb6bcccd upstream. If the hash tree itself is sufficiently corrupt in addition to data blocks, it's possible for error correction to end up in a deep recursive loop, which eventually causes a kernel panic. This change limits the recursion to a reasonable level during a single I/O operation. Fixes: a739ff3f543a ("dm verity: add support for forward error correction") Signed-off-by: Sami Tolvanen <samitolvanen@google.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-10dm verity: add support for forward error correctionSami Tolvanen
Add support for correcting corrupted blocks using Reed-Solomon. This code uses RS(255, N) interleaved across data and hash blocks. Each error-correcting block covers N bytes evenly distributed across the combined total data, so that each byte is a maximum distance away from the others. This makes it possible to recover from several consecutive corrupted blocks with relatively small space overhead. In addition, using verity hashes to locate erasures nearly doubles the effectiveness of error correction. Being able to detect corrupted blocks also improves performance, because only corrupted blocks need to corrected. For a 2 GiB partition, RS(255, 253) (two parity bytes for each 253-byte block) can correct up to 16 MiB of consecutive corrupted blocks if erasures can be located, and 8 MiB if they cannot, with 16 MiB space overhead. Signed-off-by: Sami Tolvanen <samitolvanen@google.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
