path: root/drivers/md/dm.h
2008-04-25dm: expose macrosAlasdair G Kergon
Make dm.h macros and inlines available in include/linux/device-mapper.h Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm kcopyd: remove redundant client countingMikulas Patocka
Remove client counting code that is no longer needed. Initialization and destruction is made globally from dm_init and dm_exit and is not based on client counts. Initialization allocates only one empty slab cache, so there is no negative impact from performing the initialization always, regardless of whether some client uses kcopyd or not. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm log: clean interfaceHeinz Mauelshagen
Clean up the dm-log interface to prepare for publishing it in include/linux. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2007-12-20dm: trigger change uevent on renameAlasdair G Kergon
Insert a missing KOBJ_CHANGE notification when a device is renamed. Cc: Scott James Remnant <scott@ubuntu.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2007-12-20dm: table detect io beyond deviceJun'ichi Nomura
This patch fixes a panic on shrinking a DM device if there is outstanding I/O to the part of the device that is being removed. (Normally this doesn't happen - a filesystem would be resized first, for example.) The bug is that __clone_and_map() assumes dm_table_find_target() always returns a valid pointer. It may fail if a bio arrives from the block layer but its target sector is no longer included in the DM btree. This patch appends an empty entry to table->targets[] which will be returned by a lookup beyond the end of the device. After calling dm_table_find_target(), __clone_and_map() and target_message() check for this condition using dm_target_is_valid(). Sample test script to trigger oops:
2007-10-16block: convert blkdev_issue_flush() to use empty barriersJens Axboe
Then we can get rid of ->issue_flush_fn() and all the driver private implementations of that. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-12dm: add ratelimit logging macrosJonathan Brassow
Add ratelimit extension to dm logging macros. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] dm: suspend: add noflush pushbackKiyoshi Ueda
In device-mapper I/O is sometimes queued within targets for later processing. For example the multipath target can be configured to store I/O when no paths are available instead of returning it -EIO. This patch allows the device-mapper core to instruct a target to transfer the contents of any such in-target queue back into the core. This frees up the resources used by the target so the core can replace that target with an alternative one and then resend the I/O to it. Without this patch the only way to change the target in such circumstances involves returning the I/O with an error back to the filesystem/application. In the multipath case, this patch will let us add new paths for existing I/O to try after all the existing paths have failed. DMF_NOFLUSH_SUSPENDING ---------------------- If the DM_NOFLUSH_FLAG ioctl option is specified at suspend time, the DMF_NOFLUSH_SUSPENDING flag is set in md->flags during dm_suspend(). It is always cleared before dm_suspend() returns. The flag must be visible while the target is flushing pending I/Os so it is set before presuspend where the flush starts and unset after the wait for md->pending where the flush ends. Target drivers can check this flag by calling dm_noflush_suspending(). DM_MAPIO_REQUEUE / DM_ENDIO_REQUEUE ----------------------------------- A target's map() function can now return DM_MAPIO_REQUEUE to request the device mapper core queue the bio. Similarly, a target's end_io() function can return DM_ENDIO_REQUEUE to request the same. This has been labelled 'pushback'. The __map_bio() and clone_endio() functions in the core treat these return values as errors and call dec_pending() to end the I/O. dec_pending ----------- dec_pending() saves the pushback request in struct dm_io->error. Once all the split clones have ended, dec_pending() will put the original bio on the md->pushback list. Note that this supercedes any I/O errors. It is possible for the suspend with DM_NOFLUSH_FLAG to be aborted while in progress (e.g. by user interrupt). dec_pending() checks for this and returns -EIO if it happened. pushdback list and pushback_lock -------------------------------- The bio is queued on md->pushback temporarily in dec_pending(), and after all pending I/Os return, md->pushback is merged into md->deferred in dm_suspend() for re-issuing at resume time. md->pushback_lock protects md->pushback. The lock should be held with irq disabled because dec_pending() can be called from interrupt context. Queueing bios to md->pushback in dec_pending() must be done atomically with the check for DMF_NOFLUSH_SUSPENDING flag. So md->pushback_lock is held when checking the flag. Otherwise dec_pending() may queue a bio to md->pushback after the interrupted dm_suspend() flushes md->pushback. Then the bio would be left in md->pushback. Flag setting in dm_suspend() can be done without md->pushback_lock because the flag is checked only after presuspend and the set value is already made visible via the target's presuspend function. The flag can be checked without md->pushback_lock (e.g. the first part of the dec_pending() or target drivers), because the flag is checked again with md->pushback_lock held when the bio is really queued to md->pushback as described above. So even if the flag is cleared after the lockless checkings, the bio isn't left in md->pushback but returned to applications with -EIO. Other notes on the current patch -------------------------------- - md->pushback is added to the struct mapped_device instead of using md->deferred directly because md->io_lock which protects md->deferred is rw_semaphore and can't be used in interrupt context like dec_pending(), and md->io_lock protects the DMF_BLOCK_IO flag of md->flags too. - Don't issue lock_fs() in dm_suspend() if the DM_NOFLUSH_FLAG ioctl option is specified, because I/Os generated by lock_fs() would be pushed back and never return if there were no valid devices. - If an error occurs in dm_suspend() after the DMF_NOFLUSH_SUSPENDING flag is set, md->pushback must be flushed because I/Os may be queued to the list already. (flush_and_out label in dm_suspend()) Test results ------------ I have tested using multipath target with the next patch. The following tests are for regression/compatibility: - I/Os succeed when valid paths exist; - I/Os fail when there are no valid paths and queue_if_no_path is not set; - I/Os are queued in the multipath target when there are no valid paths and queue_if_no_path is set; - The queued I/Os above fail when suspend is issued without the DM_NOFLUSH_FLAG ioctl option. I/Os spanning 2 multipath targets also fail. The following tests are for the normal code path of new pushback feature: - Queued I/Os in the multipath target are flushed from the target but don't return when suspend is issued with the DM_NOFLUSH_FLAG ioctl option; - The I/Os above are queued in the multipath target again when resume is issued without path recovery; - The I/Os above succeed when resume is issued after path recovery or table load; - Queued I/Os in the multipath target succeed when resume is issued with the DM_NOFLUSH_FLAG ioctl option after table load. I/Os spanning 2 multipath targets also succeed. The following tests are for the error paths of the new pushback feature: - When the bdget_disk() fails in dm_suspend(), the DMF_NOFLUSH_SUSPENDING flag is cleared and I/Os already queued to the pushback list are flushed properly. - When suspend with the DM_NOFLUSH_FLAG ioctl option is interrupted, o I/Os which had already been queued to the pushback list at the time don't return, and are re-issued at resume time; o I/Os which hadn't been returned at the time return with EIO. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: dm-devel@redhat.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] dm: ioctl: add noflush suspendKiyoshi Ueda
Provide a dm ioctl option to request noflush suspending. (See next patch for what this is for.) As the interface is extended, the version number is incremented. Other than accepting the new option through the interface, There is no change to existing behaviour. Test results: Confirmed the option is given from user-space correctly. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: dm-devel@redhat.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] dm: map and endio return code clarificationKiyoshi Ueda
Tighten the use of return values from the target map and end_io functions. Values of 2 and above are now explictly reserved for future use. There are no existing targets using such values. The patch has no effect on existing behaviour. o Reserve return values of 2 and above from target map functions. Any positive value currently indicates "mapping complete", but all existing drivers use the value 1. We now make that a requirement so we can assign new meaning to higher values in future. The new definition of return values from target map functions is: < 0 : error = 0 : The target will handle the io (DM_MAPIO_SUBMITTED). = 1 : Mapping completed (DM_MAPIO_REMAPPED). > 1 : Reserved (undefined). Previously this was the same as '= 1'. o Reserve return values of 2 and above from target end_io functions for similar reasons. DM_ENDIO_INCOMPLETE is introduced for a return value of 1. Test results: I have tested by using the multipath target. I/Os succeed when valid paths exist. I/Os are queued in the multipath target when there are no valid paths and queue_if_no_path is set. I/Os fail when there are no valid paths and queue_if_no_path is not set. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: dm-devel@redhat.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] dm: suspend: parameter changeKiyoshi Ueda
Change the interface of dm_suspend() so that we can pass several options without increasing the number of parameters. The existing 'do_lockfs' integer parameter is replaced by a flag DM_SUSPEND_LOCKFS_FLAG. There is no functional change to the code. Test results: I have tested 'dmsetup suspend' command with/without the '--nolockfs' option and confirmed the do_lockfs value is correctly set. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: dm-devel@redhat.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] dm table: add target preresumeMilan Broz
This patch adds a target preresume hook. It is called before the targets are resumed and if it returns an error the resume gets cancelled. The crypt target will use this to indicate that it is unable to process I/O because no encryption key has been supplied. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] dm: add debug macroBryn Reeves
Add CONFIG_DM_DEBUG and DMDEBUG() macro. Signed-off-by: Bryn Reeves <breeves@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: improve error message consistencyAlasdair G Kergon
Tidy device-mapper error messages to include context information automatically. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: prevent removal if openAlasdair G Kergon
If you misuse the device-mapper interface (or there's a bug in your userspace tools) it's possible to end up with 'unlinked' mapped devices that cannot be removed until you reboot (along with uninterruptible processes). This patch prevents you from removing a device that is still open. It introduces dm_lock_for_deletion() which is called when a device is about to be removed to ensure that nothing has it open and nothing further can open it. It uses a private open_count for this which also lets us remove one of the problematic bdget_disk() calls elsewhere. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: add exportsAlasdair G Kergon
Move definitions of core device-mapper functions for manipulating mapped devices and their tables to <linux/device-mapper.h> advertising their availability for use elsewhere in the kernel. Protect the contents of device-mapper.h with ifdef __KERNEL__. And throw in a few formatting clean-ups and extra comments. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: consolidate creation functionsAlasdair G Kergon
Merge dm_create() and dm_create_with_minor() by introducing the special value DM_ANY_MINOR to request the allocation of the next available minor number. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm store geometryDarrick J. Wong
Allow drive geometry to be stored with a new DM_DEV_SET_GEOMETRY ioctl. Device-mapper will now respond to HDIO_GETGEO. If the geometry information is not available, zero will be returned for all of the parameters. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm table: store mdMike Anderson
Store an up-pointer to the owning struct mapped_device in every table when it is created. Access it with: struct mapped_device *dm_table_get_md(struct dm_table *t) Tables linked to md must be destroyed before the md itself. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm: tidy mdptrAlasdair G Kergon
Change dm_get_mdptr() to take a struct mapped_device instead of dev_t. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm: remove SECTOR_FORMATAndrew Morton
We don't know what type sector_t has. Sometimes it's unsigned long, sometimes it's unsigned long long. For example on ppc64 it's unsigned long with CONFIG_LBD=n and on x86_64 it's unsigned long long with CONFIG_LBD=n. The way to handle all of this is to always use unsigned long long and to always typecast the sector_t when printing it. Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] device-mapper: make lock_fs optionalAlasdair G Kergon
Devices only needs syncing when creating snapshots, so make this optional when suspending a device. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] device-mapper: scanf sector format changeAlasdair G Kergon
Use %llu not %Lu in sscanf/printf format strings. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] device-mapper: add dm_get_mdDavid Teigland
Add dm_get_dev() to get a mapped device given its dev_t. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
