path: root/drivers/md/linear.h
2009-06-18md/linear: use call_rcu to free obsolete 'conf' structures.NeilBrown
Current, when we update the 'conf' structure, when adding a drive to a linear array, we keep the old version around until the array is finally stopped, as it is not safe to free it immediately. Now that we have rcu protection on all accesses to 'conf', we can use call_rcu to free it more promptly. Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-16md: Removing num_sector and replacing start_sector with end_sectorSandeep K Sinha
Remove num_sectors from dev_info and replace start_sector with end_sector. This makes a lot of comparisons much simpler. Signed-off-by: Sandeep K Sinha <sandeepksinha@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-16md: Removal of hash table in linear raidSandeep K Sinha
Get rid of sector_div and hash table for linear raid and replace with a linear search in which_dev. The hash table adds a lot of complexity for little if any gain. Ultimately a binary search will be used which will have smaller cache foot print, a similar number of memory access, and no divisions. Signed-off-by: Sandeep K Sinha <sandeepksinha@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-16md: remove mddev_to_conf "helper" macroNeilBrown
Having a macro just to cast a void* isn't really helpful. I would must rather see that we are simply de-referencing ->private, than have to know what the macro does. So open code the macro everywhere and remove the pointless cast. Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move lots of #include lines out of .h files and into .cNeilBrown
This makes the includes more explicit, and is preparation for moving md_k.h to drivers/md/md.h Remove include/raid/md.h as its only remaining use was to #include other files. Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move headers out of include/linux/raid/Christoph Hellwig
Move the headers with the local structures for the disciplines and bitmap.h into drivers/md/ so that they are more easily grepable for hacking and not far away. md.h is left where it is for now as there are some uses from the outside. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: NeilBrown <neilb@suse.de>
