Add new parameter to 'sync_page_io'.
The new parameter allows us to distinguish between metadata and data
operations. This becomes important later when we add the ability to
use separate devices for data and metadata.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Noticed-by: Russell King <linux@arm.linux.org.uk>
Signed-off-by: NeilBrown <neilb@suse.de>
When we fail to start a raid10 for some reason, we call
md_unregister_thread to kill the thread that was created.
Unfortunately md_thread() will then make one call into the handler
(raid10d) even though md_wakeup_thread has not been called. This is
not safe and as md_unregister_thread is called after mddev->private
has been set to NULL, it will definitely cause a NULL dereference.
So fix this at both ends:
- md_thread should only call the handler if THREAD_WAKEUP has been
set.
- raid10 should call md_unregister_thread before setting things
to NULL just like all the other raid modules do.
This is applicable to 2.6.35 and later.
Cc: stable@kernel.org
Reported-by: "Citizen" <citizen_lee@thecus.com>
bio_clone and bio_alloc allocate from a common bio pool.
If an md device is stacked with other devices that use this pool, or under
something like swap which uses the pool, then the multiple calls on
the pool can cause deadlocks.
So allocate a local bio pool for each md array and use that rather
than the common pool.
This pool is used both for regular IO and metadata updates.
Currently sync_page_io takes a 'bdev'.
Every caller passes 'rdev->bdev'.
We will soon want another field out of the rdev in sync_page_io,
So just pass the rdev instead of the bdev out of it.
bio_alloc can never fail (as it uses a mempool) but an block
indefinitely, especially if the caller is holding a reference to a
previously allocated bio.
So these to places which both handle failure and hold multiple bios
should not use bio_alloc, they should use bio_kmalloc.
It is not safe to allocate from a mempool while holding an item
previously allocated from that mempool as that can deadlock when the
mempool is close to exhaustion.
So don't use a bio list to collect the bios to write to multiple
devices in raid1 and raid10.
Instead queue each bio as it becomes available so an unplug will
activate all previously allocated bios and so a new bio has a chance
of being allocated.
This means we must set the 'remaining' count to '1' before submitting
any requests, then when all are submitted, decrement 'remaining' and
possible handle the write completion at that point.
Reported-by: Torsten Kaiser <just.for.lkml@googlemail.com>
Tested-by: Torsten Kaiser <just.for.lkml@googlemail.com>
bitmap_get_counter returns the number of sectors covered
by the counter in a pass-by-reference variable.
In some cases this can be very large, so make it a sector_t
for safety.
This patch converts md to support REQ_FLUSH/FUA instead of now
deprecated REQ_HARDBARRIER. In the core part (md.c), the following
changes are notable.
* Unlike REQ_HARDBARRIER, REQ_FLUSH/FUA don't interfere with
processing of other requests and thus there is no reason to mark the
queue congested while FLUSH/FUA is in progress.
* REQ_FLUSH/FUA failures are final and its users don't need retry
logic. Retry logic is removed.
* Preflush needs to be issued to all member devices but FUA writes can
be handled the same way as other writes - their processing can be
deferred to request_queue of member devices. md_barrier_request()
is renamed to md_flush_request() and simplified accordingly.
For linear, raid0 and multipath, the core changes are enough. raid1,
5 and 10 need the following conversions.
* raid1: Handling of FLUSH/FUA bio's can simply be deferred to
request_queues of member devices. Barrier related logic removed.
* raid5: Queue draining logic dropped. FUA bit is propagated through
biodrain and stripe resconstruction such that all the updated parts
of the stripe are written out with FUA writes if any of the dirtying
writes was FUA. preread_active_stripes handling in make_request()
is updated as suggested by Neil Brown.
* raid10: FUA bit needs to be propagated to write clones.
linear, raid0, 1, 5 and 10 tested.
Reviewed-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 7b6d91daee5cac6402186ff224c3af39d79f4a0e changed the behaviour
of a few variables in raid1 and raid10 from flags to bit-sets, but
left them as type 'bool' so they did not work.
Change them (back) to unsigned long.
(historical note: see 1ef04fefe2241087d9db7e9615c3f11b516e36cf)
Reported-by: Jiri Slaby <jslaby@suse.cz> and many others
md_check_recovery expects ->spare_active to return 'true' if any
spares were activated, but none of them do, so the consequent change
in 'degraded' is not notified through sysfs.
So count the number of spares activated, subtract it from 'degraded'
just once, and return it.
Reported-by: Adrian Drzewiecki <adriand@vmware.com>
When RAID1 is done syncing disks, it'll update the state
of synced rdevs to In_sync. But it neglected to notify
sysfs that the attribute changed. So any programs that
are waiting for an rdev's state to change will not be
woken.
(raid5/raid10 added by neilb)
Signed-off-by: Adrian Drzewiecki <adriand@vmware.com>
* 'for-linus' of git://neil.brown.name/md: (24 commits)
md: clean up do_md_stop
md: fix another deadlock with removing sysfs attributes.
md: move revalidate_disk() back outside open_mutex
md/raid10: fix deadlock with unaligned read during resync
md/bitmap: separate out loading a bitmap from initialising the structures.
md/bitmap: prepare for storing write-intent-bitmap via dm-dirty-log.
md/bitmap: optimise scanning of empty bitmaps.
md/bitmap: clean up plugging calls.
md/bitmap: reduce dependence on sysfs.
md/bitmap: white space clean up and similar.
md/raid5: export raid5 unplugging interface.
md/plug: optionally use plugger to unplug an array during resync/recovery.
md/raid5: add simple plugging infrastructure.
md/raid5: export is_congested test
raid5: Don't set read-ahead when there is no queue
md: add support for raising dm events.
md: export various start/stop interfaces
md: split out md_rdev_init
md: be more careful setting MD_CHANGE_CLEAN
md/raid5: ensure we create a unique name for kmem_cache when mddev has no gendisk
Remove the current bio flags and reuse the request flags for the bio, too.
This allows to more easily trace the type of I/O from the filesystem
down to the block driver. There were two flags in the bio that were
missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've
renamed two request flags that had a superflous RW in them.
Note that the flags are in bio.h despite having the REQ_ name - as
blkdev.h includes bio.h that is the only way to go for now.
If the 'bio_split' path in raid10-read is used while
resync/recovery is happening it is possible to deadlock.
Fix this be elevating ->nr_waiting for the duration of both
parts of the split request.
This fixes a bug that has been present since 2.6.22
but has only started manifesting recently for unknown reasons.
It is suitable for and -stable since then.
Reported-by: Justin Bronder <jsbronder@gentoo.org>
Tested-by: Justin Bronder <jsbronder@gentoo.org>
Use mddev->new_layout in setup_conf.
Also use new_chunk, and don't set ->degraded in takeover(). That
gets set in run()
Signed-off-by: Maciej Trela <maciej.trela@intel.com>
Most array level changes leave the list of devices largely unchanged,
possibly causing one at the end to become redundant.
However conversions between RAID0 and RAID10 need to renumber
all devices (except 0).
This renumbering is currently being done in the ->run method when the
new personality takes over. However this is too late as the common
code in md.c might already have invalidated some of the devices if
they had a ->raid_disk number that appeared to high.
Moving it into the ->takeover method is too early as the array is
still active at that time and wrong ->raid_disk numbers could cause
confusion.
So add a ->new_raid_disk field to mdk_rdev_s and use it to communicate
the new raid_disk number.
Now the common code knows exactly which devices need to be renumbered,
and which can be invalidated, and can do it all at a convenient time
when the array is suspend.
It can also update some symlinks in sysfs which previously were not be
updated correctly.
Reported-by: Maciej Trela <maciej.trela@intel.com>
Such NULL pointer dereference can occur when the driver was fixing the
read errors/bad blocks and the disk was physically removed
causing a system crash. This patch check if the
rcu_dereference() returns valid rdev before accessing it in fix_read_error().
Signed-off-by: Prasanna S. Panchamukhi <prasanna.panchamukhi@riverbed.com>
Signed-off-by: Rob Becker <rbecker@riverbed.com>
drivers/md/md.c
- Resolved conflict in md_update_sb
- Added extra 'NULL' arg to new instance of sysfs_get_dirent.
read_balance uses a "unsigned long" for a sector number which
will get truncated beyond 2TB.
This will cause read-balancing to be non-optimal, and can cause
data to be read from the 'wrong' branch during a resync. This has a
very small chance of returning wrong data.
Reported-by: Jordan Russell <jr-list-2010@quo.to>
All raid10 printk messages now start
md/raid10:md-device-name:
We used to pass the personality make_request function direct
to the block layer so the first argument had to be a queue.
But now we have the intermediary md_make_request so it makes
at lot more sense to pass a struct mddev_s.
It makes it possible to have an mddev without its own queue too.
While I generally prefer letting personalities do as much as possible,
given that we have a central md_make_request anyway we may as well use
it to simplify code.
Also this centralises knowledge of ->gendisk which will help later.
In a subsequent patch we will make it possible to change
mddev->raid_disks while a RAID0 or RAID10 array is active. This is
part of the process of reshaping such an array.
This means that we cannot use this value while processes requests
(it is OK to use it during initialisation as we are locked against
changes then).
Both RAID0 and RAID10 have the same value stored in the private data
structure, so use that value instead.
void pointers do not need to be cast to other pointer types.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
If a component device has a merge_bvec_fn then as we never call it
we must ensure we never need to. Currently this is done by setting
max_sector to 1 PAGE, however this does not stop a bio being created
with several sub-page iovecs that would violate the merge_bvec_fn.
So instead set max_segments to 1 and set the segment boundary to the
same as a page boundary to ensure there is only ever one single-page
segment of IO requested at a time.
This can particularly be an issue when 'xen' is used as it is
known to submit multiple small buffers in a single bio.
The block layer calling convention is blk_queue_<limit name>.
blk_queue_max_sectors predates this practice, leading to some confusion.
Rename the function to appropriately reflect that its intended use is to
set max_hw_sectors.
Also introduce a temporary wrapper for backwards compability. This can
be removed after the merge window is closed.
Suggested by Oren Held <orenhe@il.ibm.com>
We've noticed severe lasting performance degradation of our raid
arrays when we have drives that yield large amounts of media errors.
The raid10 module will queue each failed read for retry, and also
will attempt call fix_read_error() to perform the read recovery.
Read recovery is performed while the array is frozen, so repeated
recovery attempts can degrade the performance of the array for
extended periods of time.
With this patch I propose adding a per md device max number of
corrected read attempts. Each rdev will maintain a count of
read correction attempts in the rdev->read_errors field (not
used currently for raid10). When we enter fix_read_error()
we'll check to see when the last read error occurred, and
divide the read error count by 2 for every hour since the
last read error. If at that point our read error count
exceeds the read error threshold, we'll fail the raid device.
In addition in this patch I add sysfs nodes (get/set) for
the per md max_read_errors attribute, the rdev->read_errors
attribute, and added some printk's to indicate when
fix_read_error fails to repair an rdev.
For testing I used debugfs->fail_make_request to inject
IO errors to the rdev while doing IO to the raid array.
Signed-off-by: Robert Becker <Rob.Becker@riverbed.com>
When we get a read error on a device in a RAID10, and attempting to
repair the error fails, print more useful messages about why it
failed.
As bitmap_create and bitmap_destroy already set thread->timeout
as appropriate, there is no need to do it in raid10_quiesce.
There is a possible need to wake the thread after the timeout
has been set low, but it is better to do that where the timeout
is actually set low, in bitmap_create.
This removes a lot of multiplications by HZ.
... and into bitmap_info. These are all configuration parameters
that need to be set before the bitmap is created.
Previously barriers were only supported on RAID1. This is because
other levels requires synchronisation across all devices and so needed
a different approach.
Here is that approach.
When a barrier arrives, we send a zero-length barrier to every active
device. When that completes - and if the original request was not
empty - we submit the barrier request itself (with the barrier flag
cleared) and then submit a fresh load of zero length barriers.
The barrier request itself is asynchronous, but any subsequent
request will block until the barrier completes.
The reason for clearing the barrier flag is that a barrier request is
allowed to fail. If we pass a non-empty barrier through a striping
raid level it is conceivable that part of it could succeed and part
could fail. That would be way too hard to deal with.
So if the first run of zero length barriers succeed, we assume all is
sufficiently well that we send the request and ignore errors in the
second run of barriers.
RAID5 needs extra care as write requests may not have been submitted
to the underlying devices yet. So we flush the stripe cache before
proceeding with the barrier.
Note that the second set of zero-length barriers are submitted
immediately after the original request is submitted. Thus when
a personality finds mddev->barrier to be set during make_request,
it should not return from make_request until the corresponding
per-device request(s) have been queued.
That will be done in later patches.
Reviewed-by: Andre Noll <maan@systemlinux.org>
Both raid1 and raid10 create a mempool during startup.
If the 'alloc' function for this mempool fails, unplug_slaves
is called.
If that happens when the pool is being initialised, unplug_slaves
will try to use the 'conf' structure that isn't filled in yet, and
badness will happen.
So ensure that unplug_slaves doesn't get called unless we know
that the conf structure if fully initialised.
During 'check' of a raid1 or raid10 it is possible for the management
thread to spend a lot of time running 'memcmp' on blocks from
different devices, so make sure the thread has a chance to schedule.
raid5d already has a cond_resched (in process_stripe).
Reported-By: Lee Howard <faxguy@howardsilvan.com>
Recently Jens has changed bio_rw_flagged() logic by following
commit 1f98a13f623e0ef666690a18c1250335fc6d7ef1. Now it returns
bool instead of int. This broke raid1/raid10 RW bits manipulation logic.
One of visible result is BUG_ON triggering due to empty barrier
here scsi_lib.c:1108 scsi_setup_fs_cmnd()
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
This should writeback from coming when the device is temporarily
suspended.
The management thread for raid4,5,6 arrays are all called
mdX_raid5, independent of the actual raid level, which is wrong and
can be confusion.
So change md_register_thread to use the name from the personality
unless no alternate name (like 'resync' or 'reshape') is given.
This is simpler and more correct.
Cc: Jinzc <zhenchengjin@gmail.com>
Rename some variable and remove some duplicate definitions
to avoid there warnings. None of them are actual errors.
Get rid of any functions that test for these bits and make callers
use bio_rw_flagged() directly. Then it is at least directly apparent
what variable and flag they check.
This patch replaces md_integrity_check() by two new public functions:
md_integrity_register() and md_integrity_add_rdev() which are both
personality-independent.
md_integrity_register() is called from the ->run and ->hot_remove
methods of all personalities that support data integrity. The
function iterates over the component devices of the array and
determines if all active devices are integrity capable and if their
profiles match. If this is the case, the common profile is registered
for the mddev via blk_integrity_register().
The second new function, md_integrity_add_rdev() is called from the
->hot_add_disk methods, i.e. whenever a new device is being added
to a raid array. If the new device does not support data integrity,
or has a profile different from the one already registered, data
integrity for the mddev is disabled.
For raid0 and linear, only the call to md_integrity_register() from
the ->run method is necessary.
Signed-off-by: Andre Noll <maan@systemlinux.org>
Switch MD over to the new disk_stack_limits() function which checks for
aligment and adjusts preferred I/O sizes when stacking.
Also indicate preferred I/O sizes where applicable.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Currently, the md layer checks in analyze_sbs() if the raid level
supports reconstruction (mddev->level >= 1) and if reconstruction is
in progress (mddev->recovery_cp != MaxSector).
Move that printk into the personality code of those raid levels that
care (levels 1, 4, 5, 6, 10).
This patch renames the chunk_size field to chunk_sectors with the
implied change of semantics. Since
is_power_of_2(chunk_size) = is_power_of_2(chunk_sectors << 9)
= is_power_of_2(chunk_sectors)
these bits don't need an adjustment for the shift.
have raid10 check chunk size in run method instead of in md
Signed-off-by: raziebe@gmail.com
Having a macro just to cast a void* isn't really helpful.
I would must rather see that we are simply de-referencing ->private,
than have to know what the macro does.
So open code the macro everywhere and remove the pointless cast.
Convert all external users of queue limits to using wrapper functions
instead of poking the request queue variables directly.
