path: root/drivers/md/raid5.h
2016-04-12RAID5: revert e9e4c377e2f563 to fix a livelockShaohua Li
commit 6ab2a4b806ae21b6c3e47c5ff1285ec06d505325 upstream. Revert commit e9e4c377e2f563(md/raid5: per hash value and exclusive wait_for_stripe) The problem is raid5_get_active_stripe waits on conf->wait_for_stripe[hash]. Assume hash is 0. My test release stripes in this order: - release all stripes with hash 0 - raid5_get_active_stripe still sleeps since active_stripes > max_nr_stripes * 3 / 4 - release all stripes with hash other than 0. active_stripes becomes 0 - raid5_get_active_stripe still sleeps, since nobody wakes up wait_for_stripe[0] The system live locks. The problem is active_stripes isn't a per-hash count. Revert the patch makes the live lock go away. Cc: Yuanhan Liu <yuanhan.liu@linux.intel.com> Cc: NeilBrown <neilb@suse.de> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12RAID5: check_reshape() shouldn't call mddev_suspendShaohua Li
commit 27a353c026a879a1001e5eac4bda75b16262c44a upstream. check_reshape() is called from raid5d thread. raid5d thread shouldn't call mddev_suspend(), because mddev_suspend() waits for all IO finish but IO is handled in raid5d thread, we could easily deadlock here. This issue is introduced by 738a273 ("md/raid5: fix allocation of 'scribble' array.") Reported-and-tested-by: Artur Paszkiewicz <artur.paszkiewicz@intel.com> Reviewed-by: NeilBrown <neilb@suse.com> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-01raid5-cache: IO error handlingShaohua Li
There are 3 places the raid5-cache dispatches IO. The discard IO error doesn't matter, so we ignore it. The superblock write IO error can be handled in MD core. The remaining are log write and flush. When the IO error happens, we mark log disk faulty and fail all write IO. Read IO is still allowed to run. Userspace will get a notification too and corresponding daemon can choose setting raid array readonly for example. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: NeilBrown <neilb@suse.com>
2015-11-01raid5-cache: move reclaim stop to quiesceShaohua Li
Move reclaim stop to quiesce handling, where is safer for this stuff. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: NeilBrown <neilb@suse.com>
2015-11-01raid5-cache: optimize FLUSH IO with log enabledShaohua Li
With log enabled, bio is written to raid disks after the bio is settled down in log disk. The recovery guarantees we can recovery the bio data from log disk, so we we skip FLUSH IO. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: NeilBrown <neilb@suse.com>
2015-10-24raid5: log reclaim supportShaohua Li
This is the reclaim support for raid5 log. A stripe write will have following steps: 1. reconstruct the stripe, read data/calculate parity. ops_run_io prepares to write data/parity to raid disks 2. hijack ops_run_io. stripe data/parity is appending to log disk 3. flush log disk cache 4. ops_run_io run again and do normal operation. stripe data/parity is written in raid array disks. raid core can return io to upper layer. 5. flush cache of all raid array disks 6. update super block 7. log disk space used by the stripe can be reused In practice, several stripes consist of an io_unit and we will batch several io_unit in different steps, but the whole process doesn't change. It's possible io return just after data/parity hit log disk, but then read IO will need read from log disk. For simplicity, IO return happens at step 4, where read IO can directly read from raid disks. Currently reclaim run if there is specific reclaimable space (1/4 disk size or 10G) or we are out of space. Reclaim is just to free log disk spaces, it doesn't impact data consistency. The size based force reclaim is to make sure log isn't too big, so recovery doesn't scan log too much. Recovery make sure raid disks and log disk have the same data of a stripe. If crash happens before 4, recovery might/might not recovery stripe's data/parity depending on if data/parity and its checksum matches. In either case, this doesn't change the syntax of an IO write. After step 3, stripe is guaranteed recoverable, because stripe's data/parity is persistent in log disk. In some cases, log disk content and raid disks content of a stripe are the same, but recovery will still copy log disk content to raid disks, this doesn't impact data consistency. space reuse happens after superblock update and cache flush. There is one situation we want to avoid. A broken meta in the middle of a log causes recovery can't find meta at the head of log. If operations require meta at the head persistent in log, we must make sure meta before it persistent in log too. The case is stripe data/parity is in log and we start write stripe to raid disks (before step 4). stripe data/parity must be persistent in log before we do the write to raid disks. The solution is we restrictly maintain io_unit list order. In this case, we only write stripes of an io_unit to raid disks till the io_unit is the first one whose data/parity is in log. The io_unit list order is important for other cases too. For example, some io_unit are reclaimable and others not. They can be mixed in the list, we shouldn't reuse space of an unreclaimable io_unit. Includes fixes to problems which were... Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: NeilBrown <neilb@suse.com>
2015-10-24raid5: add basic stripe logShaohua Li
This introduces a simple log for raid5. Data/parity writing to raid array first writes to the log, then write to raid array disks. If crash happens, we can recovery data from the log. This can speed up raid resync and fix write hole issue. The log structure is pretty simple. Data/meta data is stored in block unit, which is 4k generally. It has only one type of meta data block. The meta data block can track 3 types of data, stripe data, stripe parity and flush block. MD superblock will point to the last valid meta data block. Each meta data block has checksum/seq number, so recovery can scan the log correctly. We store a checksum of stripe data/parity to the metadata block, so meta data and stripe data/parity can be written to log disk together. otherwise, meta data write must wait till stripe data/parity is finished. For stripe data, meta data block will record stripe data sector and size. Currently the size is always 4k. This meta data record can be made simpler if we just fix write hole (eg, we can record data of a stripe's different disks together), but this format can be extended to support caching in the future, which must record data address/size. For stripe parity, meta data block will record stripe sector. It's size should be 4k (for raid5) or 8k (for raid6). We always store p parity first. This format should work for caching too. flush block indicates a stripe is in raid array disks. Fixing write hole doesn't need this type of meta data, it's for caching extension. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: NeilBrown <neilb@suse.com>
2015-10-24raid5: add a new state for stripe log handlingShaohua Li
When a stripe finishes construction, we write the stripe to raid in ops_run_io normally. With log, we do a bunch of other operations before the stripe is written to raid. Mainly write the stripe to log disk, flush disk cache and so on. The operations are still driven by raid5d and run in the stripe state machine. We introduce a new state for such stripe (trapped into log). The stripe is in this state from the time it first enters ops_run_io (finish construction) to the time it is written to raid. Since we know the state is only for log, we bypass other check/operation in handle_stripe. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: NeilBrown <neilb@suse.com>
2015-10-24raid5: export some functionsShaohua Li
Next several patches use some raid5 functions, rename them with raid5 prefix and export out. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: NeilBrown <neilb@suse.com>
2015-08-31md/raid5: ensure device failure recorded before write request returns.NeilBrown
When a write to one of the devices of a RAID5/6 fails, the failure is recorded in the metadata of the other devices so that after a restart the data on the failed drive wont be trusted even if that drive seems to be working again (maybe a cable was unplugged). Similarly when we record a bad-block in response to a write failure, we must not let the write complete until the bad-block update is safe. Currently there is no interlock between the write request completing and the metadata update. So it is possible that the write will complete, the app will confirm success in some way, and then the machine will crash before the metadata update completes. This is an extremely small hole for a racy to fit in, but it is theoretically possible and so should be closed. So: - set MD_CHANGE_PENDING when requesting a metadata update for a failed device, so we can know with certainty when it completes - queue requests that completed when MD_CHANGE_PENDING is set to only be processed after the metadata update completes - call raid_end_bio_io() on bios in that queue when the time comes. Signed-off-by: NeilBrown <neilb@suse.com>
2015-08-31md/raid5: use bio_list for the list of bios to return.NeilBrown
This will make it easier to splice two lists together which will be needed in future patch. Signed-off-by: NeilBrown <neilb@suse.com>
2015-07-22md/raid5: avoid races when changing cache size.NeilBrown
Cache size can grow or shrink due to various pressures at any time. So when we resize the cache as part of a 'grow' operation (i.e. change the size to allow more devices) we need to blocks that automatic growing/shrinking. So introduce a mutex. auto grow/shrink uses mutex_trylock() and just doesn't bother if there is a blockage. Resizing the whole cache holds the mutex to ensure that the correct number of new stripes is allocated. This bug can result in some stripes not being freed when an array is stopped. This leads to the kmem_cache not being freed and a subsequent array can try to use the same kmem_cache and get confused. Fixes: edbe83ab4c27 ("md/raid5: allow the stripe_cache to grow and shrink.") Cc: stable@vger.kernel.org (4.1 - please delay until 2 weeks after release of 4.2) Signed-off-by: NeilBrown <neilb@suse.com>
2015-06-17md/raid5: per hash value and exclusive wait_for_stripeYuanhan Liu
I noticed heavy spin lock contention at get_active_stripe() with fsmark multiple thread write workloads. Here is how this hot contention comes from. We have limited stripes, and it's a multiple thread write workload. Hence, those stripes will be taken soon, which puts later processes to sleep for waiting free stripes. When enough stripes(>= 1/4 total stripes) are released, all process are woken, trying to get the lock. But there is one only being able to get this lock for each hash lock, making other processes spinning out there for acquiring the lock. Thus, it's effectiveless to wakeup all processes and let them battle for a lock that permits one to access only each time. Instead, we could make it be a exclusive wake up: wake up one process only. That avoids the heavy spin lock contention naturally. To do the exclusive wake up, we've to split wait_for_stripe into multiple wait queues, to make it per hash value, just like the hash lock. Here are some test results I have got with this patch applied(all test run 3 times): `fsmark.files_per_sec' ===================== next-20150317 this patch ------------------------- ------------------------- metric_value ±stddev metric_value ±stddev change testbox/benchmark/testcase-params ------------------------- ------------------------- -------- ------------------------------ 25.600 ±0.0 92.700 ±2.5 262.1% ivb44/fsmark/1x-64t-4BRD_12G-RAID5-btrfs-4M-30G-fsyncBeforeClose 25.600 ±0.0 77.800 ±0.6 203.9% ivb44/fsmark/1x-64t-9BRD_6G-RAID5-btrfs-4M-30G-fsyncBeforeClose 32.000 ±0.0 93.800 ±1.7 193.1% ivb44/fsmark/1x-64t-4BRD_12G-RAID5-ext4-4M-30G-fsyncBeforeClose 32.000 ±0.0 81.233 ±1.7 153.9% ivb44/fsmark/1x-64t-9BRD_6G-RAID5-ext4-4M-30G-fsyncBeforeClose 48.800 ±14.5 99.667 ±2.0 104.2% ivb44/fsmark/1x-64t-4BRD_12G-RAID5-xfs-4M-30G-fsyncBeforeClose 6.400 ±0.0 12.800 ±0.0 100.0% ivb44/fsmark/1x-64t-3HDD-RAID5-btrfs-4M-40G-fsyncBeforeClose 63.133 ±8.2 82.800 ±0.7 31.2% ivb44/fsmark/1x-64t-9BRD_6G-RAID5-xfs-4M-30G-fsyncBeforeClose 245.067 ±0.7 306.567 ±7.9 25.1% ivb44/fsmark/1x-64t-4BRD_12G-RAID5-f2fs-4M-30G-fsyncBeforeClose 17.533 ±0.3 21.000 ±0.8 19.8% ivb44/fsmark/1x-1t-3HDD-RAID5-xfs-4M-40G-fsyncBeforeClose 188.167 ±1.9 215.033 ±3.1 14.3% ivb44/fsmark/1x-1t-4BRD_12G-RAID5-btrfs-4M-30G-NoSync 254.500 ±1.8 290.733 ±2.4 14.2% ivb44/fsmark/1x-1t-9BRD_6G-RAID5-btrfs-4M-30G-NoSync `time.system_time' ===================== next-20150317 this patch ------------------------- ------------------------- metric_value ±stddev metric_value ±stddev change testbox/benchmark/testcase-params ------------------------- ------------------------- -------- ------------------------------ 7235.603 ±1.2 185.163 ±1.9 -97.4% ivb44/fsmark/1x-64t-4BRD_12G-RAID5-btrfs-4M-30G-fsyncBeforeClose 7666.883 ±2.9 202.750 ±1.0 -97.4% ivb44/fsmark/1x-64t-9BRD_6G-RAID5-btrfs-4M-30G-fsyncBeforeClose 14567.893 ±0.7 421.230 ±0.4 -97.1% ivb44/fsmark/1x-64t-3HDD-RAID5-btrfs-4M-40G-fsyncBeforeClose 3697.667 ±14.0 148.190 ±1.7 -96.0% ivb44/fsmark/1x-64t-4BRD_12G-RAID5-xfs-4M-30G-fsyncBeforeClose 5572.867 ±3.8 310.717 ±1.4 -94.4% ivb44/fsmark/1x-64t-9BRD_6G-RAID5-ext4-4M-30G-fsyncBeforeClose 5565.050 ±0.5 313.277 ±1.5 -94.4% ivb44/fsmark/1x-64t-4BRD_12G-RAID5-ext4-4M-30G-fsyncBeforeClose 2420.707 ±17.1 171.043 ±2.7 -92.9% ivb44/fsmark/1x-64t-9BRD_6G-RAID5-xfs-4M-30G-fsyncBeforeClose 3743.300 ±4.6 379.827 ±3.5 -89.9% ivb44/fsmark/1x-64t-3HDD-RAID5-ext4-4M-40G-fsyncBeforeClose 3308.687 ±6.3 363.050 ±2.0 -89.0% ivb44/fsmark/1x-64t-3HDD-RAID5-xfs-4M-40G-fsyncBeforeClose Where, 1x: where 'x' means iterations or loop, corresponding to the 'L' option of fsmark 1t, 64t: where 't' means thread 4M: means the single file size, corresponding to the '-s' option of fsmark 40G, 30G, 120G: means the total test size 4BRD_12G: BRD is the ramdisk, where '4' means 4 ramdisk, and where '12G' means the size of one ramdisk. So, it would be 48G in total. And we made a raid on those ramdisk As you can see, though there are no much performance gain for hard disk workload, the system time is dropped heavily, up to 97%. And as expected, the performance increased a lot, up to 260%, for fast device(ram disk). v2: use bits instead of array to note down wait queue need to wake up. Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-06-17md/raid5: split wait_for_stripe and introduce wait_for_quiescentYuanhan Liu
I noticed heavy spin lock contention at get_active_stripe(), introduced at being wake up stage, where a bunch of processes try to re-hold the spin lock again. After giving some thoughts on this issue, I found the lock could be relieved(and even avoided) if we turn the wait_for_stripe to per waitqueue for each lock hash and make the wake up exclusive: wake up one process each time, which avoids the lock contention naturally. Before go hacking with wait_for_stripe, I found it actually has 2 usages: for the array to enter or leave the quiescent state, and also to wait for an available stripe in each of the hash lists. So this patch splits the first usage off into a separate wait_queue, wait_for_quiescent, and the next patch will turn the second usage into one waitqueue for each hash value, and make it exclusive, to relieve the lock contention. v2: wake_up(wait_for_quiescent) when (active_stripes == 0) Commit log refactor suggestion from Neil. Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-05-28md/raid5: be more selective about distributing flags across batch.NeilBrown
When a batch of stripes is broken up, we keep some of the flags that were per-stripe, and copy other flags from the head to all others. This only happens while a stripe is being handled, so many of the flags are irrelevant. The "SYNC_FLAGS" (which I've renamed to make it clear there are several) and STRIPE_DEGRADED are set per-stripe and so need to be preserved. STRIPE_INSYNC is the only flag that is set on the head that needs to be propagated to all others. For safety, add a WARN_ON if others are set, except: STRIPE_HANDLE - this is safe and per-stripe and we are going to set in several cases anyway STRIPE_INSYNC STRIPE_IO_STARTED - this is just a hint and doesn't hurt. STRIPE_ON_PLUG_LIST STRIPE_ON_RELEASE_LIST - It is a point pointless for a batched stripe to be on one of these lists, but it can happen as can be safely ignored. Signed-off-by: NeilBrown <neilb@suse.de>
2015-05-28md/raid5: close race between STRIPE_BIT_DELAY and batching.NeilBrown
When we add a write to a stripe we need to make sure the bitmap bit is set. While doing that the stripe is not locked so it could be added to a batch after which further changes to STRIPE_BIT_DELAY and ->bm_seq are ineffective. So we need to hold off adding to a stripe until bitmap_startwrite has completed at least once, and we need to avoid further changes to STRIPE_BIT_DELAY once the stripe has been added to a batch. If a bitmap_startwrite() completes after the stripe was added to a batch, it will not have set the bit, only incremented a counter, so no extra delay of the stripe is needed. Reported-by: Shaohua Li <shli@kernel.org> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22md/raid5: allow the stripe_cache to grow and shrink.NeilBrown
The default setting of 256 stripe_heads is probably much too small for many configurations. So it is best to make it auto-configure. Shrinking the cache under memory pressure is easy. The only interesting part here is that we put a fairly high cost ('seeks') on shrinking the cache as the cost is greater than just having to read more data, it reduces parallelism. Growing the cache on demand needs to be done carefully. If we allow fast growth, that can upset memory balance as lots of dirty memory can quickly turn into lots of memory queued in the stripe_cache. It is important for the raid5 block device to appear congested to allow write-throttling to work. So we only add stripes slowly. We set a flag when an allocation fails because all stripes are in use, allocate at a convenient time when that flag is set, and don't allow it to be set again until at least one stripe_head has been released for re-use. This means that a spurt of requests will only cause one stripe_head to be allocated, but a steady stream of requests will slowly increase the cache size - until memory pressure puts it back again. It could take hours to reach a steady state. The value written to, and displayed in, stripe_cache_size is used as a minimum. The cache can grow above this and shrink back down to it. The actual size is not directly visible, though it can be deduced to some extent by watching stripe_cache_active. Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22md/raid5: change ->inactive_blocked to a bit-flag.NeilBrown
This allows us to easily add more (atomic) flags. Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22md/raid5: introduce configuration option rmw_levelMarkus Stockhausen
Depending on the available coding we allow optimized rmw logic for write operations. To support easier testing this patch allows manual control of the rmw/rcw descision through the interface /sys/block/mdX/md/rmw_level. The configuration can handle three levels of control. rmw_level=0: Disable rmw for all RAID types. Hardware assisted P/Q calculation has no implementation path yet to factor in/out chunks of a syndrome. Enforcing this level can be benefical for slow CPUs with hardware syndrome support and fast SSDs. rmw_level=1: Estimate rmw IOs and rcw IOs. Execute rmw only if we will save IOs. This equals the "old" unpatched behaviour and will be the default. rmw_level=2: Execute rmw even if calculated IOs for rmw and rcw are equal. We might have higher CPU consumption because of calculating the parity twice but it can be benefical otherwise. E.g. RAID4 with fast dedicated parity disk/SSD. The option is implemented just to be forward-looking and will ONLY work with this patch! Signed-off-by: Markus Stockhausen <stockhausen@collogia.de> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22md/raid5: activate raid6 rmw featureMarkus Stockhausen
Glue it altogehter. The raid6 rmw path should work the same as the already existing raid5 logic. So emulate the prexor handling/flags and split functions as needed. 1) Enable xor_syndrome() in the async layer. 2) Split ops_run_prexor() into RAID4/5 and RAID6 logic. Xor the syndrome at the start of a rmw run as we did it before for the single parity. 3) Take care of rmw run in ops_run_reconstruct6(). Again process only the changed pages to get syndrome back into sync. 4) Enhance set_syndrome_sources() to fill NULL pages if we are in a rmw run. The lower layers will calculate start & end pages from that and call the xor_syndrome() correspondingly. 5) Adapt the several places where we ignored Q handling up to now. Performance numbers for a single E5630 system with a mix of 10 7200k desktop/server disks. 300 seconds random write with 8 threads onto a 3,2TB (10*400GB) RAID6 64K chunk without spare (group_thread_cnt=4) bsize rmw_level=1 rmw_level=0 rmw_level=1 rmw_level=0 skip_copy=1 skip_copy=1 skip_copy=0 skip_copy=0 4K 115 KB/s 141 KB/s 165 KB/s 140 KB/s 8K 225 KB/s 275 KB/s 324 KB/s 274 KB/s 16K 434 KB/s 536 KB/s 640 KB/s 534 KB/s 32K 751 KB/s 1,051 KB/s 1,234 KB/s 1,045 KB/s 64K 1,339 KB/s 1,958 KB/s 2,282 KB/s 1,962 KB/s 128K 2,673 KB/s 3,862 KB/s 4,113 KB/s 3,898 KB/s 256K 7,685 KB/s 7,539 KB/s 7,557 KB/s 7,638 KB/s 512K 19,556 KB/s 19,558 KB/s 19,652 KB/s 19,688 Kb/s Signed-off-by: Markus Stockhausen <stockhausen@collogia.de> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22raid5: handle expansion/resync case with stripe batchingshli@kernel.org
expansion/resync can grab a stripe when the stripe is in batch list. Since all stripes in batch list must be in the same state, we can't allow some stripes run into expansion/resync. So we delay expansion/resync for stripe in batch list. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22raid5: handle io error of batch listshli@kernel.org
If io error happens in any stripe of a batch list, the batch list will be split, then normal process will run for the stripes in the list. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22RAID5: batch adjacent full stripe writeshli@kernel.org
stripe cache is 4k size. Even adjacent full stripe writes are handled in 4k unit. Idealy we should use big size for adjacent full stripe writes. Bigger stripe cache size means less stripes runing in the state machine so can reduce cpu overhead. And also bigger size can cause bigger IO size dispatched to under layer disks. With below patch, we will automatically batch adjacent full stripe write together. Such stripes will be added to the batch list. Only the first stripe of the list will be put to handle_list and so run handle_stripe(). Some steps of handle_stripe() are extended to cover all stripes of the list, including ops_run_io, ops_run_biodrain and so on. With this patch, we have less stripes running in handle_stripe() and we send IO of whole stripe list together to increase IO size. Stripes added to a batch list have some limitations. A batch list can only include full stripe write and can't cross chunk boundary to make sure stripes have the same parity disks. Stripes in a batch list must be in the same state (no written, toread and so on). If a stripe is in a batch list, all new read/write to add_stripe_bio will be blocked to overlap conflict till the batch list is handled. The limitations will make sure stripes in a batch list be in exactly the same state in the life circly. I did test running 160k randwrite in a RAID5 array with 32k chunk size and 6 PCIe SSD. This patch improves around 30% performance and IO size to under layer disk is exactly 32k. I also run a 4k randwrite test in the same array to make sure the performance isn't changed with the patch. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22raid5: track overwrite disk countshli@kernel.org
Track overwrite disk count, so we can know if a stripe is a full stripe write. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22raid5: add a new flag to track if a stripe can be batchedshli@kernel.org
A freshly new stripe with write request can be batched. Any time the stripe is handled or new read is queued, the flag will be cleared. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-22raid5: use flex_array for scribble datashli@kernel.org
Use flex_array for scribble data. Next patch will batch several stripes together, so scribble data should be able to cover several stripes, so this patch also allocates scribble data for stripes across a chunk. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2015-02-04md: make ->congested robust against personality changes.NeilBrown
There is currently no locking around calls to the 'congested' bdi function. If called at an awkward time while an array is being converted from one level (or personality) to another, there is a tiny chance of running code in an unreferenced module etc. So add a 'congested' function to the md_personality operations structure, and call it with appropriate locking from a central 'mddev_congested'. When the array personality is changing the array will be 'suspended' so no IO is processed. If mddev_congested detects this, it simply reports that the array is congested, which is a safe guess. As mddev_suspend calls synchronize_rcu(), mddev_congested can avoid races by included the whole call inside an rcu_read_lock() region. This require that the congested functions for all subordinate devices can be run under rcu_lock. Fortunately this is the case. Signed-off-by: NeilBrown <neilb@suse.de>
2014-10-14md: remove unwanted white space from md.cNeilBrown
My editor shows much of this is RED. Signed-off-by: NeilBrown <neilb@suse.de>
2014-05-29raid5: add an option to avoid copy data from bio to stripe cacheShaohua Li
The stripe cache has two goals: 1. cache data, so next time if data can be found in stripe cache, disk access can be avoided. 2. stable data. data is copied from bio to stripe cache and calculated parity. data written to disk is from stripe cache, so if upper layer changes bio data, data written to disk isn't impacted. In my environment, I can guarantee 2 will not happen. And BDI_CAP_STABLE_WRITES can guarantee 2 too. For 1, it's not common too. block plug mechanism will dispatch a bunch of sequentail small requests together. And since I'm using SSD, I'm using small chunk size. It's rare case stripe cache is really useful. So I'd like to avoid the copy from bio to stripe cache and it's very helpful for performance. In my 1M randwrite tests, avoid the copy can increase the performance more than 30%. Of course, this shouldn't be enabled by default. It's reported enabling BDI_CAP_STABLE_WRITES can harm some workloads before, so I added an option to control it. Neilb: changed BUG_ON to WARN_ON Removed some assignments from raid5_build_block which are now not needed. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-11-20Merge tag 'md/3.13' of git://neil.brown.name/mdLinus Torvalds
Pull md update from Neil Brown: "Mostly optimisations and obscure bug fixes. - raid5 gets less lock contention - raid1 gets less contention between normal-io and resync-io during resync" * tag 'md/3.13' of git://neil.brown.name/md: md/raid5: Use conf->device_lock protect changing of multi-thread resources. md/raid5: Before freeing old multi-thread worker, it should flush them. md/raid5: For stripe with R5_ReadNoMerge, we replace REQ_FLUSH with REQ_NOMERGE. UAPI: include <asm/byteorder.h> in linux/raid/md_p.h raid1: Rewrite the implementation of iobarrier. raid1: Add some macros to make code clearly. raid1: Replace raise_barrier/lower_barrier with freeze_array/unfreeze_array when reconfiguring the array. raid1: Add a field array_frozen to indicate whether raid in freeze state. md: Convert use of typedef ctl_table to struct ctl_table md/raid5: avoid deadlock when raid5 array has unack badblocks during md_stop_writes. md: use MD_RECOVERY_INTR instead of kthread_should_stop in resync thread. md: fix some places where mddev_lock return value is not checked. raid5: Retry R5_ReadNoMerge flag when hit a read error. raid5: relieve lock contention in get_active_stripe() raid5: relieve lock contention in get_active_stripe() wait: add wait_event_cmd() md/raid5.c: add proper locking to error path of raid5_start_reshape. md: fix calculation of stacking limits on level change. raid5: Use slow_path to release stripe when mddev->thread is null
2013-11-19raid5: relieve lock contention in get_active_stripe()Shaohua Li
track empty inactive list count, so md_raid5_congested() can use it to make decision. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual earth-shaking, news-breaking, rocket science pile from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: usb: Fix typo in Documentation/usb/gadget_configs.txt doc: add missing files to timers/00-INDEX timekeeping: Fix some trivial typos in comments mm: Fix some trivial typos in comments irq: Fix some trivial typos in comments NUMA: fix typos in Kconfig help text mm: update 00-INDEX doc: Documentation/DMA-attributes.txt fix typo DRM: comment: `halve' -> `half' Docs: Kconfig: `devlopers' -> `developers' doc: typo on word accounting in kprobes.c in mutliple architectures treewide: fix "usefull" typo treewide: fix "distingush" typo mm/Kconfig: Grammar s/an/a/ kexec: Typo s/the/then/ Documentation/kvm: Update cpuid documentation for steal time and pv eoi treewide: Fix common typo in "identify" __page_to_pfn: Fix typo in comment Correct some typos for word frequency clk: fixed-factor: Fix a trivial typo ...
2013-11-14raid5: relieve lock contention in get_active_stripe()Shaohua Li
get_active_stripe() is the last place we have lock contention. It has two paths. One is stripe isn't found and new stripe is allocated, the other is stripe is found. The first path basically calls __find_stripe and init_stripe. It accesses conf->generation, conf->previous_raid_disks, conf->raid_disks, conf->prev_chunk_sectors, conf->chunk_sectors, conf->max_degraded, conf->prev_algo, conf->algorithm, the stripe_hashtbl and inactive_list. Except stripe_hashtbl and inactive_list, other fields are changed very rarely. With this patch, we split inactive_list and add new hash locks. Each free stripe belongs to a specific inactive list. Which inactive list is determined by stripe's lock_hash. Note, even a stripe hasn't a sector assigned, it has a lock_hash assigned. Stripe's inactive list is protected by a hash lock, which is determined by it's lock_hash too. The lock_hash is derivied from current stripe_hashtbl hash, which guarantees any stripe_hashtbl list will be assigned to a specific lock_hash, so we can use new hash lock to protect stripe_hashtbl list too. The goal of the new hash locks introduced is we can only use the new locks in the first path of get_active_stripe(). Since we have several hash locks, lock contention is relieved significantly. The first path of get_active_stripe() accesses other fields, since they are changed rarely, changing them now need take conf->device_lock and all hash locks. For a slow path, this isn't a problem. If we need lock device_lock and hash lock, we always lock hash lock first. The tricky part is release_stripe and friends. We need take device_lock first. Neil's suggestion is we put inactive stripes to a temporary list and readd it to inactive_list after device_lock is released. In this way, we add stripes to temporary list with device_lock hold and remove stripes from the list with hash lock hold. So we don't allow concurrent access to the temporary list, which means we need allocate temporary list for all participants of release_stripe. One downside is free stripes are maintained in their inactive list, they can't across between the lists. By default, we have total 256 stripes and 8 lists, so each list will have 32 stripes. It's possible one list has free stripe but other list hasn't. The chance should be rare because stripes allocation are even distributed. And we can always allocate more stripes for cache, several mega bytes memory isn't a big deal. This completely removes the lock contention of the first path of get_active_stripe(). It slows down the second code path a little bit though because we now need takes two locks, but since the hash lock isn't contended, the overhead should be quite small (several atomic instructions). The second path of get_active_stripe() (basically sequential write or big request size randwrite) still has lock contentions. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-10-14treewide: fix "distingush" typoMichael Opdenacker
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-09-02raid5: only wakeup necessary threadsShaohua Li
If there are not enough stripes to handle, we'd better not always queue all available work_structs. If one worker can only handle small or even none stripes, it will impact request merge and create lock contention. With this patch, the number of work_struct running will depend on pending stripes number. Note: some statistics info used in the patch are accessed without locking protection. This should doesn't matter, we just try best to avoid queue unnecessary work_struct. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-08-28md/raid5: use seqcount to protect access to shape in make_request.NeilBrown
make_request() access various shape parameters (raid_disks, chunk_size etc) which might be changed by raid5_start_reshape(). If the later is called at and awkward time during the form, the wrong stripe_head might be used. So introduce a 'seqcount' and after finding a stripe_head make sure there is no reason to expect that we got the wrong one. Signed-off-by: NeilBrown <neilb@suse.de>
2013-08-28raid5: offload stripe handle to workqueueShaohua Li
This is another attempt to create multiple threads to handle raid5 stripes. This time I use workqueue. raid5 handles request (especially write) in stripe unit. A stripe is page size aligned/long and acrosses all disks. Writing to any disk sector, raid5 runs a state machine for the corresponding stripe, which includes reading some disks of the stripe, calculating parity, and writing some disks of the stripe. The state machine is running in raid5d thread currently. Since there is only one thread, it doesn't scale well for high speed storage. An obvious solution is multi-threading. To get better performance, we have some requirements: a. locality. stripe corresponding to request submitted from one cpu is better handled in thread in local cpu or local node. local cpu is preferred but some times could be a bottleneck, for example, parity calculation is too heavy. local node running has wide adaptability. b. configurablity. Different setup of raid5 array might need diffent configuration. Especially the thread number. More threads don't always mean better performance because of lock contentions. My original implementation is creating some kernel threads. There are interfaces to control which cpu's stripe each thread should handle. And userspace can set affinity of the threads. This provides biggest flexibility and configurability. But it's hard to use and apparently a new thread pool implementation is disfavor. Recent workqueue improvement is quite promising. unbound workqueue will be bound to numa node. If WQ_SYSFS is set in workqueue, there are sysfs option to do affinity setting. For example, we can only include one HT sibling in affinity. Since work is non-reentrant by default, and we can control running thread number by limiting dispatched work_struct number. In this patch, I created several stripe worker group. A group is a numa node. stripes from cpus of one node will be added to a group list. Workqueue thread of one node will only handle stripes of worker group of the node. In this way, stripe handling has numa node locality. And as I said, we can control thread number by limiting dispatched work_struct number. The work_struct callback function handles several stripes in one run. A typical work queue usage is to run one unit in each work_struct. In raid5 case, the unit is a stripe. But we can't do that: a. Though handling a stripe doesn't need lock because of reference accounting and stripe isn't in any list, queuing a work_struct for each stripe will make workqueue lock contended very heavily. b. blk_start_plug()/blk_finish_plug() should surround stripe handle, as we might dispatch request. If each work_struct only handles one stripe, such block plug is meaningless. This implementation can't do very fine grained configuration. But the numa binding is most popular usage model, should be enough for most workloads. Note: since we have only one stripe queue, switching to multi-thread might decrease request size dispatching down to low level layer. The impact depends on thread number, raid configuration and workload. So multi-thread raid5 might not be proper for all setups. Changes V1 -> V2: 1. remove WQ_NON_REENTRANT 2. disabling multi-threading by default 3. Add more descriptions in changelog Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-08-28raid5: make release_stripe locklessShaohua Li
release_stripe still has big lock contention. We just add the stripe to a llist without taking device_lock. We let the raid5d thread to do the real stripe release, which must hold device_lock anyway. In this way, release_stripe doesn't hold any locks. The side effect is the released stripes order is changed. But sounds not a big deal, stripes are never handled in order. And I thought block layer can already do nice request merge, which means order isn't that important. I kept the unplug release batch, which is unnecessary with this patch from lock contention avoid point of view, and actually if we delete it, the stripe_head release_list and lru can share storage. But the unplug release batch is also helpful for request merge. We probably can delay wakeup raid5d till unplug, but I'm still afraid of the case which raid5d is running. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-07-25md/raid5: fix interaction of 'replace' and 'recovery'.NeilBrown
If a device in a RAID4/5/6 is being replaced while another is being recovered, then the writes to the replacement device currently don't happen, resulting in corruption when the replacement completes and the new drive takes over. This is because the replacement writes are only triggered when 's.replacing' is set and not when the similar 's.sync' is set (which is the case during resync and recovery - it means all devices need to be read). So schedule those writes when s.replacing is set as well. In this case we cannot use "STRIPE_INSYNC" to record that the replacement has happened as that is needed for recording that any parity calculation is complete. So introduce STRIPE_REPLACED to record if the replacement has happened. For safety we should also check that STRIPE_COMPUTE_RUN is not set. This has a similar effect to the "s.locked == 0" test. The latter ensure that now IO has been flagged but not started. The former checks if any parity calculation has been flagged by not started. We must wait for both of these to complete before triggering the 'replace'. Add a similar test to the subsequent check for "are we finished yet". This possibly isn't needed (is subsumed in the STRIPE_INSYNC test), but it makes it more obvious that the REPLACE will happen before we think we are finished. Finally if a NeedReplace device is not UPTODATE then that is an error. We really must trigger a warning. This bug was introduced in commit 9a3e1101b827a59ac9036a672f5fa8d5279d0fe2 (md/raid5: detect and handle replacements during recovery.) which introduced replacement for raid5. That was in 3.3-rc3, so any stable kernel since then would benefit from this fix. Cc: stable@vger.kernel.org (3.3+) Reported-by: qindehua <13691222965@163.com> Tested-by: qindehua <qindehua@163.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-03-20md: remove CONFIG_MULTICORE_RAID456 entirelyPaul Bolle
Once instance of this Kconfig macro remained after commit 51acbcec6c42b24482bac18e42befc822524535d ("md: remove CONFIG_MULTICORE_RAID456"). Remove that one too. And, while we're at it, also remove it from the defconfig files that carry it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: NeilBrown <neilb@suse.de>
2013-03-20md/raid5: ensure sync and DISCARD don't happen at the same time.NeilBrown
A number of problems can occur due to races between resync/recovery and discard. - if sync_request calls handle_stripe() while a discard is happening on the stripe, it might call handle_stripe_clean_event before all of the individual discard requests have completed (so some devices are still locked, but not all). Since commit ca64cae96037de16e4af92678814f5d4bf0c1c65 md/raid5: Make sure we clear R5_Discard when discard is finished. this will cause R5_Discard to be cleared for the parity device, so handle_stripe_clean_event() will not be called when the other devices do become unlocked, so their ->written will not be cleared. This ultimately leads to a WARN_ON in init_stripe and a lock-up. - If handle_stripe_clean_event() does clear R5_UPTODATE at an awkward time for resync, it can lead to s->uptodate being less than disks in handle_parity_checks5(), which triggers a BUG (because it is one). So: - keep R5_Discard on the parity device until all other devices have completed their discard request - make sure we don't try to have a 'discard' and a 'sync' action at the same time. This involves a new stripe flag to we know when a 'discard' is happening, and the use of R5_Overlap on the parity disk so when a discard is wanted while a sync is active, so we know to wake up the discard at the appropriate time. Discard support for RAID5 was added in 3.7, so this is suitable for any -stable kernel since 3.7. Cc: stable@vger.kernel.org (v3.7+) Reported-by: Jes Sorensen <Jes.Sorensen@redhat.com> Tested-by: Jes Sorensen <Jes.Sorensen@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11MD: raid5 trim supportShaohua Li
Discard for raid4/5/6 has limitation. If discard request size is small, we do discard for one disk, but we need calculate parity and write parity disk. To correctly calculate parity, zero_after_discard must be guaranteed. Even it's true, we need do discard for one disk but write another disks, which makes the parity disks wear out fast. This doesn't make sense. So an efficient discard for raid4/5/6 should discard all data disks and parity disks, which requires the write pattern to be (A, A+chunk_size, A+chunk_size*2...). If A's size is smaller than chunk_size, such pattern is almost impossible in practice. So in this patch, I only handle the case that A's size equals to chunk_size. That is discard request should be aligned to stripe size and its size is multiple of stripe size. Since we can only handle request with specific alignment and size (or part of the request fitting stripes), we can't guarantee zero_after_discard even zero_after_discard is true in low level drives. The block layer doesn't send down correctly aligned requests even correct discard alignment is set, so I must filter out. For raid4/5/6 parity calculation, if data is 0, parity is 0. So if zero_after_discard is true for all disks, data is consistent after discard. Otherwise, data might be lost. Let's consider a scenario: discard a stripe, write data to one disk and write parity disk. The stripe could be still inconsistent till then depending on using data from other data disks or parity disks to calculate new parity. If the disk is broken, we can't restore it. So in this patch, we only enable discard support if all disks have zero_after_discard. If discard fails in one disk, we face the similar inconsistent issue above. The patch will make discard follow the same path as normal write request. If discard fails, a resync will be scheduled to make the data consistent. This isn't good to have extra writes, but data consistency is important. If a subsequent read/write request hits raid5 cache of a discarded stripe, the discarded dev page should have zero filled, so the data is consistent. This patch will always zero dev page for discarded request stripe. This isn't optimal because discard request doesn't need such payload. Next patch will avoid it. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-08-02Merge tag 'md-3.6' of git://neil.brown.name/mdLinus Torvalds
Pull additional md update from NeilBrown: "This contains a few patches that depend on plugging changes in the block layer so needed to wait for those. It also contains a Kconfig fix for the new RAID10 support in dm-raid." * tag 'md-3.6' of git://neil.brown.name/md: md/dm-raid: DM_RAID should select MD_RAID10 md/raid1: submit IO from originating thread instead of md thread. raid5: raid5d handle stripe in batch way raid5: make_request use batch stripe release
2012-08-02raid5: make_request use batch stripe releaseShaohua Li
make_request() does stripe release for every stripe and the stripe usually has count 1, which makes previous release_stripe() optimization not work. In my test, this release_stripe() becomes the heaviest pleace to take conf->device_lock after previous patches applied. Below patch makes stripe release batch. All the stripes will be released in unplug. The STRIPE_ON_UNPLUG_LIST bit is to protect concurrent access stripe lru. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-07-31raid5: Add R5_ReadNoMerge flag which prevent bio from merging at block layermajianpeng
Because bios will merge at block-layer,so bios-error may caused by other bio which be merged into to the same request. Using this flag,it will find exactly error-sector and not do redundant operation like re-write and re-read. V0->V1:Using REQ_FLUSH instead REQ_NOMERGE avoid bio merging at block layer. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-07-19raid5: add a per-stripe lockShaohua Li
Add a per-stripe lock to protect stripe specific data. The purpose is to reduce lock contention of conf->device_lock. stripe ->toread, ->towrite are protected by per-stripe lock. Accessing bio list of the stripe is always serialized by this lock, so adding bio to the lists (add_stripe_bio()) and removing bio from the lists (like ops_run_biofill()) not race. If bio in ->read, ->written ... list are not shared by multiple stripes, we don't need any lock to protect ->read, ->written, because STRIPE_ACTIVE will protect them. If the bio are shared, there are two protections: 1. bi_phys_segments acts as a reference count 2. traverse the list uses r5_next_bio, which makes traverse never access bio not belonging to the stripe Let's have an example: | stripe1 | stripe2 | stripe3 | ...bio1......|bio2|bio3|....bio4..... stripe2 has 4 bios, when it's finished, it will decrement bi_phys_segments for all bios, but only end_bio for bio2 and bio3. bio1->bi_next still points to bio2, but this doesn't matter. When stripe1 is finished, it will not touch bio2 because of r5_next_bio check. Next time stripe1 will end_bio for bio1 and stripe3 will end_bio bio4. before add_stripe_bio() addes a bio to a stripe, we already increament the bio bi_phys_segments, so don't worry other stripes release the bio. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-05-22raid5: support sync requestShaohua Li
REQ_SYNC is ignored in current raid5 code. Block layer does use it to do policy, for example ioscheduler. This patch adds it. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-05-21md/raid5: allow for change in data_offset while managing a reshape.NeilBrown
The important issue here is incorporating the different in data_offset into calculations concerning when we might need to over-write data that is still thought to be valid. To this end we find the minimum offset difference across all devices and add that where appropriate. Signed-off-by: NeilBrown <neilb@suse.de>
2011-12-23md/raid5: detect and handle replacements during recovery.NeilBrown
During recovery we want to write to the replacement but not the original. So we have two new flags - R5_NeedReplace if this stripe has a replacement that needs to be written at some stage - R5_WantReplace if NeedReplace, and the data is available, and a 'sync' has been requested on this stripe. We also distinguish between 'sync and replace' which need to read all other devices, and 'replace' which only needs to read the devices being replaced. Note that during resync we always write to any replacement device. It might not need to be written to, but as we don't read to compare, we have to write to be sure. Signed-off-by: NeilBrown <neilb@suse.de>
2011-12-23md/raid5: writes should get directed to replacement as well as original.NeilBrown
When writing, we need to submit two writes, one to the original, and one to the replacement - if there is a replacement. If the write to the replacement results in a write error, we just fail the device. We only try to record write errors to the original. When writing for recovery, we shouldn't write to the original. This will be addressed in a subsequent patch that generally addresses recovery. Reviewed-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
