path: root/drivers/md
2010-04-23md/raid5: fix previous patch.NeilBrown
Previous patch changes stripe and chunk_number to sector_t but mistakenly did not update all of the divisions to use sector_dev(). This patch changes all the those divisions (actually the '%' operator) to sector_div. Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@kernel.org Tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
2010-04-20md/raid5: allow for more than 2^31 chunks.NeilBrown
With many large drives and small chunk sizes it is possible to create a RAID5 with more than 2^31 chunks. Make sure this works. Reported-by: Brett King <king.br@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@kernel.org
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-18Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: deal with merge_bvec_fn in component devices better.
2010-03-16md: deal with merge_bvec_fn in component devices better.NeilBrown
If a component device has a merge_bvec_fn then as we never call it we must ensure we never need to. Currently this is done by setting max_sector to 1 PAGE, however this does not stop a bio being created with several sub-page iovecs that would violate the merge_bvec_fn. So instead set max_segments to 1 and set the segment boundary to the same as a page boundary to ensure there is only ever one single-page segment of IO requested at a time. This can particularly be an issue when 'xen' is used as it is known to submit multiple small buffers in a single bio. Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@kernel.org
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-06dm raid1: fix deadlock when suspending failed deviceTakahiro Yasui
To prevent deadlock, bios in the hold list should be flushed before dm_rh_stop_recovery() is called in mirror_suspend(). The recovery can't start because there are pending bios and therefore dm_rh_stop_recovery deadlocks. When there are pending bios in the hold list, the recovery waits for the completion of the bios after recovery_count is acquired. The recovery_count is released when the recovery finished, however, the bios in the hold list are processed after dm_rh_stop_recovery() in mirror_presuspend(). dm_rh_stop_recovery() also acquires recovery_count, then deadlock occurs. Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Mikulas Patocka <mpatocka@redhat.com>
2010-03-06dm: eliminate some holes data structuresMike Snitzer
Eliminate a 4-byte hole in 'struct dm_io_memory' by moving 'offset' above the 'ptr' to which it applies (size reduced from 24 to 16 bytes). And by association, 1-4 byte hole is eliminated in 'struct dm_io_request' (size reduced from 56 to 48 bytes). Eliminate all 6 4-byte holes and 1 cache-line in 'struct dm_snapshot' (size reduced from 392 to 368 bytes). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm ioctl: introduce flag indicating uevent was generatedPeter Rajnoha
Set a new DM_UEVENT_GENERATED_FLAG when returning from ioctls to indicate that a uevent was actually generated. This tells the userspace caller that it may need to wait for the event to be processed. Signed-off-by: Peter Rajnoha <prajnoha@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm: free dm_io before bio_endio not afterMikulas Patocka
Free the dm_io structure before calling bio_endio() instead of after it, to ensure that the io_pool containing it is not referenced after it is freed. This partially fixes a problem described here https://www.redhat.com/archives/dm-devel/2010-February/msg00109.html thread 1: bio_endio(bio, io_error); /* scheduling happens */ thread 2: close the device remove the device thread 1: free_io(md, io); Thread 2, when removing the device, sees non-empty md->io_pool (because the io hasn't been freed by thread 1 yet) and may crash with BUG in mempool_free. Thread 1 may also crash, when freeing into a nonexisting mempool. To fix this we must make sure that bio_endio() is the last call and the md structure is not accessed afterwards. There is another bio_endio in process_barrier, but it is called from the thread and the thread is destroyed prior to freeing the mempools, so this call is not affected by the bug. A similar bug exists with module unloads - the module may be unloaded immediately after bio_endio - but that is more difficult to fix. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm table: remove unused dm_get_device range parametersNikanth Karthikesan
Remove unused parameters(start and len) of dm_get_device() and fix the callers. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm ioctl: only issue uevent on resume if state changedMike Snitzer
Only issue a uevent on a resume if the state of the device changed, i.e. if it was suspended and/or its table was replaced. Signed-off-by: Dave Wysochanski <dwysocha@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm raid1: always return error if all legs failMikulas Patocka
If all mirror legs fail, always return an error instead of holding the bio, even if the handle_errors option was set. At present it is the responsibility of the driver underneath us to deal with retries, multipath etc. The patch adds the bio to the failures list instead of holding it directly. do_failures tests first if all legs failed and, if so, returns the bio with -EIO. If any leg is still alive and handle_errors is set, do_failures calls hold_bio. Reviewed-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: refactor pg_initKiyoshi Ueda
This patch pulls the pg_init path activation code out of process_queued_ios() into a new function. No functional change. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: wait for pg_init completion when suspendingKiyoshi Ueda
When suspending the device we must wait for all I/O to complete, but pg-init may be still in progress even after flushing the workqueue for kmpath_handlerd in multipath_postsuspend. This patch waits for pg-init completion correctly in multipath_postsuspend(). Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: hold io until all pg_inits completedKiyoshi Ueda
m->queue_io is set to block processing I/Os, and it needs to be kept while pg-init, which issues multiple path activations, is in progress. But m->queue is cleared when a path activation completes without error in pg_init_done(), even while other path activations are in progress. That may cause undesired -EIO on paths which are not complete activation. This patch fixes that by not clearing m->queue_io until all path activations complete. (Before the hardware handlers were moved into the SCSI layer, pg_init only used one path.) Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: avoid storing private suspended stateKiyoshi Ueda
'suspended' flag in struct multipath was introduced to check whether the multipath target is in suspended state, but the same check is done through dm_suspended() now, so remove the flag and related code. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm table: remove dm_get from dm_table_get_mdKiyoshi Ueda
Remove the dm_get() in dm_table_get_md() because dm_table_get_md() could be called from presuspend/postsuspend, which are called while mapped_device is in DMF_FREEING state, where dm_get() is not allowed. Justification for that is the lifetime of both objects: As far as the current dm design/implementation, mapped_device is never freed while targets are doing something, because dm core waits for targets to become quiet in dm_put() using presuspend/postsuspend. So targets should be able to touch mapped_device without holding reference count of the mapped_device, and we should allow targets to touch mapped_device even if it is in DMF_FREEING state. Backgrounds: I'm trying to remove the multipath internal queue, since dm core now has a generic queue for request-based dm. In the patch-set, the multipath target wants to request dm core to start/stop queue. One of such start/stop requests can happen during postsuspend() while the target waits for pg-init to complete, because the target stops queue when starting pg-init and tries to restart it when completing pg-init. Since queue belongs to mapped_device, it involves calling dm_table_get_md() and dm_put(). On the other hand, postsuspend() is called in dm_put() for mapped_device which is in DMF_FREEING state, and that triggers BUG_ON(DMF_FREEING) in the 2nd dm_put(). I had tried to solve this problem by changing only multipath not to touch mapped_device which is in DMF_FREEING state, but I couldn't and I came up with a question why we need dm_get() in dm_table_get_md(). Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: skip activate_path for failed pathsMoger, Babu
This patch adds two minor fixes while processing device mapper path activation. Skip failed paths while calling activate_path. If the path is already failed then activate_path will fail for sure. We don't have to call in that case. In some case this might cause prolonged retries unnecessarily. Change the misleading message if the path being activated fails with SCSI_DH_NOSYS. Signed-off-by: Babu Moger <babu.moger@lsi.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm mpath: pass struct pgpath to pg init doneMoger, Babu
This patch removes some unnecessary argument casting. There is no functional change with this patch. Passes 'struct pgpath' through to pg_init_done() instead of the enclosed 'struct dm_path'. Tested the changes with LSI storage.. CC: Chandra Seetharaman <chandra.seetharaman@us.ibm.com> Signed-off-by: Babu Moger <babu.moger@lsi.com> Acked-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: add __percpu sparse annotations to what's left percpu: add __percpu sparse annotations to fs percpu: add __percpu sparse annotations to core kernel subsystems local_t: Remove leftover local.h this_cpu: Remove pageset_notifier this_cpu: Page allocator conversion percpu, x86: Generic inc / dec percpu instructions local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c module: Use this_cpu_xx to dynamically allocate counters local_t: Remove cpu_local_xx macros percpu: refactor the code in pcpu_[de]populate_chunk() percpu: remove compile warnings caused by __verify_pcpu_ptr() percpu: make accessors check for percpu pointer in sparse percpu: add __percpu for sparse. percpu: make access macros universal percpu: remove per_cpu__ prefix.
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-17percpu: add __percpu sparse annotations to what's leftTejun Heo
Add __percpu sparse annotations to places which didn't make it in one of the previous patches. All converions are trivial. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Neil Brown <neilb@suse.de>
2010-02-16dm: sysfs revert add empty release function to avoid debug warningAlasdair G Kergon
Revert commit d2bb7df8cac647b92f51fb84ae735771e7adbfa7 at Greg's request. Author: Milan Broz <mbroz@redhat.com> Date: Thu Dec 10 23:51:53 2009 +0000 dm: sysfs add empty release function to avoid debug warning This patch just removes an unnecessary warning: kobject: 'dm': does not have a release() function, it is broken and must be fixed. The kobject is embedded in mapped device struct, so code does not need to release memory explicitly here. Cc: Greg KH <gregkh@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-16dm mpath: fix stall when requeueing ioKiyoshi Ueda
This patch fixes the problem that system may stall if target's ->map_rq returns DM_MAPIO_REQUEUE in map_request(). E.g. stall happens on 1 CPU box when a dm-mpath device with queue_if_no_path bounces between all-paths-down and paths-up on I/O load. When target's ->map_rq returns DM_MAPIO_REQUEUE, map_request() requeues the request and returns to dm_request_fn(). Then, dm_request_fn() doesn't exit the I/O dispatching loop and continues processing the requeued request again. This map and requeue loop can be done with interrupt disabled, so 1 CPU system can be stalled if this situation happens. For example, commands below can stall my 1 CPU box within 1 minute or so: # dmsetup table mp mp: 0 2097152 multipath 1 queue_if_no_path 0 1 1 service-time 0 1 2 8:144 1 1 # while true; do dd if=/dev/mapper/mp of=/dev/null bs=1M count=100; done & # while true; do \ > dmsetup message mp 0 "fail_path 8:144" \ > dmsetup suspend --noflush mp \ > dmsetup resume mp \ > dmsetup message mp 0 "reinstate_path 8:144" \ > done To fix the problem above, this patch changes dm_request_fn() to exit the I/O dispatching loop once if a request is requeued in map_request(). Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-16dm raid1: fix null pointer dereference in suspendTakahiro Yasui
When suspending a failed mirror, bios are completed by mirror_end_io() and __rh_lookup() in dm_rh_dec() returns NULL where a non-NULL return value is required by design. Fix this by not changing the state of the recovery failed region from DM_RH_RECOVERING to DM_RH_NOSYNC in dm_rh_recovery_end(). Issue On 2.6.33-rc1 kernel, I hit the bug when I suspended the failed mirror by dmsetup command. BUG: unable to handle kernel NULL pointer dereference at 00000020 IP: [<f94f38e2>] dm_rh_dec+0x35/0xa1 [dm_region_hash] ... EIP: 0060:[<f94f38e2>] EFLAGS: 00010046 CPU: 0 EIP is at dm_rh_dec+0x35/0xa1 [dm_region_hash] EAX: 00000286 EBX: 00000000 ECX: 00000286 EDX: 00000000 ESI: eff79eac EDI: eff79e80 EBP: f6915cd4 ESP: f6915cc4 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process dmsetup (pid: 2849, ti=f6914000 task=eff03e80 task.ti=f6914000) ... Call Trace: [<f9530af6>] ? mirror_end_io+0x53/0x1b1 [dm_mirror] [<f9413104>] ? clone_endio+0x4d/0xa2 [dm_mod] [<f9530aa3>] ? mirror_end_io+0x0/0x1b1 [dm_mirror] [<f94130b7>] ? clone_endio+0x0/0xa2 [dm_mod] [<c02d6bcb>] ? bio_endio+0x28/0x2b [<f952f303>] ? hold_bio+0x2d/0x62 [dm_mirror] [<f952f942>] ? mirror_presuspend+0xeb/0xf7 [dm_mirror] [<c02aa3e2>] ? vmap_page_range+0xb/0xd [<f9414c8d>] ? suspend_targets+0x2d/0x3b [dm_mod] [<f9414ca9>] ? dm_table_presuspend_targets+0xe/0x10 [dm_mod] [<f941456f>] ? dm_suspend+0x4d/0x150 [dm_mod] [<f941767d>] ? dev_suspend+0x55/0x18a [dm_mod] [<c0343762>] ? _copy_from_user+0x42/0x56 [<f9417fb0>] ? dm_ctl_ioctl+0x22c/0x281 [dm_mod] [<f9417628>] ? dev_suspend+0x0/0x18a [dm_mod] [<f9417d84>] ? dm_ctl_ioctl+0x0/0x281 [dm_mod] [<c02c3c4b>] ? vfs_ioctl+0x22/0x85 [<c02c422c>] ? do_vfs_ioctl+0x4cb/0x516 [<c02c42b7>] ? sys_ioctl+0x40/0x5a [<c0202858>] ? sysenter_do_call+0x12/0x28 Analysis When recovery process of a region failed, dm_rh_recovery_end() function changes the state of the region from RM_RH_RECOVERING to DM_RH_NOSYNC. When recovery_complete() is executed between dm_rh_update_states() and dm_writes() in do_mirror(), bios are processed with the region state, DM_RH_NOSYNC. However, the region data is freed without checking its pending count when dm_rh_update_states() is called next time. When bios are finished by mirror_end_io(), __rh_lookup() in dm_rh_dec() returns NULL even though a valid return value are expected. Solution Remove the state change of the recovery failed region from DM_RH_RECOVERING to DM_RH_NOSYNC in dm_rh_recovery_end(). We can remove the state change because: - If the region data has been released by dm_rh_update_states(), a new region data is created with the state of DM_RH_NOSYNC, and bios are processed according to the DM_RH_NOSYNC state. - If the region data has not been released by dm_rh_update_states(), a state of the region is DM_RH_RECOVERING and bios are put in the delayed_bio list. The flag change from DM_RH_RECOVERING to DM_RH_NOSYNC in dm_rh_recovery_end() was added in the following commit: dm raid1: handle resync failures author Jonathan Brassow <jbrassow@redhat.com> Thu, 12 Jul 2007 16:29:04 +0000 (17:29 +0100) http://git.kernel.org/linus/f44db678edcc6f4c2779ac43f63f0b9dfa28b724 Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Reviewed-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-16dm raid1: fail writes if errors are not handled and log failsMikulas Patocka
If the mirror log fails when the handle_errors option was not selected and there is no remaining valid mirror leg, writes return success even though they weren't actually written to any device. This patch completes them with EIO instead. This code path is taken: do_writes: bio_list_merge(&ms->failures, &sync); do_failures: if (!get_valid_mirror(ms)) (false) else if (errors_handled(ms)) (false) else bio_endio(bio, 0); The logic in do_failures is based on presuming that the write was already tried: if it succeeded at least on one leg (without handle_errors) it is reported as success. Reference: https://bugzilla.redhat.com/show_bug.cgi?id=555197 Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-16dm log: userspace fix overhead_size calcuationsJonathan Brassow
This patch fixes two bugs that revolve around the miscalculation and misuse of the variable 'overhead_size'. 'overhead_size' is the size of the various header structures used during communication. The first bug is the use of 'sizeof' with the pointer of a structure instead of the structure itself - resulting in the wrong size being computed. This is then used in a check to see if the payload (data_size) would be to large for the preallocated structure. Since the bug produces a smaller value for the overhead, it was possible for the structure to be breached. (Although the current users of the code do not currently send enough data to trigger this bug.) The second bug is that the 'overhead_size' value is used to compute how much of the preallocated space should be cleared before populating it with fresh data. This should have simply been 'sizeof(struct cn_msg)' not overhead_size. The fact that 'overhead_size' was computed incorrectly made this problem "less bad" - leaving only a pointer's worth of space at the end uncleared. Thus, this bug was never producing a bad result, but still needs to be fixed - especially now that the value is computed correctly. Cc: stable@kernel.org Signed-off-by: Jonathan Brassow <jbrassow@redhat.com Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-16dm snapshot: persistent annotate work_queue as on stackMike Snitzer
chunk_io() declares its 'struct mdata_req' on the stack and then initializes its 'struct work_struct' member. Annotate the initialization of this workqueue with INIT_WORK_ON_STACK to suppress a debugobjects warning seen when CONFIG_DEBUG_OBJECTS_WORK is enabled. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-16dm stripe: avoid divide by zero with invalid stripe countNikanth Karthikesan
If a table containing zero as stripe count is passed into stripe_ctr the code attempts to divide by zero. This patch changes DM_TABLE_LOAD to return -EINVAL if the stripe count is zero. We now get the following error messages: device-mapper: table: 253:0: striped: Invalid stripe count device-mapper: ioctl: error adding target to table Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Cc: stable@kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-10md: fix some lockdep issues between md and sysfs.NeilBrown
====== This fix is related to http://bugzilla.kernel.org/show_bug.cgi?id=15142 but does not address that exact issue. ====== sysfs does like attributes being removed while they are being accessed (i.e. read or written) and waits for the access to complete. As accessing some md attributes takes the same lock that is held while removing those attributes a deadlock can occur. This patch addresses 3 issues in md that could lead to this deadlock. Two relate to calling flush_scheduled_work while the lock is held. This is probably a bad idea in general and as we use schedule_work to delete various sysfs objects it is particularly bad. In one case flush_scheduled_work is called from md_alloc (called by md_probe) called from do_md_run which holds the lock. This call is only present to ensure that ->gendisk is set. However we can be sure that gendisk is always set (though possibly we couldn't when that code was originally written. This is because do_md_run is called in three different contexts: 1/ from md_ioctl. This requires that md_open has succeeded, and it fails if ->gendisk is not set. 2/ from writing a sysfs attribute. This can only happen if the mddev has been registered in sysfs which happens in md_alloc after ->gendisk has been set. 3/ from autorun_array which is only called by autorun_devices, which checks for ->gendisk to be set before calling autorun_array. So the call to md_probe in do_md_run can be removed, and the check on ->gendisk can also go. In the other case flush_scheduled_work is being called in do_md_stop, purportedly to wait for all md_delayed_delete calls (which delete the component rdevs) to complete. However there really isn't any need to wait for them - they have already been disconnected in all important ways. The third issue is that raid5->stop() removes some attribute names while the lock is held. There is already some infrastructure in place to delay attribute removal until after the lock is released (using schedule_work). So extend that infrastructure to remove the raid5_attrs_group. This does not address all lockdep issues related to the sysfs "s_active" lock. The rest can be address by splitting that lockdep context between symlinks and non-symlinks which hopefully will happen. Signed-off-by: NeilBrown <neilb@suse.de>
2010-02-09md: fix 'degraded' calculation when starting a reshape.NeilBrown
This code was written long ago when it was not possible to reshape a degraded array. Now it is so the current level of degraded-ness needs to be taken in to account. Also newly addded devices should only reduce degradedness if they are deemed to be in-sync. In particular, if you convert a RAID5 to a RAID6, and increase the number of devices at the same time, then the 5->6 conversion will make the array degraded so the current code will produce a wrong value for 'degraded' - "-1" to be precise. If the reshape runs to completion end_reshape will calculate a correct new value for 'degraded', but if a device fails during the reshape an incorrect decision might be made based on the incorrect value of "degraded". This patch is suitable for 2.6.32-stable and if they are still open, 2.6.31-stable and 2.6.30-stable as well. Cc: stable@kernel.org Reported-by: Michael Evans <mjevans1983@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2010-01-11DM: Fix device mapper topology stackingMartin K. Petersen
Make DM use bdev_stack_limits() function so that partition offsets get taken into account when calculating alignment. Clarify stacking warnings. Also remove obsolete clearing of final alignment_offset and misalignment flag. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: Alasdair G. Kergon <agk@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-30md: allow a resync that is waiting for other resync to complete, to be aborted.NeilBrown
If two arrays share a device, then they will not both resync at the same time. One will wait for the other to complete. While waiting, the MD_RECOVERY_INTR flag is not checked so a device failure, which would make the resync pointless, does not cause the resync to abort, so the failed device cannot be removed (as it cannot be remove while a resync is happening). So add a test for MD_RECOVERY_INTR. Reported-by: Brett Russ <bruss@netezza.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-30md: remove unnecessary code from do_md_runNeilBrown
Since commit dfc7064500061677720fa26352963c772d3ebe6b, ->hot_remove_disks has not removed non-failed devices from an array until recovery is no longer possible. So the code in do_md_run to get around the fact that md_check_recovery (which calls ->hot_remove_disks) would remove partially-in-sync devices is no longer needed. So remove it. Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-30md: make recovery started by do_md_run() visible via sync_actionDan Williams
By default md_do_sync() will perform recovery if no other actions are specified. However, action_show() relies on MD_RECOVERY_RECOVER to be set otherwise it returns 'idle'. So, add a missing set MD_RECOVERY_RECOVER when starting recovery. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-30md: fix small irregularity with start_ro module parameterNeilBrown
The start_ro modules parameter can be used to force arrays to be started in 'auto-readonly' in which they are read-only until the first write. This ensures that no resync/recovery happens until something else writes to the device. This is important for resume-from-disk off an md array. However if an array is started 'readonly' (by writing 'readonly' to the 'array_state' sysfs attribute) we want it to be really 'readonly', not 'auto-readonly'. So strengthen the condition to only set auto-readonly if the array is not already read-only. Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-30md: Fix unfortunate interaction with evmsNeilBrown
evms configures md arrays by: open device send ioctl close device for each different ioctl needed. Since 2.6.29, the device can disappear after the 'close' unless a significant configuration has happened to the device. The change made by "SET_ARRAY_INFO" can too minor to stop the device from disappearing, but important enough that losing the change is bad. So: make sure SET_ARRAY_INFO sets mddev->ctime, and keep the device active as long as ctime is non-zero (it gets zeroed with lots of other things when the array is stopped). This is suitable for -stable kernels since 2.6.29. Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@kernel.org
2009-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (80 commits) dm snapshot: use merge origin if snapshot invalid dm snapshot: report merge failure in status dm snapshot: merge consecutive chunks together dm snapshot: trigger exceptions in remaining snapshots during merge dm snapshot: delay merging a chunk until writes to it complete dm snapshot: queue writes to chunks being merged dm snapshot: add merging dm snapshot: permit only one merge at once dm snapshot: support barriers in snapshot merge target dm snapshot: avoid allocating exceptions in merge dm snapshot: rework writing to origin dm snapshot: add merge target dm exception store: add merge specific methods dm snapshot: create function for chunk_is_tracked wait dm snapshot: make bio optional in __origin_write dm mpath: reject messages when device is suspended dm: export suspended state to targets dm: rename dm_suspended to dm_suspended_md dm: swap target postsuspend call and setting suspended flag dm crypt: add plain64 iv ...
2009-12-15drivers/md/md.c: use %pU to print UUIDsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14md: add 'recovery_start' per-device sysfs attributeDan Williams
Enable external metadata arrays to manage rebuild checkpointing via a md/dev-XXX/recovery_start attribute which reflects rdev->recovery_offset Also update resync_start_store to allow 'none' to be written, for consistency. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-14md: rcu_read_lock() walk of mddev->disks in md_do_sync()Dan Williams
Other walks of this list are either under rcu_read_lock() or the list mutation lock (mddev_lock()). This protects against the improbable case of a disk being removed from the array at the start of md_do_sync(). Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-12-14md: integrate spares into array at earliest opportunity.NeilBrown
As v1.x metadata can record that a member of the array is not completely recovered, it make sense to record that a spare has become a regular member of the array at the earliest opportunity. So remove the tests on "recovery_offset > 0" in super_1_sync as they really aren't needed, and schedule a metadata update immediately after adding spares to a degraded array. This means that if a crash happens immediately after a recovery starts, the new device will be included in the array and recovery will continue from wherever it was up to. Previously this didn't happen unless recovery was at least 1/16 of the way through. Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-14md: move compat_ioctl handling into md.cArnd Bergmann
The RAID ioctls are only implemented in md.c, so the handling for them should also be moved there from fs/compat_ioctl.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Neil Brown <neilb@suse.de> Cc: Andre Noll <maan@systemlinux.org> Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-14md: revise Kconfig help for MD_MULTIPATHNeilBrown
Make it clear in the config message that MD_MULTIPATH is not under active development. Cc: Oren Held <orenhe@il.ibm.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-14md: add MODULE_DESCRIPTION for all md related modules.NeilBrown
Suggested by Oren Held <orenhe@il.ibm.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-14raid: improve MD/raid10 handling of correctable read errors.Robert Becker
We've noticed severe lasting performance degradation of our raid arrays when we have drives that yield large amounts of media errors. The raid10 module will queue each failed read for retry, and also will attempt call fix_read_error() to perform the read recovery. Read recovery is performed while the array is frozen, so repeated recovery attempts can degrade the performance of the array for extended periods of time. With this patch I propose adding a per md device max number of corrected read attempts. Each rdev will maintain a count of read correction attempts in the rdev->read_errors field (not used currently for raid10). When we enter fix_read_error() we'll check to see when the last read error occurred, and divide the read error count by 2 for every hour since the last read error. If at that point our read error count exceeds the read error threshold, we'll fail the raid device. In addition in this patch I add sysfs nodes (get/set) for the per md max_read_errors attribute, the rdev->read_errors attribute, and added some printk's to indicate when fix_read_error fails to repair an rdev. For testing I used debugfs->fail_make_request to inject IO errors to the rdev while doing IO to the raid array. Signed-off-by: Robert Becker <Rob.Becker@riverbed.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-14md/raid10: print more useful messages on device failure.Robert Becker
When we get a read error on a device in a RAID10, and attempting to repair the error fails, print more useful messages about why it failed. Signed-off-by: Robert Becker <Rob.Becker@riverbed.com> Signed-off-by: NeilBrown <neilb@suse.de>
