path: root/drivers/md
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-03-03netlink: kill eff_cap from struct netlink_skb_parmsPatrick McHardy
Netlink message processing in the kernel is synchronous these days, capabilities can be checked directly in security_netlink_recv() from the current process. Signed-off-by: Patrick McHardy <kaber@trash.net> Reviewed-by: James Morris <jmorris@namei.org> [chrisw: update to include pohmelfs and uvesafb] Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24md: Fix - again - partition detection when array becomes activeNeilBrown
Revert b821eaa572fd737faaf6928ba046e571526c36c6 and f3b99be19ded511a1bf05a148276239d9f13eefa When I wrote the first of these I had a wrong idea about the lifetime of 'struct block_device'. It can disappear at any time that the block device is not open if it falls out of the inode cache. So relying on the 'size' recorded with it to detect when the device size has changed and so we need to revalidate, is wrong. Rather, we really do need the 'changed' attribute stored directly in the mddev and set/tested as appropriate. Without this patch, a sequence of: mknod / open / close / unlink (which can cause a block_device to be created and then destroyed) will result in a rescan of the partition table and consequence removal and addition of partitions. Several of these in a row can get udev racing to create and unlink and other code can get confused. With the patch, the rescan is only performed when needed and so there are no races. This is suitable for any stable kernel from 2.6.35. Reported-by: "Wojcik, Krzysztof" <krzysztof.wojcik@intel.com> Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@kernel.org
2011-02-21Merge branch 'master' into for-2.6.39Tejun Heo
2011-02-21md: avoid spinlock problem in blk_throtl_exitNeilBrown
blk_throtl_exit assumes that ->queue_lock still exists, so make sure that it does. To do this, we stop redirecting ->queue_lock to conf->device_lock and leave it pointing where it is initialised - __queue_lock. As the blk_plug functions check the ->queue_lock is held, we now take that spin_lock explicitly around the plug functions. We don't need the locking, just the warning removal. This is needed for any kernel with the blk_throtl code, which is which is 2.6.37 and later. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-16md: correctly handle probe of an 'mdp' device.NeilBrown
'mdp' devices are md devices with preallocated device numbers for partitions. As such it is possible to mknod and open a partition before opening the whole device. this causes md_probe() to be called with a device number of a partition, which in-turn calls mddev_find with such a number. However mddev_find expects the number of a 'whole device' and does the wrong thing with partition numbers. So add code to mddev_find to remove the 'partition' part of a device number and just work with the 'whole device'. This patch addresses https://bugzilla.kernel.org/show_bug.cgi?id=28652 Reported-by: hkmaly@bigfoot.com Signed-off-by: NeilBrown <neilb@suse.de> Cc: <stable@kernel.org>
2011-02-16md: don't set_capacity before array is active.NeilBrown
If the desired size of an array is set (via sysfs) before the array is active (which is the normal sequence), we currrently call set_capacity immediately. This means that a subsequent 'open' (as can be caused by some udev-triggers program) will notice the new size and try to probe for partitions. However as the array isn't quite ready yet the read will fail. Then when the array is read, as the size doesn't change again we don't try to re-probe. So when setting array size via sysfs, only call set_capacity if the array is already active. Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-14md: Fix raid1->raid0 takeoverKrzysztof Wojcik
Takeover raid1->raid0 not succeded. Kernel message is shown: "md/raid0:md126: too few disks (1 of 2) - aborting!" Problem was that we weren't updating ->raid_disks for that takeover, unlike all the others. Signed-off-by: Krzysztof Wojcik <krzysztof.wojcik@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-12[SCSI] dm mpath: propagate target errors immediatelyHannes Reinecke
DM now has more information about the nature of the underlying storage failure. Path failure is avoided if a request failed due to a target error. Instead the target error is immediately passed up the stack. Discard requests that fail due to non-target errors may now be retried. Errors restricted to the path will be retried or returned if no paths are available, irregarding the no_path_retry setting. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-08FIX: md: process hangs at wait_barrier after 0->10 takeoverKrzysztof Wojcik
Following symptoms were observed: 1. After raid0->raid10 takeover operation we have array with 2 missing disks. When we add disk for rebuild, recovery process starts as expected but it does not finish- it stops at about 90%, md126_resync process hangs in "D" state. 2. Similar behavior is when we have mounted raid0 array and we execute takeover to raid10. After this when we try to unmount array- it causes process umount hangs in "D" In scenarios above processes hang at the same function- wait_barrier in raid10.c. Process waits in macro "wait_event_lock_irq" until the "!conf->barrier" condition will be true. In scenarios above it never happens. Reason was that at the end of level_store, after calling pers->run, we call mddev_resume. This calls pers->quiesce(mddev, 0) with RAID10, that calls lower_barrier. However raise_barrier hadn't been called on that 'conf' yet, so conf->barrier becomes negative, which is bad. This patch introduces setting conf->barrier=1 after takeover operation. It prevents to become barrier negative after call lower_barrier(). Signed-off-by: Krzysztof Wojcik <krzysztof.wojcik@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-08md_make_request: don't touch the bio after calling make_requestChris Mason
md_make_request was calling bio_sectors() for part_stat_add after it was calling the make_request function. This is bad because the make_request function can free the bio and because the bi_size field can change around. The fix here was suggested by Jens Axboe. It saves the sector count before the make_request call. I hit this with CONFIG_DEBUG_PAGEALLOC turned on while trying to break his pretty fusionio card. Cc: <stable@kernel.org> Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-02md: Don't allow slot_store while resync/recovery is happening.NeilBrown
Activating a spare in an array while resync/recovery is already happening can lead the that spare being marked in-sync when it isn't really. So don't allow the 'slot' to be set (this activating the device) while resync/recovery is happening. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-31md: don't clear curr_resync_completed at end of resync.NeilBrown
There is no need to set this to zero at this point. It will be set to zero by remove_and_add_spares or at the start of md_do_sync at the latest. And setting it to zero before MD_RECOVERY_RUNNING is cleared can make a 'zero' appear briefly in the 'sync_completed' sysfs attribute just as resync is finishing. So simply remove this setting to zero. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-31md: Don't use remove_and_add_spares to remove failed devices from a ↵NeilBrown
read-only array remove_and_add_spares is called in two places where the needs really are very different. remove_and_add_spares should not be called on an array which is about to be reshaped as some extra devices might have been manually added and that would remove them. However if the array is 'read-auto', that will currently happen, which is bad. So in the 'ro != 0' case don't call remove_and_add_spares but simply remove the failed devices as the comment suggests is needed. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-31Add raid1->raid0 takeover supportKrzysztof Wojcik
This patch introduces raid 1 to raid0 takeover operation in kernel space. Signed-off-by: Krzysztof Wojcik <krzysztof.wojcik@intel.com> Signed-off-by: Neil Brown <neilb@nbeee.brown>
2011-01-31md: Remove the AllReserved flag for component devices.NeilBrown
This flag is not needed and is used badly. Devices that are included in a native-metadata array are reserved exclusively for that array - and currently have AllReserved set. They all are bd_claimed for the rdev and so cannot be shared. Devices that are included in external-metadata arrays can be shared among multiple arrays - providing there is no overlap. These are bd_claimed for md in general - not for a particular rdev. When changing the amount of a device that is used in an array we need to check for overlap. This currently includes a check on AllReserved So even without overlap, sharing with an AllReserved device is not allowed. However the bd_claim usage already precludes sharing with these devices, so the test on AllReserved is not needed. And in fact it is wrong. As this is the only use of AllReserved, simply remove all usage and definition of AllReserved. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-31md: don't abort checking spares as soon as one cannot be added.NeilBrown
As spares can be added manually before a reshape starts, we need to find them all to mark some of them as in_sync. Previously we would abort looking for spares when we found an unallocated spare what could not be added to the array (implying there was no room for new spares). However already-added spares could be later in the list, so we need to keep searching. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-31md: fix the test for finding spares in raid5_start_reshape.NeilBrown
As spares can be added to the array before the reshape is started, we need to find and count them when checking there are enough. The array could have been degraded, so we need to check all devices, no just those out side of the range of devices in the array before the reshape. So instead of checking the index, check the In_sync flag as that reliably tells if the device is a spare or this purpose. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-31md: simplify some 'if' conditionals in raid5_start_reshape.NeilBrown
There are two consecutive 'if' statements. if (mddev->delta_disks >= 0) .... if (mddev->delta_disks > 0) The code in the second is equally valid if delta_disks == 0, and these two statements are the only place that 'added_devices' is used. So make them a single if statement, make added_devices a local variable, and re-indent it all. No functional change. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-31md: revert change to raid_disks on failure.NeilBrown
If we try to update_raid_disks and it fails, we should put 'delta_disks' back to zero. This is important because some code, such as slot_store, assumes that delta_disks has been validated. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-25workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUERTejun Heo
WQ_RESCUER is now an internal flag and should only be used in the workqueue implementation proper. Use WQ_MEM_RECLAIM instead. This doesn't introduce any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: dm-devel@redhat.com Cc: Neil Brown <neilb@suse.de>
2011-01-14block: restore multiple bd_link_disk_holder() supportTejun Heo
Commit e09b457b (block: simplify holder symlink handling) incorrectly assumed that there is only one link at maximum. dm may use multiple links and expects block layer to track reference count for each link, which is different from and unrelated to the exclusive device holder identified by @holder when the device is opened. Remove the single holder assumption and automatic removal of the link and revive the per-link reference count tracking. The code essentially behaves the same as before commit e09b457b sans the unnecessary kobject reference count dancing. While at it, note that this facility should not be used by anyone else than the current ones. Sysfs symlinks shouldn't be abused like this and the whole thing doesn't belong in the block layer at all. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Milan Broz <mbroz@redhat.com> Cc: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Neil Brown <neilb@suse.de> Cc: linux-raid@vger.kernel.org Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (32 commits) dm: raid456 basic support dm: per target unplug callback support dm: introduce target callbacks and congestion callback dm mpath: delay activate_path retry on SCSI_DH_RETRY dm: remove superfluous irq disablement in dm_request_fn dm log: use PTR_ERR value instead of ENOMEM dm snapshot: avoid storing private suspended state dm snapshot: persistent make metadata_wq multithreaded dm: use non reentrant workqueues if equivalent dm: convert workqueues to alloc_ordered dm stripe: switch from local workqueue to system_wq dm: dont use flush_scheduled_work dm snapshot: remove unused dm_snapshot queued_bios_work dm ioctl: suppress needless warning messages dm crypt: add loop aes iv generator dm crypt: add multi key capability dm crypt: add post iv call to iv generator dm crypt: use io thread for reads only if mempool exhausted dm crypt: scale to multiple cpus dm crypt: simplify compatible table output ...
2011-01-13Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Fix removal of extra drives when converting RAID6 to RAID5 md: range check slot number when manually adding a spare. md/raid5: handle manually-added spares in start_reshape. md: fix sync_completed reporting for very large drives (>2TB) md: allow suspend_lo and suspend_hi to decrease as well as increase. md: Don't let implementation detail of curr_resync leak out through sysfs. md: separate meta and data devs md-new-param-to_sync_page_io md-new-param-to-calc_dev_sboffset md: Be more careful about clearing flags bit in ->recovery md: md_stop_writes requires mddev_lock. md/raid5: use sysfs_notify_dirent_safe to avoid NULL pointer md: Ensure no IO request to get md device before it is properly initialised. md: Fix single printks with multiple KERN_<level>s md: fix regression resulting in delays in clearing bits in a bitmap md: fix regression with re-adding devices to arrays with no metadata
2011-01-14md: Fix removal of extra drives when converting RAID6 to RAID5NeilBrown
When a RAID6 is converted to a RAID5, the extra drive should be discarded. However it isn't due to a typo in a comparison. This bug was introduced in commit e93f68a1fc6 in 2.6.35-rc4 and is suitable for any -stable since than. As the extra drive is not removed, the 'degraded' counter is wrong and so the RAID5 will not respond correctly to a subsequent failure. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md: range check slot number when manually adding a spare.NeilBrown
When adding a spare to an active array, we should check the slot number, but allow it to be larger than raid_disks if a reshape is being prepared. Apply the same test when adding a device to an array-under-construction. It already had most of the test in place, but not quite all. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md/raid5: handle manually-added spares in start_reshape.NeilBrown
It is possible to manually add spares to specific slots before starting a reshape. raid5_start_reshape should recognised this possibility and include it in the accounting. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md: fix sync_completed reporting for very large drives (>2TB)Rémi Rérolle
The values exported in the sync_completed file are unsigned long, which overflows with very large drives, resulting in wrong values reported. Since sync_completed uses sectors as unit, we'll start getting wrong values with components larger than 2TB. This patch simply replaces the use of unsigned long by unsigned long long. Signed-off-by: Rémi Rérolle <rrerolle@lacie.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md: allow suspend_lo and suspend_hi to decrease as well as increase.NeilBrown
The sysfs attributes 'suspend_lo' and 'suspend_hi' describe a region to which read/writes are suspended so that the under lying data can be manipulated without user-space noticing. Currently the window they describe can only move forwards along the device. However this is an unnecessary restriction which will cause problems with planned developments. So relax this restriction and allow these endpoints to move arbitrarily. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md: Don't let implementation detail of curr_resync leak out through sysfs.NeilBrown
mddev->curr_resync has artificial values of '1' and '2' which are used by the code which ensures only one resync is happening at a time on any given device. These values are internal and should never be exposed to user-space (except when translated appropriately as in the 'pending' status in /proc/mdstat). Unfortunately they are as ->curr_resync is assigned to ->curr_resync_completed and that value is directly visible through sysfs. So change the assignments to ->curr_resync_completed to get the same valued from elsewhere in a form that doesn't have the magic '1' or '2' values. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md: separate meta and data devsJonathan Brassow
Allow the metadata to be on a separate device from the data. This doesn't mean the data and metadata will by on separate physical devices - it simply gives device-mapper and userspace tools more flexibility. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md-new-param-to_sync_page_ioJonathan Brassow
Add new parameter to 'sync_page_io'. The new parameter allows us to distinguish between metadata and data operations. This becomes important later when we add the ability to use separate devices for data and metadata. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
2011-01-14md-new-param-to-calc_dev_sboffsetJonathan Brassow
When we allow for separate devices for data and metadata in a later patch, we will need to be able to calculate the superblock offset based on more than the bdev. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
2011-01-14md: Be more careful about clearing flags bit in ->recoveryNeilBrown
Setting ->recovery to 0 is generally not a good idea as it could clear bits that shouldn't be cleared. In particular, MD_RECOVERY_FROZEN should only be cleared on explicit request from user-space. So when we need to clear things, just clear the bits that need clearing. As there are a few different places which reap a resync process - and some do an incomplte job - factor out the code for doing the from md_check_recovery and call that function instead of open coding part of it. Signed-off-by: NeilBrown <neilb@suse.de> Reported-by: Jonathan Brassow <jbrassow@redhat.com>
2011-01-14md: md_stop_writes requires mddev_lock.NeilBrown
As md_stop_writes manipulates the sync_thread and calls md_update_sb, it need to be called with mddev_lock held. In all internal cases it is, but the symbol is exported for dm-raid to call and in that case the lock won't be help. Do make an exported version which takes the lock, and an internal version which does not. Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md/raid5: use sysfs_notify_dirent_safe to avoid NULL pointerJonathan Brassow
With the module parameter 'start_dirty_degraded' set, raid5_spare_active() previously called sysfs_notify_dirent() with a NULL argument (rdev->sysfs_state) when a rebuild finished. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2011-01-14md: Ensure no IO request to get md device before it is properly initialised.NeilBrown
When an md device is in the process of coming on line it is possible for an IO request (typically a partition table probe) to get through before the array is fully initialised, which can cause unexpected behaviour (e.g. a crash). So explicitly record when the array is ready for IO and don't allow IO through until then. There is no possibility for a similar problem when the array is going off-line as there must only be one 'open' at that time, and it is busy off-lining the array and so cannot send IO requests. So no memory barrier is needed in md_stop() This has been a bug since commit 409c57f3801 in 2.6.30 which introduced md_make_request. Before then, each personality would register its own make_request_fn when it was ready. This is suitable for any stable kernel from 2.6.30.y onwards. Cc: <stable@kernel.org> Signed-off-by: NeilBrown <neilb@suse.de> Reported-by: "Hawrylewicz Czarnowski, Przemyslaw" <przemyslaw.hawrylewicz.czarnowski@intel.com>
2011-01-14md: Fix single printks with multiple KERN_<level>sJoe Perches
Noticed-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-14md: fix regression resulting in delays in clearing bits in a bitmapNeilBrown
commit 589a594be1fb (2.6.37-rc4) fixed a problem were md_thread would sometimes call the ->run function at a bad time. If an error is detected during array start up after the md_thread has been started, the md_thread is killed. This resulted in the ->run function being called once. However the array may not be in a state that it is safe to call ->run. However the fix imposed meant that ->run was not called on a timeout. This means that when an array goes idle, bitmap bits do not get cleared promptly. While the array is busy the bits will still be cleared when appropriate so this is not very serious. There is no risk to data. Change the test so that we only avoid calling ->run when the thread is being stopped. This more explicitly addresses the problem situation. This is suitable for 2.6.37-stable and any -stable kernel to which 589a594be1fb was applied. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-01-13dm: raid456 basic supportNeilBrown
This patch is the skeleton for the DM target that will be the bridge from DM to MD (initially RAID456 and later RAID1). It provides a way to use device-mapper interfaces to the MD RAID456 drivers. As with all device-mapper targets, the nominal public interfaces are the constructor (CTR) tables and the status outputs (both STATUSTYPE_INFO and STATUSTYPE_TABLE). The CTR table looks like the following: 1: <s> <l> raid \ 2: <raid_type> <#raid_params> <raid_params> \ 3: <#raid_devs> <meta_dev1> <dev1> .. <meta_devN> <devN> Line 1 contains the standard first three arguments to any device-mapper target - the start, length, and target type fields. The target type in this case is "raid". Line 2 contains the arguments that define the particular raid type/personality/level, the required arguments for that raid type, and any optional arguments. Possible raid types include: raid4, raid5_la, raid5_ls, raid5_rs, raid6_zr, raid6_nr, and raid6_nc. (again, raid1 is planned for the future.) The list of required and optional parameters is the same for all the current raid types. The required parameters are positional, while the optional parameters are given as key/value pairs. The possible parameters are as follows: <chunk_size> Chunk size in sectors. [[no]sync] Force/Prevent RAID initialization [rebuild <idx>] Rebuild the drive indicated by the index [daemon_sleep <ms>] Time between bitmap daemon work to clear bits [min_recovery_rate <kB/sec/disk>] Throttle RAID initialization [max_recovery_rate <kB/sec/disk>] Throttle RAID initialization [max_write_behind <value>] See '-write-behind=' (man mdadm) [stripe_cache <sectors>] Stripe cache size for higher RAIDs Line 3 contains the list of devices that compose the array in metadata/data device pairs. If the metadata is stored separately, a '-' is given for the metadata device position. If a drive has failed or is missing at creation time, a '-' can be given for both the metadata and data drives for a given position. Examples: # RAID4 - 4 data drives, 1 parity # No metadata devices specified to hold superblock/bitmap info # Chunk size of 1MiB # (Lines separated for easy reading) 0 1960893648 raid \ raid4 1 2048 \ 5 - 8:17 - 8:33 - 8:49 - 8:65 - 8:81 # RAID4 - 4 data drives, 1 parity (no metadata devices) # Chunk size of 1MiB, force RAID initialization, # min recovery rate at 20 kiB/sec/disk 0 1960893648 raid \ raid4 4 2048 min_recovery_rate 20 sync\ 5 - 8:17 - 8:33 - 8:49 - 8:65 - 8:81 Performing a 'dmsetup table' should display the CTR table used to construct the mapping (with possible reordering of optional parameters). Performing a 'dmsetup status' will yield information on the state and health of the array. The output is as follows: 1: <s> <l> raid \ 2: <raid_type> <#devices> <1 health char for each dev> <resync_ratio> Line 1 is standard DM output. Line 2 is best shown by example: 0 1960893648 raid raid4 5 AAAAA 2/490221568 Here we can see the RAID type is raid4, there are 5 devices - all of which are 'A'live, and the array is 2/490221568 complete with recovery. Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm: per target unplug callback supportNeilBrown
Add per-target unplug callback support. Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm: introduce target callbacks and congestion callbackNeilBrown
DM currently implements congestion checking by checking on congestion in each component device. For raid456 we need to also check if the stripe cache is congested. Add per-target congestion checker callback support. Extending the target_callbacks structure with additional callback functions allows for establishing multiple callbacks per-target (a callback is also needed for unplug). Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm mpath: delay activate_path retry on SCSI_DH_RETRYChandra Seetharaman
This patch adds a user-configurable 'pg_init_delay_msecs' feature. Use this feature to specify the number of milliseconds to delay before retrying scsi_dh_activate, when SCSI_DH_RETRY is returned. SCSI Device Handlers return SCSI_DH_IMM_RETRY if we could retry activation immediately and SCSI_DH_RETRY in cases where it is better to retry after some delay. Currently we immediately retry scsi_dh_activate irrespective of SCSI_DH_IMM_RETRY and SCSI_DH_RETRY. The 'pg_init_delay_msecs' feature may be provided during table create or load, e.g.: dmsetup create --table "0 20971520 multipath 3 queue_if_no_path \ pg_init_delay_msecs 2500 ..." mpatha The default for 'pg_init_delay_msecs' is 2000 milliseconds. Maximum configurable delay is 60000 milliseconds. Specifying a 'pg_init_delay_msecs' of 0 will cause immediate retry. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Acked-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm: remove superfluous irq disablement in dm_request_fnKiyoshi Ueda
This patch changes spin_lock_irq() to spin_lock() in dm_request_fn(). This patch is just a clean-up and no functional change. The spin_lock_irq() was leftover from the early request-based dm code, where map_request() used to enable interrupts. Since current map_request() never enables interrupts, we can change it to spin_lock() to match the prior spin_unlock(). Auditing through the dm and block-layer code called from map_request(), I confirmed all functions save/restore interrupt status, so no function returning with interrupts enabled. Also I haven't observed any problem on my test environment which uses scsi and lpfc driver after heavy I/O testing with occasional path down/up. Added BUG_ON() to detect breakage in future. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm log: use PTR_ERR value instead of ENOMEMDan Carpenter
It's nicer to return the PTR_ERR() value instead of just returning -ENOMEM. In the current code the PTR_ERR() value is always equal to -ENOMEM so this doesn't actually affect anything, but still... In addition, dm_dirty_log_create() doesn't check for a specific -ENOMEM return. So this change is safe relative to potential for a non -ENOMEM return in the future. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm snapshot: avoid storing private suspended stateMike Snitzer
Use dm_suspended() rather than having each snapshot target maintain a private 'suspended' flag in struct dm_snapshot. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm snapshot: persistent make metadata_wq multithreadedTejun Heo
metadata_wq serves on-stack work items from chunk_io(). Even if multiple chunk_io() are simultaneously in progress, each is independent and queued only once, so multithreaded workqueue can be safely used. Switch metadata_wq to multithread and flush the work item instead of the workqueue in chunk_io(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
