commit b761dcf1217760a42f7897c31dcb649f59b2333e upstream.
In reshape_request it already adds len to sector_nr already. It's wrong to add len to
sector_nr again after adding pages to bio. If there is bad block it can't copy one chunk
at a time, it needs to goto read_more. Now the sector_nr is wrong. It can cause data
corruption.
Cc: stable@vger.kernel.org # v3.16+
Signed-off-by: Xiao Ni <xni@redhat.com>
Signed-off-by: Song Liu <songliubraving@fb.com>
commit 4ae280b4ee3463fa57bbe6eede26b97daff8a0f1 upstream.
When provisioning a new data block for a virtual block, either because
the block was previously unallocated or because we are breaking sharing,
if the whole block of data is being overwritten the bio that triggered
the provisioning is issued immediately, skipping copying or zeroing of
the data block.
When this bio completes the new mapping is inserted in to the pool's
metadata by process_prepared_mapping(), where the bio completion is
signaled to the upper layers.
This completion is signaled without first committing the metadata. If
the bio in question has the REQ_FUA flag set and the system crashes
right after its completion and before the next metadata commit, then the
write is lost despite the REQ_FUA flag requiring that I/O completion for
this request must only be signaled after the data has been committed to
non-volatile storage.
Fix this by deferring the completion of overwrite bios, with the REQ_FUA
flag set, until after the metadata has been committed.
Signed-off-by: Nikos Tsironis <ntsironis@arrikto.com>
Acked-by: Joe Thornber <ejt@redhat.com>
Acked-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit ff0c129d3b5ecb3df7c8f5e2236582bf745b6c5f upstream.
bio_sectors() returns the value in the units of 512-byte sectors (no
matter what the real sector size of the device). dm-crypt multiplies
bio_sectors() by on_disk_tag_size to calculate the space allocated for
integrity tags. If dm-crypt is running with sector size larger than
512b, it allocates more data than is needed.
Device Mapper trims the extra space when passing the bio to
dm-integrity, so this bug didn't result in any visible misbehavior.
But it must be fixed to avoid wasteful memory allocation for the block
integrity payload.
Fixes: ef43aa38063a6 ("dm crypt: add cryptographic data integrity protection (authenticated encryption)")
Cc: stable@vger.kernel.org # 4.12+
Reported-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit dfcc34c99f3ebc16b787b118763bf9cb6b1efc7a upstream.
sync_request_write no longer submits writes to a Faulty device. This has
the unfortunate side effect that bitmap bits can be incorrectly cleared
if a recovery is interrupted (previously, end_sync_write would have
prevented this). This means the next recovery may not copy everything
it should, potentially corrupting data.
Add a function for doing the proper md_bitmap_end_sync, called from
end_sync_write and the Faulty case in sync_request_write.
backport note to 4.14: s/md_bitmap_end_sync/bitmap_end_sync
Cc: stable@vger.kernel.org 4.14+
Fixes: 0c9d5b127f69 ("md/raid1: avoid reusing a resync bio after error handling.")
Reviewed-by: Jack Wang <jinpu.wang@cloud.ionos.com>
Tested-by: Jack Wang <jinpu.wang@cloud.ionos.com>
Signed-off-by: Nate Dailey <nate.dailey@stratus.com>
[ Upstream commit e820d55cb99dd93ac2dc949cf486bb187e5cd70d ]
When both regular IO and resync IO happen at the same time,
and if we also need to split regular. Then we can see tasks
hang due to barrier.
1. resync thread
[ 1463.757205] INFO: task md1_resync:5215 blocked for more than 480 seconds.
[ 1463.757207] Not tainted 4.19.5-1-default #1
[ 1463.757209] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 1463.757212] md1_resync D 0 5215 2 0x80000000
[ 1463.757216] Call Trace:
[ 1463.757223] ? __schedule+0x29a/0x880
[ 1463.757231] ? raise_barrier+0x8d/0x140 [raid10]
[ 1463.757236] schedule+0x78/0x110
[ 1463.757243] raise_barrier+0x8d/0x140 [raid10]
[ 1463.757248] ? wait_woken+0x80/0x80
[ 1463.757257] raid10_sync_request+0x1f6/0x1e30 [raid10]
[ 1463.757265] ? _raw_spin_unlock_irq+0x22/0x40
[ 1463.757284] ? is_mddev_idle+0x125/0x137 [md_mod]
[ 1463.757302] md_do_sync.cold.78+0x404/0x969 [md_mod]
[ 1463.757311] ? wait_woken+0x80/0x80
[ 1463.757336] ? md_rdev_init+0xb0/0xb0 [md_mod]
[ 1463.757351] md_thread+0xe9/0x140 [md_mod]
[ 1463.757358] ? _raw_spin_unlock_irqrestore+0x2e/0x60
[ 1463.757364] ? __kthread_parkme+0x4c/0x70
[ 1463.757369] kthread+0x112/0x130
[ 1463.757374] ? kthread_create_worker_on_cpu+0x40/0x40
[ 1463.757380] ret_from_fork+0x3a/0x50
2. regular IO
[ 1463.760679] INFO: task kworker/0:8:5367 blocked for more than 480 seconds.
[ 1463.760683] Not tainted 4.19.5-1-default #1
[ 1463.760684] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 1463.760687] kworker/0:8 D 0 5367 2 0x80000000
[ 1463.760718] Workqueue: md submit_flushes [md_mod]
[ 1463.760721] Call Trace:
[ 1463.760731] ? __schedule+0x29a/0x880
[ 1463.760741] ? wait_barrier+0xdd/0x170 [raid10]
[ 1463.760746] schedule+0x78/0x110
[ 1463.760753] wait_barrier+0xdd/0x170 [raid10]
[ 1463.760761] ? wait_woken+0x80/0x80
[ 1463.760768] raid10_write_request+0xf2/0x900 [raid10]
[ 1463.760774] ? wait_woken+0x80/0x80
[ 1463.760778] ? mempool_alloc+0x55/0x160
[ 1463.760795] ? md_write_start+0xa9/0x270 [md_mod]
[ 1463.760801] ? try_to_wake_up+0x44/0x470
[ 1463.760810] raid10_make_request+0xc1/0x120 [raid10]
[ 1463.760816] ? wait_woken+0x80/0x80
[ 1463.760831] md_handle_request+0x121/0x190 [md_mod]
[ 1463.760851] md_make_request+0x78/0x190 [md_mod]
[ 1463.760860] generic_make_request+0x1c6/0x470
[ 1463.760870] raid10_write_request+0x77a/0x900 [raid10]
[ 1463.760875] ? wait_woken+0x80/0x80
[ 1463.760879] ? mempool_alloc+0x55/0x160
[ 1463.760895] ? md_write_start+0xa9/0x270 [md_mod]
[ 1463.760904] raid10_make_request+0xc1/0x120 [raid10]
[ 1463.760910] ? wait_woken+0x80/0x80
[ 1463.760926] md_handle_request+0x121/0x190 [md_mod]
[ 1463.760931] ? _raw_spin_unlock_irq+0x22/0x40
[ 1463.760936] ? finish_task_switch+0x74/0x260
[ 1463.760954] submit_flushes+0x21/0x40 [md_mod]
So resync io is waiting for regular write io to complete to
decrease nr_pending (conf->barrier++ is called before waiting).
The regular write io splits another bio after call wait_barrier
which call nr_pending++, then the splitted bio would continue
with raid10_write_request -> wait_barrier, so the splitted bio
has to wait for barrier to be zero, then deadlock happens as
follows.
resync io regular io
raise_barrier
wait_barrier
wait_barrier
To resolve the issue, we need to call allow_barrier to decrease
nr_pending before generic_make_request since regular IO is not
issued to underlying devices, and wait_barrier is called again
to ensure no internal IO happening.
Fixes: fc9977dd069e ("md/raid10: simplify the splitting of requests.")
Reported-and-tested-by: Siniša Bandin <sinisa@4net.rs>
Signed-off-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit 483cbbeddd5fe2c80fd4141ff0748fa06c4ff146 upstream.
This fixes the case when md array assembly fails because of raid cache recovery
unable to allocate a stripe, despite attempts to replay stripes and increase
cache size. This happens because stripes released by r5c_recovery_replay_stripes
and raid5_set_cache_size don't become available for allocation immediately.
Released stripes first are placed on conf->released_stripes list and require
md thread to merge them on conf->inactive_list before they can be allocated.
Patch allows final allocation attempt during cache recovery to wait for
new stripes to become availabe for allocation.
Cc: linux-raid@vger.kernel.org
Cc: Shaohua Li <shli@kernel.org>
Cc: linux-stable <stable@vger.kernel.org> # 4.10+
Fixes: b4c625c67362 ("md/r5cache: r5cache recovery: part 1")
Signed-off-by: Alexei Naberezhnov <anaberezhnov@fb.com>
commit 1856b9f7bcc8e9bdcccc360aabb56fbd4dd6c565 upstream.
The dm-crypt cipher specification in a mapping table is defined as:
cipher[:keycount]-chainmode-ivmode[:ivopts]
or (new crypt API format):
capi:cipher_api_spec-ivmode[:ivopts]
For ESSIV, the parameter includes hash specification, for example:
aes-cbc-essiv:sha256
The implementation expected that additional IV option to never include
another dash '-' character.
But, with SHA3, there are names like sha3-256; so the mapping table
parser fails:
dmsetup create test --table "0 8 crypt aes-cbc-essiv:sha3-256 9c1185a5c5e9fc54612808977ee8f5b9e 0 /dev/sdb 0"
dmsetup create test --table "0 8 crypt capi:cbc(aes)-essiv:sha3-256 9c1185a5c5e9fc54612808977ee8f5b9e 0 /dev/sdb 0"
device-mapper: crypt: Ignoring unexpected additional cipher options
device-mapper: table: 253:0: crypt: Error creating IV
device-mapper: ioctl: error adding target to table
Fix the dm-crypt constructor to ignore additional dash in IV options and
also remove a bogus warning (that is ignored anyway).
Signed-off-by: Milan Broz <gmazyland@gmail.com>
commit d445bd9cec1a850c2100fcf53684c13b3fd934f2 upstream.
Commit 00a0ea33b495 ("dm thin: do not queue freed thin mapping for next
stage processing") changed process_prepared_discard_passdown_pt1() to
increment all the blocks being discarded until after the passdown had
completed to avoid them being prematurely reused.
IO issued to a thin device that breaks sharing with a snapshot, followed
by a discard issued to snapshot(s) that previously shared the block(s),
results in passdown_double_checking_shared_status() being called to
iterate through the blocks double checking their reference count is zero
and issuing the passdown if so. So a side effect of commit 00a0ea33b495
is passdown_double_checking_shared_status() was broken.
Fix this by checking if the block reference count is greater than 1.
Also, rename dm_pool_block_is_used() to dm_pool_block_is_shared().
Fixes: 00a0ea33b495 ("dm thin: do not queue freed thin mapping for next stage processing")
Cc: stable@vger.kernel.org # 4.9+
Reported-by: ryan.p.norwood@gmail.com
Signed-off-by: Joe Thornber <ejt@redhat.com>
[ Upstream commit ef87bfc24f9b8da82c89aff493df20f078bc9cb1 ]
Reference to a device in device-mapper table contains offset in sectors.
If the sector_t is 32bit integer (CONFIG_LBDAF is not set), then
several device-mapper targets can overflow this offset and validity
check is then performed on a wrong offset and a wrong table is activated.
See for example (on 32bit without CONFIG_LBDAF) this overflow:
# dmsetup create test --table "0 2048 linear /dev/sdg 4294967297"
# dmsetup table test
0 2048 linear 8:96 1
This patch adds explicit check for overflow if the offset is sector_t type.
Reviewed-by: Mikulas Patocka <mpatocka@redhat.com>
[ Upstream commit 721b1d98fb517ae99ab3b757021cf81db41e67be ]
kcopyd has no upper limit to the number of jobs one can allocate and
issue. Under certain workloads this can lead to excessive memory usage
and workqueue stalls. For example, when creating multiple dm-snapshot
targets with a 4K chunk size and then writing to the origin through the
page cache. Syncing the page cache causes a large number of BIOs to be
issued to the dm-snapshot origin target, which itself issues an even
larger (because of the BIO splitting taking place) number of kcopyd
jobs.
Running the following test, from the device mapper test suite [1],
dmtest run --suite snapshot -n many_snapshots_of_same_volume_N
, with 8 active snapshots, results in the kcopyd job slab cache growing
to 10G. Depending on the available system RAM this can lead to the OOM
killer killing user processes:
[463.492878] kthreadd invoked oom-killer: gfp_mask=0x6040c0(GFP_KERNEL|__GFP_COMP),
nodemask=(null), order=1, oom_score_adj=0
[463.492894] kthreadd cpuset=/ mems_allowed=0
[463.492948] CPU: 7 PID: 2 Comm: kthreadd Not tainted 4.19.0-rc7 #3
[463.492950] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
[463.492952] Call Trace:
[463.492964] dump_stack+0x7d/0xbb
[463.492973] dump_header+0x6b/0x2fc
[463.492987] ? lockdep_hardirqs_on+0xee/0x190
[463.493012] oom_kill_process+0x302/0x370
[463.493021] out_of_memory+0x113/0x560
[463.493030] __alloc_pages_slowpath+0xf40/0x1020
[463.493055] __alloc_pages_nodemask+0x348/0x3c0
[463.493067] cache_grow_begin+0x81/0x8b0
[463.493072] ? cache_grow_begin+0x874/0x8b0
[463.493078] fallback_alloc+0x1e4/0x280
[463.493092] kmem_cache_alloc_node+0xd6/0x370
[463.493098] ? copy_process.part.31+0x1c5/0x20d0
[463.493105] copy_process.part.31+0x1c5/0x20d0
[463.493115] ? __lock_acquire+0x3cc/0x1550
[463.493121] ? __switch_to_asm+0x34/0x70
[463.493129] ? kthread_create_worker_on_cpu+0x70/0x70
[463.493135] ? finish_task_switch+0x90/0x280
[463.493165] _do_fork+0xe0/0x6d0
[463.493191] ? kthreadd+0x19f/0x220
[463.493233] kernel_thread+0x25/0x30
[463.493235] kthreadd+0x1bf/0x220
[463.493242] ? kthread_create_on_cpu+0x90/0x90
[463.493248] ret_from_fork+0x3a/0x50
[463.493279] Mem-Info:
[463.493285] active_anon:20631 inactive_anon:4831 isolated_anon:0
[463.493285] active_file:80216 inactive_file:80107 isolated_file:435
[463.493285] unevictable:0 dirty:51266 writeback:109372 unstable:0
[463.493285] slab_reclaimable:31191 slab_unreclaimable:3483521
[463.493285] mapped:526 shmem:4903 pagetables:1759 bounce:0
[463.493285] free:33623 free_pcp:2392 free_cma:0
[463.493489] Unreclaimable slab info:
[463.493513] Name Used Total
[463.493522] bio-6 1028KB 1028KB
[463.493525] bio-5 1028KB 1028KB
[463.493528] dm_snap_pending_exception 236783KB 243789KB
[463.493531] dm_exception 41KB 42KB
[463.493534] bio-4 1216KB 1216KB
[463.493537] bio-3 439396KB 439396KB
[463.493539] kcopyd_job 6973427KB 6973427KB
[463.494340] Out of memory: Kill process 1298 (ruby2.3) score 1 or sacrifice child
[463.494673] Killed process 1298 (ruby2.3) total-vm:435740kB, anon-rss:20180kB, file-rss:4kB, shmem-rss:0kB
[463.506437] oom_reaper: reaped process 1298 (ruby2.3), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Moreover, issuing a large number of kcopyd jobs results in kcopyd
hogging the CPU, while processing them. As a result, processing of work
items, queued for execution on the same CPU as the currently running
kcopyd thread, is stalled for long periods of time, hurting performance.
Running the aforementioned test we get, in dmesg, messages like the
following:
[67501.194592] BUG: workqueue lockup - pool cpus=4 node=0 flags=0x0 nice=0 stuck for 27s!
[67501.195586] Showing busy workqueues and worker pools:
[67501.195591] workqueue events: flags=0x0
[67501.195597] pwq 8: cpus=4 node=0 flags=0x0 nice=0 active=1/256
[67501.195611] pending: cache_reap
[67501.195641] workqueue mm_percpu_wq: flags=0x8
[67501.195645] pwq 8: cpus=4 node=0 flags=0x0 nice=0 active=1/256
[67501.195656] pending: vmstat_update
[67501.195682] workqueue kblockd: flags=0x18
[67501.195687] pwq 5: cpus=2 node=0 flags=0x0 nice=-20 active=1/256
[67501.195698] pending: blk_timeout_work
[67501.195753] workqueue kcopyd: flags=0x8
[67501.195757] pwq 8: cpus=4 node=0 flags=0x0 nice=0 active=1/256
[67501.195768] pending: do_work [dm_mod]
[67501.195802] workqueue kcopyd: flags=0x8
[67501.195806] pwq 8: cpus=4 node=0 flags=0x0 nice=0 active=1/256
[67501.195817] pending: do_work [dm_mod]
[67501.195834] workqueue kcopyd: flags=0x8
[67501.195838] pwq 8: cpus=4 node=0 flags=0x0 nice=0 active=1/256
[67501.195848] pending: do_work [dm_mod]
[67501.195881] workqueue kcopyd: flags=0x8
[67501.195885] pwq 8: cpus=4 node=0 flags=0x0 nice=0 active=1/256
[67501.195896] pending: do_work [dm_mod]
[67501.195920] workqueue kcopyd: flags=0x8
[67501.195924] pwq 8: cpus=4 node=0 flags=0x0 nice=0 active=2/256
[67501.195935] in-flight: 67:do_work [dm_mod]
[67501.195945] pending: do_work [dm_mod]
[67501.195961] pool 8: cpus=4 node=0 flags=0x0 nice=0 hung=27s workers=3 idle: 129 23765
The root cause for these issues is the way dm-snapshot uses kcopyd. In
particular, the lack of an explicit or implicit limit to the maximum
number of in-flight COW jobs. The merging path is not affected because
it implicitly limits the in-flight kcopyd jobs to one.
Fix these issues by using a semaphore to limit the maximum number of
in-flight kcopyd jobs. We grab the semaphore before allocating a new
kcopyd job in start_copy() and start_full_bio() and release it after the
job finishes in copy_callback().
The initial semaphore value is configurable through a module parameter,
to allow fine tuning the maximum number of in-flight COW jobs. Setting
this parameter to zero initializes the semaphore to INT_MAX.
A default value of 2048 maximum in-flight kcopyd jobs was chosen. This
value was decided experimentally as a trade-off between memory
consumption, stalling the kernel's workqueues and maintaining a high
enough throughput.
Re-running the aforementioned test:
* Workqueue stalls are eliminated
* kcopyd's job slab cache uses a maximum of 130MB
* The time taken by the test to write to the snapshot-origin target is
reduced from 05m20.48s to 03m26.38s
[1] https://github.com/jthornber/device-mapper-test-suite
Signed-off-by: Ilias Tsitsimpis <iliastsi@arrikto.com>
[ Upstream commit d7e6b8dfc7bcb3f4f3a18313581f67486a725b52 ]
When using kcopyd to run callbacks through dm_kcopyd_do_callback() or
submitting copy jobs with a source size of 0, the jobs are pushed
directly to the complete_jobs list, which could be under processing by
the kcopyd thread. As a result, the kcopyd thread can continue running
completed jobs indefinitely, without releasing the CPU, as long as
someone keeps submitting new completed jobs through the aforementioned
paths. Processing of work items, queued for execution on the same CPU as
the currently running kcopyd thread, is thus stalled for excessive
amounts of time, hurting performance.
dmtest run --suite snapshot -n parallel_io_to_many_snaps_N
, with 8 active snapshots, we get, in dmesg, messages like the
following:
[68899.948523] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 95s!
[68899.949282] Showing busy workqueues and worker pools:
[68899.949288] workqueue events: flags=0x0
[68899.949295] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256
[68899.949306] pending: vmstat_shepherd, cache_reap
[68899.949331] workqueue mm_percpu_wq: flags=0x8
[68899.949337] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[68899.949345] pending: vmstat_update
[68899.949387] workqueue dm_bufio_cache: flags=0x8
[68899.949392] pwq 4: cpus=2 node=0 flags=0x0 nice=0 active=1/256
[68899.949400] pending: work_fn [dm_bufio]
[68899.949423] workqueue kcopyd: flags=0x8
[68899.949429] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[68899.949437] pending: do_work [dm_mod]
[68899.949452] workqueue kcopyd: flags=0x8
[68899.949458] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=2/256
[68899.949466] in-flight: 13:do_work [dm_mod]
[68899.949474] pending: do_work [dm_mod]
[68899.949487] workqueue kcopyd: flags=0x8
[68899.949493] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[68899.949501] pending: do_work [dm_mod]
[68899.949515] workqueue kcopyd: flags=0x8
[68899.949521] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[68899.949529] pending: do_work [dm_mod]
[68899.949541] workqueue kcopyd: flags=0x8
[68899.949547] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[68899.949555] pending: do_work [dm_mod]
[68899.949568] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=95s workers=4 idle: 27130 27223 1084
Fix this by splitting the complete_jobs list into two parts: A user
facing part, named callback_jobs, and one used internally by kcopyd,
retaining the name complete_jobs. dm_kcopyd_do_callback() and
dispatch_job() now push their jobs to the callback_jobs list, which is
spliced to the complete_jobs list once, every time the kcopyd thread
wakes up. This prevents kcopyd from hogging the CPU indefinitely and
causing workqueue stalls.
* The maximum writing time among all targets is reduced from 09m37.10s
to 06m04.85s and the total run time of the test is reduced from
10m43.591s to 7m19.199s
[ Upstream commit 8d683dcd65c037efc9fb38c696ec9b65b306e573 ]
The iv_offset in the mapping table of crypt target is a 64bit number when
IV algorithm is plain64, plain64be, essiv or benbi. It will be assigned to
iv_offset of struct crypt_config, cc_sector of struct convert_context and
iv_sector of struct dm_crypt_request. These structures members are defined
as a sector_t. But sector_t is 32bit when CONFIG_LBDAF is not set in 32bit
kernel. In this situation sector_t is not big enough to store the 64bit
iv_offset.
Here is a reproducer.
Prepare test image and device (loop is automatically allocated by cryptsetup):
# dd if=/dev/zero of=tst.img bs=1M count=1
# echo "tst"|cryptsetup open --type plain -c aes-xts-plain64 \
--skip 500000000000000000 tst.img test
On 32bit system (use IV offset value that overflows to 64bit; CONFIG_LBDAF if off)
and device checksum is wrong:
# dmsetup table test --showkeys
0 2048 crypt aes-xts-plain64 dfa7cfe3c481f2239155739c42e539ae8f2d38f304dcc89d20b26f69daaf0933 3551657984 7:0 0
# sha256sum /dev/mapper/test
533e25c09176632b3794f35303488c4a8f3f965dffffa6ec2df347c168cb6c19 /dev/mapper/test
On 64bit system (and on 32bit system with the patch), table and checksum is now correct:
0 2048 crypt aes-xts-plain64 dfa7cfe3c481f2239155739c42e539ae8f2d38f304dcc89d20b26f69daaf0933 500000000000000000 7:0 0
5d16160f9d5f8c33d8051e65fdb4f003cc31cd652b5abb08f03aa6fce0df75fc /dev/mapper/test
Signed-off-by: AliOS system security <alios_sys_security@linux.alibaba.com>
Tested-and-Reviewed-by: Milan Broz <gmazyland@gmail.com>
commit c6d6e9b0f6b4201c77f2cea3964dd122697e3543 upstream.
Update DM to set the bdi's io_pages. This fixes reads to be capped at
the device's max request size (even if user's read IO exceeds the
established readahead setting).
Fixes: 9491ae4a ("mm: don't cap request size based on read-ahead setting")
Reviewed-by: Jens Axboe <axboe@kernel.dk>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
Decoupled version bump from commit f6c367585d0 ("dm thin: send event
about thin-pool state change _after_ making it") because version bumps
just create conflicts when backporting to the stable trees.
Sending a DM event before a thin-pool state change is about to happen is
a bug. It wasn't realized until it became clear that userspace response
to the event raced with the actual state change that the event was
meant to notify about.
Fix this by first updating internal thin-pool state to reflect what the
DM event is being issued about. This fixes a long-standing racey/buggy
userspace device-mapper-test-suite 'resize_io' test that would get an
event but not find the state it was looking for -- so it would just go
on to hang because no other events caused the test to reevaluate the
thin-pool's state.
struct bioctx includes the ref refcount_t to track the number of I/O
fragments used to process a target BIO as well as ensure that the zone
of the BIO is kept in the active state throughout the lifetime of the
BIO. However, since decrementing of this reference count is done in the
target .end_io method, the function bio_endio() must be called multiple
times for read and write target BIOs, which causes problems with the
value of the __bi_remaining struct bio field for chained BIOs (e.g. the
clone BIO passed by dm core is large and splits into fragments by the
block layer), resulting in incorrect values and inconsistencies with the
BIO_CHAIN flag setting. This is turn triggers the BUG_ON() call:
BUG_ON(atomic_read(&bio->__bi_remaining) <= 0);
in bio_remaining_done() called from bio_endio().
Fix this ensuring that bio_endio() is called only once for any target
BIO by always using internal clone BIOs for processing any read or
write target BIO. This allows reference counting using the target BIO
context counter to trigger the target BIO completion bio_endio() call
once all data, metadata and other zone work triggered by the BIO
complete.
Overall, this simplifies the code too as the target .end_io becomes
unnecessary and differences between read and write BIO issuing and
completion processing disappear.
Fixes: 3b1a94c88b79 ("dm zoned: drive-managed zoned block device target")
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
Otherwise the incoming bios, of various types, won't be shaped based on
the DM device's advertised limits.
Depends-on: af67c31fba ("blk: remove bio_set arg from blk_queue_split()")
Fixes: 744889b7cb ("block: don't deal with discard limit in blkdev_issue_discard()")
Otherwise dm_bitset_cursor_begin() return -ENODATA. Other calls to
dm_bitset_cursor_begin() have similar negative checks.
Fixes inability to create a cache in passthrough mode (even though doing
so makes no sense).
Fixes: 0d963b6e65 ("dm cache metadata: fix metadata2 format's blocks_are_clean_separate_dirty")
Reported-by: David Teigland <teigland@redhat.com>
Pull block layer fixes from Jens Axboe:
"The biggest part of this pull request is the revert of the blkcg
cleanup series. It had one fix earlier for a stacked device issue, but
another one was reported. Rather than play whack-a-mole with this,
revert the entire series and try again for the next kernel release.
Apart from that, only small fixes/changes.
Summary:
- Indentation fixup for mtip32xx (Colin Ian King)
- The blkcg cleanup series revert (Dennis Zhou)
- Two NVMe fixes. One fixing a regression in the nvme request
initialization in this merge window, causing nvme-fc to not work.
The other is a suspend/resume p2p resource issue (James, Keith)
- Fix sg discard merge, allowing us to merge in cases where we didn't
before (Jianchao Wang)
- Call rq_qos_exit() after the queue is frozen, preventing a hang
(Ming)
- Fix brd queue setup, fixing an oops if we fail setting up all
devices (Ming)"
* tag 'for-linus-20181102' of git://git.kernel.dk/linux-block:
nvme-pci: fix conflicting p2p resource adds
nvme-fc: fix request private initialization
blkcg: revert blkcg cleanups series
block: brd: associate with queue until adding disk
block: call rq_qos_exit() after queue is frozen
mtip32xx: clean an indentation issue, remove extraneous tabs
block: fix the DISCARD request merge
This reverts a series committed earlier due to null pointer exception
bug report in [1]. It seems there are edge case interactions that I did
not consider and will need some time to understand what causes the
adverse interactions.
The original series can be found in [2] with a follow up series in [3].
[1] https://www.spinics.net/lists/cgroups/msg20719.html
[2] https://lore.kernel.org/lkml/20180911184137.35897-1-dennisszhou@gmail.com/
[3] https://lore.kernel.org/lkml/20181020185612.51587-1-dennis@kernel.org/
This reverts the following commits:
d459d853c2ed, b2c3fa546705, 101246ec02b5, b3b9f24f5fcc, e2b0989954ae,
f0fcb3ec89f3, c839e7a03f92, bdc2491708c4, 74b7c02a9bc1, 5bf9a1f3b4ef,
a7b39b4e961c, 07b05bcc3213, 49f4c2dc2b50, 27e6fa996c53
Signed-off-by: Dennis Zhou <dennis@kernel.org>
Pull md updates from Shaohua Li:
"This mainly improves raid10 cluster and fixes some bugs:
- raid10 cluster improvements from Guoqing
- Memory leak fixes from Jack and Xiao
- raid10 hang fix from Alex
- raid5 block faulty device fix from Mariusz
- metadata update fix from Neil
- Invalid disk role fix from Me
- Other clearnups"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/shli/md:
MD: Memory leak when flush bio size is zero
md: fix memleak for mempool
md-cluster: remove suspend_info
md-cluster: send BITMAP_NEEDS_SYNC message if reshaping is interrupted
md-cluster/bitmap: don't call md_bitmap_sync_with_cluster during reshaping stage
md-cluster/raid10: don't call remove_and_add_spares during reshaping stage
md-cluster/raid10: call update_size in md_reap_sync_thread
md-cluster: introduce resync_info_get interface for sanity check
md-cluster/raid10: support add disk under grow mode
md-cluster/raid10: resize all the bitmaps before start reshape
MD: fix invalid stored role for a disk - try2
md/bitmap: use mddev_suspend/resume instead of ->quiesce()
md: remove redundant code that is no longer reachable
md: allow metadata updates while suspending an array - fix
md/raid10: Fix raid10 replace hang when new added disk faulty
raid5: block failing device if raid will be failed
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper updates from Mike Snitzer:
- The biggest change this cycle is to remove support for the legacy IO
path (.request_fn) from request-based DM.
Jens has already started preparing for complete removal of the legacy
IO path in 4.21 but this earlier removal of support from DM has been
coordinated with Jens (as evidenced by the commit being attributed to
him).
Making request-based DM exclussively blk-mq only cleans up that
portion of DM core quite nicely.
- Convert the thinp and zoned targets over to using refcount_t where
applicable.
- A couple fixes to the DM zoned target for refcounting and other races
buried in the implementation of metadata block creation and use.
- Small cleanups to remove redundant unlikely() around a couple
WARN_ON_ONCE().
- Simplify how dm-ioctl copies from userspace, eliminating some
potential for a malicious user trying to change the executed ioctl
after its processing has begun.
- Tweaked DM crypt target to use the DM device name when naming the
various workqueues created for a particular DM crypt device (makes
the N workqueues for a DM crypt device more easily understood and
enhances user's accounting capabilities at a glance via "ps")
- Small fixup to remove dead branch in DM writecache's memory_entry().
* tag 'for-4.20/dm-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm writecache: remove disabled code in memory_entry()
dm zoned: fix various dmz_get_mblock() issues
dm zoned: fix metadata block ref counting
dm raid: avoid bitmap with raid4/5/6 journal device
dm crypt: make workqueue names device-specific
dm: add dm_table_device_name()
dm ioctl: harden copy_params()'s copy_from_user() from malicious users
dm: remove unnecessary unlikely() around WARN_ON_ONCE()
dm zoned: target: use refcount_t for dm zoned reference counters
dm thin: use refcount_t for thin_c reference counting
dm table: require that request-based DM be layered on blk-mq devices
dm: rename DM_TYPE_MQ_REQUEST_BASED to DM_TYPE_REQUEST_BASED
dm: remove legacy request-based IO path
Pull more block layer updates from Jens Axboe:
- Set of patches improving support for zoned devices. This was ready
before the merge window, but I was late in picking it up and hence it
missed the original pull request (Damien, Christoph)
- libata no link power management quirk addition for a Samsung drive
(Diego Viola)
- Fix for a performance regression in BFQ that went into this merge
window (Federico Motta)
- Fix for a missing dma mask setting return value check (Gustavo)
- Typo in the gdrom queue failure case (me)
- NULL pointer deref fix for xen-blkfront (Vasilis Liaskovitis)
- Fixing the get_rq trace point placement in blk-mq (Xiaoguang Wang)
- Removal of a set-but-not-read variable in cdrom (zhong jiang)
* tag 'for-linus-20181026' of git://git.kernel.dk/linux-block:
libata: Apply NOLPM quirk for SAMSUNG MZ7TD256HAFV-000L9
block, bfq: fix asymmetric scenarios detection
gdrom: fix mistake in assignment of error
blk-mq: place trace_block_getrq() in correct place
block: Introduce blk_revalidate_disk_zones()
block: add a report_zones method
block: Expose queue nr_zones in sysfs
block: Improve zone reset execution
block: Introduce BLKGETNRZONES ioctl
block: Introduce BLKGETZONESZ ioctl
block: Limit allocation of zone descriptors for report zones
block: Introduce blkdev_nr_zones() helper
scsi: sd_zbc: Fix sd_zbc_check_zones() error checks
scsi: sd_zbc: Reduce boot device scan and revalidate time
scsi: sd_zbc: Rearrange code
cdrom: remove set but not used variable 'tocuse'
skd: fix unchecked return values
xen/blkfront: avoid NULL blkfront_info dereference on device removal
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"API:
- Remove VLA usage
- Add cryptostat user-space interface
- Add notifier for new crypto algorithms
Algorithms:
- Add OFB mode
- Remove speck
Drivers:
- Remove x86/sha*-mb as they are buggy
- Remove pcbc(aes) from x86/aesni
- Improve performance of arm/ghash-ce by up to 85%
- Implement CTS-CBC in arm64/aes-blk, faster by up to 50%
- Remove PMULL based arm64/crc32 driver
- Use PMULL in arm64/crct10dif
- Add aes-ctr support in s5p-sss
- Add caam/qi2 driver
Others:
- Pick better transform if one becomes available in crc-t10dif"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (124 commits)
crypto: chelsio - Update ntx queue received from cxgb4
crypto: ccree - avoid implicit enum conversion
crypto: caam - add SPDX license identifier to all files
crypto: caam/qi - simplify CGR allocation, freeing
crypto: mxs-dcp - make symbols 'sha1_null_hash' and 'sha256_null_hash' static
crypto: arm64/aes-blk - ensure XTS mask is always loaded
crypto: testmgr - fix sizeof() on COMP_BUF_SIZE
crypto: chtls - remove set but not used variable 'csk'
crypto: axis - fix platform_no_drv_owner.cocci warnings
crypto: x86/aes-ni - fix build error following fpu template removal
crypto: arm64/aes - fix handling sub-block CTS-CBC inputs
crypto: caam/qi2 - avoid double export
crypto: mxs-dcp - Fix AES issues
crypto: mxs-dcp - Fix SHA null hashes and output length
crypto: mxs-dcp - Implement sha import/export
crypto: aegis/generic - fix for big endian systems
crypto: morus/generic - fix for big endian systems
crypto: lrw - fix rebase error after out of bounds fix
crypto: cavium/nitrox - use pci_alloc_irq_vectors() while enabling MSI-X.
crypto: cavium/nitrox - NITROX command queue changes.
Drivers exposing zoned block devices have to initialize and maintain
correctness (i.e. revalidate) of the device zone bitmaps attached to
the device request queue (seq_zones_bitmap and seq_zones_wlock).
To simplify coding this, introduce a generic helper function
blk_revalidate_disk_zones() suitable for most (and likely all) cases.
This new function always update the seq_zones_bitmap and seq_zones_wlock
bitmaps as well as the queue nr_zones field when called for a disk
using a request based queue. For a disk using a BIO based queue, only
the number of zones is updated since these queues do not have
schedulers and so do not need the zone bitmaps.
With this change, the zone bitmap initialization code in sd_zbc.c can be
replaced with a call to this function in sd_zbc_read_zones(), which is
called from the disk revalidate block operation method.
A call to blk_revalidate_disk_zones() is also added to the null_blk
driver for devices created with the zoned mode enabled.
Finally, to ensure that zoned devices created with dm-linear or
dm-flakey expose the correct number of zones through sysfs, a call to
blk_revalidate_disk_zones() is added to dm_table_set_restrictions().
The zone bitmaps allocated and initialized with
blk_revalidate_disk_zones() are freed automatically from
__blk_release_queue() using the block internal function
blk_queue_free_zone_bitmaps().
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Mike Snitzer <snitzer@redhat.com>
Dispatching a report zones command through the request queue is a major
pain due to the command reply payload rewriting necessary. Given that
blkdev_report_zones() is executing everything synchronously, implement
report zones as a block device file operation instead, allowing major
simplification of the code in many places.
sd, null-blk, dm-linear and dm-flakey being the only block device
drivers supporting exposing zoned block devices, these drivers are
modified to provide the device side implementation of the
report_zones() block device file operation.
For device mappers, a new report_zones() target type operation is
defined so that the upper block layer calls blkdev_report_zones() can
be propagated down to the underlying devices of the dm targets.
Implementation for this new operation is added to the dm-linear and
dm-flakey targets.
[Damien]
* Changed method block_device argument to gendisk
* Various bug fixes and improvements
* Added support for null_blk, dm-linear and dm-flakey.
Introduce the blkdev_nr_zones() helper function to get the total
number of zones of a zoned block device. This number is always 0 for a
regular block device (q->limits.zoned == BLK_ZONED_NONE case).
Replace hard-coded number of zones calculation in dmz_get_zoned_device()
with a call to this helper.
Pull block layer updates from Jens Axboe:
"This is the main pull request for block changes for 4.20. This
contains:
- Series enabling runtime PM for blk-mq (Bart).
- Two pull requests from Christoph for NVMe, with items such as;
- Better AEN tracking
- Multipath improvements
- RDMA fixes
- Rework of FC for target removal
- Fixes for issues identified by static checkers
- Fabric cleanups, as prep for TCP transport
- Various cleanups and bug fixes
- Block merging cleanups (Christoph)
- Conversion of drivers to generic DMA mapping API (Christoph)
- Series fixing ref count issues with blkcg (Dennis)
- Series improving BFQ heuristics (Paolo, et al)
- Series improving heuristics for the Kyber IO scheduler (Omar)
- Removal of dangerous bio_rewind_iter() API (Ming)
- Apply single queue IPI redirection logic to blk-mq (Ming)
- Set of fixes and improvements for bcache (Coly et al)
- Series closing a hotplug race with sysfs group attributes (Hannes)
- Set of patches for lightnvm:
- pblk trace support (Hans)
- SPDX license header update (Javier)
- Tons of refactoring patches to cleanly abstract the 1.2 and 2.0
specs behind a common core interface. (Javier, Matias)
- Enable pblk to use a common interface to retrieve chunk metadata
(Matias)
- Bug fixes (Various)
- Set of fixes and updates to the blk IO latency target (Josef)
- blk-mq queue number updates fixes (Jianchao)
- Convert a bunch of drivers from the old legacy IO interface to
blk-mq. This will conclude with the removal of the legacy IO
interface itself in 4.21, with the rest of the drivers (me, Omar)
- Removal of the DAC960 driver. The SCSI tree will introduce two
replacement drivers for this (Hannes)"
* tag 'for-4.20/block-20181021' of git://git.kernel.dk/linux-block: (204 commits)
block: setup bounce bio_sets properly
blkcg: reassociate bios when make_request() is called recursively
blkcg: fix edge case for blk_get_rl() under memory pressure
nvme-fabrics: move controller options matching to fabrics
nvme-rdma: always have a valid trsvcid
mtip32xx: fully switch to the generic DMA API
rsxx: switch to the generic DMA API
umem: switch to the generic DMA API
sx8: switch to the generic DMA API
sx8: remove dead IF_64BIT_DMA_IS_POSSIBLE code
skd: switch to the generic DMA API
ubd: remove use of blk_rq_map_sg
nvme-pci: remove duplicate check
drivers/block: Remove DAC960 driver
nvme-pci: fix hot removal during error handling
nvmet-fcloop: suppress a compiler warning
nvme-core: make implicit seed truncation explicit
nvmet-fc: fix kernel-doc headers
nvme-fc: rework the request initialization code
nvme-fc: introduce struct nvme_fcp_op_w_sgl
flush_pool is leaked when flush bio size is zero
Fixes: 5a409b4f56d5 ("MD: fix lock contention for flush bios")
Signed-off-by: David Jeffery <djeffery@redhat.com>
I noticed kmemleak report memory leak when run create/stop
md in a loop, backtrace:
[<000000001ca975e7>] mempool_create_node+0x86/0xd0
[<0000000095576bcd>] md_run+0x1057/0x1410 [md_mod]
[<000000007b45c5fc>] do_md_run+0x15/0x130 [md_mod]
[<000000001ede9ec0>] md_ioctl+0x1f49/0x25d0 [md_mod]
[<000000004142cacf>] blkdev_ioctl+0x680/0xd00
The root cause is we alloc mddev->flush_pool and
mddev->flush_bio_pool in md_run, but from do_md_stop
will not call into md_stop but __md_stop, move the
mempool_destroy to __md_stop fixes the problem for me.
The bug was introduced in 5a409b4f56d5, the fixes should go to
4.18+
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
Reviewed-by: Xiao Ni <xni@redhat.com>
This dead branch was missed during review. It only makes memory_entry()
more inefficient due to needless call to is_power_of_2(), etc.
Reported-by: shenghui <shhuiw@foxmail.com>
dmz_fetch_mblock() called from dmz_get_mblock() has a race since the
allocation of the new metadata block descriptor and its insertion in
the cache rbtree with the READING state is not atomic. Two different
contexts requesting the same block may end up each adding two different
descriptors of the same block to the cache.
Another problem for this function is that the BIO for processing the
block read is allocated after the metadata block descriptor is inserted
in the cache rbtree. If the BIO allocation fails, the metadata block
descriptor is freed without first being removed from the rbtree.
Fix the first problem by checking again if the requested block is not in
the cache right before inserting the newly allocated descriptor,
atomically under the mblk_lock spinlock. The second problem is fixed by
simply allocating the BIO before inserting the new block in the cache.
Finally, since dmz_fetch_mblock() also increments a block reference
counter, rename the function to dmz_get_mblock_slow(). To be symmetric
and clear, also rename dmz_lookup_mblock() to dmz_get_mblock_fast() and
increment the block reference counter directly in that function rather
than in dmz_get_mblock().
Since the ref field of struct dmz_mblock is always used with the
spinlock of struct dmz_metadata locked, there is no need to use an
atomic_t type. Change the type of the ref field to an unsigne
integer.
With raid4/5/6, journal device and write intent bitmap are mutually exclusive.
Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com>
Previously, we allow multiple nodes can resync device, but we
had changed it to only support one node can do resync at one
time, but suspend_info is still used.
Now, let's remove the structure and use suspend_lo/hi to record
the range.
Reviewed-by: NeilBrown <neilb@suse.com>
We need to continue the reshaping if it was interrupted in
original node. So original node should call resync_bitmap
in case reshaping is aborted.
Then BITMAP_NEEDS_SYNC message is broadcasted to other nodes,
node which continues the reshaping should restart reshape from
mddev->reshape_position instead of from the first beginning.
When reshape is happening in one node, other nodes could receive
lots of RESYNCING messages, so md_bitmap_sync_with_cluster is called.
Since the resyncing window is typically small in these RESYNCING
messages, so WARN is always triggered, so we should not call the
func when reshape is happening.
remove_and_add_spares is not needed if reshape is
happening in another node, because raid10_add_disk
called inside raid10_start_reshape would handle the
role changes of disk. Plus, remove_and_add_spares
can't deal with the role change due to reshape.
We need to change the capacity in all nodes after one node
finishs reshape. And as we did before, we can't change the
capacity directly in md_do_sync, instead, the capacity should
be only changed in update_size or received CHANGE_CAPACITY
msg.
So master node calls update_size after completes reshape in
md_reap_sync_thread, but we need to skip ops->update_size if
MD_CLOSING is set since reshaping could not be finish.
Since the resync region from suspend_info means one node
is reshaping this area, so the position of reshape_progress
should be included in the area.
For clustered raid10 scenario, we need to let all the nodes
know about that a new disk is added to the array, and the
reshape caused by add new member just need to be happened in
one node, but other nodes should know about the change.
Since reshape means read data from somewhere (which is already
used by array) and write data to unused region. Obviously, it
is awful if one node is reading data from address while another
node is writing to the same address. Considering we have
implemented suspend writes in the resyncing area, so we can
just broadcast the reading address to other nodes to avoid the
trouble.
For master node, it would call reshape_request then update sb
during the reshape period. To avoid above trouble, we call
resync_info_update to send RESYNC message in reshape_request.
Then from slave node's view, it receives two type messages:
1. RESYNCING message
Slave node add the address (where master node reading data from)
to suspend list.
2. METADATA_UPDATED message
Once slave nodes know the reshaping is started in master node,
it is time to update reshape position and call start_reshape to
follow master node's step. After reshape is done, only reshape
position is need to be updated, so the majority task of reshaping
is happened on the master node.
To support add disk under grow mode, we need to resize
all the bitmaps of each node before reshape, so that we
can ensure all nodes have the same view of the bitmap of
the clustered raid.
So after the master node resized the bitmap, it broadcast
a message to other slave nodes, and it checks the size of
each bitmap are same or not by compare pages. We can only
continue the reshaping after all nodes update the bitmap
to the same size (by checking the pages), otherwise revert
bitmap size to previous value.
The resize_bitmaps interface and BITMAP_RESIZE message are
introduced in md-cluster.c for the purpose.
Make cpu-usage debugging easier by naming workqueues per device.
Example ps output:
root 413 0.0 0.0 0 0 ? I< paź02 0:00 [kcryptd_io/253:0]
root 414 0.0 0.0 0 0 ? I< paź02 0:00 [kcryptd/253:0]
root 415 0.0 0.0 0 0 ? S paź02 1:10 [dmcrypt_write/253:0]
root 465 0.0 0.0 0 0 ? I< paź02 0:00 [kcryptd_io/253:2]
root 466 0.0 0.0 0 0 ? I< paź02 0:00 [kcryptd/253:2]
root 467 0.0 0.0 0 0 ? S paź02 2:06 [dmcrypt_write/253:2]
root 15359 0.2 0.0 0 0 ? I< 19:43 0:25 [kworker/u17:8-kcryptd/253:0]
root 16563 0.2 0.0 0 0 ? I< 20:10 0:18 [kworker/u17:0-kcryptd/253:2]
root 23205 0.1 0.0 0 0 ? I< 21:21 0:04 [kworker/u17:4-kcryptd/253:0]
root 13383 0.1 0.0 0 0 ? I< 21:32 0:02 [kworker/u17:2-kcryptd/253:2]
root 2610 0.1 0.0 0 0 ? I< 21:42 0:01 [kworker/u17:12-kcryptd/253:2]
root 20124 0.1 0.0 0 0 ? I< 21:56 0:01 [kworker/u17:1-kcryptd/253:2]
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Add a shortcut for dm_device_name(dm_table_get_md(t)).
In copy_params(), the struct 'dm_ioctl' is first copied from the user
space buffer 'user' to 'param_kernel' and the field 'data_size' is
checked against 'minimum_data_size' (size of 'struct dm_ioctl' payload
up to its 'data' member). If the check fails, an error code EINVAL will be
returned. Otherwise, param_kernel->data_size is used to do a second copy,
which copies from the same user-space buffer to 'dmi'. After the second
copy, only 'dmi->data_size' is checked against 'param_kernel->data_size'.
Given that the buffer 'user' resides in the user space, a malicious
user-space process can race to change the content in the buffer between
the two copies. This way, the attacker can inject inconsistent data
into 'dmi' (versus previously validated 'param_kernel').
Fix redundant copying of 'minimum_data_size' from user-space buffer by
using the first copy stored in 'param_kernel'. Also remove the
'data_size' check after the second copy because it is now unnecessary.
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
WARN_ON() already contains an unlikely(), so it's not necessary to
wrap it into another.
Signed-off-by: Igor Stoppa <igor.stoppa@huawei.com>
The API surrounding refcount_t should be used in place of atomic_t
when variables are being used as reference counters. This API can
prevent issues such as counter overflows and use-after-free
conditions. Within the dm zoned target stack, the atomic_t API is
used for bioctx->ref and cw->refcount. Change these to use
refcount_t, avoiding the issues mentioned.
Signed-off-by: John Pittman <jpittman@redhat.com>
Reviewed-by: Damien Le Moal <damien.lemoal@wdc.com>
Tested-by: Damien Le Moal <damien.lemoal@wdc.com>
when variables are being used as reference counters. It can
potentially prevent reference counter overflows and use-after-free
conditions. In the dm thin layer, one such example is tc->refcount.
Change this from the atomic_t API to the refcount_t API to prevent
mentioned conditions.
Commit d595567dc4f0 (MD: fix invalid stored role for a disk) broke linear
hotadd. Let's only fix the role for disks in raid1/10.
Based on Guoqing's original patch.
Reported-by: kernel test robot <rong.a.chen@intel.com>
Cc: Gioh Kim <gi-oh.kim@profitbricks.com>
Cc: Guoqing Jiang <gqjiang@suse.com>
Now that request-based DM (multipath) is blk-mq only: this restriction
is required while the legacy request-based IO path still exists.
