path: root/drivers/media/Kconfig
2006-10-04V4L/DVB (4706): Do not enable VIDEO_V4L2 unconditionallyMaciej W. Rozycki
The VIDEO_V4L2 config setting is enabled unconditionally, even for configurations with no support for this subsystem whatsoever. The following patch adds the necessary dependency. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-10V4L/DVB (4605): Fixes an issue with V4L1 and make headers-installMauro Carvalho Chehab
V4L1 support should be disabled when no CONFIG_VIDEO_V4L1_COMPAT is defined, to allow checking for broken V4L2 ports. This is very important during the migration phase for V4L2 API. However, userspace apps should be capable of using both APIs, since they need to test at runtime, via VIDIOCGCAP ioctl, if V4L1 is supported. So, when __KERNEL__ is not defined, those ioctls and corresponding structs should be visible. This patch also removes the obsolete defines HAVE_V4L1 and HAVE_V4L2, that where causing some confusion, and were replaced by CONFIG_VIDEO_V4L1_COMPAT and CONFIG_VIDEO_V4L2. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-26V4L/DVB (4214): Make VIDEO_CX2341X a selectable build optionMichael Krufky
The cx2341x mpeg encoder module is used by cx88-blackbird, pvrusb2 and the external ivtv driver. This patch allows for cx2341x to be selected without having to also select cx88-blackbird. This will be needed to build the external ivtv driver or the standalone pvrusb2 driver against kernel 2.6.18 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4191): Add CX2341X MPEG encoder module.Hans Verkuil
Adds the cx2341x.c module that handles the programming of the Conexant cx23415/6 MPEG encoder chip used by cx88-blackbird, pvrusb2 and ivtv. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4052): Wrong syntax: instead of bool, it was written booleanMauro Carvalho Chehab
2006-05-12V4L/DVB (3774): Create V4L1 config optionsMauro Carvalho Chehab
V4L1 API is depreciated and should be removed soon from kernel. This patch adds two new options, one to disable V4L1 drivers, and another to disable V4L1 compat module. This way, it would be easy to check what still depends on V4L1 stuff, allowing also to test if app works fine with V4L2 only support. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3619): Whitespace cleanupMauro Carvalho Chehab
2006-03-25V4L/DVB (3599a): Move drivers/usb/media to drivers/media/videoMauro Carvalho Chehab
Because of historic reasons, there are two separate directories with V4L stuff. Most drivers are located at driver/media/video. However, some code for USB Webcams were inserted under drivers/usb/media. This makes difficult for module authors to know were things should be. Also, makes Kconfig menu confusing for normal users. This patch moves all V4L content under drivers/usb/media to drivers/media/video, and fixes Kconfig/Makefile entries. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
