path: root/drivers/media/Kconfig
2013-06-20[media] Fix build when drivers are builtin and frontend modulesMauro Carvalho Chehab
There are a large number of reports that the media build is not compiling when some drivers are compiled as builtin, while the needed frontends are compiled as module. On the last one of such reports: From: kbuild test robot <fengguang.wu@intel.com> Subject: saa7134-dvb.c:undefined reference to `zl10039_attach' The .config file has: CONFIG_VIDEO_SAA7134=y CONFIG_VIDEO_SAA7134_DVB=y # CONFIG_MEDIA_ATTACH is not set CONFIG_DVB_ZL10039=m And it produces all those errors: drivers/built-in.o: In function `set_type': tuner-core.c:(.text+0x2f263e): undefined reference to `tea5767_attach' tuner-core.c:(.text+0x2f273e): undefined reference to `tda9887_attach' drivers/built-in.o: In function `tuner_probe': tuner-core.c:(.text+0x2f2d20): undefined reference to `tea5767_autodetection' drivers/built-in.o: In function `av7110_attach': av7110.c:(.text+0x330bda): undefined reference to `ves1x93_attach' av7110.c:(.text+0x330bf7): undefined reference to `stv0299_attach' av7110.c:(.text+0x330c63): undefined reference to `tda8083_attach' av7110.c:(.text+0x330d09): undefined reference to `ves1x93_attach' av7110.c:(.text+0x330d33): undefined reference to `tda8083_attach' av7110.c:(.text+0x330d5d): undefined reference to `stv0297_attach' av7110.c:(.text+0x330dbe): undefined reference to `stv0299_attach' drivers/built-in.o: In function `tuner_attach_dtt7520x': ngene-cards.c:(.text+0x3381cb): undefined reference to `dvb_pll_attach' drivers/built-in.o: In function `demod_attach_lg330x': ngene-cards.c:(.text+0x33828a): undefined reference to `lgdt330x_attach' drivers/built-in.o: In function `demod_attach_stv0900': ngene-cards.c:(.text+0x3383d5): undefined reference to `stv090x_attach' drivers/built-in.o: In function `cineS2_probe': ngene-cards.c:(.text+0x338b7f): undefined reference to `drxk_attach' drivers/built-in.o: In function `configure_tda827x_fe': saa7134-dvb.c:(.text+0x346ae7): undefined reference to `tda10046_attach' drivers/built-in.o: In function `dvb_init': saa7134-dvb.c:(.text+0x347283): undefined reference to `mt352_attach' saa7134-dvb.c:(.text+0x3472cd): undefined reference to `mt352_attach' saa7134-dvb.c:(.text+0x34731c): undefined reference to `tda10046_attach' saa7134-dvb.c:(.text+0x34733c): undefined reference to `tda10046_attach' saa7134-dvb.c:(.text+0x34735c): undefined reference to `tda10046_attach' saa7134-dvb.c:(.text+0x347378): undefined reference to `tda10046_attach' saa7134-dvb.c:(.text+0x3473db): undefined reference to `tda10046_attach' drivers/built-in.o:saa7134-dvb.c:(.text+0x347502): more undefined references to `tda10046_attach' follow drivers/built-in.o: In function `dvb_init': saa7134-dvb.c:(.text+0x347812): undefined reference to `mt352_attach' saa7134-dvb.c:(.text+0x347951): undefined reference to `mt312_attach' saa7134-dvb.c:(.text+0x3479a9): undefined reference to `mt312_attach' >> saa7134-dvb.c:(.text+0x3479c1): undefined reference to `zl10039_attach' This is happening because a builtin module can't use directly a symbol found on a module. By enabling CONFIG_MEDIA_ATTACH, the configuration becomes valid, as dvb_attach() macro loads the module if needed, making the symbol available to the builtin module. While this bug started to appear after the patches that use IS_DEFINED macro (like changeset 7b34be71db533f3e0cf93d53cf62d036cdb5418a), this bug is a way ancient than that. The thing is that, before the IS_DEFINED() patches, the logic used to be: && defined(MODULE)) struct dvb_frontend *zl10039_attach(struct dvb_frontend *fe, u8 i2c_addr, struct i2c_adapter *i2c); static inline struct dvb_frontend *zl10039_attach(struct dvb_frontend *fe, u8 i2c_addr, struct i2c_adapter *i2c) { printk(KERN_WARNING "%s: driver disabled by Kconfig\n", __func__); return NULL; } The above code, with the .config file used, was evoluting to FALSE (instead of TRUE as it should be, as CONFIG_DVB_ZL10039 is 'm'), and were adding the static inline code at saa7134-dvb, instead of the external call. So, while it weren't producing any compilation error, the code weren't working either. So, as the overhead for using CONFIG_MEDIA_ATTACH is minimal, just enable it, if MODULES is defined. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Some cleanups at V4L2 documentation - new drivers: ts2020 frontend, ov9650 sensor, s5c73m3 sensor, sh-mobile veu mem2mem driver, radio-ma901, davinci_vpfe staging driver - Lots of missing MAINTAINERS entries added - several em28xx driver improvements, including its conversion to videobuf2 - several fixups on drivers to make them to better comply with the API - DVB core: add support for DVBv5 stats, allowing the implementation of statistics for new standards like ISDB - mb86a20s: add statistics to the driver - lots of new board additions, cleanups, and driver improvements. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (596 commits) [media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff) [media] rtl28xxu: Add USB IDs for Compro VideoMate U620F [media] em28xx: add usb id for terratec h5 rev. 3 [media] media: rc: gpio-ir-recv: add support for device tree parsing [media] mceusb: move check earlier to make smatch happy [media] radio-si470x doc: add info about v4l2-ctl and sox+alsa [media] staging: media: Remove unnecessary OOM messages [media] sh_vou: Use vou_dev instead of vou_file wherever possible [media] sh_vou: Use video_drvdata() [media] drivers/media/platform/soc_camera/pxa_camera.c: use devm_ functions [media] mt9t112: mt9t111 format set up differs from mt9t112 [media] sh-mobile-ceu-camera: fix SHARPNESS control default Revert "[media] fc0011: Return early, if the frequency is already tuned" [media] cx18/ivtv: fix regression: remove __init from a non-init function [media] em28xx: fix analog streaming with USB bulk transfers [media] stv0900: remove unnecessary null pointer check [media] fc0011: Return early, if the frequency is already tuned [media] fc0011: Add some sanity checks and cleanups [media] fc0011: Fix xin value clamping Revert "[media] [PATH,1/2] mxl5007 move reset to attach" ...
2013-01-11drivers/media: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] Improve media Kconfig menuHans Verkuil
I've always found it very confusing that the "Media ancillary drivers (tuners, sensors, i2c, frontends)" comment came after the "Autoselect" option. This patch moves it up and changes the "Autoselect" text to correspond more closely to the "Media ancillary drivers" comment. It also fixes two typos. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] ttpci: Fix a missing Kconfig dependencyMauro Carvalho Chehab
Fix a Kconfig warning that appears with allmodconfig on arm: warning: (DVB_USB_PCTV452E) selects TTPCI_EEPROM which has unmet direct dependencies (MEDIA_SUPPORT && MEDIA_PCI_SUPPORT && MEDIA_DIGITAL_TV_SUPPORT && I2C) Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-17[media] Kconfig: Fix dependencies for driver autoselect optionsMauro Carvalho Chehab
This option is a merge of both analog TV and DVB CUSTOMISE. At the merge, the dependencies were not done right: the menu currently appears only for analog TV. It should also be opened for digital TV. As there are other I2C devices there (flash devices, etc) that aren't related to either one, it is better to make it generic enough to open for all media devices with video. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-21[media] Kconfig: merge all customise options into just oneMauro Carvalho Chehab
Instead of having 3 options to allow customizing the media sub-drivers (tuners, I2C drivers, frontends), merge all of them into just one. That simplifies the life for users, as they can just keep this untouched. Life for developers is also simpler, as there's now just one Kconfig item to remember, for the ancillary sub-drivers providing supports for chips that could change from one board design to another. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-21[media] Cleanup media Kconfig filesMauro Carvalho Chehab
- get rid of ridden V4L2_COMMON symbol This symbol is not needed anymore; it can be folded with V4L2 one, simplifying the Kconfig a little bit; - Comment why some Kconfig items are needed; - Remove if test for MEDIA_CAMERA_SUPPORT, replacing it by depends on. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-21[media] Kconfig reorganizationMauro Carvalho Chehab
Reorganize the Kconfig order, for it to be a little more intuitive. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move i2c files into drivers/media/i2cMauro Carvalho Chehab
Move ancillary I2C drivers into drivers/media/i2c, in order to better organize them. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] reorganize the API core itemsMauro Carvalho Chehab
Reorganize the API core changes for them to appear closer to the items that enable them, and not at the drivers part of the menu. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move parallel port/isa video drivers to drivers/media/parport/Mauro Carvalho Chehab
We should keep just the I2C drivers under drivers/media/video, and then rename it to drivers/media/i2c. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] siano: break it into common, mmc and usbMauro Carvalho Chehab
siano is, in fact, 2 drivers: one for MMC and one for USB, plus a common bus-independent code. Break it accordingly. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] common: move media/common/tuners to media/tunersMauro Carvalho Chehab
Move the tuners one level up, as the "common" directory will be used by drivers that are shared between more than one driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] b2c2: break it into common/pci/usb directoriesMauro Carvalho Chehab
b2c2 is, in fact, 2 drivers: one for PCI and one for USB, plus a common bus-independent code. Break it accordingly. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] Rename media/dvb as media/pciMauro Carvalho Chehab
The remaining dvb drivers are pci, so rename them to match the bus. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] dvb-usb: move it to drivers/media/usb/dvb-usbMauro Carvalho Chehab
As media/dvb will be removed, move it to a proper place. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] firewire: move it one level upMauro Carvalho Chehab
Move firewire to one level up, as the dvb subdirectory will be removed. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] move the dvb/frontends to drivers/media/dvb-frontendsMauro Carvalho Chehab
Raise the DVB frontends one level up, as the intention is to remove the drivers/media/dvb directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] dvb: move the dvb core one level upMauro Carvalho Chehab
just like the V4L2 core, move the DVB core to drivers/media, as the intention is to get rid of both "video" and "dvb" directories. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] v4l: move v4l2 core into a separate directoryMauro Carvalho Chehab
Currently, the v4l2 core is mixed together with other non-core drivers. Move them into a separate directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-06[media] Kconfig: Split the core support options from the driver onesMauro Carvalho Chehab
Better arrange the remote controller driver items to happen after the core support, on their proper menus, and making clerarer what is media core options and what is media driver options. Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-05[media] media: Remove VIDEO_MEDIA Kconfig optionMauro Carvalho Chehab
In the past, it was possible to have either DVB or V4L2 core as module and the other as builtin. Such config never make much sense, and created several issues in order to make the Kconfig dependency to work, as all drivers that depend on both (most TV drivers) would need to be compiled as 'm'. Due to that, the VIDEO_MEDIA config option were added. Instead of such weird approach, let's just use the MEDIA_SUPPORT =y or =m to select if the media subsystem core will be either builtin or module, simplifying the building system logic. Also, fix the tuners configuration, by enabling them only if a tuner is required. So, if just webcam/grabbers support is selected, no tuner option will be selected. Also, if only digital TV is selected, no analog tuner support is selected. That removes the need of using EXPERT customise options, when analog TV is not selected. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-05[media] media: reorganize the main Kconfig itemsMauro Carvalho Chehab
Change the main items to: <m> Multimedia support ---> [ ] Cameras/video grabbers support [ ] Analog TV support [ ] Digital TV support [ ] AM/FM radio receivers/transmitters support [ ] Remote Controller support This provides an interface that is clearer to end users that are compiling the Kernel, and will allow the building system to automatically unselect drivers for unused functions. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] DVB: dvb-net, make the kconfig text helpfulJiri Slaby
Telling the user they can disable an option if they want is not the much useful. Describe what it is good for instead. The text was derived from Mauro's email. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Hans Petter Selasky <hselasky@c2i.net> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Hans Petter Selasky <hselasky@c2i.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] media: DVB_NET must depend on DVB_COREGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] Make DVB NET configurable in the kernelHans Petter Selasky
Signed-off-by: Hans Petter Selasky <hselasky@c2i.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Create v4l2 subdev file handle structureStanimir Varbanov
Used for storing subdev information per file handle and hold V4L2 file handle. Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Antti Koskipaa <akoskipa@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Media device node supportLaurent Pinchart
The media_devnode structure provides support for registering and unregistering character devices using a dynamic major number. Reference counting is handled internally, making device drivers easier to write without having to solve the open/disconnect race condition issue over and over again. The code is based on video/v4l2-dev.c. [mchehab@redhat.com: Remove linux/smp_lock.h include to not break compilation on bisect] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] dabusb: Move it to staging to be deprecatedMauro Carvalho Chehab
dabusb driver were conceived as an experimental driver for a test device. The driver never supported any shipped product, and, while there were some updates on it in 2003, for an ancient product, those changes were never submitted upstream. Also, there's no DocBook for its API, nor any upstream discussion. So, better to remove it, on .39. If later needed, we may rescue it from git logs. For now, let's move it to staging. Acked-by: Deti Fliegl <deti@fliegl.de> Cc: Deti Fliegl <deti@fliegl.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Remove VIDEO_V4L1 Kconfig optionMauro Carvalho Chehab
There's no sense on keeping VIDEO_V4L1 Kconfig option just because of two deprecated drivers moved to staging scheduled to die on 2.6.39. Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] V4L: remove V4L1 compatibility modeHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] rename drivers/media/IR to drives/media/rcMauro Carvalho Chehab
2010-11-08[media] v4l: kill the BKLArnd Bergmann
All of the hard problems for BKL removal appear to be solved in the v4l-dvb/master tree. This removes the BKL from the various open functions that do not need it, or only use it to protect an open count. The zoran driver is nontrivial in this regard, so I introduce a new mutex that locks both the open/release and the ioctl functions. Someone with access to the hardware can probably improve that by using the existing lock in all cases. Finally, all drivers that still use the locked version of the ioctl function now get called under a new mutex instead of the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-12-16V4L/DVB (13612): IR: Move common IR code to drivers/media/IRMauro Carvalho Chehab
This is the first step of creating a common code for IR that can be used by other input devices. For now, keep IR dir at drivers/media, to easy the movement of the IR files, but later patches may move it to drivers/IR or drivers/input/IR. No functional changes is done on this patch. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11881): one kconfig controls them allRandy Dunlap
Add a kconfig symbol that allows someone to disable all multimedia config options at one time. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10633): DAB: fix typoMárton Németh
Fix typo in "DAB adapters" section in Kconfig. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (8392): media/Kconfig: Convert V4L1_COMPAT select into "depends on"Mauro Carvalho Chehab
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8274): sms1xxx: build cleanup after driver relocationMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8258): add support for SMS1010 and SMS1150 based digital television ↵Michael Krufky
devices initial driver drop, provided by Siano Mobile Silicon, Inc. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7898): Fix VIDEO_MEDIA Kconfig logicMauro Carvalho Chehab
If one of DVB_CORE or VIDEO_DEV is a module, the modules that can be used by both DVB and V4L cores should also be a module, otherwise, it will break its dependencies. This Kconfig logic implements the following: CONFIG_VIDEO_DEV CONFIG_DVB_CORE CONFIG_VIDEO_MEDIA N N N N M M N Y Y M N M M M M M Y M Y N Y Y M M Y Y Y Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29Fix V4L/DVB core help messagesMauro Carvalho Chehab
2008-04-29V4L/DVB(7767): Move tuners to common/tunersMauro Carvalho Chehab
There were several issues in the past, caused by the hybrid tuner design, since now, the same tuner can be used by drivers/media/dvb and drivers/media/video. Kconfig items were rearranged, to split V4L/DVB core from their drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7584): Fix build that occurs when CONFIG_VIDEO_PMS=y and ↵Mauro Carvalho Chehab
VIDEO_V4L2_COMMON=m This patch removes zoran checks for VIDEO_V4L2, since this API is always present, when V4L is selected. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7483): tuner-simple: fix broken build dependencyMichael Krufky
tuner-simple is the only module that uses tuner-types - these will be merged to a single module in the future. For now, build both of them if TUNER_SIMPLE is selected. This fixes the following build warning, if tuner-simple is selected without tuner-types: WARNING: "tuner_count" [tuner-simple.ko] undefined! WARNING: "tuners" [tuner-simple.ko] undefined! Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7237): Convert videobuf-dma-sg to generic DMA APIGuennadi Liakhovetski
videobuf-dma-sg does not need to depend on PCI. Switch it to using generic DMA API, convert all affected drivers, relax Kconfig restriction, improve compile-time type checking, fix some Coding Style violations while at it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7196): Lift videobuf-dma-sg's PCI dependency, until it is fixedGuennadi Liakhovetski
videobuf-dma-sg.c should be converted to the generic DMA API to make it also useful for non-PCI configurations. Even now it can be used thanks to compatibility macros in include/asm-generic/pci-dma-compat.h. This has been verified to work on PXA270 CPU with the pxa_camera.c soc-camera driver. For this the following temporary work-around is needed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7125): tuner: build tuner-types independently of tuner-coreMichael Krufky
tuner-types is needed for tuner-simple, and does not need to be bound to tuner-core. Any caller of tuner-simple, including tuner-core, needs to pass a structure from tuner-types into tuner-simple at attach-time. Export the two needed symbols from tuner-types for now, so that card-level drivers can attach tuner-simple for hybrid dvb_frontend devices. We will remove this dependency altogether as tuner refactoring phase 3 progresses. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
