path: root/drivers/media/common/saa7146_core.c
2008-04-24V4L/DVB (7508): media/common/ replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-30NULL noise: drivers/mediaAl Viro
Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/media/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-11-04V4L/DVB (6495): saa7146: saa7146_wait_for_debi_done fixesOliver Endriss
Two fixes for the 'saa7146_wait_for_debi_done' code: (a) Timeout did not work when the routine was called with interrupts disabled. (b) Reduce PCI I/O load caused by saa7146_wait_for_debi_done. Seems to be very important on fast machines! Based on code posted by Hartmut Birr @vdr-portal. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-09V4L/DVB (6252): Adapt drivers to use the newer videobuf modulesMauro Carvalho Chehab
PCI-dependent videobuf_foo methods were renamed as videobuf_pci_foo. Also, videobuf_dmabuf is now part of videobuf-dma-sg private struct. So, to access it, a subroutine call is needed. This patch renames all occurences of those function calls to be consistent with the video-buf split. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981 Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
2007-10-09V4L/DVB (5987): saa7146: clean-up irq processingOliver Endriss
Interrupt processing fixed: First handle interrupt, then acknowledge it. Otherwise the same interrupt might occur twice. Cleaned-up i2c interrupt handler and i2c error messages. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5934): dvb-ttpci/saa7146: Replace saa7146_i2c_transfer by generic ↵Oliver Endriss
i2c_transfer Convert av7110_v4l.c to use i2c_transfer() instead of saa7146_i2c_transfer(). Make saa7146_i2c_transfer() static. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5835): saa7146/dvb-ttpci: Fix signedness warnings (gcc 4.1.1, ↵Oliver Endriss
kernel 2.6.22) Fix signedness warnings (gcc 4.1.1, kernel 2.6.22). Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5592): DMA: Correctly free resources on error, sync PCI streamed dataJon Burgess
I added saa7146_vmalloc_destroy_pgtable() which frees the resources allocated by saa7146_vmalloc_build_pgtable() and updated the callers in budget-core.c and av7110.c. I have also been through the updated functions and updated the error paths to ensure they free all allocated resources on error. I also realised that there are other callers to saa7146_pgtable_free() which did not have any sg DMA mapped so it seems wrong to add the pci_unmap_sg() into that function. Instead I created saa7146_vmalloc_destroy_pgtable() to do this. Also included in this patch are the previous fixes for pci_unmap_sg() and syncing the PCI streamed data to work with a SWIOTLB and match the requirements documented in DMA-API.txt. Signed-off-by: Jon Burgess <jburgess777@googlemail.com> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: media: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21V4L/DVB (3485): BUG_ON() Conversion in drivers/video/mediaEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3318b): sem2mutex: drivers/media/, #2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-12-12[PATCH] V4L/DVB: (3086c) Whitespaces cleanups part 3Mauro Carvalho Chehab
Clean up whitespaces at v4l/dvb files Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] vfree and kfree cleanup in drivers/Jesper Juhl
This patch does a full cleanup of 'NULL checks before vfree', and a partial cleanup of calls to kfree for all of drivers/ - the kfree bit is partial in that I only did the files that also had vfree calls in them. The patch also gets rid of some redundant (void *) casts of pointers being passed to [vk]free, and a some tiny whitespace corrections also crept in. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: ttpci: fix timeout handling to be save with PREEMPTOliver Endriss
Timeout handling fixed, especially for preemtible kernels and/or high system load. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: saa7146: kj pci_module_init cleanupChristophe Lucas
http://kerneljanitors.org/TODO - convert from pci_module_init to pci_register_driver Signed-off-by: Christophe Lucas <c.lucas@ifrance.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: saa7146: no need to initialize static/global variables to 0Johannes Stezenbach
no need to initialize static/global variables to 0 Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
