path: root/drivers/media/common/saa7146_fops.c
2008-03-30NULL noise: drivers/mediaAl Viro
Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25V4L/DVB (7035): drivers/media/common: Add missing video_device_releaseJulia Lawall
Video_device_alloc returns the result of a kzalloc. In this case, the value is stored in a local variable which is not copied elsewhere before the point of the error return (video_register_device does not save its first argument anywhere if it returns a negative value). Thus, a video_device_release it needed before the error return. The problem was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T,T1,T2; identifier E; statement S; expression x1,x2,x3; int ret; @@ T E; ... * E = video_device_alloc(...); if (E == NULL) S ... when != video_device_release(...,(T1)E,...) when != if (E != NULL) { ... video_device_release(...,(T1)E,...); ...} when != x1 = (T1)E when != E = x3; when any if (...) { ... when != video_device_release(...,(T2)E,...) when != if (E != NULL) { ... video_device_release(...,(T2)E,...); ...} when != x2 = (T2)E ( * return; | * return ret; ) } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> CC: Oliver Endriss <o.endriss@gmx.de> CC: Michael Hunold <michael@mihu.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6600): V4L: videobuf: don't chew up namespace STATE_.*, convert to ↵Brandon Philips
VIDEOBUF_ s/STATE_NEEDS_INIT/VIDEOBUF_NEEDS_INIT/g s/STATE_PREPARED/VIDEOBUF_PREPARED/g s/STATE_QUEUED/VIDEOBUF_QUEUED/g s/STATE_ACTIVE/VIDEOBUF_ACTIVE/g s/STATE_DONE/VIDEOBUF_DONE/g s/STATE_ERROR/VIDEOBUF_ERROR/g s/STATE_IDLE/VIDEOBUF_IDLE/g Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6252): Adapt drivers to use the newer videobuf modulesMauro Carvalho Chehab
PCI-dependent videobuf_foo methods were renamed as videobuf_pci_foo. Also, videobuf_dmabuf is now part of videobuf-dma-sg private struct. So, to access it, a subroutine call is needed. This patch renames all occurences of those function calls to be consistent with the video-buf split. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981 Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
2007-05-09V4L/DVB (5591): Saa7146: proper prototype for saa7146_video_do_ioctl()Adrian Bunk
This patch adds a proper prototype for saa7146_video_do_ioctl() in include/media/saa7146_vv.h. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5160): Saa7146_vv: pass correct memory size to pci_free_consistentMarco Schluessler
Pass correct memory size to pci_free_consistent. Signed-off-by: Marco Schluessler <marco@lordzodiac.de> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26V4L/DVB (4421): V4L2 Conversion: saa5246a, saa5249, vino, hexium_orion, ↵Mauro Carvalho Chehab
hexium_gemini Just a few adjustments were required on those drivers to be V4L2 compliant. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3770): Kill drivers/media/common/saa7146_vv_ksyms.cAdrian Bunk
This patch moves the EXPORT_SYMBOL's from drivers/media/common/saa7146_vv_ksyms.c to the files with the actual functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3516): Make video_buf more genericMauro Carvalho Chehab
Video_buf were concerned to allow PCI devices to be used as video capture devices. This patch extends video_buf features by virtualizing pci-dependent functions and allowing other type of devices to use it. It is still DMA centric, although it may be used also by devices that emulates scatter/gather behavior or a DMA device Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3485): BUG_ON() Conversion in drivers/video/mediaEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3318b): sem2mutex: drivers/media/, #2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3325): WSS output interface for av7110Oliver Endriss
- Implemented v4l2 api for sliced vbi data output to pass WSS data from userspace to the av7110 Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3218): Whitespace cleanupsMichael Krufky
- minor whitespace cleanups Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-12-12[PATCH] V4L/DVB: (3086c) Whitespaces cleanups part 3Mauro Carvalho Chehab
Clean up whitespaces at v4l/dvb files Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] dvb: remove version.h dependenciesOlaf Hering
Remove all #include <linux/version.h> and all references to LINUX_VERSION_CODE and KERNEL_VERSION. Based on patch by Olaf Hering. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] make various thing staticAdrian Bunk
Another rollup of patches which give various symbols static scope Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
