Implement Philips FM1216MK5.
1. Implement get_stereo function.
2. Add correct data byte for FM radio mode
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Change order data of buffer in FM simple_tune function. It is usefull for:
1. Set data of tuner with CP bit UP. 0xCE for MK5 or 0xC6 for MK3
2. When call simple_fm_tune, read this byte from config and overwrite
this byte in function simple_radio_bandswitch for set CP bit to OFF.
Of course it can be usefull for other tuner for overwrite default
settings of FM.
Signed-off-by: Andy Walls <awalls@radix.net>
As reported by David Engel <david@istwok.net>, ATSC115 doesn't work
fine with mythtv. This software opens both analog and dvb interfaces of
saa7134.
What happens is that some tuner commands are going to the wrong place,
as shown at the logs:
Feb 12 20:37:48 opus kernel: tuner-simple 1-0061: using tuner params #0 (ntsc)
Feb 12 20:37:48 opus kernel: tuner-simple 1-0061: freq = 67.25 (1076), range = 0, config = 0xce, cb = 0x01
Feb 12 20:37:48 opus kernel: tuner-simple 1-0061: Freq= 67.25 MHz, V_IF=45.75 MHz, Offset=0.00 MHz, div=1808
Feb 12 20:37:48 opus kernel: tuner 1-0061: tv freq set to 67.25
Feb 12 20:37:48 opus kernel: tuner-simple 1-000a: using tuner params #0 (ntsc)
Feb 12 20:37:48 opus kernel: tuner-simple 1-000a: freq = 67.25 (1076), range = 0, config = 0xce, cb = 0x01
Feb 12 20:37:48 opus kernel: tuner-simple 1-000a: Freq= 67.25 MHz, V_IF=45.75 MHz, Offset=0.00 MHz, div=1808
Feb 12 20:37:48 opus kernel: tuner-simple 1-000a: tv 0x07 0x10 0xce 0x01
Feb 12 20:37:48 opus kernel: tuner-simple 1-0061: tv 0x07 0x10 0xce 0x01
This happens due to a hack at TUV1236D analog setup, where it replaces
tuner address, at 0x61 for 0x0a, in order to save a few memory bytes.
The code assumes that nobody else would try to access the tuner during
that setup, but the point is that there's no lock to protect such
access. So, this opens the possibility of race conditions to happen.
Instead of hacking tuner address, this patch uses a temporary var with
the proper tuner value to be used during the setup. This should save
the issue, although we should consider to write some analog/digital
lock at saa7134 driver.
zero error
A user reported the following OOPS with his pcHDTV HD5500 card, which
uses a cx88 PCI bridge with a LG-TDVS-H06xF frontend module, made up
of a TUA6034 tuner, TDA988x IF demod, and LG DT3303 ATSC/QAM demod.
Somehow, tuner-core gets loaded before the digital driver configures
the tuner, and tuner-core somehow incorrectly sets the tuner type to
LG NTSC (TAPE series) instead of LG TDVS-H06xF. This tuner type does
not have the tuning stepsize defined, so an OOPS occurs during the
digital tune function.
We still dont know how the type gets set incorrectly in the first place.
The user has a tainted kernel with a binary nividia module, which COULD
have something to do with this, but it's hard to say for sure.
Nevertheless, to avoid this division by zero, we should check that
stepsize is defined. If stepsize is not defined, print an error and
bail out on the tune request.
cx8800 0000:05:01.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
cx88[0]: subsystem: 7063:5500, board: pcHDTV HD5500 HDTV [card=47,autodetected], frontend(s): 1
cx88[0]: TV tuner type 47, Radio tuner type -1
tuner' 2-0043: chip found @ 0x86 (cx88[0])
tda9887 2-0043: creating new instance
tda9887 2-0043: tda988[5/6/7] found
tuner' 2-0061: chip found @ 0xc2 (cx88[0])
tuner-simple 2-0061: creating new instance
tuner-simple 2-0061: type set to 47 (LG NTSC (TAPE series))
cx88[0]/0: found at 0000:05:01.0, rev: 5, irq: 19, latency: 32, mmio: 0xea000000
cx88[0]/0: registered device video1 [v4l2]
cx88[0]/0: registered device vbi1
cx88_audio 0000:05:01.1: PCI INT A -> GSI 19 (level, low) -> IRQ 19
cx88[0]/1: CX88x/0: ALSA support for cx2388x boards
cx88[0]/2: cx2388x 8802 Driver Manager
cx88-mpeg driver manager 0000:05:01.2: PCI INT A -> GSI 19 (level, low) -> IRQ 19
cx88[0]/2: found at 0000:05:01.2, rev: 5, irq: 19, latency: 32, mmio: 0xec000000
cx8802_probe() allocating 1 frontend(s)
cx88/2: cx2388x dvb driver version 0.0.6 loaded
cx88/2: registering cx8802 driver, type: dvb access: shared
cx88[0]/2: subsystem: 7063:5500, board: pcHDTV HD5500 HDTV [card=47]
cx88[0]/2: cx2388x based DVB/ATSC card
tuner-simple 2-0061: attaching existing instance
tuner-simple 2-0061: type set to 64 (LG NTSC (TAPE series))
tda9887 2-0043: attaching existing instance
DVB: registering new adapter (cx88[0])
DVB: registering adapter 0 frontend 0 (LG Electronics LGDT3303 VSB/QAM Frontend)...
[snip]
stepsize=0
divide error: 0000 [1] SMP
CPU 1
Modules linked in: nls_utf8 fuse sco bridge stp bnep l2cap bluetooth sunrpc nf_conntrack_netbios_ns nf_conntrack_ftp ip6t_REJECT nf_conntrack_ipv6 ip6table_filter ip6_tables ipv6 cpufreq_ondemand acpi_cpufreq freq_table xfs lgdt330x dm_multipath cx88_dvb cx88_vp3054_i2c uinput tda9887 tda8290 snd_emu10k1_synth snd_emux_synth snd_seq_virmidi snd_seq_midi_emul tuner_simple tuner_types tuner msp3400 cx8800 cx88_alsa cx8802 snd_emu10k1 cx88xx snd_rawmidi snd_ac97_codec ir_common ac97_bus saa7115 snd_seq_dummy snd_seq_oss snd_seq_midi_event videobuf_dvb snd_seq dvb_core snd_pcm_oss snd_mixer_oss snd_pcm snd_seq_device videobuf_dma_sg ppdev parport_pc snd_timer videobuf_core snd_page_alloc btcx_risc emu10k1_gp ivtv i2c_algo_bit cx2341x snd_util_mem snd_hwdep nvidia(P) gameport v4l2_common i2c_i801 snd soundcore parport videodev v4l1_compat v4l2_compat_ioctl32 tveeprom i2c_core pcspkr iTCO_wdt iTCO_vendor_support sky2 joydev floppy shpchp ata_generic pata_acpi pata_jmicron [last unloaded: microcode]
Pid: 3553, comm: kdvb-ad-0-fe-0 Tainted: P 2.6.27.9-159.fc10.x86_64 #1
RIP: 0010:[<ffffffffa09bc37a>] [<ffffffffa09bc37a>] simple_dvb_calc_regs+0xab/0x281 [tuner_simple]
RSP: 0018:ffff8800605dfd30 EFLAGS: 00010246
RAX: 000000000365c040 RBX: ffff8800605dfdb0 RCX: ffff88007acb8c10
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000246
RBP: ffff8800605dfda0 R08: ffff8800605dfba0 R09: 0000000000000082
R10: 00000010e73c9df1 R11: 0000000100000000 R12: ffff88007ac29c00
R13: ffff88007ac29c00 R14: ffff88007acbb408 R15: ffffffffa09b6fb0
FS: 0000000000000000(0000) GS:ffff88007f804880(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000004e8f40 CR3: 000000007114e000 CR4: 00000000000006e0
Process kdvb-ad-0-fe-0 (pid: 3553, threadinfo ffff8800605de000, task ffff88006fca0000)
Stack: ffff8800605dfd40 00000000ffffffa1 ffff88007c055860 0000000000000001
ffff8800605dfda0 ffff8800605dfda0 ffff88007acb8c10 ffffffffa004e48c
8e01880000000390 ffff88007acb8c10 ffff88007ac29c00 0000000000000000
Call Trace:
[<ffffffffa004e48c>] ? i2c_transfer+0x80/0x8b [i2c_core]
[<ffffffffa09bc768>] simple_dvb_set_params+0x3e/0x9b [tuner_simple]
[<ffffffffa0a0335a>] lgdt330x_set_parameters+0x188/0x1b9 [lgdt330x]
[<ffffffffa08c9116>] dvb_frontend_swzigzag_autotune+0x18e/0x1b5 [dvb_core]
[<ffffffffa08c9f6a>] dvb_frontend_swzigzag+0x1bc/0x21e [dvb_core]
[<ffffffffa08ca4f4>] dvb_frontend_thread+0x528/0x62b [dvb_core]
[<ffffffff810551e1>] ? autoremove_wake_function+0x0/0x38
[<ffffffffa08c9fcc>] ? dvb_frontend_thread+0x0/0x62b [dvb_core]
[<ffffffff81054e9b>] kthread+0x49/0x76
[<ffffffff810116e9>] child_rip+0xa/0x11
[<ffffffff81010a07>] ? restore_args+0x0/0x30
[<ffffffff81054e52>] ? kthread+0x0/0x76
[<ffffffff810116df>] ? child_rip+0x0/0x11
Code: 48 8b 05 2a 4e 00 00 41 8b 77 1c 31 d2 0f b7 40 0a 89 f1 03 45 d0 d1 e9 03 0d 23 4e 00 00 69 c0 24 f4 00 00 8d 04 01 48 8b 4d c0 <f7> f6 8a 55 d6 88 53 04 41 89 c4 c1 e8 08 88 43 01 8a 45 d7 44
RIP [<ffffffffa09bc37a>] simple_dvb_calc_regs+0xab/0x281 [tuner_simple]
RSP <ffff8800605dfd30>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
This tuner was already supported by proxy as an FMD1216ME, however,
the MEX uses a different FM Radio IF so this addition is now required.
Signed-off-by: Darron Broad <darron@kewl.org>
Signed-off-by: Steven Toth <stoth@linuxtv.org>
The break after the return or goto serves no purpose.
Reviewed-by: Richard Genoud <richard.genoud@gmail.com>
Thanks to Sistema Fenix (http://www.sistemafenix.com.br/) and CDI Brasil
(www.cdibrasil.com.br/) for sponsoring this development.
Signed-off-by: Gilberto <gilberto@sistemafenix.com.br>
Fixed a lot of sparse warnings: mostly warnings about shadowed variables
and signed/unsigned mismatches.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
v4l2-dev.h
The video_device_create_file and video_device_remove_file functions can be
removed from v4l2-dev.h, removing the dependency on videodev.h in v4l2-dev.h.
Also removed a few more videodev.h includes that should have been videodev2.h.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
simple_tuner_attach()
The tuner_warn() macro relies on the local variable "priv" to be a valid
pointer. There was a case in simple_tuner_attach() where this cannot be the
case yet, so tuner_warn() would dereference a NULL "priv" pointer. Changed
the tuner_warn() to a printk() with the originally intended output format.
There were several issues in the past, caused by the hybrid tuner design, since
now, the same tuner can be used by drivers/media/dvb and drivers/media/video.
Kconfig items were rearranged, to split V4L/DVB core from their drivers.
