path: root/drivers/media/common/tuners/xc5000.c
2008-05-14V4L/DVB (7893): xc5000: bug-fix: allow multiple devices in a single systemMichael Krufky
The current code passes a context pointer in the xc5000_config struct. This context pointer is used in the tuner_callback function, used to reset the device after firmware download. The xc5000_config struct is a static structure, whose .priv member was being assigned before calling xc5000_attach(). If there are more than one of the same device type installed on a single system, the last one to assign xc5000_config.priv will "win", and all others will cease to function properly. This patch passes the context pointer in xc5000_attach() rather that storing it within the static struct xc5000_config. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB(7767): Move tuners to common/tunersMauro Carvalho Chehab
There were several issues in the past, caused by the hybrid tuner design, since now, the same tuner can be used by drivers/media/dvb and drivers/media/video. Kconfig items were rearranged, to split V4L/DVB core from their drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
