Add copyright line for xc5000.c.
Cc: Steven Toth <stoth@kernellabs.com>
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
completion
Instead of polling at 100ms intervals for register writes, poll at 5ms
intervals. This is consistent with the xc5000 specification, and improves
tuning time by up to 500 ms on devices that such as the au0828 which do not
properly implement i2c clock stretching (since the five register writes that
occur for a tuning request often do not complete immediately but do complete
far before 100ms has gone by).
The net amount of time we wait before timing out is unchanged (500ms).
This patch adds XC5000 supports for DVB-T 6MHz and 8MHz bandwidth.
Signed-off-by: David T.L. Wong <davidtlwong@gmail.com>
redistribution rights
Xceive has graciously allowed us to now freely redistribute the xc5000
firmware, which eliminates the need for users to manually extract the blob
from the Hauppauge driver.
Thanks to Brian Mathews <bmathews@xceive.com> for providing this code
Provide for the ability for a user to disable putting the tuner to sleep, in
case he doesn't want to incur the cost of reloading the firmware when starting
up his/her application. The module options are intentionally identical to
xc3028.
Make it a little more obvious in the dmesg output what is going on during
firmware upload. This is more important for boards like the HVR-950q that
take nearly seven seconds to do the upload.
Starting in firmware version 1.1.44, Xceive recommends using the FINERFREQ for
all normal tuning (the doc indicates reg 0x03 should only be used for fast
scanning for channel lock)
Expose the firmware build number along with the other version info
Xceive got rid of the XREG_POWER_DOWN register in later firmware revisions.
Their technical support informed me that the correct way to put the tuner
to sleep is to pull the reset pin (but don't reload the firmware).
This switches to a new version of the xc5000 firmware, extracted from the
latest Hauppauge driver. It includes the support for the XREG_BUSY register
(a lack of which was causing tuning to take 3200ms instead of around 300ms).
Don't sleep for 400ms polling the tuner's lock if in digital mode (since the
xc5000 lock status registers appear to only be reliable in analog mode)
Signed-off-by: Devin Heitmueller <devin.heitmueller@gmail.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Bring back the code that puts the xc5000 to sleep. For the Pinnacle 801e
this results in power consumption at idle dropping from 325ma to 124ma.
If there are *actually* any devices that don't work in this configuration,
they should set dvb_frontend.ops.tuner_ops.sleep to NULL (per mkrufky's
suggestion)
Also, had to make sure we were making sure the firmware was loaded in the
digital version of set_params, or else we end up get i2c errors if the
device is asleep
Make return value checking for calls to i2c routines explicit.
Cleanup the i2c write routine, getting rid of a passthrough function with only
one caller
This patch centralizes the i2c read functions, and eliminates pass-through
function only called by one caller.
Make reading of xc5000 registers an atomic i2c transaction in case we're on a
multi-master bus.
Properly handle tuner reset failures (before it was always returning success)
Use the physical device rather than the i2c adapter as the reference
device when loading firmwares. This will prevent the sysfs name
collision with i2c-dev that has been reported many times.
I may have missed other drivers which need the same fix.
than 5380
The xc5000 driver has a bug where the IF is always set to whatever the first
caller to dvb_attach() provides. This fails when the device requires an IF
other than 5380 and the analog driver is loaded first through tuner-core
(which always supplies the hard-coded value of 5380).
Thanks to Michael Krufky <mkrufky@linuxtv.org> and Steven Toth
<stoth@linuxtv.org> for providing sample hardware, engineering level support,
and testing.
Signed-off-by: Devin Heitmueller <dheitmueller@linuxtv.org>
Signed-off-by: Srinivasa Deevi <srinivasa.deevi@conexant.com>
The init_fw option was broken for the HVR-950q because we would call the reset
callback inside of dvb_attach() and the callback had not been setup yet.
Michael Krufky (who added the init_fw feature) says it's no longer required,
so just remove the option completely.
Thanks to user Zzeiss from #linuxtv chat for reporting the issue and
Michael Krufky <mkrufky@linuxtv.org> for proposing the fix.
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
xc5000: Checkpatch compliance
Signed-off-by: Steven Toth <stoth@linuxtv.org>
Dont pass devptr in xc5000_attach, dont store it in xc5000_priv.
This pointer is passed into the tuner_callback function, which always
expects a pointer to fe->dvb->priv or i2c_adapter->algo_data.
This prevents future possible bugs in new drivers, such as using a "devptr"
other that the standard fe->dvb->priv in a DVB driver.
digital is in use
Prevent an OOPS if xc5000_attach was called by tuner.ko before being called by
the DVB adapter driver. The OOPS occurs when a digital tune request is made
after tuner.ko is unloaded.
When tuner.ko is unloaded, it takes the xc5000_config structure with it.
Rather than storing a pointer to the xc5000_config structure, just store the
if_khz and tuner_callback inside the xc5000_priv internal state structure.
hardware to share state
Convert xc5000 to use the hybrid_tuner_request_state and
hybrid_tuner_release_state macros to manage state sharing between
hybrid tuner instances.
move struct xc5000_priv into xc5000.c and delete xc5000_priv.h
I need this so I can better isolate my linux email from my
corporate email.
The xc5000 firmware download process can be slow on certain devices.
Add a module option, "init_fw" to perform the firmware download during
xc5000_attach(), which would get the firmware download over with well
before any tune request is made.
When this option is enabled, it will reduce the time it takes to get a
signal lock during the first tune after driver load, but will add a few
seconds to the driver initialization.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
download is needed
This patch ensures that the xc5000 will have firmware loaded as needed if the
part is powered down or reset via gpio from the host. An example of this, in
some cases, could be after the system resumes from standby or hibernate modes.
The current code passes a context pointer in the xc5000_config struct.
This context pointer is used in the tuner_callback function, used to
reset the device after firmware download.
The xc5000_config struct is a static structure, whose .priv member was
being assigned before calling xc5000_attach(). If there are more than
one of the same device type installed on a single system, the last one
to assign xc5000_config.priv will "win", and all others will cease to
function properly.
This patch passes the context pointer in xc5000_attach() rather that
storing it within the static struct xc5000_config.
There were several issues in the past, caused by the hybrid tuner design, since
now, the same tuner can be used by drivers/media/dvb and drivers/media/video.
Kconfig items were rearranged, to split V4L/DVB core from their drivers.
