path: root/drivers/media/dvb-frontends/s5h1409.c
2015-06-09[media] dvb: Get rid of typedev usage for enumsMauro Carvalho Chehab
The DVB API was originally defined using typedefs. This is against Kernel CodingStyle, and there's no good usage here. While we can't remove its usage on userspace, we can avoid its usage in Kernelspace. So, let's do it. This patch was generated by this shell script: for j in $(grep typedef include/uapi/linux/dvb/frontend.h |cut -d' ' -f 3); do for i in $(find drivers/media -name '*.[ch]' -type f) $(find drivers/staging/media -name '*.[ch]' -type f); do sed "s,${j}_t,enum $j," <$i >a && mv a $i; done; done While here, make CodingStyle fixes on the affected lines. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> # for drivers/media/firewire/*
2014-12-22[media] media: remove emacs editor variablesHans Verkuil
1) This is not allowed by the kernel coding style 2) Just configure your editor correctly 3) It's really ugly Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2012-08-13[media] move the dvb/frontends to drivers/media/dvb-frontendsMauro Carvalho Chehab
Raise the DVB frontends one level up, as the intention is to remove the drivers/media/dvb directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
