path: root/drivers/media/dvb/cinergyT2/Kconfig
2008-10-12V4L/DVB (9107): Alternative version of Terratec Cinergy T2 driverTomi Orava
Alternative version of the Terratec Cinergy T2 driver that uses the dvb framework. Signed-off-by: Tomi Orava <tomimo@ncircle.nullnet.fi> Signed-off-by: Thierry MERLE <thierry.merle@free.fr> [mchehab@redhat.com: fix dvb Makefile] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-05-14V4L/DVB (7836): cinergyT2 build fixIngo Molnar
x86.git testing found the following build bug in v2.6.26-rc1: drivers/built-in.o: In function `cinergyt2_probe': cinergyT2.c:(.text+0xb6117): undefined reference to `input_allocate_device' cinergyT2.c:(.text+0xb6230): undefined reference to `input_register_device' cinergyT2.c:(.text+0xb623d): undefined reference to `input_free_device' with the following config: http://redhat.com/~mingo/misc/config-Sun_May__4_22_06_54_CEST_2008.bad The reason for the bug is that the cinergyT2 driver depends on CONFIG_INPUT functionality, but if INPUT is modular it's still possible to build CONFIG_DVB_CINERGYT2=y - which leads to missing symbols. The solution is to make DVB_CINERGYT2 dependent on INPUT. [ This solves the build problem - i have not tested the driver on this card. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03Fix several typos in drivers/Matt LaPlante
2006-06-25V4L/DVB (4104): Default "yes", no. default y, yes.Trent Piepho
The Kernel config programs expect 'default y' and don't understand 'default "yes"'. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3218): Whitespace cleanupsMichael Krufky
- minor whitespace cleanups Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-09-09[PATCH] dvb: cinergyT2: remote control fixesJohannes Stezenbach
IR RC fixes: - EVIOCSKEYCODE is not supported by this driver, fix potential crash when it is used by not setting rc_input_dev->keycodesize - fix key repeat handling (hopefully) - reduce default poll internal to 50msec (necessary for key repeat handling) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
