flush_scheduled_work() is deprecated and scheduled to be removed.
* Flush the used works directly.
* Replace the deprecated cancel_rearming_delayed_work() +
flush_scheduled_work() -> cancel_delayed_work_sync().
* Make sure mantis->uart_work isn't running on exit.
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: linux-media@vger.kernel.org
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
The dvb core only uses the big kernel lock in the open
and ioctl functions, which means it can be replaced with
a dvb specific mutex. Fortunately, all the ioctl functions
go through dvb_usercopy, so we can move the serialization
in there.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Fix ULE decapsulation bug when less than 4 bytes of ULE SNDU is packed
into the remaining bytes of a MPEG2-TS frame
ULE (Unidirectional Lightweight Encapsulation RFC 4326) decapsulation
code has a bug that incorrectly treats ULE SNDU packed into the
remaining 2 or 3 bytes of a MPEG2-TS frame as having invalid pointer
field on the subsequent MPEG2-TS frame.
Signed-off-by: Ang Way Chuang <wcang@nav6.org>
Acked-by: Jarod Wilson <jarod@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
uml: Pushdown the bkl from harddog_kern ioctl
sunrpc: Pushdown the bkl from sunrpc cache ioctl
sunrpc: Pushdown the bkl from ioctl
autofs4: Pushdown the bkl from ioctl
uml: Convert to unlocked_ioctls to remove implicit BKL
ncpfs: BKL ioctl pushdown
coda: Clean-up whitespace problems in pioctl.c
coda: BKL ioctl pushdown
drivers: Push down BKL into various drivers
isdn: Push down BKL into ioctl functions
scsi: Push down BKL into ioctl functions
dvb: Push down BKL into ioctl functions
smbfs: Push down BKL into ioctl function
coda/psdev: Remove BKL from ioctl function
um/mmapper: Remove BKL usage
sn_hwperf: Kill BKL usage
hfsplus: Push down BKL into ioctl function
This requires changing all users of dvb_usercopy to
omit the inode argument.
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
In mlx4, using char * to store mc address in private structure instead.
drivers/firmware/iscsi_ibft.c
invalid Payload Pointer
has a bug that causes endless loop when Payload Pointer of MPEG2-TS
frame is 182 or 183. Anyone who sends malicious MPEG2-TS frame will
cause the receiver of ULE SNDU to go into endless loop.
This patch was generated and tested against linux-2.6.32.9 and should
apply cleanly to linux-2.6.33 as well because there was only one typo
fix to dvb_net.c since v2.6.32.
This bug was brought to you by modern day Santa Claus who decided to
shower the satellite dish at Keio University with heavy snow causing
huge burst of errors. We, receiver end, received Santa Claus's gift in
the form of kernel bug.
Care has been taken not to introduce more bug by fixing this bug, but
please scrutinize the code for I always produces buggy code.
Signed-off-by: Ang Way Chuang <wcang79@gmail.com>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: stable@kernel.org
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
Use the %pM kernel extension to display the MAC address and mask.
The only difference in the output is that the output is shown in
the usual colon-separated hex notation.
something-bility is spelled as something-blity
so a grep for 'blit' would find these lines
this is so trivial that I didn't split it by subsystem / copy
additional maintainers - all changes are to comments
The only purpose is to get fewer false positives when grepping
around the kernel sources.
Signed-off-by: Dirk Hohndel <hohndel@infradead.org>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
dvb: constify VFTs
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Use internal network_device_stats that exist in network device and
net_device_ops. Compile tested only.
Simply replace netdev->priv with netdev_priv().
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (277 commits)
V4L/DVB (8415): gspca: Infinite loop in i2c_w() of etoms.
V4L/DVB (8414): videodev/cx18: fix get_index bug and error-handling lock-ups
V4L/DVB (8411): videobuf-dma-contig.c: fix 64-bit build for pre-2.6.24 kernels
V4L/DVB (8410): sh_mobile_ceu_camera: fix 64-bit compiler warnings
V4L/DVB (8397): video: convert select VIDEO_ZORAN_ZR36060 into depends on
V4L/DVB (8396): video: Fix Kbuild dependency for VIDEO_IR_I2C
V4L/DVB (8395): saa7134: Fix Kbuild dependency of ir-kbd-i2c
V4L/DVB (8394): ir-common: CodingStyle fix: move EXPORT_SYMBOL_GPL to their proper places
V4L/DVB (8393): media/video: Fix depencencies for VIDEOBUF
V4L/DVB (8392): media/Kconfig: Convert V4L1_COMPAT select into "depends on"
V4L/DVB (8390): videodev: add comment and remove magic number.
V4L/DVB (8389): videodev: simplify get_index()
V4L/DVB (8387): Some cosmetic changes
V4L/DVB (8381): ov7670: fix compile warnings
V4L/DVB (8380): saa7115: use saa7115_auto instead of saa711x as the autodetect driver name.
V4L/DVB (8379): saa7127: Make device detection optional
V4L/DVB (8378): cx18: move cx18_av_vbi_setup to av-core.c and rename to cx18_av_std_setup
V4L/DVB (8377): ivtv/cx18: ensure the default control values are correct
V4L/DVB (8376): cx25840: move cx25840_vbi_setup to core.c and rename to cx25840_std_setup
V4L/DVB (8374): gspca: No conflict of 0c45:6011 with the sn9c102 driver.
According to RFC 4326 (4.1) D-bit is MSB in net-endian 16bit.
dvb_net.c did
/* Set D-bit for CRC32 verification,
* if it was set originally. */
ulen |= 0x0080;
which works of little-endian (htons(1<<15) is 0x0080 there), but breaks
on big-endian.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Now that we have a specific lock to protect the network
device unicast and multicast lists, remove extraneous
grabs of the TX lock in cases where the code only needs
address list protection.
Add netif_addr_{lock,unlock}{,_bh}() helpers.
Use them to protect operations that operate on or read
the network device unicast and multicast address lists.
Also use them in cases where the code simply wants to
block calls into the driver's ->set_rx_mode() and
->set_multicast_list() methods.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Acked-by: Oliver Endriss <o.endriss@gmx.de>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
Acked-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits)
[SKY2]: status polling loop (post merge)
[NET]: Fix NAPI completion handling in some drivers.
[TCP]: Limit processing lost_retrans loop to work-to-do cases
[TCP]: Fix lost_retrans loop vs fastpath problems
[TCP]: No need to re-count fackets_out/sacked_out at RTO
[TCP]: Extract tcp_match_queue_to_sack from sacktag code
[TCP]: Kill almost unused variable pcount from sacktag
[TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L
[TCP]: Add bytes_acked (ABC) clearing to FRTO too
[IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2
[NETFILTER]: x_tables: add missing ip6t_modulename aliases
[NETFILTER]: nf_conntrack_tcp: fix connection reopening
[QETH]: fix qeth_main.c
[NETLINK]: fib_frontend build fixes
[IPv6]: Export userland ND options through netlink (RDNSS support)
[9P]: build fix with !CONFIG_SYSCTL
[NET]: Fix dev_put() and dev_hold() comments
[NET]: make netlink user -> kernel interface synchronious
[NET]: unify netlink kernel socket recognition
[NET]: cleanup 3rd argument in netlink_sendskb
Fix up conflicts manually in Documentation/feature-removal-schedule.txt
and my new least favourite crap, the "mod_devicetable" support in the
files include/linux/mod_devicetable.h and scripts/mod/file2alias.c.
(The latter files seem to be explicitly _designed_ to get conflicts when
different subsystems work with them - that have an absolutely horrid
lack of subsystem separation!)
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Clean whitespace brain-damage caused by previous patch,
"Fix a warning at dvb_net"
The first part of dvb_net_close() is just a cut&paste from
dvb_generic_release(), so maybe it would be better to just call
dvb_generic_release() instead?
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Acked-by: Markus Rechberger <mrechberger@gmail.com>
The Coverity checker spotted that we'd have already oops'ed if "dev"
was NULL.
Signed-off-by: Manu Abraham <manu@linuxtv.org>
static function dvb_net_sec declares input arg "pkt" as u8. However, the
same argument at dvb_net_sec_callback is defined as "const u8". When
calling dvb_net_sec, this is casted as just "u8".
gcc 4.2.1 generates a warning about that:
CC [M] drivers/media/dvb/dvb-core/dvb_net.o
drivers/media/dvb/dvb-core/dvb_net.c: In function "dvb_net_sec_callback":
drivers/media/dvb/dvb-core/dvb_net.c:905: warning: passing argument 2 of
"dvb_net_sec" discards qualifiers from pointer target type
Make some pointers const, and then delete some now unnecessary casts,
which were the wrong signedness anyway, being used to strip the const
from another pointer.
fixed hotplugging for dvbnet
Signed-off-by: Michal CIJOML Semler <cijoml@volny.cz>
Signed-off-by: Markus Rechberger <markus.rechberger@amd.com>
To clearly state the intent of copying from linear sk_buffs, _offset being a
overly long variant but interesting for the sake of saving some bytes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes
on 64bit architectures, allowing us to combine the 4 bytes hole left by the
layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4
64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN...
Many calculations that previously required that skb->{transport,network,
mac}_header be first converted to a pointer now can be done directly, being
meaningful as offsets or pointers.
For the places where we need a pointer to the mac header, it is still legal to
touch skb->mac.raw directly if just adding to, subtracting from or setting it
to another layer header.
This one also converts some more cases to skb_reset_mac_header() that my
regex missed as it had no spaces before nor after '=', ugh.
dvb_net.c: In function 'dvb_net_ule':
dvb_net.c:628: warning: format '%#lx' expects type 'long unsigned int', but argument 3 has type 'u32'
dvb_net.c:628: warning: format '%#lx' expects type 'long unsigned int', but argument 4 has type 'u32'
CRC-32 checking during ULE decapsulation always failed on x86_64 systems due
to the size of a variable used to store CRC. This bug was discovered on
Fedora Core 6 with kernel-2.6.18-1.2849. The i386 counterpart has no such
problem. This patch has been tested on 64-bit system as well as 32-bit system.
Signed-off-by: Ang Way Chuang <wcang@nrg.cs.usm.my>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Fix some problems regarding support for Unidirectional Lightweight
Encapsulation (ULE) in dvbnet.c.
The original ULE code was based on a draft. In the meantime, ULE has been
published in RFC 4326 (ftp://ftp.rfc-editor.org/in-notes/rfc4326.txt).
With these fixes, and some additions (which are included in the patch), the
decaps code should now be complient to RFC4326.
Signed-off-by: Christian Praehauser <cpraehaus@cosy.sbg.ac.at>
Various drivers use xmit_lock internally to synchronise with their
transmission routines. They do so without setting xmit_lock_owner.
This is fine as long as netpoll is not in use.
With netpoll it is possible for deadlocks to occur if xmit_lock_owner
isn't set. This is because if a printk occurs while xmit_lock is held
and xmit_lock_owner is not set can cause netpoll to attempt to take
xmit_lock recursively.
While it is possible to resolve this by getting netpoll to use
trylock, it is suboptimal because netpoll's sole objective is to
maximise the chance of getting the printk out on the wire. So
delaying or dropping the message is to be avoided as much as possible.
So the only alternative is to always set xmit_lock_owner. The
following patch does this by introducing the netif_tx_lock family of
functions that take care of setting/unsetting xmit_lock_owner.
I renamed xmit_lock to _xmit_lock to indicate that it should not be
used directly. I didn't provide irq versions of the netif_tx_lock
functions since xmit_lock is meant to be a BH-disabling lock.
This is pretty much a straight text substitution except for a small
bug fix in winbond. It currently uses
netif_stop_queue/spin_unlock_wait to stop transmission. This is
unsafe as an IRQ can potentially wake up the queue. So it is safer to
use netif_tx_disable.
The hamradio bits used spin_lock_irq but it is unnecessary as
xmit_lock must never be taken in an IRQ handler.
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
- Reverted objectionable fix in saa7146_hlp.c
- Merged in improved dvb 64-bit fixes from Peter Beutner.
Signed-off-by: Peter Beutner <p.beutner@gmx.net>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
- Fix 64-bit compile warnings
Clean up whitespaces at v4l/dvb files
Fix locking to prevent Oops on SMP systems when starting/stopping dvb network
interfaces.
Signed-off-by: Ralph Metzler <rjkm@metzlerbros.de>
Removed more unused variables and constants.
Signed-off-by: Andreas Oberritter <obi@linuxtv.org>
Signed-off-by: Johannes Stezenbach <js@linuxtv.org>
