path: root/drivers/media/dvb/dvb-usb/Kconfig
2008-06-05V4L/DVB (7910): usb: input layer dependency fixesIngo Molnar
testing of the -tip tree found the following build failures on 2.6.26-rc3: drivers/built-in.o: In function `ttusb_dec_disconnect': ttusb_dec.c:(.text+0xa2c95): undefined reference to `input_unregister_device' drivers/built-in.o: In function `dvb_usb_read_remote_control': dvb-usb-remote.c:(.text+0xa6a94): undefined reference to `input_event' with this config: http://redhat.com/~mingo/misc/config-Tue_May_20_03_48_57_CEST_2008.bad these are due to the media/dvb/usb layer having dependencies on INPUT functionality, without having that spelled out in the Kconfig file. this patch makes that dependency explicit (for the drivers affected), which solves the build error. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7851): Fix FW_LOADER depencency at v4l/dvbMauro Carvalho Chehab
Since: 1) FW_LOADER is defined as: config FW_LOADER tristate "Userspace firmware loading support" depends on HOTPLUG 2) several V4L/DVB driver just selects it; 3) select is not smart enough to auto-select HOTPLUG, if select FW_LOADER. So, All drivers that select FW_LOADER should also depend on HOTPLUG. An easier solution (for the end-user perspective) would be to "select HOTPLUG". However, live is not simple. This would cause recursive dependency issues like this one: drivers/usb/Kconfig:62:error: found recursive dependency: USB -> USB_OHCI_HCD -> I2C -> MEDIA_TUNER -> MEDIA_TUNER_XC2028 -> HOTPLUG -> PCCARD -> PCMCIA -> USB_ARCH_HAS_HCD -> MOUSE_APPLETOUCH -> USB Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29Rename common tuner Kconfig names to use the sameMauro Carvalho Chehab
namespace for all of them.
2008-04-24V4L/DVB (7441): kconfig fixes for tuner-simpleMichael Krufky
Update Kconfig for the hybrid devices recently converted to use tuner-simple rather than dvb-pll. dvb-bt8xx no longer uses dvb-pll at all, so remove all references to dvb-pll within that driver. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5955): Add support for DiB7070-based devicesPatrick Boettcher
This changeset adds support for DiB7070P-based devices by adding the dib0070-driver and putting the appropriate layouts into dib0700_devices.c It also includes a new firmware for the dib0700 which is necessary to make the DiB7070-boards work and it also should fix the i2c-problems on some boards. Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5914): Add initial support for Dual-DVB-T stickOlivier DANET
Add initial support for Dual-DVB-T stick based on DiB7700 and MT2266 - Microtune MT2266 driver. - Preliminary support for these dual tuner devices : - Pinnacle Dual DVB-T diversity - Terratec Cinergy DT USB XS diversity - Hauppauge Nova TD USB Signed-off-by: Olivier DANET <odanet@caramail.com> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5780): Dvb: Remove static dependencies on dvb-pllMichael Krufky
This patch removes all static dependencies on the dvb-pll module. All exported dvb_pll_desc's have been UNexported, and the caller will reference the individual dvb_pll_desc by it's index in the pll_list array. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Acked-by: Oliver Endriss <o.endriss@gmx.de> Acked-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5626): Marked af9005 driver as experimental and fix dependenciesLuca Olivetti
Marked af9005 driver as experimental and add dependency for qt1010; Added a dependency on qt1010 in Kconfig; Corrected the experimental gain reduction of the mt2060 in case of strong signal (though it is code included in #ifdef 0). Signed-off-by: Luca Olivetti <luca@ventoso.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5625): Add support for the AF9005 demodulator from AfatechLuca Olivetti
Signed-off-by: Luca Olivetti <luca@ventoso.org> Signed-off-by: Manu Abraham <abraham.manu@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5532): Add support for Opera S1- DVB-USBMarco Gittler
This patch adds support for DVB-Opera S1 USB 2.0 BOX. Signed-off-by: Marco Gittler <g.marco@freenet.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5363): Dvb: Remove lgh06xf driverTrent Piepho
The code of the dvb-pll driver and the lgh06xf driver is nearly identical. The main difference is that the lgh06xf driver would set the AGC TOP value on every tune call. The dvb-pll driver now has the ability to set the AGC TOP when the front-end device is opened, which is a better way to go about it. By using this ability of dvb-pll, the lgh06xf driver is made unnecessary. There is one other difference. dvb-pll will probe for the presence of an I2C pll chip by doing a one byte read, the lgh06xf driver did not do this. In some devices the PLL is not reachable over I2C at the timer the tuner is attached. Some more initialization, such as firmware loading, must take place first. None of the devices using a LG-H06xF should have this problem. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5361): Dvb-pll: Fix Kconfig files and allow dvb-pll to be optionalTrent Piepho
A number of drivers selected DVB_PLL when they did not need it, and some that did need it did not select it. The DVB_PLL option is given a name and help text, so that it will show up in the config menu. DVB_PLL support can be turned on if an out-of-tree driver needs it. The standard dvb fe customization support is added to dvb-pll.h. Since all modules which select DVB_PLL do so unconditionally, it is not possible to turn dvb-pll off when an enabled module selects it, unlike most of the other frontend/tuner drivers. This is because the users of dvb-pll have static references to dvb-pll symbols other than the attach function. If these references are removed, then dvb-pll will be disablable as the other frontend/tuner drivers are. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5238): Kconfig: qt1010 should be selected by gl861 and au6610Michael Krufky
2007-02-21V4L/DVB (5236): Initial support for Sigmatek DVB-110 DVB-TAntti Palosaari
This patch adds driver for Sigmatek DVB-110 USB DVB-T stick. Stick has based on hardware of Qtuantek QT1010 tuner, Zarlink ZL10353 (Intel CE 6353) demodulator and Alcor Micro AU6610 DVB-T USB controller. HW is rather similar as used in MSI Megasky GL861. Currently, the driver works only in USB 2.0. In my understanding USB 1.1 is also supported by hw but I cannot test it due to lack of USB 1.1 port. Device supports only isochronous mode transfers. There is also eeprom in usb controller(at least in address range 0x80 - 0xbf) for storing data, eg. firmware. Anyway, firmware loading is not used / required by the device. There seems to be at least one unknown I2C device in address 0xa0, probably remote control or GPIO. Windows drivers reads registers from 0x00 to 0x07 from this unknown address. Driver is based on gl861 module. Tuner has a lot of problems to lock with megasky qt1010 module with this hardware with some broadcasting standards. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5224): Gl861: select DVB_ZL10353 if !DVB_FE_CUSTOMISEMichael Krufky
2007-02-21V4L/DVB (5221): Dvb-usb: initial support for MSI Mega Sky 580 DVB-T based on ↵Carl Lundqvist
GL861 This patch adds support for MSI Mega Sky 580 / GL861 DVB-T USB2.0 Except for the 2 lines added to zl10353.c, zl10353_reset_attach needs to be changed. If I read the code correctly setting parallel_ts will take care of the 3rd byte, but the 2nd byte needs to be 0x0b instead of 0x03 too. I guess these changes needs to be done only for this device, not sure how to do that. The zl10353 changes have been split apart from this patch, into the next patch, soon to follow. Signed-off-by: Carl Lundqvist <comabug@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5138): Kconfig: qt1010 should be selected by m920xMichael Krufky
2007-02-21V4L/DVB (5127): M920x: update megasky driver for recent changes in the dvb treeMichael Krufky
update code to use dvb_attach() update code to reflect recent changes to the dvb_usb framework Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5126): M920x: cleanups after rename from megasky.[ch]Michael Krufky
2007-02-21V4L/DVB (5124): Dvb-usb: Initial support for MSI Mega Sky 580 based on Uli m9206Aapo Tahkola
Currently, the driver works in bulk mode supporting both USB 2.0 and 1.0 with and without hardware pid filters. The ULi m9205 also supports isochronous transfer mode, but I have dropped support for it because it depends on firmware and does not work on all USB host chips. Further, I have no firmware with remote controller support for this mode. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4863): Adding support for Pinnacle PCTV 400e DVB-SPatrick Boettcher
Adding support for Pinnacle PCTV 400e DVB-S. The module name is called ttusb2, because it this device (and other Pinnacle devices) is using the USB-protocol originally used by Technotrend device. I'm suspecting Technotrend as the device-designer. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4846): Create new lgh06xf atsc tuner moduleMichael Krufky
This patch creates a new atsc tuner module for the LG TDVS-H06xF ATSC tuners, called lgh06xf. The purpose of this change is to reduce some duplicated code, and to allow the lgh06xf tuner code to take advantage of dvb_attach(). As a side effect, the dependency of dvb-bt8xx on dvb-pll has been removed, since the lgh06xf module itself will use dvb-pll, while remaining optional for the dvb-bt8xx driver through the use of DVB_FE_CUSTOMISE Acked-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4772): Add support for DiBcom DiB7000PCPatrick Boettcher
This patch contains support for the DiB7000PC-driver. Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4524): Initial commit for the DiB7000M-demodPatrick Boettcher
Initial commit for the driver for the DiB7000M COFDM demodulator. Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-11-02V4L/DVB (4752): DVB: Add DVB_FE_CUSTOMISE support for MT2060Trent Piepho
Let the MT2060 be customized like most of the other DVB PLLs/front-ends. Also, add a missing dependency on I2C. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-04V4L/DVB (4676a): Remove Kconfig item for DiB7000M supportMauro Carvalho Chehab
Support for DiB7000M frontend were not included on 2.6.19, since still not completed. Removing Kconfig item. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4650): Misc fixes for dib0700 downloadPatrick Boettcher
Several fixes for dib0700-module. (Firmware error checking, dependency) Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4643): Multi-input patch for DVB-USB devicePatrick Boettcher
This patch is the first commit of the Multiple Input Patch for the DVB-USB frame work. It changes the DVB-USB-device to be able to have more than one streaming input (e.g. multiple DVB-T sources) on one device. This is a necessary feature for the upcoming DiB7700 driven devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB: MT2060: Code cleanups, adding to new build-mechanismPatrick Boettcher
Some minor code cleanups and added the MT2060 to new v4l-dvb-build-system, preliminarily under dvb/frontends. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4387): Add Kconfig infrastructure for dvb_attachAndrew de Quincey
Allow it to be en/disabled Disable it in < 2.6.17 due to symbol_xxx() bug Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-10V4L/DVB (4608b): i2c deps fix on DVBAndrew de Quincey
Several DVB modules depends on I2C Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4094): Cxusb: add support for DViCO FusionHDTV DVB-T Dual USB based ↵Michael Krufky
on zl10353 This patch adds support for a newer version of this device using the zl10353 frontend instead of the mt352 frontend. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4029): [PATCH] Genpix 8PSK->USB driver (Take 2)Alan Nisota
This is a patch which includes support for the GENPIX 8PSK->USB module. The board supports QPSK, BPSK and 8PSK decoding (though I don't think it will be DVB-S2 compliant) With the following patch, the boad is equivalent to a budget card (no CA Module) The patch which adds 8psk suppot will follow, but is seperate, as it requires DVB-S2 support More info on the board can be found at www.genpix-electronics.com (and they host the requisite firmwares there as well) Signed off by: Alan Nisota <alannisota@gmail.com> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-05-23V4L/DVB (4037): Make the bridge devices that depend on I2C dependant on I2CManu Abraham
Ref: Bugzilla 6179, 6589 Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3299): Kconfig: DVB_USB_CXUSB depends on DVB_LGDT330X and DVB_MT352Michael Krufky
- rename DVB_USB_CXUSB one-liner description to: Conexant USB2.0 hybrid reference design support. - with the addition of bluebird support to dvb-usb-cxusb, it now depends on lgdt330x and mt352 modules. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3323): Add Kconfig option for wrongly programmed devicesMarc Koschewski
- A new Kconfig option makes the user able to select if the dibusb-mb driver shall claim faulty programmed USB devices which are coming with default Cypress USB IDs. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-09-09[PATCH] dvb: usb: add TwinhanDTV StarBox supportPatrick Boettcher
Add driver for the TwinhanDTV StarBox and clones. Thanks to Ralph Metzler for his initial work on this box and thanks to Twinhan for their support. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb: add supprt for WideView WT-220UPatrick Boettcher
Add support and rewrote some parts with the help of vendor information (Thanks to Steve Chang from WideView, Inc.): o added support for the WT-220U (Pensize DVB-T receiver) o corrected byte order for unc,ber and the pid filter o corrected number of pids that can be fetched at the same time. o added some comments in Kconfig-file o added USB IDs for the WT-220U Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb: fix WideView USB idsPatrick Boettcher
o Steve Chang reported the real name behind 0x14aa: WideView, changed USB IDs accordingly. o fixed an assignment Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb Kconfig help text updatePatrick Boettcher
o corrected some typos o added the Wikilink pointing to the USB device list Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb: support Medion hybrid USB2.0 DVB-T/analogue boxPatrick Boettcher
Add preliminary support for the Medion Hybrid USB2.0 DVB-T/Analogue box. Analogue part is not working yet (cx25842 --> ivtv?). Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] dvb: Add generalized dvb-usb driverJohannes Stezenbach
Add generalized dvb-usb driver which supports a wide variety of devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
