path: root/drivers/media/dvb/dvb-usb/a800.c
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4749): Fixed DVB-USB-Adapter indentionPatrick Boettcher
While converting everything to DVB-USB-Adapter, there was a wrong indention. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4643): Multi-input patch for DVB-USB devicePatrick Boettcher
This patch is the first commit of the Multiple Input Patch for the DVB-USB frame work. It changes the DVB-USB-device to be able to have more than one streaming input (e.g. multiple DVB-T sources) on one device. This is a necessary feature for the upcoming DiB7700 driven devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4464): FIX_ AverTV A800 troubleKlaus Frahm
A new revision of the Avermedia A800 does not reenumerate after download the firmware. Signed-off-by: Klaus Frahm <frahm@irsamc.ups-tlse.fr> Signed-off-by: Martin Habbecke <M.Habbecke@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-01[PATCH] DVB: Small cleanups and CodeStyle fixesAdrian Bunk
- Small cleanups: - make needlessly global functions static - every file should #include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] dvb: remove duplicate key definitionsThorsten Maerz
The duplicate key definitions cause misinterpretations with other keys, e.g. the "TELETEXT" key clashes with "CHANNEL_UP" and thus can not be used with LIRC. This patch removes these duplicates. Signed-off-by: Thorsten Maerz <torte@netztorte.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Cc: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] dvb: usb: core: change dvb_usb_device_init() APIPatrick Boettcher
Change the init call to optionally return the new dvb_usb_device directly. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb/pci: correct syntax of driver name fieldsPatrick Boettcher
Change the name-field of the pci_driver and usb_driver structs to the name of the module after compilation. It seems that this field is used in some places where special characters are not allowed. Thanks to Alan Halverson for finding this problem. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb: A800 rc and timeout fixesAndrew Hodgson
o add some remote control codes o not using HZ for control_msg-timeout Signed-off-by: Andrew Hodgson <a.s.hodgson@gmail.com> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] dvb: Add generalized dvb-usb driverJohannes Stezenbach
Add generalized dvb-usb driver which supports a wide variety of devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
