path: root/drivers/media/dvb/dvb-usb/af9005.c
2008-10-12V4L/DVB (8906): v4l-dvb: fix assorted sparse warningsHans Verkuil
Fix sparse warnings. None are serious, but cutting down on these helps find future serious sparse warnings/errors. Redid the av7710.c patch based on a suggestion by Oliver Endriss. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7054): ansonic branded dvb-t usb stick support in the af9005 driverLuca Olivetti
Marcos Melero (marcosmelero at gmail.com) reported he could make his dvb-t usb stick work with the af9005 driver by changing the device ids (10b9:6000). The stick is branded "Ansonic" (one of the brands of a spanish chain of supermarkets) with no other identification of the model. Since neither Marcos nor me know the OEM for the stick, in the attached patch I used Ansonic for the ids/description. Signed-off-by: Luca Olivetti <luca@ventoso.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5625): Add support for the AF9005 demodulator from AfatechLuca Olivetti
Signed-off-by: Luca Olivetti <luca@ventoso.org> Signed-off-by: Manu Abraham <abraham.manu@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
