path: root/drivers/media/dvb/dvb-usb/dvb-usb-common.h
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4643): Multi-input patch for DVB-USB devicePatrick Boettcher
This patch is the first commit of the Multiple Input Patch for the DVB-USB frame work. It changes the DVB-USB-device to be able to have more than one streaming input (e.g. multiple DVB-T sources) on one device. This is a necessary feature for the upcoming DiB7700 driven devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09DVB (2420): Makes integration of future devices easierPatrick Boettcher
- To make the integration of future devices easier - modified the dvb-usb-part to allow a device-specific firmware download - added an option to specify whether a device reconnects after a firmware download or not. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-07-07[PATCH] dvb: usb: add module parm to disable remote control pollingPatrick Boettcher
Add module parameter to deactive remote control polling. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb: add isochronous streaming methodPatrick Boettcher
Added isochronous-streaming method. Changed memory (de)allocation behaviour accordingly. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] dvb: Add generalized dvb-usb driverJohannes Stezenbach
Add generalized dvb-usb driver which supports a wide variety of devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
