Stanse found that in gp8psk_load_bcm4500fw there is missing a check for
return value of kmalloc. Add one and bail out appropriatelly.
I have been informed by the manufacturer that the patch currently in the v4l tree to support the Genpix-CW3K version of the hardware will actually
damage the firmware on recent units. As he seems to not want this hardware supported in Linux, and I do not know how to detect the difference between
affected and not-affected units, I am requesting the immediate removal of support for this device. This patch removes a portion of the changeset
dce7e08ed2b1 applied 2007-08-18 relating to this specific device.
Adapted patch to not remove code, but to only to comment it out.
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
This patch converts the gp8psk module to use the S2API.
It pretends to be DVB-S2 capable in order to allow the various
supported modulations (8PSK, QPSK-Turbo, etc), and keep software
compatibility with the S2API patches for Mythtv and VDR.
Signed-off by: Alan Nisota <alannisota@gmail.com>
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The adapter_nr module options can be used to allocate static adapter
numbers on a driver level. It avoids problems with changing DVB apapter
numbers after warm/cold boot or device unplugging and repluging.
Each driver holds DVB_MAX_ADAPTER long array of the preferred order of
adapter numbers.
options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a
reversed allocation of adapter numbers.
With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If
both are already in use it will allocate the lowest free adapter number.
Signed-off-by: Janne Grunau <janne-dvb@grunau.be>
Acked-by: Hermann Pitton <hermann.pitton@arcor.de>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
This patch #if 0's the unused gp8psk_bcm4500_reload()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
There are now 4 different versions of the GENPIX USB adapter. The
newest 'Skywalker' models are fully self-contained, and need no
additional hardware to be used. A very reliable DVB-S card even without
using any of the alternate modulatations (which this kernel module does
not currently support)
The following patch adds support for all 4 versions of the genpix
adapter (www.genpix-electronics.com).
Signed-off-by: Alan Nisota alannisota@gmail.com
While converting everything to DVB-USB-Adapter, there was a wrong indention.
Use NULL instead of 0 for pointer value, eliminate sparse warnings.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This patch is the first commit of the Multiple Input Patch for the DVB-USB frame
work.
It changes the DVB-USB-device to be able to have more than one streaming input
(e.g. multiple DVB-T sources) on one device. This is a necessary feature for
the upcoming DiB7700 driven devices.
Minor code cleanup on the genpix-module.
This is a patch which includes support for the GENPIX 8PSK->USB module. The
board supports QPSK, BPSK and 8PSK decoding (though I don't think it will be
DVB-S2 compliant) With the following patch, the boad is equivalent to a budget
card (no CA Module)
The patch which adds 8psk suppot will follow, but is seperate, as it requires
DVB-S2 support
More info on the board can be found at www.genpix-electronics.com (and they
host the requisite firmwares there as well)
Signed off by: Alan Nisota <alannisota@gmail.com>
