Prevent NULL dereference if kmalloc() fails.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
In order to be closer to V4L IR implementation, it is needed to replace
u8 custom, data
to:
u16 scan
This allows using non-rc5 mappings, like the 8 bit keycodes used on older
protocols. It will also allow future implementations of rc6 keystrokes
when needed.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The adapter_nr module options can be used to allocate static adapter
numbers on a driver level. It avoids problems with changing DVB apapter
numbers after warm/cold boot or device unplugging and repluging.
Each driver holds DVB_MAX_ADAPTER long array of the preferred order of
adapter numbers.
options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a
reversed allocation of adapter numbers.
With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If
both are already in use it will allocate the lowest free adapter number.
Signed-off-by: Janne Grunau <janne-dvb@grunau.be>
Acked-by: Hermann Pitton <hermann.pitton@arcor.de>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Aapo Tahkola <aet@rasterburn.org>
Enable second adapter on LifeView TV Walker Twin DVB-T USB2.0
Make sure devices manufactured by Dposh are not affected by previous hw
pid filtering changes
Doing so might crash it.
Spotted by Jeremy Nysen.
Disable second adapter on LifeView TV Walker Twin while it doesn't work
properly.
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
Do not follow 80-col limit where it would cause inconsistency.
deb_rc is used by the dvb-usb core framework. This patch replaces all
occurances of deb_rc with deb, in m920x.c, so that its clear that we're
not using dvb-usb's deb_rc.
Some of the devices supported by the m920x driver have identical functions used
for tuner_attach and frontend_attach. This patch consolidates the functions in
question, and updates the debug code to be generic for each. This patch
decreases the size of the kernel.
- Group the tuner configurations together.
- Group the demod configurations together.
- Group the device-specific initialization functions together.
- Group demod_attach functions together.
- Group tuner_attach functions together.
- 80-column cleanups
- spaces between operators
- tabbing style
These devices are sold by various companies and chains not involved in
hardware manufacturing business. This particular device owned by
winisch (from irc) had a sticker with text "TCM 234292" on it. This device
was never opened so it is possible that Dposh did not manufacture this
stick. However, the bundled software and their product line points into
that direction. Also thanks to Michael Krufky for spotting this hw
filtering problem and thus avoiding hair loss.
Hardware pid filters and the bundled remote controller are not currently
supported on this device.
Add support for "LifeView TV Walker Twin" (USB IDs 10fd:0513, 10fd:0514)
Add support for Anubis Electronics "Lifeview" (USB-ID: 0x10fd:0x1513)
Signed-off-by: Pierre Willenbrock <pierre@pirsoft.de>
Signed-off-by: Pierre Willenbrock <pierre@pirsoft.dnsalias.org>
This function should work for all m920x-based devices.
Change a 00 to just 0
Detect zero-length I2C messages and return not supported. I think I know
how to send one, but the problem is getting the slave's ack. The only
point of a zero-length message is for probing; too see if the slave will
ack its address. Since we don't know how to get the ack, we can't
support zero-length messages in a useful way, so it's probably best to
just return not supported for them.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Write some better documentation about what might be known about how the
m920x I2C works, since a datasheet is lacking.
The I2C xfer function should now handle more types of I2C transactions
than it could before. Those it can't, will return error codes instead of
being executed incorrectly. Multi-byte reads were not being done
correctly, which should be fixed.
- Implement m920x i2c as suggested by Pierre Willenbrock
- remove "magic" hack
- r/w bit is not part of the i2c address
- move hardware remarks to header file
Move filter caps from device caps to adapter caps for the megasky driver.
This fixes usb1.1 operation.
Fixes qt1010 identification bug with megasky caused by
the Quantek QT1010 tuner module patch.
QT1010:
- old qt1010-code totally rewritten and put in own kernel module
- same enhancements as my earlier QT1010 125kHz patch
- tuner initialization
- register 1f calculation
- register 20 calculation
- register 25 calculation
m920x: (MSI Megasky)
- use new QT1010 module instead of old code
Signed-off-by: Antti Palosaari <crope@iki.fi>
move .caps from the adapter properties to the device properties.
Thanks to Martin Schwier for confirming this fix.
- removed extra newline
- removed NULL entry
- fixed versions.txt
The megasky_tuner_attach function is not specific to this device.
This patch renames it to qt1010_tuner_attach and moves it into the qt1010
header file.
- Removed some needless brances
- Removed an unneeded check for adapter[0]
- Removed unneeded declaration of .generic_bulk_ctrl_endpoint = 0x01
Some cleanups and suggestions from Patrick Boettcher.
Dropped the mutex in m9206_rc_query using #if 0, because
M9206_CORE, M9206_I2C, M9206_FILTER and M9206_FW can be accessed
concurrently.
Thanks to both Aapo Tahkola and Patrick Boettcher.
- hardware pid filtering no longer enabled unless in usb 1.x mode
- more responsive rc handling
- some minor bug fixes and code refolding
- m9206_write delay dropped (doesn't seem to be needed)
qt1010 is a tuner used in some other devices, so this code should be put
into a separate file so that it could be reused by other drivers.
update code to use dvb_attach()
update code to reflect recent changes to the dvb_usb framework
