path: root/drivers/media/dvb/dvb-usb/umt-010.c
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5780): Dvb: Remove static dependencies on dvb-pllMichael Krufky
This patch removes all static dependencies on the dvb-pll module. All exported dvb_pll_desc's have been UNexported, and the caller will reference the individual dvb_pll_desc by it's index in the pll_list array. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Acked-by: Oliver Endriss <o.endriss@gmx.de> Acked-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5650): Umt-010: trivial whitespace cleanupMichael Krufky
2007-07-18V4L/DVB (5649): Umt-010: convert tua6034 handling to properly use dvb-pllMichael Krufky
2006-12-10V4L/DVB (4749): Fixed DVB-USB-Adapter indentionPatrick Boettcher
While converting everything to DVB-USB-Adapter, there was a wrong indention. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4643): Multi-input patch for DVB-USB devicePatrick Boettcher
This patch is the first commit of the Multiple Input Patch for the DVB-USB frame work. It changes the DVB-USB-device to be able to have more than one streaming input (e.g. multiple DVB-T sources) on one device. This is a necessary feature for the upcoming DiB7700 driven devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4386): Convert DVB devices to use dvb_attach()Andrew de Quincey
Only devices using > 1 frontend were ported; ones which did not are left using static binding. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4028): Change dvb_frontend_ops to be a real field instead of a ↵Patrick Boettcher
pointer field inside dvb_frontend The dvb_frontend_ops is a pointer inside dvb_frontend. That's why every demod-driver is having a field of dvb_frontend_ops in its private-state-struct and using the reference for filling the pointer-field in dvb_frontend. - It saves at least two lines of code per demod-driver, - reduces object size (one less dereference per frontend_ops-access), - be coherent with dvb_tuner_ops, - makes it a little bit easier for newbies to understand how it works and - avoids stupid mistakes because you would have to copy the dvb_frontend_ops always, before you could assign the static pointer directly, which was dangerous. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4027): Fixes after dvb_tuner_ops-conversionPatrick Boettcher
Some of the dvb_tuner_ops-pointer were set before having a dvb_frontend creating. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3893): Convert calls from _pllbuf() to _calc_reg()Andrew de Quincey
Johannes Stezenbach suggested this change - definite improvement. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3882): Convert dvb-usb/umt-010 to refactored tuner codeAndrew de Quincey
Hook tuner call into tuner_ops. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] dvb: usb: core: change dvb_usb_device_init() APIPatrick Boettcher
Change the init call to optionally return the new dvb_usb_device directly. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: usb/pci: correct syntax of driver name fieldsPatrick Boettcher
Change the name-field of the pci_driver and usb_driver structs to the name of the module after compilation. It seems that this field is used in some places where special characters are not allowed. Thanks to Alan Halverson for finding this problem. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] dvb: Add generalized dvb-usb driverJohannes Stezenbach
Add generalized dvb-usb driver which supports a wide variety of devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
