Add support for ST STV0288 demodulator and cards with it,
such as TeVii S420.
Patch is co-authored with Georg Acher <acher@baycom.de>
Signed-off-by: Georg Acher <acher@baycom.de>
Signed-off-by: Igor M. Liplianin <liplianin@me.by>
Add support for Silicon Laboratories SI2109/2110 demodulator
and cards with it, such as DvbWorld PCI2002.
Adds support for the COnexant cx24116 DVB-S2 demodulator.
TODO: checkpatch cleanup.
Signed-off-by: Steven Toth <stoth@linuxtv.org>
- initial driver for the Afatech AF9013 demodulator
Signed-off-by: Antti Palosaari <crope@iki.fi>
[mchehab.redhat.com: having a global var called 'debug' is not a good idea. rename it to af9013_debug]
Reactivated dummy frontend driver which is extremely useful for debugging.
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
Add support for Magic-Pro DMB-TH usb stick. DMB-TH is the HDTV broadcast
standard used in Hong Kong and China.
I've also attached a second patch against the dvb-apps repository which
adds a DMB-TH scan file for Hong Kong.
Since the ProHDTV stick contains a DMB-TH decoder (lgs8gl5) onboard,
it outputs MPEG-TS to the PC.
Signed-off-by: Timothy Lee <timothy.lee@siriushk.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Also for the new DVB_DRX397XD driver the FW_LOADER select and the
corresponding dependency on HOTPLUG can be removed.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
After commit d9b19199e4894089456aaad295023263b5225c1a
(always enable FW_LOADER unless EMBEDDED=y) we can remove
the FW_LOADER select's and corresponding dependencies
on HOTPLUG.
DVB-T demodulator
The module needs an external firmware file.
The module has been tested on a Pinnacle 330e, but with modules that
are currently not part of the linux-dvb tree. So consider this highly
experimental, don't use this code unless you are an experienced kernel
developer.
create mode 100644 drivers/media/dvb/frontends/drx397xD.c
create mode 100644 drivers/media/dvb/frontends/drx397xD.h
create mode 100644 drivers/media/dvb/frontends/drx397xD_fw.h
Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com>
kconfig description
This patch does some small cleanup to mt312.
It changes kconfig description to also list the ZL10313.
It does change some strange symbol names to be consistent with
module name mt312 and naming of all other functions in there.
* vp310_mt312_ops -> mt312_ops
* vp310_mt312_attach -> mt312_attach
Adds a MODULE_AUTHOR for me
Signed-off-by: Matthias Schwarzott <zzam@gentoo.org>
Since:
1) FW_LOADER is defined as:
config FW_LOADER
tristate "Userspace firmware loading support"
depends on HOTPLUG
2) several V4L/DVB driver just selects it;
3) select is not smart enough to auto-select HOTPLUG, if select FW_LOADER.
So, All drivers that select FW_LOADER should also depend on HOTPLUG.
An easier solution (for the end-user perspective) would be to "select HOTPLUG".
However, live is not simple. This would cause recursive dependency issues like
this one:
drivers/usb/Kconfig:62:error: found recursive dependency: USB -> USB_OHCI_HCD
-> I2C -> MEDIA_TUNER -> MEDIA_TUNER_XC2028 -> HOTPLUG -> PCCARD -> PCMCIA ->
USB_ARCH_HAS_HCD -> MOUSE_APPLETOUCH -> USB
Those tuners are currently used only under media/dvb. However,
they can support also analog TV. Better to move them to the same place
as the other hybrid tuners. This would make easier to use those tuners also
by analog drivers.
There are some DVB-S tuners together with DVB-S tags, while
others together with tuners. Better to have all of them together.
There were several issues in the past, caused by the hybrid tuner design, since
now, the same tuner can be used by drivers/media/dvb and drivers/media/video.
Kconfig items were rearranged, to split V4L/DVB core from their drivers.
This adds full support for this demodulator.
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Adding support for the NXP TDA10048HN DVB OFDM demodulator
Including support for the AU0828 USB Bridge.
Including support for the AU8522 ATSC/QAM Demodulator.
Change type of buffer variables from void* to u8* to save some casts.
The chip can control 2 LNBs independently.
The driver distinguishes them by evaluating the MSB of the override_set
parameter of the isl6405_attach function.
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
This is an all formats tuner, QAM, ATSC, DVB-T and others.
Only ATSC and QAM have been tested.
analog demod
Add basic support for NXP TDA8295 analog demod and TDA18271 tuner silicon.
TDA8295 + TDA8275a not yet tested.
TDA8290 + TDA18271 not yet supported.
Digital mode of TDA18271 not yet tested & needs more work.
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
s/driver/drives/1
This changeset adds support for DiB7070P-based devices by adding the
dib0070-driver and putting the appropriate layouts into
dib0700_devices.c
It also includes a new firmware for the dib0700 which is necessary to
make the DiB7070-boards work and it also should fix the i2c-problems
on some boards.
Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr>
Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr>
This patch adds support for the Samsung S5H1409 demodulator, also known
as the Conexant CX24227 demodulator. 8VSB mode has been tested and QAM
has been implemented based on the spec, although it's untested.
The S5H1409 / CX24227 appears on various Hauppauge boards.
This adds support for the Microtune MT2131 tuner. 8VSB mode has been
tested but QAM support will likely require more register work. Hauppauge
have not announced any QAM devices using the MT2131 so QAM remains
undone.
For legal reasons, Microtune allowed us to write a GPL driver providing
we did not document in significant detail any of the registers. This
explains the lack of comments or defined on register names.
Add initial support for Dual-DVB-T stick based on DiB7700 and MT2266
- Microtune MT2266 driver.
- Preliminary support for these dual tuner devices :
- Pinnacle Dual DVB-T diversity
- Terratec Cinergy DT USB XS diversity
- Hauppauge Nova TD USB
Signed-off-by: Olivier DANET <odanet@caramail.com>
Add support for the frontend TDA10023 and add cards that need the
tda10023.
Signed-off-by: Hartmut Birr <e9hack@googlemail.com>
Signed-off-by: Georg Acher <acher@in.tum.de>
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
The code of the dvb-pll driver and the lgh06xf driver is nearly
identical. The main difference is that the lgh06xf driver would set the
AGC TOP value on every tune call. The dvb-pll driver now has the ability
to set the AGC TOP when the front-end device is opened, which is a better
way to go about it. By using this ability of dvb-pll, the lgh06xf driver
is made unnecessary.
There is one other difference. dvb-pll will probe for the presence of an
I2C pll chip by doing a one byte read, the lgh06xf driver did not do
this. In some devices the PLL is not reachable over I2C at the timer the
tuner is attached. Some more initialization, such as firmware loading,
must take place first. None of the devices using a LG-H06xF should have
this problem.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
A number of drivers selected DVB_PLL when they did not need it, and some
that did need it did not select it.
The DVB_PLL option is given a name and help text, so that it will show up
in the config menu. DVB_PLL support can be turned on if an out-of-tree
driver needs it.
The standard dvb fe customization support is added to dvb-pll.h. Since
all modules which select DVB_PLL do so unconditionally, it is not
possible to turn dvb-pll off when an enabled module selects it, unlike
most of the other frontend/tuner drivers. This is because the users of
dvb-pll have static references to dvb-pll symbols other than the attach
function. If these references are removed, then dvb-pll will be
disablable as the other frontend/tuner drivers are.
The patch moves the tda827x dvb tuning code to a separate module
QT1010:
- old qt1010-code totally rewritten and put in own kernel module
- same enhancements as my earlier QT1010 125kHz patch
- tuner initialization
- register 1f calculation
- register 20 calculation
- register 25 calculation
m920x: (MSI Megasky)
- use new QT1010 module instead of old code
This patch creates a new atsc tuner module for the LG TDVS-H06xF ATSC tuners,
called lgh06xf. The purpose of this change is to reduce some duplicated
code, and to allow the lgh06xf tuner code to take advantage of dvb_attach().
As a side effect, the dependency of dvb-bt8xx on dvb-pll has been removed,
since the lgh06xf module itself will use dvb-pll, while remaining optional
for the dvb-bt8xx driver through the use of DVB_FE_CUSTOMISE
Acked-by: Andrew de Quincey <adq_dvb@lidskialf.net>
This patch contains support for the DiB7000PC-driver.
Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr>
First working version of the dib7000m-driver.
This commit also makes the Hauppauge NOVA-T Stick working.
Signed-off-by: Francois Kanounnikoff <fkanounnikoff@dibcom.fr>
Let the MT2060 be customized like most of the other DVB PLLs/front-ends.
Also, add a missing dependency on I2C.
This driver was originally in budget-av.c, however I have extracted it into
a seperate file to permit reuse.
I also reworked the code to make it maintainable. I then examined the KNC1
windows drivers and rewrote the code in order to configure the PLL as they
do. This solves a lot of reported tuning problems.
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
Some minor code cleanups and added the MT2060 to new v4l-dvb-build-system, preliminarily under dvb/frontends.
This was breaking the build if i2c was not previously set
TDA10086 is a new DVB-S demodulator
TDA826x is a DVB-S Silicon Tuner
Several DVB modules depends on I2C
Driver for the ISL6421 LNB chip
Convert lnbp21.h into a linux kernel module.
Fix up previous users to use it.
Convert dvb-ttusb-budget to use it.
It's "Terrestrial"
- Added firmware download comments to or51211 and or51132 Kconfig help text.
- Corrected typo for NxtWave NXT200X
- Added "Oren" manufacturer name to menu items for OR51132 and OR51211
- Removed "(pcHDTV HDx000 card)" from Oren frontends menu item names,
This isn't necessary, as these frontends are selected by the card drivers,
build configuration (DVB_BT8XX and VIDEO_CX88_DVB).
DVB-T Plus support
Add support for the FE6600 tuner used on the DVB-T Hybrid board.
Add support for the Zarlink ZL10353 DVB-T demodulator, which supersedes the
MT352, used on the DViCO FusionHDTV DVB-T Hybrid and later model Plus boards.
Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au>
This patch contains the following possible cleanups:
- update the Kconfig help to mention the VP310
- merge vp310_attach and mt312_attach into a new vp310_mt312_attach
to remove some code duplication
The at76c651 and tda80xx frontends are currently completely unused, IOW
their only effect is making the kernel larger for people accitentially
enabling them.
The current in-kernel drivers differ from the drivers at cvs.tuxbox.org,
and re-adding them when parts of the dbox2 project get merged should be
trivial.
- Kill nxt2002 module in favor of nxt200x.
- Repair broken nxt2002 support in the nxt200x module.
- Make the flexcop driver use nxt200x instead of the nxt2002 module for the
Air2PC 2nd generation PCI card.
- Remove the nxt2002 module from cvs and kernel build.
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
