Raise the DVB frontends one level up, as the intention is to remove
the drivers/media/dvb directory.
This patchs adds support for the DiBcom DiB0090 RF tuner and for
DiBcom's reference design STK8096GP. Small extracts of the DiB0070 and
the DiB8000-driver into a common codebase.
Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com>
Signed-off-by: Olivier Grenie <Olivier.Grenie@dibcom.fr>
Fix build dependency on function, dib0070_ctrl_agc_filter
[mchehab@redhat.com: reverted the quick workaround 3f48258e50ef4]
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
In order to follow a little bit the kernel coding style from now on
after the generation of that driver file and indent -linux call is
emitted.
General update of the dib0070-driver based on DiBcom's latest release.
New driver features can enable better performance in some reception situations.
Signed-off-by: Patrick Boettcher <Patrick.Boettcher@dibcom.fr>
This function prototype is defined but the function itself does not exist.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
with dvb-usb-cxusb
Allow dvb-usb-cxusb to be built without dib7000p or dib0070 selected
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
This changeset adds support for DiB7070P-based devices by adding the
dib0070-driver and putting the appropriate layouts into
dib0700_devices.c
It also includes a new firmware for the dib0700 which is necessary to
make the DiB7070-boards work and it also should fix the i2c-problems
on some boards.
Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr>
Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr>
