path: root/drivers/media/dvb/frontends/dib3000mc.c
2008-01-25V4L/DVB (7070): Fix some tuning problemsSoeren Moch
The attached patch solves all my vdr tuning problems on a dib7000p nova-t stick as far as I could check within the last weekend. It disables streaming while tuning, like that the number of faulty TS packets is reduced. Signed-off-by: Soeren Moch <Soeren.Moch@stud.uni-hannover.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7067): fix autoserach in the Hauppauge NOVA-T 500Jose Alberto Reguero
This patch fix autoserach in the Hauppauge NOVA-T 500. Signed-off-by: Jose Alberto Reguero <jareguero@telefonica.net> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5963): Module parameter description for SFN workaroundPatrick Boettcher
Thanks to Matt Doran I found that there the module parameter description was not OK. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5960): Add module parameter to enable SFN workaroundMatt Doran
In some areas in the world the broadcasters are not using the same cellid for each transmitter in a SFN. The DiBcom has problems with that setup. The module parameter buggy_sfn_workaround makes it re-usable. Signed-off-by: Matt Doran <matt.doran@papercut.biz> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5955): Add support for DiB7070-based devicesPatrick Boettcher
This changeset adds support for DiB7070P-based devices by adding the dib0070-driver and putting the appropriate layouts into dib0700_devices.c It also includes a new firmware for the dib0700 which is necessary to make the DiB7070-boards work and it also should fix the i2c-problems on some boards. Signed-off-by: Jean-Philippe Sibers <jpsibers@dibcom.fr> Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5954): Sync with DiBcom Driver Release 2.1.3 + some improvementsPatrick Boettcher
This changesets syncs the OpenSource driver for DiBcom demodulators with version 2.1.3 of DiBcom reference driver. There were some improvements since the last release for linux-dvb, e.g.: - stepped AGC startup - less space for initialization - diversity synchronization Furthermore this changeset contains the following things: - latest AGC settings for MT2266-based devices (namely Nova-TD and other) will improve the sensitivity - support for STK7700D reference design in dib0700-devices - remove some line-breaks when debugging is enabled - getting rid of layer between frontend_parameters and ofdm_channel used in dib*-drivers Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4998): [PATCH] DIB3000MC and NOVA T USB2 #2Mario Rossi
Second part of the patch to make the autosearch work again with DiB3000P/MC. Signed-off-by: Mario Rossi <mariofutire@googlemail.com> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4955): Fix autosearch indexMario Rossi
After rewriting the driver the wrong autosearch index was used when COFDM-parameter needed to be detected. Thanks to Mario Rossi who found it. Signed-off-by: Mario Rossi <mariofutire@googlemail.com> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4773): Misc fixes for DiB3000 and DiB7000Patrick Boettcher
This patch contains several fixes for the autosearch algorithm and other small ones. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-14V4L/DVB (4750): AGC command1/2 is board specificPatrick Boettcher
Added config-struct-parameter to take board-specific AGC command 1 and 2 into account. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4653): Misc fixes for Nova-T 500Patrick Boettcher
- forward the clock to the slave undivided - when sleeping the 3000 do not shutdown the clock Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4652): Misc fixes for DiB3000MC and Nova-T 500Patrick Boettcher
- make the timing frequency update work. - fix AGC calibration for Nova-T 500 Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4648): Hauppauge Nova-T 500 support addedPatrick Boettcher
This changeset finalizes the support of the Hauppauge Nova-T 500 (Dual DVB-T). It adds correct AGC setting for the 3000P, correct firmware download state detection. Additionally it fixes the mt2060-driver to be able to be used with dvb_attach. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4646): Misc. changes, DiB3000MC, MT2060Patrick Boettcher
Changed the attach-function of the dib3000mc-driver to return only one frontend. In case of multiple dib3000-chips on one board, one has to call the i2c-enumeration manually before. Added a field to Microtune 2060 config to output the clock to other tuners/device on a board. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4530): Another fix for the PID parsingPatrick Boettcher
Still the pid_parse bit was erased. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4529): Keep the PID parse bit when resetting the output modePatrick Boettcher
Matthieu Castet found that with the rewritten dib3000mc-driver the PID-parsing was handled correctly. This changeset fixes it. Thanks Matthieu Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4472): Remove debug-print from dib3000mcPatrick Boettcher
Removed and commented a small debug function. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB: DiB3000MC: set FE to NULL after being freedPatrick Boettcher
DiB3000MC: set FE to NULL after being freed Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB: Complete rewrite of the DiB3000mc-driverPatrick Boettcher
A complete rewrite of the DiB3000MC/P driver has been done. It is now much more easy to maintain and to get improvements inside. Additionally the tuning time has been reduced and the usage of the driver is much more understandable now. Signed-off-by: Patrick Boettcher <pboettcher@dibcom.fr> Signed-off-by: Francois KANOUNNIKOFF <fkanounnikoff@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB: Cleanups for mt2060-integrationPatrick Boettcher
- some coding style fixes for newly added mt2060 - moved agc-config from fixed values in dib3000mc to configurable ones - whitespace clean-ups for usb-id-file Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB: Adding support for MT2060 and thus for some DVB-USB-devices based on itOlivier DANET
- MT2060 tuner driver - Added support for some USB DVB-T devices based on Dib3000P Signed-off-by: Olivier DANET <odanet@caramail.com> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4028): Change dvb_frontend_ops to be a real field instead of a ↵Patrick Boettcher
pointer field inside dvb_frontend The dvb_frontend_ops is a pointer inside dvb_frontend. That's why every demod-driver is having a field of dvb_frontend_ops in its private-state-struct and using the reference for filling the pointer-field in dvb_frontend. - It saves at least two lines of code per demod-driver, - reduces object size (one less dereference per frontend_ops-access), - be coherent with dvb_tuner_ops, - makes it a little bit easier for newbies to understand how it works and - avoids stupid mistakes because you would have to copy the dvb_frontend_ops always, before you could assign the static pointer directly, which was dangerous. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3870): Convert dib3000* to refactored tuner codeAndrew de Quincey
Convert to tuner_ops calls. Remove pll function pointers from structure. Remove unneeded tuner calls. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] dvb: remove version.h dependenciesOlaf Hering
Remove all #include <linux/version.h> and all references to LINUX_VERSION_CODE and KERNEL_VERSION. Based on patch by Olaf Hering. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] dvb: Add generalized dvb-usb driverJohannes Stezenbach
Add generalized dvb-usb driver which supports a wide variety of devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: dib3000: add NULL pointer checkJohannes Stezenbach
prevent NULL pointer related Oopses (Patrick Boettcher) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: remove unnecessary casts in frontendsJohannes Stezenbach
remove unnecessary casts in frontends (Kenneth Aafloy) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
